DIY: $50 (or less) Intake For The GE. CAI / SRI
Old Sep 8, 2011 | 08:32 PM
  #301
VanLeuven's Avatar
adding an intake made your shifting smoother?
and you're adding a chip?
referring to my previous post, yes and yes
Under full acceleration, the shift would happen with a loud vibration (over resonation inside the intake i presume), now with the SRI, that is no more the case.
As far as the chip is concerned, it's a sub $100 ecu safe chip, just seeing how it functions, not expecting 13 second miles lol
Old Sep 8, 2011 | 09:46 PM
  #302
leath213's Avatar
great diy, very well done sir
Old Sep 28, 2011 | 01:24 AM
  #303
petawabit's Avatar
agreed. may do this after i told myself that i'm not going to mod the engine of this car
Old Sep 28, 2011 | 01:14 PM
  #304
kurisux92's Avatar
You'll be happy you did it.
Old Sep 28, 2011 | 07:18 PM
  #305
FittedOnEm's Avatar
whats best to use to cut the intake lid? i read that most people used a hacksaw but someone mentioned that using a kitchen knife is easier
Old Oct 21, 2011 | 03:12 AM
  #306
Lyon[Nightroad]'s Avatar
After much bored testing, I finally figured out where all the cold air was hiding in this engine bay. It's in front of the battery and to the side of the radiator. This causes the air to come from the foglight/fender area at near ambient with little to no 'heat soak'. Best part of this config is that it only needs 1 45 degree bend.
This probably wont work with the stock battery but hey you have room to upgrade to damn near anysize battery you want now that the airbox is gone.
Old Oct 21, 2011 | 10:00 AM
  #307
ThEvil0nE's Avatar
yup... that's where the coldest part of the engine bay is. that's where my catch can is and in cooler weather my catch can is ice cold
Old Oct 21, 2011 | 12:51 PM
  #308
fitisbamf's Avatar
where do u think the cold air is comming from? i blocked off the rad so all air thru the front has to pass thru it. i have a little scoop from the grill thru to the air filter and i have my "ram" from my fog light housing. do u think im still in the "cold spot"
Old Nov 30, 2011 | 01:55 PM
  #309
brEAd's Avatar
my intake fell off when i got rear ended. had to throw it back on on the side of the freeway
Old Dec 10, 2011 | 09:22 PM
  #310
TheDilweed's Avatar
can i get a parts list? very specific as to what size i need. the parts list in the first page kinda confuses me a bit. and will i need anything to support it from bouncing around?
Old Dec 14, 2011 | 02:03 AM
  #311
TheDilweed's Avatar
so i pretty much went through with it. and i love it. the only thing is that after about 15 miles of driving, my check engine light went on. did anyone else experience this? any ideas on what it could be?
Old Dec 14, 2011 | 07:46 PM
  #312
kurisux92's Avatar
Could be an air leak somewhere, or it could be your MAF sensor has failed (Doubt it), or you did not use the original MAF tube. Some people say it's because it's backward, but I actually tried to put it in backwards and it's impossible. It could be for something else. One really cold night my CEL came on, and come to find out it was just the gas cap.
Old Dec 15, 2011 | 03:13 AM
  #313
TheDilweed's Avatar
i just reset my ecu and it went away. didnt come back yet. but my filter is touching my master cylinder. i'm worried that it will eventually rub a hole in it. should i be worried or...
Old Jan 11, 2012 | 02:57 PM
  #314
Java^FiT's Avatar
For anyone following this thread looking to just buy one of these and are familiar with the modifications I have done to my version, I am selling my intake and heatshield. Please PM me if you are interested or have any questions Thanks!
Old Feb 9, 2012 | 06:52 AM
  #315
BlackPearlFIT's Avatar
Did this the other day, everything was fine until I made one snip (about .25" long) with the wire cutters and the MAF tube cracked in half. I highly suggest to people to use a hand saw the whole time to avoid this from happening. Hope this helps.
Old Feb 15, 2012 | 12:38 AM
  #316
No fun! Deleted mention of wire cutters on main post. Hope you were able to make it work.
Old Feb 15, 2012 | 06:34 AM
  #317
yeah i made it work, just heated up some wire to seal the plastic back
Old Mar 22, 2012 | 02:36 PM
  #318
RiverFitter's Avatar
Has anyone done this DIY using a MAF adapter like this one Spectre Performance
instead of cutting up the OEM air box...
It would seem to make sense, save some work sanding the OEM part and keep the original intake intact...
Old Mar 23, 2012 | 08:09 AM
  #319
Yes.
No, it did not read accurately.
Old Mar 25, 2012 | 05:29 PM
  #320
NewFitGuy09's Avatar
Originally Posted by FitDEEZ
Finished product
I tried this intake design too, my only question was do you have a clamp where the tube and the box connect? Im thinking of putting one. I think it needs on to keep from shaking/coming loose?
