Sprintex Supercharger Install
Old Jan 23, 2014 | 01:23 AM
  #421
1SickVeilsideZ's Avatar
I'm for sure no expert when it comes to reading the graphs, but it looks like your AFR isn't consistent? It should stay pretty linear? Looks like as you make power you start to run lean?
With my car I know if I redline I will trigger limp mode, but that's because it will misfire, I haven't thrown any lean codes as of yet since the tune.
Mine is a 2010 MT though, so I know there might be some differences.
Old Jan 23, 2014 | 01:29 AM
  #422
Fuzzyfunk's Avatar
Thanks for the info! Did church ever tell you to upgrade your fuel pump? Or was it already upgraded when you went for your tune?
Old Jan 23, 2014 | 01:33 AM
  #423
Fuzzyfunk's Avatar
Also from what I see in the graph, the AFR starts to dip at 4k, I was no where near 4k when I got the cel and car died on me. It was from barely gently pressing the gas. I was prolly at 2k or 3k at most.
  #424
^^ No I haven't upgraded my fuel pump yet, but I am planning to do that and get bigger injectors as well.
Old Jan 23, 2014 | 01:41 AM
  #425
Fuzzyfunk's Avatar
Nice! Which fuel pump & injectors are you planning to get? DSM mentioned the EVO X or RDX fuel pumps.
Old Jan 23, 2014 | 02:17 AM
  #426
^^ Not sure yet, everything is an experiment right now, trying to get everything dialed in. I'll do some reading and research and see exactly what will work best before I dump more money into it.
Old Jan 23, 2014 | 11:13 AM
  #427
SprintexUSA's Avatar
Call Deatschwerks and ask for Chris if you would like some larger injectors. He says he has some that will fit. 410cc RDX injectors are overkill. He has some 350cc units that would fit but need a plug adapter. The EVO pump is a drop-in.
Fuzzy--Wiggle your harness with the car running and see if the car dies. We've noticed an occasionally loose connection on the black ground wire on the 10 pin plug. If the box is unmounted, the pins can get a little loose inside the harness. Dielectric grease helps cram everything together, but the pin fitment could definitely be better.
Old Jan 23, 2014 | 11:48 AM
  #428
Fuzzyfunk's Avatar
Thank you! Will do!
Old Jan 23, 2014 | 12:14 PM
  #429
jonathan13's Avatar
I actually used hot glue to hold my pins in the connector because as I noted earlier in the thread I did have some minor issues with my pins not wanting to stay in the connector. I held the plug vertical and ran a bunch of hot glue in there and it seems to be holding together nicely. It also helps keep any moisture out of there.
Old Jan 23, 2014 | 12:52 PM
  #430
Fuzzyfunk's Avatar
Hmmm interesting. Glad it's holding on for you!
Gary, Does Sprintex plan on making a plug and play harness in the future for this piggyback? I think more people will be willing to jump in and get the sc once they know there won't be a need to solder wires together. Just a thought.
Old Jan 23, 2014 | 02:38 PM
  #431
DiamondStarMonsters's Avatar
Originally Posted by Fuzzyfunk
Thank you! Will do!
The RDX 410cc/min injectors are cheaper, more linear at low pulsewidths (idle/cruise) and have one of the best spray patterns/atomizer discs of any injector OE or aftermarket.
They also will allow you enough headroom to switch to E85 for a more aggressive tune after you drop in the Evo X pump.
Parts you need:
Order RDX injectors. Acura Part # 16450-RWC-A01
Order Scion TC clips: Toyota Part # 90980-11875
Old Jan 23, 2014 | 04:01 PM
  #432
Steven Hung's Avatar
Boomslang has all the connectors for the Honda Fit GE. Rustin Bernskoetter told me the AEM FIC 6 harness would be available fairly soon for ordering. It would be another option in addition to the SMT8L.
Old Jan 23, 2014 | 04:06 PM
  #433
Fuzzyfunk's Avatar
Parts you need:
Thanks DSM!! I will probably go with the EVO X fuel pump since everyone is saying its a drop in. E85 is really not in my plans. If this wasn't my dd, that may change but not anytime soon.
There's no need to upgrade the injectors correct?
Old Jan 23, 2014 | 04:07 PM
  #434
TPColgett's Avatar
That is a HUGE change as Honda had a strangle hold on GE ECU/Harness plugs...
If that has really changed, than the ability to relatively easily and actively tune the GE for FI, or heck even stay compliant for SCCA Street Touring regulations (MUST be a plug and play harness) becomes a reality.
Old Jan 23, 2014 | 04:10 PM
  #435
TPColgett's Avatar
also,
a buddy just recently dropped an evo 8/9 (we were not sure) directly into his GD for S's&G's.... No FlashPro so it ran STUPID rich till he took it out.
IIRC, the Evo X pump is more compact and should be an even easier swap...
Does anyone know what GD/GE and then 8/9/X pumps are flow rated for?
Old Jan 23, 2014 | 05:22 PM
  #436
Honda Fit GE Fuel Pump Spec
Volts 12
Pressure 45-55
Flow 35-45GPH, 159-205LPH
Outlet Size 5/16"
According to this Email I received from Rustin. You could ask Rustin when would the AEM FIC 6 harness be available.
Old Jan 23, 2014 | 09:11 PM
  #437
Is #19 the correct part to order from a 2011 Mitsubishi Lancer Evolution GSR to pull the fuel pump out of?
[ 19 ] FUEL SYSTEM / FUEL SYSTEM / FUEL SYSTEM COMPONENTS / Filter assy filter assy
PARTS: Part included with fuel pump assembly.
MSRP Core ? Save Online Price $149.28 $0.00 $34.63 $114.65
Flow Rates
Old Jan 24, 2014 | 12:16 AM
  #438
Fuzzyfunk's Avatar
Would like to know as well before I end up purchasing the incorrect one.
Old Jan 24, 2014 | 09:29 AM
  #439
mikeGe82012's Avatar
Where can I get a Sprintex supercharge for my 2012 fit sport and would it work with a auto tranny??
Old Jan 24, 2014 | 12:49 PM
  #440
jonathan13's Avatar
Yes it will work with auto. RPMExtreme.com. Talk to Jon.
