Installed: Variable Intermittent Wipers 2009 USDM Fit Sport MT Non-Navi
Old Aug 31, 2009 | 05:21 PM
  #141
triton.'s Avatar
I'll take mine, how to I send payment?
Old Aug 31, 2009 | 07:17 PM
  #142
PNW101's Avatar
Niko,
It looks like you could do a thriving business in (1) obtaining the wires, (2) putting them together as a set to work with the new variable intermittent wiper stalk and (3) selling them to anxious DIYers like us (because I would buy a set in a heartbeat and it seems there are others who would too). Would you be willing to do that? If yes, where do we sign up? If not, could you tell the rest of us (a) what wire set you obtained, (b) where and (c) how you made it work so the rest of us can replicate your success? Thanks a lot!
Old Aug 31, 2009 | 11:42 PM
  #143
FitStir's Avatar
Sent off, thanks again Niko.
Old Sep 1, 2009 | 12:06 AM
  #144
niko3257's Avatar
FitFreak GE8 DIY Guy
1. aenokea set paid and mailed
2. justintime set paid and mailed
3. goredox set paid and mailed
4. choro-Q_Fit set paid and mailed
5. pbuck Q paid and mailed
6. triton you will get a Q nothing else left LMK
7. red 05 Dropped out
8. schlappette you will get a Q nothing else left LMK
9. fitstir Q paid and mailed
10. mscott set paid and mailed
11. bigmitch set paid and mailed
12. clicq Q paid and mailed
13. 09 Fit LMK
Old Sep 2, 2009 | 08:36 AM
  #145
09 Fit's Avatar
PMed.
Thanks Nick!
Old Sep 2, 2009 | 10:22 AM
  #146
niko3257's Avatar
6. triton Q paid and mailed
13. 09 Fit Q paid and mailed
Old Sep 3, 2009 | 03:54 AM
  #147
niko3257's Avatar
all gone. every ones stuff is out.
Old Sep 3, 2009 | 12:04 PM
  #148
ForceFit's Avatar
Anyone with a micrometer been able to measure the Q fitting?
Maybe Bernardi or College Hills Honda can be encouraged to add the wire to the Wiper Stalk part for the FIT (like College Hills Honda did for the Accord Horn upgrade for the FIT).
I've got my stalk. Just need the connecting wire.
Old Sep 3, 2009 | 08:04 PM
  #149
justintime's Avatar
Niko:
Got my wire today, thanks! We need to know which pin corresponds to which connector (Wiper, or Q connector). Any easy way to tell before I start this mod?
Old Sep 3, 2009 | 09:01 PM
  #150
kotarou's Avatar
justintime, Could you please post a photo of both connectors side by side to have an idea ?
Old Sep 3, 2009 | 10:01 PM
  #151
justintime's Avatar
Sure thing, here they are. Not sure which is which though!
Old Sep 3, 2009 | 10:36 PM
  #152
kotarou's Avatar
justintime, Thank you very much.
By looking on your last picture, (I'm just guessing)... the Stalk pin is the one on the left and the Q the one on the right, since people said that the Q is smaller.
As you can see, I'm on the other hemisphere of the world, but trying to do the same.
I Already got a FIT GE6 and this:
The 04320-SAA-A00, fit's perfectly on the stalk.
And here the connector itself
I'm just not sure if i have the right stuff.
Old Sep 4, 2009 | 12:00 AM
  #153
niko3257's Avatar
on this image the pin on top is the Q and the bottom
pin is the wiper.
another way. the wiper pin is bigger and the Q is smaller.
Old Sep 4, 2009 | 12:47 AM
  #154
pbuck's Avatar
Got my Q wire today - thanks Nick!
Here are some micrometer measurements as best as I could make them given that the wire is attached - these are all outside dimensions:
Q- terminal:
Side view: overall length including crimp tabs 0.635", length of barrel 0.283"
End on view: height of barrel 0.079", width of barrel 0.066.
Wiper terminal (I have the 04320-SAA-A00 It looks slightly different from the one in justintime's photos - it has a shorter barrel)
Side view: overall length including crimp tabs 0.697", length of barrel 0.255"
End on view: height of barrel 0.088", width of barrel 0.081.
Paul
Old Sep 4, 2009 | 06:26 AM
  #155
kotarou's Avatar
pbuck, Now we need a micrometer to check too.
So can we use the 04320-SAA-A00 for the wiper connector?
Old Sep 4, 2009 | 06:27 AM
  #156
justintime's Avatar
Niko, thanks for the info. I think I have a last question:
To insert the pin on the Q connector, is it necessary to 'dislodge' the connector tab first? Or can you insert it right through from the back without un-securing the connector tab first?
You know what worries me sick? Dislodging the tab and then find that I have released all the other pins by mistake!!!!
Old Sep 4, 2009 | 06:29 AM
  #157
justintime's Avatar
No guarantee of anything in my opinion... for example, BOTH pins that I have fit the wiper male pin. But only one is the correct part that will fit and snap securely onto the connector itself!
Old Sep 4, 2009 | 06:39 AM
  #158
kotarou's Avatar
justintime, Hmm... I see.
So Just one will lock on the connector. I'll try with 04320-SAA-A00.
About the Q one, i think it's not possible to use the same part, right?
Old Sep 4, 2009 | 08:28 AM
  #159
justintime's Avatar
I would like to suggest to anyone doing this mod: The FIRST thing you want to do is disconnect the positive terminal of the battery. This will help prevent any shorts while you're fiddling around with the pins etc. Make sure you have your Radio Code handy!!!!
I once shorted my entire cluster, and lost speedometer, lighting, etc. NOT FUN.
Old Sep 4, 2009 | 10:05 AM
  #160
justintime's Avatar
Im having this same issue too! How to separate these pieces?! Tips please
Originally Posted by pbuck
So, I'm trying it - but I'm having a little difficulty getting the white pin retainer separated from the main connector body at the wiper stalk end.
Is there a technique to this? In the photo below mscott already has this done.
Thanks,
Paul
