Old Jun 12, 2012 | 01:57 PM
  #5341
Subie's Avatar
Originally Posted by Cocowheat
Yep, theres also the charge harness. pain in the ass really. I'm really not too good with wiring, which I will leave to the more experience guy here at work. Anyways work finally picked up today. So no working on my k harness.
So what's with the harness? Are you replacing, upgrading, rerouting it?
Old Jun 12, 2012 | 02:04 PM
  #5342
Cocowheat's Avatar
It came off the k20z3 I just bought. So it's actually the engine and charge harness for a 2008 civic SI.
I'm just getting familiarize with it, see what plugs go where, do what. That's why I bought a helms manual.
I might be trying to use a s2000 or racepak iq3 gauge cluster if I can't retain my OE day function, but for the time being, that's the goal.
Old Jun 12, 2012 | 02:07 PM
  #5343
MEATBABY's Avatar
This is going to be awesome.
Old Jun 12, 2012 | 02:59 PM
  #5344
Dwalbert320's Avatar
Took the bulldogs for a ride.
This is Henry Thurston de Touraine
I also have a female. Her name is Victoria. She is the back. Not much for windows that one.
Old Jun 15, 2012 | 10:26 PM
  #5345
malraux's Avatar
Oil change to 0w-20 Honda oil. Used sample is ready to send to Blackstone. Who the heck though that putting the oil fill location under the cowl?
I'll be changing the ATF to start getting the new formula in as soon as I pick up a long stem funnel.
Old Jun 15, 2012 | 10:31 PM
  #5346
SilverBullet's Avatar
Interested in the UOA.
Old Jun 15, 2012 | 11:00 PM
  #5347
malraux's Avatar
I don't know how applicable it'll be to anyone else. I change based on time rather than the MM; I get to 1 year before I get to 15%. 6000 miles, 40% left on the MM this time. It'll pick up this next year when my toddler starts preK. But even that's ~10 miles round trip.
Regardless, I'll post results when I get them.
Old Jun 15, 2012 | 11:09 PM
  #5348
Basically it shows how the oil holds up. If you include mpg it will give an idea how the oil handles the fuel too. Your right about being applicable to other cars because every situation is different but still interested.
Old Jun 15, 2012 | 11:12 PM
  #5349
DaveFL's Avatar
After seeing above posts feel my mods today are a little lame. hardest thing was making a lens removal tool so as not to break the lucite.
Installed LED's today, happened to be in the Fit last week trying to check something in the manual and discovered I couldn't see with available lights, now I can see and read the print. Changed map lights, overhead and while I was at it the cargo area light, but it will take some modification as a recessed light facing down would be better if it was mounted at a better angle.
Last week was more of a challenge taking off front end and bumper to install tow baseplate, brake cables, installing and wiring new rear lights. Hardest part was drilling the firewall at the right place, couldn't see what was on engine side so had to remove air cleaner.
Old Jun 16, 2012 | 06:13 PM
  #5350
malraux's Avatar
ATF drain and fill. Fluid looked ok, slightly dark but not bad. Drain plug had a fair amount of metal shavings that looked more or less like everyone else's pictures that I've seen. That said, whoever was responsible for setting the fluid change values for the Service Manual should have his eyes inspected. 2.6 qts was still almost a quart low. Oil change values weren't as bad, but it still took a full 4 qts instead of the 3.8 the manual says.
Old Jun 16, 2012 | 06:36 PM
  #5351
MEATBABY's Avatar
There's always going to be a little gap between the recommended fluid capacity and the "filled to the brim" capacity, if that's what you did. I'd say 0.2 qts would be that gap. I've always put the 3.8 qts of oil in mine and it's absolutely fine. Can't compare on the tranny fluid because I have M/T, but when I changed mine a few months back I think it took damn close to the recommended amount.
Old Jun 16, 2012 | 08:50 PM
  #5352
krunk13's Avatar
Finally got some tint 38% front 18% rear
Old Jun 16, 2012 | 10:09 PM
  #5353
ThEvil0nE's Avatar
earlier today... Wagon LifeStyle Norbori Flags took their first flight
Old Jun 16, 2012 | 11:40 PM
  #5354
j1nNju1c3's Avatar
Installed my T1R downpipe. Really makes a difference.
Was a bitch to take off though
Old Jun 16, 2012 | 11:58 PM
  #5355
FittedOnEm's Avatar
You're running it on an auto right? Can you describe the difference a bit more? lol thanks
Old Jun 17, 2012 | 12:22 AM
  #5356
j1nNju1c3's Avatar
No problem. First off, I have a Tanabe Touring Medallion EU axleback and an Injen SRI with an upgraded KnN filter.
After installing the downpipe, the VTEC hits way harder and the sound is more audible. No drone in the cabin and that's partly due to the axleback being quiet, which is a plus. Low end wasn't affected, it just increased mid-range.
It's great to have! I'm considering their b-pipe to see if it will help a bit more.
Old Jun 17, 2012 | 01:09 PM
  #5357
Under_Score's Avatar
Black on Ivory Clazzio Covers
I have had them for about a month and was finally able to get some pictures today. Better late than never I suppose. Here is a sneak preview to entice you into clicking the link above.
Old Jun 17, 2012 | 01:47 PM
  #5358
raiderfit's Avatar
those seats look nice.
Old Jun 17, 2012 | 02:16 PM
  #5359
Thanks raiderfit!
Old Jun 17, 2012 | 04:56 PM
  #5360
thefit09's Avatar
Agree especially on alabaster silver.
