DIY lower your GE8 Fit
Old Sep 4, 2009 | 12:53 AM
  #181
dianosaur's Avatar
So, I'm a little confused about this axle popping out.
Does anyone have pictures or anything to better explain it?
I just want to be sure when I do it, I'm jacking it up in the right spot and jacking it up high enough. It sucks already to have to take off the front cowl, but the axle thing makes me iffy.
Old Sep 4, 2009 | 11:44 AM
  #182
niko3257's Avatar
FitFreak GE8 DIY Guy
take a look at this pic. in this position the shock is fully extended.
just make sure you get a jack stand or a jack to hold the control
arm in it's place. just don't let it get any lower. jack it up higher if
anything. cause once you take out the two sturt bolts it will drop
and thats what your trying to avoid. this will cause the axle to
pull out of the socket it's in. then you have fun so try to avoid
that happening. well i hope this kind of explains it better.
good luck
Old Oct 6, 2009 | 01:08 PM
  #183
Fitcious's Avatar
hi guys,
quick question:
1. is it required to remove the bumpstops in the rear? if not, will it be an annoyance down the road (i.e. creaking noises, weird noises, danger in driving?)
2. If bumpstops were removed, and i wanted to go back to stock in the future, is it true that i have to buy the whole unit for the rear as stated by another member on this forum, rather than just buying new bumpstops?
Old Oct 7, 2009 | 05:07 AM
  #184
Lek's Avatar
Lek
That's what Honda told me about the rear, but you can buy aftermarket bumpstops easily if you know the size. Measure them before you cut them.
Old Nov 18, 2009 | 07:28 PM
  #185
Lek's Avatar
Lek
Bilstien B14 for Honda Jazz/Fit. Progressive springs with a 0-30mm drop.
Honda Jazz B14
http://www.hondajazzlover.com/forum/...?topic=18079.0
Old Dec 2, 2009 | 11:37 PM
  #186
jbyron's Avatar
Thanks for this DIY! I followed it to a T and it all worked great. To remove that metal collar I first opened it up with one pass of the dremel along the seam, then a strong screw driver. To pop the bumpstop back in I just used a vice grip and a soft pad in front of the metal end and it literally went POP back in. For the second bumpstop I just held the boot with all my might while my friend cut it.
btw this is all for my mom's Fit (early x-mas present) on DF210s 17x7 +42 with 205/40/17
For the bumpstops I cut them just like yours and have no problems. Tanabe recommended cutting 30% and yours was just about that much. I DID encounter the dreaded axle pop out lol though I had no idea that's what it was because I took every precaution to prevent it (jackstand under control arm AND bucket under rotor haha).
check here for my thread where some guys helped me through it (and god bless them):
https://www.fitfreak.net/forums/2nd-...tall-help.html
There are pics of the final product too.
Final word, I had to use TWO sets of camber bolts up front (both top and bottom 19mm bolts are now fastcam bolts) and 2.25 degrees of negative camber in front to prevent rubbing. But good news is it only rubbed on HUGE bumps going 50mph or more. Bad news is that socal freeways are nothing but one huge bump after another haha. Those who know the 405 know what I'm talking about.
hope this info helps
also, my mint sport rims with 8k only on them are for sale, haha.
Old Dec 6, 2009 | 04:36 PM
  #187
doctor1foot's Avatar
This is the outcome of following this DIY. t1r s-coils
Old Dec 6, 2009 | 07:26 PM
  #188
niko3257's Avatar
looks good and nice pic
Old Dec 6, 2009 | 09:42 PM
  #189
Iceman's Avatar
how is the ride on the T1R's? I need something that will lower and ride good. Unlike my PIC's, which are rough as hell on the road, but on the track its a different story.
Old Dec 6, 2009 | 10:27 PM
  #190
actually i feel like the ride comfort feels the same as stock. Its not like I take super fast tight turns all day. I took it around a circle in my block and it feels nice and tight, but daily driving normally feels as smooth as stock.
Old Dec 7, 2009 | 05:46 AM
  #191
Benggolf's Avatar
I have DF210 and my friend installed T1Rs.
The ride on his car is noticably harder compared to mine.
Both cars are on stock shock absorbers.
Old Jan 11, 2010 | 10:08 PM
  #192
Scala's Avatar
Nice thread! great work! will be using this soon for my fit!
Old Feb 2, 2010 | 09:45 PM
  #193
Tork's Avatar
Hey Nick,
I just noticed a nice correction can be made here.
The rear shock collars, you do not have to pry them open to get to the rear bump stops. Just put the allen wrench in the shock end, clamp a vice grip on the collar. Then apply a little bit of pull up pressure while turning the vice grip counter clock wise. They simply unscrew right off.
I have done it twice this way. Back early summer with springs/cutting bump stop and a month ago when I installed air shocks. Sorry I did not mention this sooner.
Sorry if someone else caught this. I didn't go back and read the 10 pages of posts.
Mike
Old Feb 3, 2010 | 12:04 AM
  #194
niko3257's Avatar
Originally Posted by Tork
Hey Nick,
Mike
thats Mike.
never thought of doing that cause they just looked so tight.
guess we learned something new.
thanks
Old Feb 3, 2010 | 09:54 AM
  #195
Tork's Avatar
Well Nick all your DIY's are so dang good and helpful, it is a wonder I was able to find a bit of a short cut.
Old Feb 4, 2010 | 12:19 AM
  #196
niko3257's Avatar
LOL
thanks for the props Mike.
i edited my post and added the info you stated
in the proper section.
hopefully this makes everyones experience easier
Old Mar 28, 2010 | 11:14 PM
  #197
Socialvegetable's Avatar
Ok, So my dad (pro mechanic) and I installed my DF210's at his garage this afternoon. We were able to do the fronts without removing any extra plastic, wiper motor, etc. using a small allen bit in the top of the struts, and a small wrench. I'm not sure it was any easier than removing all the plastic, but it worked.
I've got a small problem now, though. We road tested it, and everything looks and rides well, but after I got it home, I noticed a small squeak. When sitting still, If I turn the wheel all the way clockwise, then quickly turn back counterclockwise, there's a rub/squeak sound that seems to be coming from the top of the passenger strut, right about when the wheel passes the 1/4 turn mark.
Everything went back together without a hitch, the only exception being that the axle on the passenger side seemed to bind up and wouldn't rotate without a little coercion, while we were reinstalling the passenger-side strut.
I'm going to take it in for an alignment check this week, and I'll ask the techs to troubleshoot, but I figured I'd see if anyone else has experienced anything similar. There appears to be no actual problem, and the squeak only occurs in the exact circumstances I explained above. Turning the wheel slowly back, doesn't do it, and it only does it when turning counterclockwise in that one position.
Old Mar 30, 2010 | 11:28 PM
  #198
Took it to the shop tonight after the squeak got worse. Simple problem, the lower rubber collar at the top of the strut was a tiny bit crooked, and when the strut rocked, the collar rotated unevenly, causing the noise. Very easy to fix...the problem was getting the car up onto one of the lifts at my dad's garage. The frame was touching on the alignment rack, so we had to use the hydraulic post lift...only it's really old and doesn't sink all the way into the floor. Fine for most cars, but the lowered fit wouldn't clear without climbing onto 2x4s first.
Ah, the joys of a lowered suspension. Everything is perfect now, though, and I couldn't be happier.
Old Mar 31, 2010 | 12:24 AM
  #199
hondaFORlife's Avatar
me and fitdeez installed the dropzone springs on our fits,..
we didnt cut the bumpstops.. i kinda just wanna confirm, if we did, would it ride lower?
Old Mar 31, 2010 | 12:49 AM
  #200
niko3257's Avatar
if your cars have springs that lower 1.2'' they should be cut.
i forgot to cut my front one and the car was sitting on bump
stop when i put it back down.
but then again min was 1.5 in the front and 1.2 in the rear.
