KWSC Kit Release Ramblings
Old May 28, 2008 | 12:27 PM
  #361
xorbe's Avatar
too bad the supercard isn't adjustable somehow... seems like it would be in the position to adjust fuel injector duty cycle, or something like that.
also remember, the stock honda injectors don't like >80% duty cycle KW said i think, so 205cc aftermarket may be a bit more powerful than "stock 185cc" than the numbers would suggest?
Old May 28, 2008 | 12:30 PM
  #362
gotfitted's Avatar
Originally Posted by DynamicFit
As promised here are they dyno charts from
Before Mods: Mugen header, Mugen drop-in filter, J's Racing catback
After Mods: Jackson Racing Supercharger base kit, J's racing catback
Tom
wait, so the after mods don't include the Mugen header? have you ran with the mugen header with the upgraded injectors yet?
Old May 28, 2008 | 12:57 PM
  #363
OJRKraftWerks's Avatar
Former Vendor
leonine, I have been in contact with your shop. Hopefully they will stay in contact.
We hope that you guys will contact us to help solve your issues, because this will allow us to better understand what is going on. It seems that the exhaust setups you guys have are not efficient enough for the Injector upgrade. We are working hard to solve this problem, but it is very difficult when we have never seen this issue.
-OJR
  #364
leonine's Avatar
oscar is awaiting my mechanics call after he gets the injectors off and test drives it. should know more shortly. it could be a bad injector but no way to know that without sending it back to rc for testing i suppose.
Old May 28, 2008 | 01:22 PM
  #365
Illusive's Avatar
hmmmm weird. I'm sure the T1R header has just as big of pipes as the Megan one.
Old May 28, 2008 | 01:36 PM
  #366
leonine's Avatar
right but you are not running a test pipe and your exhaust and test pipe are not 60mm.
Old May 28, 2008 | 01:43 PM
  #367
xorbe's Avatar
yeah, exactly what was the confirmed upgraded injectors kit prototype install again? it was megan header + 60mm test pipe + 60mm exhaust then?
i thought i read not to touch the cat on a stock Fit, as it would run lean. as in, after-market header fine, after-market cat-back fine, but don't remove the cat without tuning AFR.
so maybe it's the test pipe that really requires the injector upgrade.
Old May 28, 2008 | 02:14 PM
  #368
leonine's Avatar
i am running a test pipe and am running way too rich. even in open loop my a/f is supposed to be in the low to mid 11's but i am 10.4 and maybe even lower. the AEM gauge starts in the low 10's.
Old May 28, 2008 | 02:38 PM
  #369
DynamicFit's Avatar
I never had the injector upgrade. I decided to wait for the hondata reflash.
Old May 28, 2008 | 03:03 PM
  #370
xorbe's Avatar
remember, none of us have seen a c15-16 based dyno chart yet, everything is c15-60 so far... (for all of us a/t people reading and waiting)
As promised here are they dyno charts from ... From this you can see that although the Jackson racing supercharger does make some good additional power after 4.5 grand ...
strange, i remember from a previous chart that the SC pull away point was about 3.5k rpms... maybe that one had more mods, rats, i wish i knew where that dyno plot was.
Old May 28, 2008 | 03:35 PM
  #371
eldaino's Avatar
Originally Posted by aliencowboy
Ok,
I will try to answer the questions the best i can! I love it...
1. Passing on the freeway you only need a little gas not allot like stock
and you are gone, no strain on engine at all, even under boost the motor does not feel like is is straining like stock.
2. It feels a He_l of alot quicker is the only way to put it.
3. When I first drove the car it had the A/C on and there was more power than it had before without A/C on, very happy with the results, and still happy.
4. The car feels "normal" until you give it some gas, a little pedal, and you can feel it.
That's about it.
If anyone in the area wants to take a ride or drive it (with me along), let me know that way everyone will get an un-biased opinion.
Hope this helped
AC
awesome. maybe the base kit will be all that i need. i would love to only have to worry about an axle back, it makes everything cheaper. thanks for the info man!
Old May 28, 2008 | 03:39 PM
  #372
eldaino's Avatar
Originally Posted by xorbe
i *am* getting the header. i just don't know about getting cat-back exhaust, and how involved that is, or if there's any gains from that with the 5# kit+header.
well, i thought they said the hondata would not be available for the a/t kit, but if it is, i'd have to see how involved it is. i wasn't planning on it. i've already bit off more than i had planned to chew already... and the hondata isn't going to pass CA smog test i suspect. i can wrench off the injectors and header if i must in 2012, but redoing the car computer, that's too much i think.
how's the new avatar icon?
liking the avatar man.
everyone keeps saying that the hondata is NOT available, but i think its just that it hasn't been discussed if it IS going to be available. (feel free to chime in kraftwerks, it'll stop my thread crapping. )
i figured you were trying to stay carb legal...from what everyone is saying though, especially leonie, you may be better off with a cat or axle back and no header at all. But it seems the biggest culprit is the injectors. all this makes me wonder what the 310's on the hondata would do, but then again, its a re-amped ecu to go along with it.
Old May 28, 2008 | 03:46 PM
  #373
eldaino's Avatar
Originally Posted by leonine
here's what i know so far:
3) my mechanic did comment that the injectors seemed to by quite a big step up for only 5 psi. he also said that my mugen setup (header/axleback) is more geared for naturally aspirated motors). he said mugen in general is set up this way from his experience. this could also be causing a flow restriction which is running too rich.
my guys are top notch and i take there word. they are authorized installers for the old JR kits and have been doing this for a LONG time. depending in the a/f readings i will either keep the stock injectors on or look into the 195's from RC.
crap. this is making me re-think my decision to go with the mugen header. and it makes sense, as they typically only do n/a stuff. (well...with the exception of a lot of their fit protoypes, as they have all been F.I.! wtf? )
so do we have to end up running the megan set up?
the other exhaust components i was considering are ones that justin also uses , (spoon b pipe and fujistubo) but sometimes its hard to get the specs on the diameter of a lot of jdm stuff.
Crap crap cuhhhhrap. I guess its going to be base kit+axleback (for looks and sound.) for me. but apparently, thats not too bad, ...and a LOT less trouble.
Old May 28, 2008 | 03:51 PM
  #374
leonine's Avatar
here are the results
so my mechanic put the stock injectors back on and blasted it down the road and back. the a/f was between 11.7 and 11.9 which a little on the lean side but not where detonation would occur. also not sure how hard the injectors are working (>80%) so i will be monitoring this closely for fluctuations. so for now i am out the cost of the injector upgrade but at least the car is running better. seems that the ultimate cause is the exhaust restricting flow although i have a header/test pipe and the whole shabang. maybe it is the diameter or the axle back is very restrictive.
I am going to drive it like that for a little while and might deside to go with a 195cc and see if that gets me in the sweet spot of low to mid 11's a/f while still not causing any CEL. it will take a few days for the ecu to reset so hopefully by the end of the week my scangauge will say "Ready" meaning ecu completed test and it will pass inspecion which is due in a few weeks.
This has been a learning experience for me for sure. i hope i have provided some useful info for other members who are having this problem.
Old May 28, 2008 | 03:52 PM
  #375
eldaino's Avatar
yeah, that sounds about right. as far as what requires the injector upgrade, i think its not just the testpipe/cat-delete. according to oscar, if you run the injectors, you must have a cat back and headers.
Old May 28, 2008 | 04:17 PM
  #376
leonine's Avatar
i can't speak to other components but if anything it is not the header but the axle back imo. even with the test pipe and header at idle it is pretty quiet. when i had the skunk2 60mm cat back i put the same test pipe on and it was not drivable because it was too loud.
so again it seems that depending on the setup you have you would either need to stay with the stock injectors, 195cc(maybe) or 205cc.
to say that the header/test pipe requires the injector upgrade i think has been proven to be an untrue statement in some cases.
I sure hope my car still has that oomph it did before when i drive it home tonight.
Old May 28, 2008 | 04:24 PM
  #377
xorbe's Avatar
and the AFR sensor, how hard is it to install? where does it mount exactly?
Old May 28, 2008 | 05:09 PM
  #378
Former Vendor
surely some of us have enough skill around here to o-scope the output of the supercard and whip up an adjustable circuit. what do injector controlling pulses look like?
The SuperCard is chipped with a non-adjustable program. Please do not try to modify our electronics.
-OJR
Old May 28, 2008 | 05:10 PM
  #379
leonine's Avatar
not hard at all. took me about 2 hours. you can mount it wherever you want in the cockpit. you will need to have an 2nd o2 bung welded on to the cat or test pipe depending on the model you get. some come with their home made 02 sensors. i chose AEM because it comes with a Bosch wideband o2 sensor. others i saw had some home made thing. then it is just running the wires through the firewall and hooking it up.
Old May 28, 2008 | 05:38 PM
  #380
Illusive's Avatar
Just purchased a T1R Test Pipe and T1R 50S Ver.2 Exhaust to replace my Fujitsubo one. Also added an O2 bung to the test pipe and will be installing the AEM Wideband UEGO gauge like leonine to monitor the A/F ratio.
