KWSC Kit Release Ramblings
Old May 29, 2008 | 09:41 AM
  #401
Illusive's Avatar
REXXXXXXX can you elaborate on your boost leaks? Would like to hear where you are finding yours.
Old May 29, 2008 | 10:01 AM
  #402
Illusive's Avatar
Oh and anyone who has installed some gauges, if you installed a Oil Pressure Gauge, how many PSI should I expect my oil pressure go up to?
Old May 29, 2008 | 10:02 AM
  #403
leonine's Avatar
this came from a temple of vtec article. i dont know if it is inner or outer. probably inner. that's what matters. all i know is the 50mm is significantly larger than stock looking at it.
Old May 29, 2008 | 10:11 AM
  #404
SickFit's Avatar
Originally Posted by claymore
16.8 with supercharger??? My mainly stock Jazz went 17.009.
Im guess you didnt reading anything else in his post. Take a look back at it and you'll notice that he had issues all day. k thx bai
Old May 29, 2008 | 10:12 AM
  #405
SickFit's Avatar
Originally Posted by DynamicFit
I'm sure the power gains would've seemed a lot more impressive if I never had a header, but I am pretty certain that once I have that and the Hondata reflash w/ injectors, I will be making a good deal more power. I'm thinking about 160 on the dyno I've been doing all my testing. Will report back once the kit has been installed.
My friend, you are close.
Old May 29, 2008 | 10:14 AM
  #406
SickFit's Avatar
+1 More specific please Rexxx. Thanks dude.
Old May 29, 2008 | 10:53 AM
  #407
claymore's Avatar
Mine runs at about 80-100 cold start with 10-30 oil then down to 25-65 when at normal temps depending on RPM from 25 at idle up to 65 or so at anything over 3000.
Old May 29, 2008 | 10:58 AM
  #408
Illusive's Avatar
hmmm ok thanks Claymore. When I get up to 4000 or so, it is ~80PSI, then on the way up to 6500, it jumps up to ~90-95.
On a cold start, it idles around 80-85PSI
Old May 29, 2008 | 11:04 AM
  #409
claymore's Avatar
Sounds like it's working good to me.
Old May 29, 2008 | 11:05 AM
  #410
Illusive's Avatar
Whew! Thanks for the verification...I looked at the gauge as it rose almost to the limit and thought to myself...thats not good haha!
Old May 29, 2008 | 11:11 AM
  #411
claymore's Avatar
Yep scared the crap out of me on the first cold start and it almost pegged the needle. Mine probably goes as high as yours at 6500 but at that speed I'm trying to hang on due to the extensive torque it's putting out and my face gets all stretched out of shape from the massive acceleration from my N/A Jazz and it's hard to read the gauges with the trees in the background flying by at those speeds.
Old May 29, 2008 | 11:26 AM
  #412
YeeFit's Avatar
So now that the injector upgrade has been removed from leonines car, does that mean there is a significant drop in power? meaning, are ppl essentially only getting approx 122whp, and ~110tq? from what I remember the injector upgrade brought the KW kit to 145whp, ~125tq to the wheels.
It's great that everything works well now, but now you won't be getting as much power as you hoped for... but the 122hp/110tq was with stock exhaust right? meaning now you can run a header and cat-back, so that should give some better numbers?
What if you ran the Hondata Reflash Package with the upgraded 310cc injectors? That should probably get you more power right?
Sorry for all the question marks, but I have decided to get this kit and will be picking it up in person this july and I want to make sure it is the right choice for me.
Old May 29, 2008 | 11:42 AM
  #413
Illusive's Avatar
Been watching "The Fast and the Furious" again eh? haha!
Old May 29, 2008 | 11:56 AM
  #414
OJRKraftWerks's Avatar
Former Vendor
Originally Posted by REXXXXXXXXX
took her to the track on friday night. im not even going to post my results. i was so mad... reason being - i found a huge boost leak the next day. I was only boosting 2 lbs at the track. Hey, at least i still beat a stock prelude by .2 sec!!! Im going back next month after catdelete/headers/hondata... hoping to break into 14's
alright, alright i ran 16.8... pretty bad. but that was at full weight, less than half boost, and AC running (it was hot as hell, i 4got to shut it off lol)
Im ordering t-bolt clamps for the whole system, cuz even at 5 psi i've noticed the Fisher Price clamps that come with the kit tend to move a little even after tightening... i've had to fix the same boost leak about 4 times now All I have to fix now is the 2 brake lines that rattle every once in a while and I'm good. When it runs at its peak, it's OH SO SWEET.
If the kit is hooked up correctly,with properly tightened hose clamps, you should have no leaks. Make sure to use a nut driver or socket to tighten the clamps if you feel you cannot get a proper torque with a screwdriver.
The shielded hose clamps included are made to be able to fit into the tight areas of the engine compartment easier than other clamps. Some clamps you simply cannot fit into areas.
If you are having any troubles, do not hesitate to contact us via KW Support Email or phone. We put the email support line in place to support our customers in the absolute best way possible.
-OJR
Old May 29, 2008 | 02:11 PM
  #415
eldaino's Avatar
Originally Posted by Hondasforlife
Yay Rexxxxx....i Want To Beat Every 4door Si....grr Si's Are Not Suppose To Be 4door....sorry In A Cranky Mood Guys...but Good I Hope I Beat An Si Atleast Once..lol
ha ha, if thats the case, they aren't even suppossed to be coupes, just hatchbacks.
Old May 29, 2008 | 02:13 PM
  #416
eldaino's Avatar
+2. especially when it coming from someone who harps on noobs for not searching things or reading them correctly the first time.
Old May 29, 2008 | 02:19 PM
  #417
leonine's Avatar
so far i have noticed a drop in "oomph" when i floor it. but as my mechanic explained and i already figured there is a trade off between performance and reliability. so with my current exhaust setup if i kept running the injector upgrade i would no doubt be harming my engine. I have always planned on keeping my ride for a LONG time. i want the most performance while keeping the reliability factor as high as possible. that is why i chose the sc in the first place.
Now the power difference is not extremely different but is noticable. so either i drop my whole exhaust and upgrade to 60mm or keep what i have and live with it. being i am so fond of my current setup and the sound i am leaning more towards staying where i am which is still NICE. i am sure i am making better power than just the "Base" kit alone.
Of course this is still all speculation until my ecu completes its ODBII tests. If so i am a happy camper ; if not i am back to sqare one
We shall see.
Old May 29, 2008 | 03:21 PM
  #418
Former Vendor
leonine,
You have it a little backwards.
You have no power drop with the removal of the injectors. If anything, you should be seeing a power gain. Also, the injector upgrade setup in no way was harming your engine! The additional fuel was not causing any harm at all.
-OJR
Old May 29, 2008 | 03:45 PM
  #419
YeeFit's Avatar
Hey OJR,
Since Leonine is having issues, possibly stemming from his exhaust, how can this be corrected? I think a lot of Fit owners who will buy this kit will have so many different exhaust combinations....
When I come to pick up my kit, and the Hondata reflash package, my setup will be a Megan Header, T1R B-Pipe, and Greddy Ti-C axleback what problems might I run into? the same as Leonine? I don't plan on doing a down pipe/test pipe.. I'm sure my exhaust diameter is 50mm.. and not 60mm... will the Hondata reflash correct these initial problems ppl are experiencing?
Old May 29, 2008 | 04:00 PM
  #420
SickFit's Avatar
Hey OJR,
Based on what Oscar and I talked about earlier over PM. You shouldnt run into any issues with your exhaust when you go hondata.
I <3 Hondata
