**Official K-Fit Pictures Thread** (no BS)
Old Apr 19, 2011 | 11:51 PM
  #101
whtsjdm's Avatar
Also, is anyone not running dbw? What dash functions do you lose? I'm going to be making a custom intake mani for mine and would prefer cable.
Old Apr 19, 2011 | 11:52 PM
  #102
DiamondStarMonsters's Avatar
Originally Posted by whtsjdm
Picking up a k20z1 swap Friday. CM twin disc ordered. Picking up a full race t3 44mm sidewinder within the next two weeks. Probably going to run a 6262. Still a long way to go. Going to hit mid 500whp on 12 lbs or so. People are going to be so mad getting beat by the mini mini van.
Nice! Which turbine are you going with the .48, .63 or .82A/R?
Old Apr 20, 2011 | 12:10 AM
  #103
whtsjdm's Avatar
Probably the .82 AR. Not 100% yet. Almost bought a supercharger today, but held off. Being that one of my best friends is Treblic, of course I got talked into going turbo haha.
Old Apr 20, 2011 | 12:35 AM
  #104
Friends don't let friends go S/C .82 will be "laggy" as I am sure you know but more power/psi!
Too many people get caught up in "spool" times. It'll haul with that much turbine on a 6262! Even at 12psi!
A wise man from Texas once said "Putting a .63A/R on that turbo is like f*cking with only the very tip of your dick" when referring to that exact turbo.
Old Apr 20, 2011 | 12:46 AM
  #105
whtsjdm's Avatar
Oh, I won't be stopping at 12psi. Car will most likely see 700+ whp at some point. Probably be sitting 600-650whp range for the street. Going to be trading my 6 speed for a 5 speed trans as well.
Old Apr 20, 2011 | 12:55 AM
  #106
MNfit's Avatar
Nay DSM I was not really plainning to run a catchcan.
damn the KFits are starting to come out of the woodworks.
I got a call from the shop today, they basicly have all the engine parts they need, there just waiting on me now to get them the car. Hopefully I can pick up my back up car this weekend and get my car to them
Old Apr 20, 2011 | 09:35 AM
  #107
JCrimson's Avatar
kind of hard to see but i have a CF coilpack cover also. =^_^=
cant wait to get this beast in.
Old Apr 20, 2011 | 09:57 AM
  #108
breadman's Avatar
iam be using a m90 sc from chevy 3.8 or possibly a m112 sc from a cobra, kit will be all custom, should be around 420-440hp and thats before cams and meth, my friend made 375 on stock k20 with m62 sc! all i got to say is in time...twin scroll and good tuning=game over
Old Apr 20, 2011 | 02:53 PM
  #109
whtsjdm's Avatar
Bumping this. Didn't getinafit use a cable tb and only had a check engine light?
Old Apr 20, 2011 | 02:58 PM
  #110
MNfit's Avatar
Well im going to be running a cable throttle as well, but im also completely ditching the stock gauge cluster for a racepak
Old Apr 20, 2011 | 03:06 PM
  #111
whtsjdm's Avatar
Yeah, I mean I will if I have to. I might anyway seeing as how the fit tach only goes to 8k. I just refuse to use dbw on a high hp turbo car if it's not necessary.
Old Apr 20, 2011 | 03:48 PM
  #112
breadman's Avatar
iam running dbw and only thing thats not working is my cruise control, but thats cuz iam using a v6 tb that has a bigger oem bore, just havent taken the time to figure out how to correct this
if you have obd 2 testing in your state, you have to use dbw to pass, if not you can use cable
that is the only reason i went with dbw is so i could pass state emission tests. if anyone needs help on how to do this i will be glad to help you out, it very easy. make sure to check with your state dmv before doing the swap to find out laws and rules. here in north carolina it checks for the vin in the ecu and set readiness codes when pluged in, if it only reads the kpro( this is when you are using cable and dont use duel ecu setup with dbw), not the fit ecu, then it see the wrong vin and see readiness codes that are not the same. you can allso check with local places that do inspections to see what is involved. i had to put a catalitic converter on when i did my exhaust so that it allso passed the visual part of the inspection. Not try to tell everyone what to do nor talk you into doing what i did, just making it known before you spend all this money and havent to redo it over.
Old Apr 20, 2011 | 04:21 PM
  #113
MNfit's Avatar
^^that is why i love MN no testing so I can run with no cat, and nothing carb legal, lol
Old Apr 20, 2011 | 04:29 PM
  #114
breadman's Avatar
the only thing they dont do here is smog testing, if they did tons of ppl would fail lol, i know in cali the motor has to be from a donor car of the same year
Old Apr 20, 2011 | 05:59 PM
  #115
whtsjdm's Avatar
Thanks breadman. I was pretty sure I wouldn't have any issues running cable, but I heard some people saying things didn't work.
Old Apr 20, 2011 | 06:06 PM
  #116
MNfit's Avatar
I think most engine swap laws are the motor has to been of the same year or new then the car its going in. If you think about it my swap then is technically not legal haha
Old Apr 20, 2011 | 06:10 PM
  #117
breadman's Avatar
i see your from va, i got a few friends there and i think yall have obd 2 testing there, make sure to double check that, if you go with a cable tb you can not use the stock gauges cuz they wont communicaite with just kpro alone, go with a racepak or whatever your preference of digital guage. cant wait to see your swap done!
Old Apr 20, 2011 | 06:19 PM
  #118
breadman's Avatar
thats is true, but most places wont take the time to check the vin on the block, only the vin that in the ecu, by stay dbw and using the dual ecu setup, scan tools will read the stock ecu and tricks the computer to thinking the L15 is still there and will read the orignal vin like nothings been done, trust me i just done it a 2 months ago, i tried not to laugh to hard when a 1.5 liter showed on their screen and i have a 2.4 in the bay lol.
Old Apr 20, 2011 | 10:20 PM
  #119
Zangoose GD3 Blue's Avatar
yes he did, which was for the DBW pedal not found... i have the same thing check engine light for the pedal
Old Apr 21, 2011 | 02:47 AM
  #120
whtsjdm's Avatar
No we don't. At least, not in my county. It varies, but the only counties that tend to do emissions is stafford and further north. I use to be an Va inspector when I was a mechanic for Dodge.
