Independent Fog Light (First Post has answer!)
Old Oct 2, 2008 | 02:57 AM
  #301
niko3257's Avatar
FitFreak GE8 DIY Guy
is this mod the same for 09 fits?
considering DRL. also my drl is disabled via fuse.
Old Nov 17, 2008 | 09:36 PM
  #302
Roger's Fit's Avatar
Yes and no. I am currently looking into a method to do this without cutting any wires. The fuse box and relays are not the same.
I did find the relay, however. It is on top of the fuse box, in the little group of 2 independent relays.
It should be easy to make the lights come on all the time with the key on.
However, i am looking for control via the switch, and keeping them on with the high beams.
Old Dec 17, 2008 | 03:59 AM
  #303
holokai's Avatar
For 1st generation USDM Fits. I did the modification to the harness on the steering column (cut the red/yellow wire) and connected it to the under dash fuse box location 26 (radio). I tested it without grounding the fog light relay and the fogs work completely independently (turn on) except when the high beams are on. Seeing as I don't have to use high beams much I figure it's good enough for me but I would like to know if there's any danger in not grounding the fog light relay (red/white wire from the bottom right relay in the under hood fuse box). Any thoughts?
Old Dec 17, 2008 | 04:56 PM
  #304
secondspassed's Avatar
Does anyone know if I do just the second half of this mod (ground the fog light relay) will my fogs still stay on when my brights turn on?
I don't care to have the fogs turn on with no other lights turned on, I just want them with brights. Anyone know?
ps- the reason is i just can't see myself wanting to have to separately turn off the fogs whenever I want my headlights off.
Old Dec 17, 2008 | 11:31 PM
  #305
HONDAMATIC's Avatar
HA! i got independent fog lights without cutting, damage or anything! but it involves the red/yellow at c204 at the fuse box, a terminal pin kit and a honda terminal set...
Old Jan 11, 2009 | 10:45 PM
  #306
SFactor2's Avatar
From: Negative Repland (exiled by fragile ego's and "can't handle the truth" babies) LMFAO ;P
using the word "completely" then using the word "except" makes me (and your english/science teacher) sad
Digitized
Toronto Community
Nov 29, 2018 02:57 PM
SgtBaxter
Nov 12, 2012 05:42 PM
mtunofun
Dec 21, 2009 11:01 AM
SFactor2
Jan 24, 2009 07:48 PM
gar1013
116
May 11, 2008 07:44 PM
