The Official "Transferable parts from GE8 to GD3" Thread
Old Nov 3, 2008 | 03:54 PM
  #201
BONES76's Avatar
Wonder if the blue mood lighting from ge fit into the gd...?
Old Nov 3, 2008 | 04:11 PM
  #202
Juliane's Avatar
No, it does not. The dash is completely different. You can buy after-market lighting which is not hard to install. There is a tutorial on this forum under Fit Lighting.
Old Nov 3, 2008 | 10:44 PM
  #203
peg_leg's Avatar
Originally Posted by Sugarphreak
Bump for any info on the dead pedal. Transferable?
i'd like to know this as well
Old Nov 4, 2008 | 08:44 AM
  #204
chimmike's Avatar
Originally Posted by dickiez
Relative To My Interest
also quick question about the i-vtec on the GE
is it going to be a hard hitting Vtec like an 06 SI
or the same vtec we have now/ 03 SI's
uh, what?
Is this a serious question or are you being facetious?
Hard hitting?
ROFL. Seriously. Funniest question of the thread.
115hp iVTEC, hard hitting? Gimme a break. No. you won't feel it. You don't even feel it in the GD3. the i simply means the cam timing is variable as well.
Old Nov 4, 2008 | 08:47 AM
  #205
chimmike's Avatar
Has anyone tried to fit the telescoping portion of the steering wheel? I've got long legs and my arms are nearly fully outstretched to the GD3 wheel in order for me to sit comfortably while driving.
Old Nov 5, 2008 | 08:18 PM
  #206
JaySmith's Avatar
Still no answer as to if the Automatic Shiftknobs are swappable?
Old Nov 6, 2008 | 09:25 AM
  #207
peg_leg's Avatar
i might check on this in a few days along with the auto shifter knob i found the dead pedal part numbers. #13 and #14
Find Honda Parts and Honda Accessories by Car Model - Bernardi Honda Parts and Accessories
Old Nov 7, 2008 | 12:49 AM
  #208
JaySmith's Avatar
I'm definitely interested in hearing your answer, as I'd love to get both items. Especially the Honda Accessories Blue Stitched shiftknob.
Old Nov 11, 2008 | 08:47 PM
  #209
peg_leg's Avatar
ive been sick so it will be the end of this week or next week before i can check
Old Nov 12, 2008 | 12:04 PM
  #210
Tofuman's Avatar
Originally Posted by chimmike
uh, what?
Hard hitting?
he wasn't referring to the power, he was referring to if there is a cam profile change-over like in K20A, K20A2, K20Z1, K20Z3, etc. instead of adjusted timing as in the K20A3, etc.
On the GD3, the motor runs on 12 valves until it is in vtec mode, then it is using all 16 valves. the GE8 uses all 16 valves all the time. the question is; do the GE8 camshafts have vtec change-over profiles?
GD3
GE8
They look nearly identical.
Old Nov 13, 2008 | 09:05 PM
  #211
grtpumpkin's Avatar
I am waiting impatiently for parts diagrams of the GE to become available so that i can get an answer to this question myself. I'm thinking that the telescoping mechanism is fairly simple, and concealed under the plastic directly behind the steering wheel. If this is the case, then it should be a straight-forward matter to install the needed parts in a GD3. Both cars have ample room in the steering-column/dashboard area to allow it. I dearly hope it will be do-able, as I really would like a tele wheel. My Mazda5 had it and i miss it a little more each day.
Old Nov 13, 2008 | 09:38 PM
  #212
theloxmyth's Avatar
Fit Gadget Freak
I'm watching (lurking ) with anticipation to find out about the tilt/telescopic wheel too!
Old Nov 13, 2008 | 10:14 PM
  #213
grtpumpkin's Avatar
The woman that owns the day-care I take my daughter to bought a GE and has been letting me crawl all over it. The telescoping mechanism appears to be a two part shaft that is enclosed in the plastic behind the wheel itself. I can't really tell if the steering column below that is identical to the GD or not, thats what I need parts diagrams for. As soon as College Hills Honda puts up the diagrams we're in business....And then I need some fool to total a GE so I can cannabalize the entire steering column LOL
Old Nov 14, 2008 | 12:32 AM
  #214
polaski's Avatar
Huh, I think honda is trying to even up their engine naming. That cam gear is too simple to adjust timing. Not to mention $10 cheaper than the GD3.
warrants further research. Doesn't make sense the L15A1 is "VTEC" and the L15A7 is "i-VTEC" with just a change in cam profiles and a new lifter design.
i-VTEC
Old Nov 14, 2008 | 01:13 AM
  #215
eldaino's Avatar
i changed my mind about the swap.
for someone who wants to run thier fit into the ground, swapping out the l15 to the newer version would be awesome.
you'd probably get better gas mileage and if the torque is appreciated even in the heavier, less sporty chassis, i can imagine how nice it would feel on the gd3. if it was smoother too...that would be great.
would the engine be a direct bolt in? everything looks like its roughly in the same place no?
Old Nov 14, 2008 | 02:08 AM
  #216
Shaggs2Dope's Avatar
Frequent FitFreak Poster
Honestly, only a dumbass would invest considerable time and money for a 9hp Gain. If you are gonna swap do a k20 or k24, and upgrade the clutch/flywheel before its installed. If you are going to do a swap put something in that's worth it. 9hp, or another 109hp. A k24 w/6 speed doubles the HP of the fit engine. Thats a lot of work and money for no real gain. Turbo before you swap.
Old Nov 16, 2008 | 08:37 PM
  #217
matt0807's Avatar
Originally Posted by JDM_DOHC_SiR
The shocks "will not work" they are much longer ..... and the spring rates for the new fit are much softer than the 1st gen...
Here is a shot of stock GD3 Suspension parts on a GE8 for referance
So the change in height has got to be the perch location on the shock.
I just installed front GD stock springs on the GE, and its not even worth taking a picture... not noticable at all.
Now the search is on for GD shocks...
Old Nov 17, 2008 | 07:58 PM
  #218
peg_leg's Avatar
i checked the dead pedal on a 09 fit it won't work and the auto shift knob won't work either.
Old Nov 17, 2008 | 08:32 PM
  #219
solbrothers's Avatar
uh, what?
Hard hitting?
not really a funny question. the difference between a D16 vtec crossover and a b16 vtec crossover is night and day.
Old Nov 17, 2008 | 08:37 PM
  #220
BONES76's Avatar
The auto shift knob wont work...bummer...why is that tho? the way it mounts? just curious
