The Official "Transferable parts from GE8 to GD3" Thread
Old Nov 17, 2008 | 08:45 PM
  #221
peg_leg's Avatar
Originally Posted by BONES76
The auto shift knob wont work...bummer...why is that tho? the way it mounts? just curious
yea the gd3's have two screws that hold it and the ge8 doesn't and the shaft on the ge8 is bigger around then the gd3.
Old Nov 18, 2008 | 03:55 PM
  #222
BONES76's Avatar
For giggles I went to the local Honda dealer where a friend works and they had the 09 accessory leather knob (AT) in stock. He said bring in to see if we can rig something. It fits exactly!! There is a trim piece that snaps over the screws on the 09. anyhow I now have the 09 leather AT knob on my 08...pics to follow when I get home from work...til then the AT knob will fit
ps you will need to buy the trim piece that snaps on the front..comes seperately....
Old Nov 18, 2008 | 05:09 PM
  #223
peg_leg's Avatar
props to you i didn't try one i just looked at it and it didn't look like it would work.
Old Nov 19, 2008 | 11:49 PM
  #224
shonda1989's Avatar
Originally Posted by Tofuman
it runs on all 16 valves at all times, and switches to a more aggressive cam lobe in 'vtec'. on our current GD3 L15A motor, it runs on 12 valves normally, but once in vtec, it runs on all 16 valves.
the economic version of VTEC will have both intake valves open but one of those valves will be a quarter open which will create a swirl and give the engine more low end torque.
also for the head swap if it stays with the honda thinking everything is the same youu just need the different gasket and the coolant channels maybe off a small amount but nothing to stop doing it.
Old Nov 25, 2008 | 04:43 PM
  #225
grtpumpkin's Avatar
I looked at the parts diagrams for the steering column on Bernardiparts.com and the news isn't good. I appears as if they redesigned the ENTIRE steering column for the GE instead of just adding a telescoping end like I had hoped they would. In order to acomplish the swap you would probably have to get into some major fabrication to get the new column to fit into and behind the old dash. Oh wells It was worth looking into anyway...
Old Nov 30, 2008 | 03:40 PM
  #226
secondspassed's Avatar
thank you, person who ACTUALLY TRIED the shift knob before claiming it wouldn't work. funny, you'd think ANYONE would think to do that.
Old Dec 2, 2008 | 01:07 AM
  #227
JaySmith's Avatar
So just to clarify before ordering, the 2009 Honda Fit Sport AT Shift Knob has been confirmed to work correct? What about the optional Blue Interior Illumination?
Old Dec 4, 2008 | 05:32 PM
  #228
BONES76's Avatar
10-4 on the shift knob...it works. I read the install instructions for the light kit and seems it should. Prob gonna my next buy an try. I have a spare slot next to my mirror switch thats needs something to go there...lol.
Old Dec 5, 2008 | 04:03 AM
  #229
junktea1's Avatar
I'm just interested in whether the rear headrests swap right out with the GD
Old Dec 6, 2008 | 12:21 PM
  #230
BONES76's Avatar
The rear headrest do and dont fit....by that I mean the post will fit down the holes witha little push. But on the 09 headrest the post are really really long and bottom out with the head rest still way up high. I m sure a little cuttin could fix that. The 08 headrest post are short.
Old Dec 8, 2008 | 01:46 AM
  #231
feared's Avatar
i thought the distance between the posts were different, so they couldnt fit even if you tried forcing them to.
Old Dec 8, 2008 | 04:50 PM
  #232
BONES76's Avatar
The only issue I had when trying was the length of the poles (headrest). Ordered the amb. light kit...find out this week if it'll work...
Old Dec 13, 2008 | 11:33 PM
  #233
JaySmith's Avatar
https://www.fitfreak.net/forums/sale...tml#post519295
Old Dec 14, 2008 | 12:42 AM
  #234
Shaggs2Dope's Avatar
Frequent FitFreak Poster
anyone know about the remote engine start? That's the only part I want off the new fit. I would really like to remote start it now that its in the 20's outside at night and early mornings. I don't wanna plug in an engine oil heater, just have it start and warmup to defrost the windshield.
Old Dec 15, 2008 | 05:37 PM
  #235
BONES76's Avatar
Got my amb light kit....everything plugs in and it works the only issue I had was fitting the light switch into the spare slot next to the mirror switch. The button is shaped differently then the slot. Trimmed one set of corners off hopefully it'll fit...if not more trimming. Before routing the wires I plugged it all in...turned on the lights...pushed the button and bam! purdy blew lights. more to come later
Old Dec 15, 2008 | 06:39 PM
  #236
Koi's Avatar
Koi
Pics please!
Old Dec 15, 2008 | 08:39 PM
  #237
Juliane's Avatar
Is this the '09 light kit or another manufacturer? Do you have an '09 or a GD3 model?
The reason I ask is that my dealer told me for sure that the '09 ambient light kit would NOT work on my '08 because of the different dash configuration.
Old Dec 15, 2008 | 09:44 PM
  #238
BONES76's Avatar
Working on uploading the pics. I have a GD3 and it is the 09 ambient kit. I had to modify the on/off switch a tad...because where it fits in next to the mirror switch is bit different. Besides the button ordeal it fits and connects perfectly....
Old Dec 15, 2008 | 10:30 PM
  #239
Juliane's Avatar
What color did you get? So the only mod you have to make is the on/off switch fitting? How do you take out that switch plate - do you punch it out from the back or what? And yes, please if you can show me how to install the light kit I'll do it myself. Or call another dealer who can put it in for me. Maybe if I order it through them and then show them that it can be done.
Old Dec 16, 2008 | 08:56 PM
  #240
BONES76's Avatar
Sorry took a while...had to get a new card reader, old one went patooey.
switch
under drivers side
pass side
blue feet
pass side blue fit
09 accessory shift knob AT
