for those that dont already know- Hondata
Old Jan 5, 2015 | 07:23 PM
  #281
lakia5524's Avatar
Originally Posted by BlueAngelFit
DSM are you still doing hondata remote tuning ? I have a 08 sport automatic, daily driver in central Florida, my goal for this year is to at least get the hondata and then a tune based on a stock fit.
Hey blueangel I wouldnt worry about getting flashpro unless its necessary. stock tune is just very minors cleanups for $600 but this is just my apennion from exspairiants.
Check out flashprotunning.com
Old Jan 6, 2015 | 03:06 PM
  #282
BlueAngelFit's Avatar
anybody have a hondata tune on a stock fit ? or was running one in the past?
Old Apr 14, 2015 | 11:16 AM
  #283
cnordt24's Avatar
It will help a little on a stock tune, but not a whole lot.. I picked one up cause I'm running intake, intake manifold, headers, cat-delete, and cat-back exhaust. It makes a huge difference with all the mods. If you plan on moding then definitely pick one up, then you can just adjust your tune as you add different mods
Old Nov 18, 2015 | 08:06 AM
  #284
dewthedew's Avatar
I do, it smoothes everything out
Old Nov 19, 2015 | 04:57 AM
  #285
kylerwho's Avatar
spoon fed
I helped tune a local guy up here on a bone stock engine and he said he had better low end, no rev hang, and something like 2 or 3 mpg boost from his commute.
Old Nov 22, 2015 | 12:39 AM
  #286
jmsplitfyre's Avatar
I didn't notice if there was already a thread for dyno numbers after tuning with Flashpro with the supporting mods.
Old Nov 22, 2015 | 01:50 AM
  #287
Myxalplyx's Avatar
What was the huge difference that you noticed?
Old Jun 20, 2016 | 09:12 PM
  #288
lakia5524's Avatar
has any one hooked up there wideband with flashpro lambda ? Wanting to get info on the ecu pin out and correct way to hook it up
Old Nov 8, 2016 | 06:09 PM
  #289
lakia5524's Avatar
anyone use the virtual dyno for there street tuning?
Virtual Dyno
Old Nov 8, 2016 | 07:21 PM
  #290
dwtaylorpdx's Avatar
It would almost be worth the cost just to avoid the false errors on the cat..
Old Nov 26, 2016 | 09:13 AM
  #291
lakia5524's Avatar
to get your full potential with the cat deletes and what not flashpro would be necessary
to run your engine most efficient because you do not want to run to lean
Old Mar 29, 2017 | 01:17 AM
  #292
joshchewuhhh's Avatar
This is amazing!! definitely going to look into this
Old Apr 2, 2017 | 12:16 PM
  #293
lakia5524's Avatar
finally got a smoother virtual dyno log , 3rd gear
is anyone using the flashplash kwsc high boost stock map? curious what kind of knock count you are getting and what your ignition is at with wide open throttle
Old Mar 27, 2018 | 10:48 AM
  #294
2gmaxboost's Avatar
lakia5524 nice numers !!
Keep it going, good job ......Is that still stock bottom end?
Old Jul 27, 2018 | 11:42 PM
  #295
airwicc's Avatar
damn that HP to Torque ratio though
silence911
Apr 14, 2019 02:24 PM
Fit FX
Feb 27, 2012 10:13 PM
annunC8
Apr 4, 2010 02:20 AM
ghettoboy247
Jun 27, 2009 08:17 PM
Hellfish
Jan 27, 2009 08:20 PM
