Old Oct 12, 2013 | 05:41 PM
  #9301
cyanosis's Avatar
washed it, ordered the circuit hero shift extender.
Old Oct 12, 2013 | 07:07 PM
  #9302
YeahItFits's Avatar
Senior Member
Long time Lurker.
The past two weeks.
Installed lowering spring; Teins.
Added the Depo Clear Smoked Tails. Not sure how I'm Feeling about these tails.
(I previously had the Depo JDM RS.)
Picked these up from someone else. Going to install these. (Whenever I get chance.)
Old Oct 12, 2013 | 11:16 PM
  #9303
Nerdsrock22's Avatar
Grabbed some fall shots of the Fit before the coils and exhaust arrive!
Old Oct 13, 2013 | 07:51 PM
  #9304
Waiz's Avatar
Avid FitFreak Poster
I had a busy day with the Panda.
-Filled up the tank with gas, $3.75 a gallon!
-Changed the oil to Mobil 1 and the Mobil 1 110 filter
-Got tires rotated and filled with nitrogen
-Washed the exterior
-Detailed the interior
Originally Posted by YeahItFits
Long time Lurker.
The past two weeks.
Are the lights plug & play? any day time shots?
I have been contemplating getting the Depo's but I'm still on the fence
Nice pics and Fit, your setup reminds me of mine
Old Oct 13, 2013 | 08:00 PM
  #9305
1SickVeilsideZ's Avatar
Old Oct 13, 2013 | 08:02 PM
  #9306
YeahItFits's Avatar
Senior Member
Yeah, they're plug and play.
I don't have any right now. Give me a sec. Lol
Which Depo Lights you thinking about?
Old Oct 13, 2013 | 08:03 PM
  #9307
YeahItFits's Avatar
Senior Member
Originally Posted by 1SickVeilsideZ
WOW.
Old Oct 13, 2013 | 08:13 PM
  #9308
YeahItFits's Avatar
Senior Member
Old Oct 14, 2013 | 01:38 AM
  #9309
inkster's Avatar
Got my new JDM bumper. Waiting for the other parts to arrive. If anyone is wondering, I ordered it from A&J racing.
Photoshopped the bumper on my car to see how it looks with USDM tails. Not bad!
Old Oct 14, 2013 | 02:06 AM
  #9310
pig_pit's Avatar
So nice. Dont forget to pick up that diffuser
Old Oct 14, 2013 | 12:27 PM
  #9311
cyanosis's Avatar
ordered the revo short shifter (mugen knockoff)
the mugen mirror cover
honda rear cargo tray and bumper applique.
still waiting on the sti lip, circuit hero shift extender and progress rear sway to show up.
now I need to decide which springs and wheels to go with and figure out a way to fully raise the rear wing and not just hinge it at the mounting bolts.
Old Oct 14, 2013 | 03:59 PM
  #9312
cyanosis's Avatar
Progress bar arrived.
installation as follows:
drive the car up on ramps,
install driver's side.
install passengers side andddddddd. FUCK YOU CYANOSIS THE RUBBER ISOLATOR FOR THE PASSENGER SIDE SPRING IS IN THE WAY OF THE MIDDLE BOLT.
spend next hour figuring out how to squeeze it in... and then how to get an allen wrench on it to hold it down while tightening. ended up jacking up the passenger side and pulling off the tire. then I had to trim part of the isolator with a razor to get the allen key on it. I wasn't about to try to take the spring off after fighting to attach the bar to the other two bolts. didn't want to undo them.
this should be a 30 minute install. took two hours. fuck my life.
Old Oct 14, 2013 | 04:01 PM
  #9313
cyanosis's Avatar
so top gear top tip on the progress RSB (rear sway bar) install for the GE8 2nd generation honda fit (keyword stuffing so it shows up in search).
take off the tires and have an allen key ready. you don't need to remove the springs, they only suggest that so that the rubber isolators on the bottom are not in the way. for 5/6 bolts on my 2011, it wasn't a problem. the last one i just trimmed the isolator a bit with a razor.
Old Oct 14, 2013 | 04:36 PM
  #9314
Wanderer.'s Avatar
After all that you could have just taken the springs out in 10 minutes I know I know, i've got this far i'm not turning around now.
I'm glad you got it installed and hope you enjoy.
Old Oct 14, 2013 | 05:01 PM
  #9315
cyanosis's Avatar
taking off the spring would have required me to undo an entire two bolts to take off the partially installed sway bar. far too much work to spend 5-10 minutes doing that. better to spend 20 hacking at the isolator with a razor and needle nose pliers like an idiot.
all said and done and there's a bizarre spring noise boing/thrum whatever on the right side when going over bumps. fuck me i may have to take off the spring anyway.
Old Oct 14, 2013 | 05:03 PM
  #9316
cyanosis's Avatar
so if i'm taking off the spring, i'm not putting the OEM one back on.
now to decide if I should go progress or swift.
Old Oct 14, 2013 | 08:00 PM
  #9317
Waiz's Avatar
Sweet, thanks for that shot.
I was thinking of picking up a set of the clear non-smoked ones. I will keep it in mind
Gorgeous!
Nice, that's going to look good!
Old Oct 14, 2013 | 08:55 PM
  #9318
cyanosis's Avatar
well, after taking every item out of the hatch area, it still clunks on the passenger side going over bumps. the shock is tight as shit on the bottom so IDK what it is. Will mess with it tomorrow AM.
le sigh. Really sucks being a car enthusiast that likes to mod but is a horrible mechanic.
Old Oct 14, 2013 | 10:05 PM
  #9319
ajp2k3's Avatar
Nerdsrock22 - Info on your retro-fit please?
Old Oct 14, 2013 | 10:53 PM
  #9320
LS460 Bi-Xenon Projectors
"Val-60R" MH1 Solenoid Conversion
"Bi-XX" Ultra High-Beam Mod
Powdercoated Front-Half (gloss black)
Modified for D2S bulbs
100mm xB LED White Angel Eyes
STi-R Clear Lens w/ Color Mod
Morimoto 5Five D2S Elite Kit
Gloss Black-Painted Reflector Bowl
It was built by BlueBoogers, I don't really know much about it.
