MODS/ACCESSORIES for the GK
Old Oct 20, 2014 | 11:27 AM
  #581
eCity Fit's Avatar
Can you tell me how to get the center console out? I see the two "screws" near the footwell on each side. I need to know how to remove gear shift knob and does it just pull up? Thanks
REPLY: Center console removal
- pop out the plastic cover behind the armrest (facing the rear seats), unplug the lighter and USB
- remove the two lower bolts
- remove the lower front center console panel containing the lighter, HDMI and USB (one screw on top - then pop it out) once done, you'll see two screws in the center which are to be removed.
- remove the gear shift knob
- the console is now held in place by a center clip (green). Just pull up the console and give is a small tug to unpop the clip. Remember to reinstall the clip back to the console if it gets stuck with the car body.
If your gearshift knob is auto there is a thread somewhere on FF that describes this. (Update: SilverEX15 to the rescue in the succeeding post)
For the 6-speed, you have to pull down the boot shift cover (held in place with plastic hooks at the base of the knob). Once you separate the cover from the knob then just unscrew to remove.
Hope that helps - rttby
Old Oct 20, 2014 | 11:48 AM
  #582
SilverEX15's Avatar
I have the CVT, so it might be a bit different if you have manual. First remove the single silver screw upper left of the 12v outlet panel. Then gently pull the panel away. Honda's diagrams give you an idea what to do and how to protect the shift knob. I didn't have to remove the knob, since the console lifted away from the trim beneath the shift knob. I haven't found a way to release the rear of the console to remove the whole thing, though. Lifting the front was good enough for my purposes.
Old Oct 20, 2014 | 05:19 PM
  #583
ROTTBOY's Avatar
Stereo install cont..........
Compare the factory OEM speakers with the mid-range priced Polks. Bigger magnets and twice the weight. Easy to figure out why Honda had to boost equalization from the OEM HU to make those factory tinny speakers sound decent.
Finished install of speakers and crossovers on the remaining doors. Feeding through the door-grommet was easy enough except for the front driver's door. On the rubber boot attached to the body, there is a plastic surround base. To add to the difficulty, once past, there is a double wall so fishing the wire was tedious.
Rear Right door bare wire
REar right door. Wire with conduit.
Speaker connected to crossover - Right rear door
Right front door Wire ready for install w/ conduit
Speaker, tweeter connected to crossover Right front door
Speaker ready for install Left front door
Speaker, tweeter connected to crossover Left Front door
Next, will layout the remaining wires and will make a temporary hook-up to the powered components. Can't wait to test.
Won't be till this weekend though - wife arrives in a couple of days so will be busy doing my regular errands.
File Type: jpg
Old Oct 20, 2014 | 08:46 PM
  #584
Vtecfreeak's Avatar
Originally Posted by ROTTBOY
Already got:
- Ultragauge
- reverse park sensor kit (Ebay) w/ LED/beep display
- i-vtec DOHC stickers (both rear doors) and plaque (rear hatch area)
- Front grill JDM emblem (still can't find the right size for the rear)
- F & R JDM RS emblems
- non-OEM Wheel locks
- LED bulbs for the interior
- 16" alloys (HD w/ 185/55x16 Kumho PA31 tires placed order 6/14 finally arrvd. 6/28)
- OEM Door visors, rear applique, Nose mask, cargo liner, Door Edge film, Cargo net, All-season mats
- OEM JDM rear LED upper piping tail-lights (as in JDM GK Hybrid)
- OEM illuminated door sills, rear seat covers, cargo tray
- OEM Sport Pedals
- Blox 6 Spd. Shift knob (to be soon replaced by OEM GK RS leather knob)
- Wheelskins Leather steering wheel cover
Stereo upgrade parts:
- Polk DB6501 (two sets) - Kenwood KSC-SW11 8" powered sub - Kenwood Excelon XR400-4 channel amp.
- Audison BIT TEN D Processor - 100 ft. of oxygen-free speaker wire 16 g. - T-Spec install kit - Dynamat Extreme (bulk) - MLV (40 sq. ft.) - Ensolite foam
- 15% tint on rear door windows & hatch glass (Llumar CTX ceramic)
Will paint the front calipers and ordered heat-resistant stickers:
link: Honda Accord Brake Caliper Decals 6pc Stickers 2013
Other items:
- retrofit aftermarket perimeter entry + OEM push/start (after spending too much money on all other accessories, now that the Fit is here, decided against this) Decided I can live with the LX Set-up after all!!!
- not to foget. Yes, I am putting a hawaiian dancing cupie doll on the dash!!!
7 years and never bought any toys for my GD. Joined FF last March and now, have gone overboard with plans for add-ons. This forum is just "BAD". Thanks a lot, everybody here!!!
What are you planning on???
We're did u find the RS badges?? And what were the part #'s
REPLY: Got mine from EBAY. Still haven't put them on. They are JDM OEM badges. Good luck shopping and post what you decide!!! - rttby
Old Oct 21, 2014 | 12:42 PM
  #585
miroman86's Avatar
Question sir, are you changing your head unit too? or just speakers? I would like to upgrade my speakers to JBL or something, but I was wondering if I have to do this much taking-out-stuff just to do that...
REply: Am keeping the OEM HU. YOu could upgrade just the speakers. It will be clearer but all depends on how much your expectations are. Am almost certain that whatever brand you get, you won't be pleased with the bass response. Scroll back to previous posts to find out why this project required the removal of the interior. Whatever you decide, don't forget to post!!!! Good luck - rottboy
Old Oct 21, 2014 | 04:24 PM
  #586
BILLBOGEY's Avatar
Wow, has there been a lot of activity since I last came to this site. You guys with the super cool looking lowering, wheel spacers, interior lighting etc..........
Definitely devilizing the rest of our GK community.
Here is my plain jane LX.
Started to install all my accessories (listed in the 1st post on this thread). So far have done a Blox Shifter knob.
Got a leather steering wheel cover (Wheelskins - made in the USA) for me and my neighbor (EX-CVT) and helped him this afternoon do the install. Mfg. says an hour. Its more like 2 hours + and that was two of us. Not perfect but definitely feels like the real thing. Can't go wrong for $50. Do not get the ones they sell for the GE. Its slightly bigger and won't have the exact fit. I measure mine and made the Special Order. Its 14 1/4" and 3 7/8".
Still have a ton of stuff to install. Next will be painting the calipers (red), installing the caliper Honda sticker, 16" alloys, rear JDM upper tail-lights. Won't happen tomorrow - its NFL Sunday.
BTW, has anyone here taken out the OEM stereo H/U??? Anyone install amps or the like??? The only place I can find for my audio stuff in under the two front seats. Any tips would be great.
Did a short 50 mile jaunt just to see what kind of mileage I could get with the manual. Was able to squeeze 46 MPG doing 60 mph (60% hwy and 40% city - no A/C) and watching that eco green light. Pretty pleased with those results. Will post what I finally get after my first fill-up.
So nice to be back!!!!!!!!
I went on the Wheelskins website and could not figure out how to special order. I then noticed the 2003-2005 civic SI wheel size is 14 1/4 X 3 7/8. So, I just ordered that wheel cover in perforated Red top and bottom with black sides. I ordered black with red inserts seat covers from GT so this will be color coordinated. I will not mess with wheels or exterior mods. This website gives you many ideas on customizing your FIT. Bill#22335
REply: If its the same size your in good shape. When it arrives make sure you have a couple of hours to spare cause that's how long its gonna take to do it properly. Can't go wrong for $50, plus, its made it our good 'ol USA!!!! - rttby
Old Oct 21, 2014 | 04:39 PM
  #587
SilverEX15's Avatar
Thanks. Nice report. I have similar Polks I want to install. Was it necessary to install the new crossovers, or just your choice?
REply: If your Polks are components (separate woofer and tweeter), your best served by installing the crossovers. If they are full range (all combined in one housing) your good to go as these would have built-in crossovers/filters (am not 100% sure on all the models). As inferred previously, the mids and the highs will both improve but I doubt if the bass would be similar. In fact, it might be worse. Hook em up and see what it sounds like. Let us know so others can follow your lead. - rttby
Old Oct 21, 2014 | 04:59 PM
  #588
nicco's Avatar
It can be pretty simple to swap the speakers and get good results. A few posts ago I posted a link to some pics of how to hack the factory wiring so as not to damage anything and be able to connect them to new speakers.
My tip is to go and invest $5 or $10 in a set of plastic trim removal tools as the plastic trims are very soft and scratch easily. Plus they make removing the clips that don't pull out with the door trim easier.
REply: Nicco has a great tip here and it makes using the OEM wiring connectors a breeze w/out resorting to cutting. If swapping with 6.5" speakers I do further remind all that if drilling is to be avoided, get the speaker adaptor brackets (there the same as for the GE's). Only very slight modification needs to be done to the brackets so they will fit perfect. Happy mod shopping to all!!!! - rttby
Old Oct 21, 2014 | 09:53 PM
  #589
Vtecfreeak's Avatar
Ok cool thanks man. Do u know the sellers name by chance?
REply: Here's the info.
09-13 FIT GE8 GENUINE HONDA JDM FRONT & REAR RS EMBLEM BADGE COMBO Item price $49.99 Seller: rebelperformanceparts
The rear looks exactly the same as what's on the JDM GK RS. The front may have to be modified as its a bracket. The GK's grill, there's no opening to screw it in. Might have to dremel part of the plastic off the front badge and use industrial double-sided tape instead. Mind you this was purchased last March, therefore, am not sure if this seller is still around. Happy shopping!!!!
Old Oct 22, 2014 | 12:06 AM
  #590
ROTTBOY's Avatar
Wires and more wires
Speaker wires laid out from sound processor and connected to crossovers.
A mess of wires getting ready for hook-up to sound processor (to be mounted on spare tire cover right beside the amp.)
Speaker wires and Remote ON soldered and shrink-wrap connected to sound processor harness.
Tomorrow will mount and wire the power and negative cables from the battery will go to respective blocks to provide "juice" for the processor, amp. and powered sub.
Old Oct 22, 2014 | 06:18 AM
  #591
Superfly's Avatar
Had to make sure that pretty Audison box was I plain view eh?
REply: Unintended but certainly noticeable!!! - rttby
Old Oct 22, 2014 | 04:07 PM
  #592
ellatron's Avatar
just ordered my OEM all weather floor mats. couldn't take seeing all the dirt ive been seeing with the stock fabric mats.. got it for $100 shipped. anyone want my fabric mats? lol
Old Oct 22, 2014 | 04:10 PM
  #593
payluder's Avatar
My brother needs the floor mat =) in the bay area too. He has the LX which doesn't come with it.
COMMENT: Could you have your brother ask the dealership again? My LX came with those carpet mats. I'm almost sure carpet mats are a standard item throughout the line-up. Good luck. - rttby
Old Oct 22, 2014 | 07:57 PM
  #594
ROTTBOY's Avatar
Power and components wired
Wires and components finally laid out
Power Blocks installed.
Positive block straight to battery. 4 gauge cable was fished through the rubber boot located on the engine firewall slightly below the brake reservoir.
Negative block connected to rear seat bolt
Kenwood Amp and Sound processor wired
Kenwood powered sub wired
Before starting all my projects, had so much time and thought everything was covered. NADA! Will go to Autozone or our local parts store tmrw and score 4 gauge and 6 gauge power cables for the amp.
As previously mentioned, OEM HU connector should arrive this weekend and am targeting Sat. for the first sound test. Should that fare well, it'll be another couple of days to tidy and secure up all wires, power blocks, components.
Finally, interior reinstall and then DRIVE, DRIVE, DRIVE at long last!!!!!!!!!
UPDATE 10/23: Wire clean-up started this morning. What a bloody mess I created!!!
Old Oct 22, 2014 | 08:29 PM
  #595
Superfly's Avatar
Very nice!
Old Oct 22, 2014 | 11:09 PM
  #596
m_x's Avatar
m_x
Is this what I would have to do to change the shift boot ring? I put a Blox shift knob on and bought an adapter to use instead of the stock shift boot ring. Do you have to remove the whole console for that?
REPLY:
Unfortunately, yes. The boot ring cannot pop out. Its secured underneath the console with 8 screws. - rttby
Here's a pic:
REPLY TO REPLY: Thanks Rottboy! Seeing the pic is a big help. My adapter ring should be here tomorrow so this will make a nice weekend project. Also, I like you method of responding within the post like this. Keeps things organized.
Old Oct 23, 2014 | 06:42 PM
  #597
Fitmo's Avatar
WeatherTechs came in today. As expected, the fit is flawless.
Old Oct 24, 2014 | 07:04 AM
  #598
SilverEX15's Avatar
What do I have to do to completely remove the center console on an EX? I can unhook the front, but I don't see a way to free the rear portion.
REply: Try following the steps in reply on post #556. Note, it applies to 6-spds. For CVT's, once you remove the shift knob, the procedure should be the same. Good luck! - rttby
Old Oct 24, 2014 | 08:22 AM
  #599
Superfly's Avatar
The back of the console is a seperate piece. It's just clipped on. Pull it off and you'll see two 8mm bolts. There will also be 3 cables that need to be unplugged. Then it will just pull out. There is also a green clip, like what's used in the doors, near the e-brake. It will just come loose when you pull up. Just make sure you reconnect it when you re-install.
Add'l: Suggest investing in some plastic trim removal tools to keep the plastic components "mark-free". These make removals easier too!!! - rttby
Pictorial reply: Hope this helps too!!! - rttby
Old Oct 24, 2014 | 08:34 AM
  #600
SilverEX15's Avatar
Thanks. I'll keep this for future reference.
