Warranty Repairs
Old Dec 25, 2007 | 03:06 AM
  #281
claymore's Avatar
Could be the floating brake calipers "floating. Next time you pull in make it a point to have your foot on the brakes and see if you still get the same noise.
Old Dec 31, 2007 | 04:01 PM
  #282
bdiehl's Avatar
Actually found a bump that I could do it every time.. it sounds like a winding down noise??? After several times I have confirmed it is not coming from the break pedal but definitely is a winding noise after hitting a bump and breaking.
THOUGHTS? I am lost on this one.
Old Jan 15, 2008 | 06:19 AM
  #283
RBrittigan's Avatar
Fog lamp bracket faulty - Passenger side. No issues for replacement - part is in, just need to get my rear to the dealer for replacement... (coming up on 3,000 miles, '08 Sport)
Old Jan 24, 2008 | 07:08 PM
  #284
tntprmtns's Avatar
Dome Light
On the dome light not fading out. I just had my car into my local dealer to find out why the dome light does not fade out when I close the door.
The had the car all day and called me before closing to say that it does not have that option. Even though it's in the manual .
Well that's the word.
Old Jan 25, 2008 | 01:53 AM
  #285
CrazyAboutMyFit's Avatar
Your dealer must be wrong. Numerous Fit owners here (check out thread under Fit lighting) have said that their dome light fades out. My dealership told me that it is supposed to fade out. Mine also does not. They want my car for a lengthy check over as to what the problem is when it's mid-week, not too busy, and convenient for me ... I'll let you know when I've had a chance to get mine looked at ... by the way, I have an LX auto. What about others?
Old Jan 26, 2008 | 02:38 PM
  #286
cheffyjay's Avatar
My dome light fades out after a min. but I have had problems with it not going out when it is supposed to (all doors shut, etc.) and as a result I leave it in the off position most of the time.
A good sign that after 29k miles this is the only problem.
Old Jan 28, 2008 | 09:01 AM
  #287
RBrittigan's Avatar
Faulty Fog Lamp House repair has been completed. Very smooth process. Anybody feel nervous / sad when their fit goes to the shop? Just don't like it not being in my driveway or with me... Beginning to wonder if I need help.
Old Feb 1, 2008 | 03:01 PM
  #288
daggonit's Avatar
I've got another thread on here listing my multiple problems with my Honda Fit but here is a list in case you missed it...
1. Broken driver's seat...the springs broke under the padding. The seat was replaced. Problem solved.
2. Leaking door. Water was getting around the seal causing the seatbelt to get wet. The seal was replaced and the problem has not returned.
3. Oil Consumption. The car loses 1/2 quart of oil every two weeks. I'm currently still trying to get this fixed. The car will most likely be turned over to Honda and claimed as a lemon.
4. Stereo replacement. The thing stopped reading discs. Stereo replaced and is working as it should.
5. Creaking dashboard...happened after new stereo install. Problem still not resolved. Dealer left huge scratch on dashboard trying to find issue. They state it was there before I brought it in...BBB claim filed.
6. Stripped lug bolts...dealer did it when I took it in to have the brakes checked (next issue). Stripped the bolts by not using supplied lock key and they made me pay for it. BBB claim filed and formal complaint filed against dealer with Honda.
4. Warped brake rotors (newest problem). Still not resolved.
Old Feb 1, 2008 | 04:19 PM
  #289
doctordoom's Avatar
Supervillain
holy moly that's a lot. do you hate honda and your fit now? from what you say, it seems like your honda dealer really SUCKS.
Old Feb 2, 2008 | 01:20 AM
  #290
jeimusu86's Avatar
that sux man....really unfortunate situation...i hope you can get a new 08 fit in return or trade it in for something nice...good luck
Old Feb 2, 2008 | 06:05 AM
  #291
F0NIX's Avatar
I have forgotten to write in this thread that I have had one warranty repair on my Jazz 1.4i LS CVT (GD1) since i got it in February 2007.
The light switch and turning light switch arm was to sensitive.
When I was turning right and using the right turning light and at the same time was tuching the arm a little forward, the front headlight turned on to long mode (nut sure what it is called in English). Even if the arm was not over the "notch".
The dealer told me that the arm was replaced with the factory one when I got the car since I got the fog-lights. The fault was probably applied then and it was the switch that was faulty not the mounting.
Anyway they orderd a new switch and replaced it just a week after I told them about the problem, with no cost for me.
Now it work like it was supposed to.
Old Feb 12, 2008 | 12:33 AM
  #292
MooEChili's Avatar
Just had faulty left front wheel bearings replaced at 8,165 miles.
Old Feb 17, 2008 | 10:34 PM
  #293
Hondasforlife's Avatar
i had Warped brake rotors....they fixed miine by replacing them with an used rotors and used brake pads which lasted about 3months..then i had to get them replaced cuz they were completely done...lol..i got the pads replaced and rotors resurfaced for $55..not bad honestly......i have been on the new pads since september...its been 5 months so far so good...probably getting HAWK brake pads for summer...
Old Feb 18, 2008 | 03:21 PM
  #294
rocksnap's Avatar
4. Warped brake rotors (newest problem). Still not resolved.[/quote]
I will bet you that your rotors are NOT warped. It is very rare to actually "warp" a rotor. You would need to have a really HOT rotor and then shock cool it by hitting a puddle or something.
What you need to do is "rebed" the pads. Do 5-7 moderate to heavy braking from 50 - 30 mph without stopping the car. You want to get thte brakes pretty hot, close to brake fade. Then drive the car several miles without using the brakes to cool them. If you can let it sit several hours till completely cool after that. This will rebed the pads to the rotors.
You actually transfer pad material to the rotors. This material can develop a high spot that gives you the feeling of a warped rotor. This procedure should buff the high spot out and leave you a nice uniform layer of pad material, fixing your "warped" rotors.
Old Feb 20, 2008 | 11:31 PM
  #295
airborne200208's Avatar
i read the post about the broken parking brake cover on the 02 jazz, and my 08 fit has the same thing. i was always so proud honda didnt use cheap plastic like mitsubishi. guess not anymore.
Old Mar 4, 2008 | 07:48 PM
  #296
Domo3234's Avatar
i had my fit for almost a month now i just noticed a buzzing sound when i turn the key onto the on position then it stops. the car runs fine and there is no check egine light
Old Mar 4, 2008 | 08:04 PM
  #297
daggonit's Avatar
You actually transfer pad material to the rotors. This material can develop a high spot that gives you the feeling of a warped rotor. This procedure should buff the high spot out and leave you a nice uniform layer of pad material, fixing your "warped" rotors.[/QUOTE]
Thanks for the advise! I'll give a try! I had the dealership look at the brakes and they told me there was nothing wrong with the rotors or the pads but they couldn't explain why the pedal felt like there was warping. The car is going back in this Thursday because the check engine light came on while I was going to work this past Monday. My Fit is a constant NIGHTMARE!
Old Mar 4, 2008 | 08:07 PM
  #298
daggonit's Avatar
My car does the same thing. I'm pretty sure it's the fuel pump. I never really gave it much thought since my Civic made the same noise but not as loud. I think it's louder in the Fit since the fuel tank is right under the front seats.
Old Mar 4, 2008 | 08:11 PM
  #299
binaryh4x's Avatar
+1 for Fuel pump
Old Mar 5, 2008 | 01:06 AM
  #300
claymore's Avatar
What a load of crap. I bet you read "the not warped article" floating around on the web with the rest of the internet myths.
It's obvious that you have never worked on brake systems and never "Turned " a rotor on a brake lathe or you wouldn't make dumb statements like "I bet you rotors are not warped". Disc brake rotors do warp frequently on both Honda's and other makes.
While "turning rotors" you can actually see, hear, feel and MEASURE how much rotors ARE WARPED and it's sure as hell not brake pad buildup. So try and learn something and go to your local brake shop and try and tell the mechanics that rotors don't warp and they will laugh you out of the shop after they show you one being turned in the brake rotor lathe so you can see for yourself how much they warp.
I guess car manufactures are just wasting their money stamping rotor turning information specs. onto the rotors.
I have warped rotors in the course of one high speed chase it doesn't take getting them wet or any other nonsense just drive and brake too hard for too long and you WILL warp your rotors.
