devmail's 2007 SSM GD3 build - The Grey Goose
Old May 6, 2018 | 08:57 PM
  #301
Fed the nitrous feed line through the recirculation vent for the heater. Drilled a 1 1/8" hole in the under part of the cowl to reuse a rubber grommet from the heater core lines to run the nitrous line into the engine bay. Now to remove the old line, run the blow down line and the electrical stuff for the kit. Good times. Also weighed the wiper motor, 5.6 lbs...wipers are 2.2 lbs total...going to leave them off for now but might add them in later when I need to drive.
Old May 6, 2018 | 09:00 PM
  #302
Office shot!
Old May 7, 2018 | 09:37 PM
  #303
Got the old nitrous feed line and blow down line removed today. The bulkheaded end of the blow down line got seized so that will need to be replaced. Ordered some fittings so I can mount the heater pressure switch and innovate psn1 bottle pressure sensor to the nitrous bottle valve where the mechanical pressure gauge normally mounts. I've had 2 of those gauges leak on me already so I'm done with those. Nitrous didn't leak out of them, just the goo inside! 🤣
Old May 8, 2018 | 09:13 PM
  #304
Removed the washer fluid reservoir, some airbag sensors, and 16ft nitrous line...saved about 6.75 lbs.
Old May 8, 2018 | 10:35 PM
  #305
tecra's Avatar
speechless
Old May 9, 2018 | 11:30 AM
  #306
Originally Posted by tecra
speechless
speechless in the good way or in the bad way? Lol
So I got to weigh the car and it was approx 2171 lbs with me in it. So thats 2031 lbs! I am pumped because my goal is under to be under 2000 lbs without me inside and I'm almost there. The car still has heavy winter tires and wheels (18 lbs ea 1.6 EL wheels), almost full tank of gas, stock hood, ungutted rear doors, passenger seat and full exhaust. Woo! pumped!
Old May 10, 2018 | 07:49 PM
  #307
tecra's Avatar
you want the truth or pleasantries? i'll say this, i remember a few months back you had to have your "tunes". now, you have no dash....
Old May 10, 2018 | 08:13 PM
  #308
I see your point. This was before we got a new car and this became my project. A Bluetooth speaker will solve that problem. 😁 The new GK will stay stock, comfortable, smooth and boring...This will be the opposite, haha.
Old May 12, 2018 | 09:10 PM
  #309
Cleaned up and painted the fuel pump cover...
Hood before...
Hood after removing 2.6 lbs of steel.
Old May 13, 2018 | 09:42 PM
  #310
Stock hood now at 12.4 lbs. At this level it gets flimsy and may require hood pins at the front for stability. Next task is to see if I can remove the hood latch and hinges altogether and just use some sort of locking hood pins.
Old May 14, 2018 | 12:08 PM
  #311
Transferred my old license plate to the new car, sent in my application for a personalized plate for this one. 🤣
Old May 18, 2018 | 02:50 PM
  #312
Gutted the hood down to 11.68 lbs, held by 4 hood pins. No damper or hinges now but its pretty easy to remove.
Also got an adapter to run the bottle pressure gauge and bottle warmer from the mechanical bottle ressure port on the bottle valve. I'll have to make a disconnect for the pressure sensor wiring, but the reason I did this is to:
1. clean up the area a bit, making it easier to connect the nitrous feed line in a small space
2. make it possible to read the bottle pressure on the innovate gauge even when the bottle is closed. A mechanical pressure sensor would be facing the wrong way and I've had 2 fail on me and don't want to use them anymore.
3. Eliminate a possibility of the bottle exploding if the heater gets left on when the bottle is closed.
4. Have as few connections as possible interrupting the flow of nitrous to the engine.
Old May 18, 2018 | 08:33 PM
  #313
Trimmed an additional 4.4 lbs of weight from the hatch, including the latch and 1 damper. It's light enough to only need 1 damper to stay open. Need some hood pins for this now. 🤣 Also finally test fitted one spare door and it fits fine...got some lexan for both rear doors coming soon. 😄 Car looks super ghetto, lol...work in progress.
Old May 21, 2018 | 04:42 PM
  #314
Fit10's Avatar
Nice set up for the laughing gas.
Old May 23, 2018 | 09:20 PM
  #315
thank you sir, I just ordered an NX blow down tube as my original Dynotune I had to cut to remove, the bulkheaded portion got seized to the frame. Also people will stop assuming I have the bottle mounted in the wrong direction as it looks like another nitrous line coming out the top or now the back.
For some reason both seat belts are now locked in a shortened position so I am going to order some simple 4 points to replace them for now. Should save a couple pounds too as the front belts and their brackets are well over 10 lbs. Getting some hood pins for the hatch tomorrow and still waiting on lexan for the rear doors to ship, it's on backorder. As well my 5/8" silicone caps to bypass the heater core should be in soon. Worked on hooking up the wiring and mounting the innovate gauge and Ultragauge, pics when complete.
Old May 24, 2018 | 11:10 AM
  #316
idrivemyself's Avatar
Devin, come on man, stop screwing around and go full Super Street with it already!
Old May 24, 2018 | 11:59 AM
  #317
who knows what state it will end up? First I have to have the power to back up the body and chassis mods. 😁
Old May 24, 2018 | 01:15 PM
  #318
nice work on the hood and hatch as far as weight reduction .
Old May 24, 2018 | 04:23 PM
  #319
Thanks! I could take the hood a step further with locking hood pins and get rid of the latch and hood release but I've heard spotty reviews of them.
Old May 24, 2018 | 09:41 PM
  #320
Fit10's Avatar
This is my new favourite thread.
