K20 Fit How To Discussion
Old Jun 27, 2008 | 01:28 AM
  #341
sy11580's Avatar
Originally Posted by pyromaster55
ok im new to the tuning scene but will the k20z1 fit into the fit, secoundly will the 6 speed maunual also fit? how much if any fab work would i have to do? what other equipment would i need and what would the rough price be? i have an 07 fit sport and it needs a serious kick in the pants.
As I know all the K-Series engine will fit in the Fit, in addition the tran. will fit also, but the tran req. to cut out the farm to make it fit (read the whole post and you will find out what gettinfit did on his car). The price roughly close to 10K, but it is depend what you want to do and what part you use!!!
Old Jun 27, 2008 | 12:23 PM
  #342
jpax's Avatar
With the hasport GDk20 mount kit yes they both will fit. fab work really is not that much at all, just a small notch in frame, and that can be done with a hole saw, or recriporcating saw, then just bend a few brake lines out of the way and mount the engine. thats all. the hard part is not to hurry lol
Old Jun 27, 2008 | 01:00 PM
  #343
Previc93's Avatar
has hasport released the wiring harness yet and also hondata with kpro???
i know the mounts and axles are already available. other than that what else is needed besides engine and trans. Shift linkage???
Old Jun 27, 2008 | 01:32 PM
  #344
Excalibur's Avatar
That much? I guess I won't be getting a fit after all.
Old Jun 28, 2008 | 01:42 AM
  #345
sy11580's Avatar
I don't know what should I say. Yes you are right 10K to mod. the car sound little crazy but if that's what you want, I don't think the $$ will STOP you.
Old Jun 28, 2008 | 01:30 PM
  #346
Excalibur's Avatar
Well, it's something I really want, however my issue is I have an 07 si right now and I could part it out, sell the car (or trade so I could get a new fit faster) and then have to pay 10k for a swap and then deal with the suspension so that it would beat what I had before, or I could keep what I have now which is almost halfway paid off and has suspension, and boltons and take some of my saved money and get a s/c and some better tires. I just can't figure out which would be better for me. Plus, on the fit forums, it's harder to get answers b/c there's not as many people nor as many enthusiasts. I would love to do the fit w/ swap and be unique, but I'm just not sure. It seems to be the wrong choice.
Old Jun 30, 2008 | 01:37 AM
  #347
forpinks's Avatar
So is there a complete K20 swap package with all the parts, ECUs, bolts, and detailed instructions that just needs to be bolted on being sold by Honda Tuning specialist?
Someone should really do that. I swear if they did, I'll buy a Fit for sure!
Who else thinks it's a good idea? *I'm pretty sure the few ones that did the swap and did lots of research would say that "If they did that, everyone will have one and we won't be unique anymore..." But, to swap noobs like me, it would be an awesome thing.
Old Jul 1, 2008 | 08:17 AM
  #348
gettinafit's Avatar
I'm not familiar with Honda Tuning specialists, but Hasport has everything you need for the swap available.
Mounts,
Axles,
Wiring,
ECU K-Pro (in conjunction with Hondata)
Header
So Call them. Hasport Performance, Inc.
Also being sold on FITswap.com!
I hope my thread has been and wil continue to be a help to the Fit K-series minded people!
I'll be on FitSwap.org with New Projects on the horizon! So check it out, FITswap.com
Old Jul 8, 2008 | 06:52 PM
  #349
mahout's Avatar
Originally Posted by gettinafit
I have an 07 Fit Sport M/T. And Today I just purchased a K20A2 Complete Changeover swap.
What do I need? Obviously the Hasport Mount Brackets.
What mounts? I have most of the Stock RSX TYPE S mounts.
I know that Jackson Racing is developing the Custom Header for Fitment in the Fit.
I Have the A2 ECU, a Key, and the Cluster from the A2.
I am assuming Hondata is necessary for some reason, can someone elaborate how and why?
The photos are a very neat installation.Great work. I am pleasantly surprized.
Old Jul 9, 2008 | 09:11 AM
  #350
gettinafit's Avatar
It's pretty straight forward. No crazy modifications needed. Just a little cutting, but anyone can make a hole!!
Hasport was great with placement and location, it feels as if the engine was meant to be there!
Old Aug 5, 2008 | 03:50 PM
  #351
Hondady's Avatar
Thumbs up K swap
I am doing a k20z3 swap in my VBP fit sport auto. Now I know you have to cut the frame rail a little on the drivers side for the trans to fit right. Also you need to move the hard brake lines out of the way. As well as the abs module. That will come close to your idler pulley. As far as using a hondada k-pro i would recommend it. Your also going to have to use your stock fit ecu if you want to retain the fit's gauges and a/c. I know that the intake manifold from the rsx type s is the best one to use. If not the k20z3 can be used with an adaptor that I believe hasport sells. Also you can use the trans from an ep3 si, a rsx 5 speed, a rsx type s 6 speed or the civic si 6 speed. I know the 6 speed from a tsx will not work. It is a costly swap. You will also need the custom axles as well. Then you have to work on braking, suspension, wheels, and tires to compensate for the extra power. If you do do the swap the car will rip!!! I can't wait till mine's done but then again I did not even start yet. Going to pick up my k20z3 bottom end on friday along with all the pulley's and accessories and the intake manifold. I just have to get the head and trans. My swap will not be done over night. I plan on sleeving the block. I plan on head work and different cam shafts. I am keeping it N/A. Going with a 12.5 compression piston and I am going to try and retain the A/C. Which I know can be done. Good with your swap. You can get info from FITswap.com and K20A.org .:. The K Series Source . Honda / Acura K20a k24a Engine Forum.
Old Aug 5, 2008 | 05:30 PM
  #352
Fa1's Avatar
Fa1
Actually the rbc intake mani flows better then the prb, but as far as fitment issues the prb should give you more room for the radiator to intake mani clearance as the rbc extends forward more.
Old Aug 6, 2008 | 12:25 AM
  #353
jeimusu86's Avatar
i envy you guys have money to do these swaps...anyone wanna sponsor me? lol
Old Aug 6, 2008 | 06:26 PM
  #354
dewthedew's Avatar
will someone explain the ecu setup to me and how it can be down? is there a harness being made or can i have one made?
Old Aug 6, 2008 | 06:40 PM
  #355
mahout's Avatar
The ECU monitors signals from sensors and controls output signals to not only your engine but to a number of other devices based on programmed calculations done by a very straight forward complex of digital state electronics that make up switches, rheostats, and ratio controls that are specific to every engine. There is no simply changing harness connectors.
If you are switching engines you will need to obtain an ECU for your replacement engine with the connectors and using wirng diagrams run the input connections to existing or added sensors. The output connections must of course mate with your engine.
Old Aug 6, 2008 | 07:41 PM
  #356
Hondady's Avatar
You need the ecu from the engine you are putting in. Or get a hondata k-pro to run the k motor's I-vtec. Also if you want to use the fit's gauges you have to use both ecu's. I don't know but hondata is working on a jumper harness for this swap. If you don't go this route then you have to get some after market gauges. I'm sure hondata will come out with it soon enough. Because I will be needing it too.
Old Aug 7, 2008 | 12:03 AM
  #357
leonine's Avatar
Your going to have to take into account the different transmission motor mount too. the a/t mount bolts up differently to the frame than the m/t mount (stock). the holes for the m/t mount do not exist on the a/t frame so the hasport motor mounts and adapter will not fit without drilling and tapping and probably welding that motor mount in place. the other 2 should bolt up.
Old Aug 8, 2008 | 05:54 PM
  #358
McLovin's Avatar
Anyone know whats the MPG numbers looking like on a K20 Fit?
Old Aug 8, 2008 | 06:11 PM
  #359
Fat Ping Cat's Avatar
its probably in the mid-high 20s mpg running premium gasoline, like the civic SI
Old Aug 8, 2008 | 06:22 PM
  #360
McLovin's Avatar
Guess I'll just stick to using it as a slow commuter :P
