Old Jan 8, 2019 | 10:49 PM
  #18301
JerrySFL's Avatar
Got the keys cut by Faster Auto Keys.com and the Honda easykeymarker worked to program the Immobilelizer and remotes. The instructions online suck but its not hard, to figure out.
Old Jan 8, 2019 | 11:02 PM
  #18302
JerrySFL's Avatar
Programed another new key to 2012 Fit
For those of you that still need an extra key this was my solution, after searching here a not finding a clear answer. I bought my daughter a 2012 that only had one key. Went on www.fasterautokeys.com you send them a picture of your key they cut it and send you a replacement for $20. That doesn’t include the electronics for the remote , had to buy that off of eBay $10 and then buy the Honda easy key maker $50 so that’s a total of $80. My local auto n stealersjip wanted $110 just for the key and to cut it, and then $140 to program to the car. I checked the local locksmiths they all ran between $125 and $200 total . The easy key maker doesn’t come with instructions and the instructions online suck but it’s not hard to basically put the key in the ignition plug in the programmer and turned ignition key on and off Then hold the unlock button on each remote, then check to see if everything works .
Old Jan 9, 2019 | 05:30 PM
  #18303
evilchargerfan's Avatar
PM'd
dibs on that thing
Old Jan 9, 2019 | 05:37 PM
  #18304
marmaladedad's Avatar
PM'd
dibs on that thing
Free key programming for all FF.net members. Woohoo!
Old Jan 10, 2019 | 06:13 PM
  #18305
Originally Posted by JerrySFL
For those of you that still need an extra key this was my solution, after searching here a not finding a clear answer. I bought my daughter a 2012 that only had one key. Went on www.faster auto keys.com you send them a picture of your key they cut it and send you a replacement for $20. That doesn’t include the electronics for the remote , had to buy that off of eBay $10 and then buy the Honda easy key maker $50 so that’s a total of $80. My local auto n stealersjip wanted $110 just for the key and to cut it, and then $140 to program to the car. I checked the local locksmiths they all ran between $125 and $200 total . The easy key maker doesn’t come with instructions and the instructions online suck but it’s not hard to basically put the key in the ignition plug in the programmer and turned ignition key on and off Then hold the unlock button on each remote, then check to see if everything works . If you need easy key programmer I can sell you mine. PM me
MINE!
/msg length
Old Jan 10, 2019 | 07:00 PM
  #18306
Originally Posted by mike410b
I know evilchargersfan is always interested in specific part numbers, so I got a pic of that too haha
heh, just noticed this!
lmk if anyone comes across the other swift's (gk specific). i'm dying to try out both sets, back to back. presently, i'm sitting on the same 4h021's and some koni oranges. as soon as I acquire the gk pn's, i'd love to test em out
Old Jan 11, 2019 | 10:40 AM
  #18307
eulogy's Avatar
wait....you changed your suspension AGAIN? lol....
Old Jan 11, 2019 | 03:04 PM
  #18308
not yet. I wanted to try out the 2 swift springs, and give a useless review =)
Old Jan 13, 2019 | 10:38 AM
  #18309
Kitsken's Avatar
Just posing after filming for my Youtube /kitsuneken video
Did you know that Nissan Note outsold Honda Fit last year 2017?! Anyone know why? I mean Honda Fit 2017 looks better than the Note, and is more versatile, Good marketing i guess??
Old Jan 13, 2019 | 02:37 PM
  #18310
GE8girl22's Avatar
I finally installed my progress rear sway bar on my ge8. It had been sitting in my room for a few months collecting dust. I have to say that the install was super easy and you DO NOT need to take off the wheels or springs. The only bolt that is hard to get in is the middle one and all you have to do is move the rubber that's in the way with a screwdriver. I drove it around town a bit and can say I do feel a pretty big difference in how it turns Into corners. It feels so much more planted. I would absolutely recommend this mod.
Old Jan 14, 2019 | 11:36 AM
  #18311
evanphi's Avatar
New headlights (Sylvania Silverstar Ultra) and air filter installed yesterday after FINALLY taking our xmas tree to the recyclers.
Old Jan 14, 2019 | 03:56 PM
  #18312
Goobers's Avatar
Today, I fucked up the supercharger on the Fit.
Well, it's a bit of an exaggeration, maybe. Apparently, the bolt for the fill port decided to chew out the threads on the sc.
I'm wondering if the bolt was a hair too small, and I just never realized. Or did I manage to actually put enough force to over-tighten it. It probably didn't help that I was re-using the crush washer I put in.
I guess, some combination of the above. *sigh*
At least, its the fill port, so I put the bolt in-place temporarily so that I can drive to a nearby ACE hardware. Hopefully, find a larger bolt that is the same diameter as a spark plug so I can use the thread chaser or at worst, the re-thread w/insert kit since I only used one of the four it came with. Oh, I checked the bolt that did the damage in the insert and the bolt is just small enough to freely spin inside the insert.
So, my first attempt will be to enlarge it to the size of a spark plug... failing that, fully enlarge it for the insert.
Edit: After a bit of shopping I got the bolt and a thread chaser to use as a hole enlarger... the only problem was, the chaser doesn't gradually widen as it wasn't designed to enlarge a hole to 14x1.25, but to only "clean" it out. This meant that initially, it wouldn't start cutting in... and when it finally did, it cut at an off angle. The bolt head and washer don't sit flush anymore. Luckily, this time the washer was a plastic one that deformed just barely enough to "seal" it.
It's something at least...
Old Jan 14, 2019 | 05:05 PM
  #18313
magellows's Avatar
Installed BC
Tried on my Rota 16x7 +40. Didn't like it. Sold it.
Got 17x7 +40 for a better fitment. Rubs on sharp turns and uneven road surfaces. Might need to cut the plastic inner guards .
Old Jan 15, 2019 | 02:34 PM
  #18314
julianachos's Avatar
Had two sets of wheels in it today and washed all the salt off. Original paint still shining, even after 503k miles.
Good to see the Jescar Power Lock + and Collinite 845 combo still doing well even though it's only been two months lol.
Also checked the oil level (life is currently showing 70% on the MM) and put on new zipties where the coolant overflow reservoir is at. One of them broke recently.
Old Jan 15, 2019 | 03:40 PM
  #18315
GolNat's Avatar
Looks great. Good decision on the wheels, those look much better.
​​​​​​Looking great for half a million miles and the places that you go!!
Old Jan 21, 2019 | 05:25 PM
  #18316
JerrySFL's Avatar
Replaced PCV valve
Replaced pcv valve on 2012 Fit woth 92k, valve was getting sticky,
Tools needed, 10mm socket to pull harness bolts, long needle nose piliers to pull clampand hose , 17mm socket for valve and a ratchet . This only took less tham 15 minutes,
Old Feb 2, 2019 | 10:31 PM
  #18317
Jarrett Hucks's Avatar
Today, I treated all the black trim pieces and ordered a few things to add to soon! I'd take photos, but it was dark out
Next week will be red tint for the taillights, yellow tint for the fog lights, broadway rearview mirror( the rearview in my jeep seemed so much bigger. I feel like I cant see anything in the stock one) and my phone mount.
Old Feb 3, 2019 | 03:34 AM
  #18318
Kitsken's Avatar
Long time no visit here super busy at work! But here are what i did to my fit so far, nothing fancy, just normal ride...
Safety and Privacy purposes. Tires were dried and rotting, and since heavy tint isnt allowed here i just bought a curtain so i can close it when i park and sleep inside my car... and you know... lol
Old Feb 5, 2019 | 12:25 PM
  #18319
mockginger's Avatar
My Fit has now become the hubby's car, and it only took him a week of driving it before he ordered an aftermarket exhaust, haha. Now we just have to wait for a break in the weather to install it.
Old Feb 6, 2019 | 07:55 PM
  #18320
GE8girl22's Avatar
Had a shop drill out the broken screw from my sprintex manifold for the map sensor. The only problem is they had a hard time getting it drilled out as sprintex uses grade 12.9 m6 screws for it. I don't really blame them but now the holes don't mach for the map sensor. Would my best bet be to block off the hole and use one of the back ports for an external map?
