Fuel Mileage Related Discussions
Old Aug 25, 2014 | 10:40 AM
  #261
SilverEX15's Avatar
Originally Posted by simonx314
Yes. And the most accurate way to calculate fuel used is to measure how much fuel was pumped into the car. Those two links at the bottom of my last post are articles which explain why the car is not as accurate at calculating how much fuel was used.
Here is another link that has a good explanation of variables that can throw off the vehicle gauge, but would not affect the pump calculation at all.
MPG Accuracy
Quote from link:
"The most accurate fuel estimates occur in vehicles equipped with MAF sensors. Vehicles which use the lower cost MAP sensors have less accurate results. However, vehicles with MAP sensors can provide reasonable results when Volumetric efficiency and injector cutoff are enabled and proper calibration is performed. (Please see the user manual for details) Much of what is discussed below applies to MAP equipped vehicles and less so for MAF equipped vehicles.
The estimate of fuel usage is ultimately only as good as the data received by UltraGauge. Each of the various engine sensors has associated errors. For example, Engine temperature may be +-5 degrees and the accuracy may vary over the temperature range(AKA non linear). Also, the sensor data may have poor granularity. For example, the OBDII Mile Per Hour(MPH) data has a granularity of 0.62 miles/hour. So the possible values are 0.62, 1.24, 1.86, 2.48MPH, etc. If the vehicle was traveling at 0.9 MPH, the value presented to UltraGauge could be either 0.62 or 1.24MPH. In this case, the value has potentially significant error at low speeds, and much less at high speeds. The errors associated with each sensor can combine and the resulting accuracy can be very poor. We have seen results as accurate as 0.01% and as inaccurate as +-13%. Your results will vary based upon your particular vehicle, configuration and calibration.
Some fuels have Ethanol and some do not. The accuracy can change if a fuel with a large percentage of Ethanol is used after calibration with a non Ethanol fuel. For example, you may perform calibration locally where simple gasoline is available. Then find less accurate results on a road trip where only Ethanol blends are available.
Also, environmental conditions can affect the accuracy. A vehicle calibrated in summer may see variation in the winter. For this reason, it is recommended to perform the MPG calibration if the environment changes significantly. It is necessary for the Vehicle's ECM to compensate for the environmental changes in order to minimize emissions. Some vehicles compensate better than others. For those that do compensate well, the environmental variation will have a much less significant effect."
Thanks. Understood.
Old Aug 26, 2014 | 09:14 PM
  #262
ophrey's Avatar
just got 46mpg on my last tank, my readout was 46.2mpg. All my other tanks have been between 1.5 and 2mpg off from my readings, I'm not sure why this last tank so much more accurate.
Old Aug 27, 2014 | 12:14 AM
  #263
noripwr's Avatar
I was reporting in the other thread that Fuelly calculated me at 38.9 mpg and my radio read out said the same thing. Maybe the car gives a more accurate read out after several fuel ups?
Old Aug 28, 2014 | 12:01 PM
  #264
simonx314's Avatar
ECON test results
I just posted some ECON button test results in a new thread. AC was off, MPG increased by about 10%.
https://www.fitfreak.net/forums/3rd-...t-results.html
Old Aug 28, 2014 | 01:06 PM
  #265
tmfit's Avatar
I think that the small engine is so sensitive to changes in driving that it will be hard to predict with any close accuracy. Only driving habit and time will tell us what we want to know. Unlike my Dodge Ram 3500 which it didn't matter if I was pulling 25,000#'s or just cruising it basically got the same mileage within about a mile. You could drive all week in the city and then near the end of the tank take a highway ride and boost the gage back up to 36 or 38 only to find it was in reality 30. I'm ok with this as I now know I normally get basically 35 mpg on my typical drives.
Old Sep 12, 2014 | 10:53 AM
  #266
tmfit's Avatar
Last fillup 32.8. Almost ALL in town driving, short trips
Old Sep 12, 2014 | 03:18 PM
  #267
SilverEX15's Avatar
I just spent a week on Cape Cod, for a total driving distance of 708 miles, home/Cape/home. The display says 46.6 MPG. When I fill it, I'll do the math and let you know the result.
Old Sep 12, 2014 | 04:15 PM
  #268
yuffers's Avatar
My commute per day is about 50 miles total. When econ mode is off I would have to fill up at the end of the 5th day (a bar or two left on the gas tank)
I tested using econ mode on with conservative driving last week and I ended up with just a bar under half on at the end of the 5th day. Sorry my specifics are too specific, but I really just wanted to point out that during my test with econ mode I was bored.
yay
Old Sep 13, 2014 | 09:05 AM
  #269
Fit Charlie's Avatar
Originally Posted by yuffers
... I really just wanted to point out that during my test with econ mode I was bored.
Having good instrumentation like a ScanGauge or an UltraGauge can change that. Being able to see exactly what mileage you're getting at the moment, for the short trip you're on and for the whole tank can open up a whole new world instead of the "I'm bored with sitting here."
Getting good mileage isn't driving like granny at all.
Old Sep 17, 2014 | 05:43 PM
  #270
8strung's Avatar
Started using cruise control in the highway, and I have had my mpg shoot way up. Fit LX MT gotten up to 42 mpg easy, might be able to go higher! Driving was hyper mile style, though, boring and coasting as much as possible. Really just trying to stretch my numbers. Really neat, though, I was at 36 going 70 with ac on, went up an instant 6 just by using cruise control at 65.
Old Sep 17, 2014 | 06:34 PM
  #271
Gina*Baby's Avatar
I'm averaging around 300mpt at this point; I have only filled up twice. I wish I had better numbers to provide; but I know that I had a 2012 Civic LX that I took across country and upon every fill, was getting around 500 mi and about 39.4mpg. Hoping at some point I can get something similar to that with the fit.
Was kind of disappointed to see that the fit only got me around 250 mi in the first tank that I had when brought home from the dealership. Was hoping it would improve but it doesn't look like it's changed too much since. The car is my daily, but it's only driven around 5 mi a day, outside of some activities during the week that are a little farther.
Old Sep 18, 2014 | 01:09 PM
  #272
Amy Ling's Avatar
3rd time refilling
This is my 3rd time filling up the tank. Still don't know when the gas light goes on, anyone knows? I usually wait till there is only 2 bars left and it's usually 7.5 gallons refilled.
So I'm thinking the bar displays 8 gallons with a 2.6 gallon reserve after all the bars are gone?
3rd time - 275.2 miles / 7.379 refilled = 37.295 miles/gallon (windows rolled down majority of the time with some ac use)
2nd time - was about 32 miles (ac always on)
I mainly drive local as I only live 5 miles away from work. I hope on the fwy for maybe only a mile and the rest is local.
Old Sep 18, 2014 | 01:20 PM
  #273
Gina*Baby's Avatar
The light does come on; I don't usually fill up my car unless the light comes on (because I like to push the envelope, LOL). I have only filled up twice and noticed the light turns on just before the last bar (it will turn on at two bars but the 2nd bar will disappear as it's lighted up). It usually leaves me with 7.625 galloons to be filled when I do fill at light.
Hope this helps!
Old Sep 18, 2014 | 01:52 PM
  #274
Stingray's Avatar
Hope this helps!
Keep waiting till the light comes on, and spend a bundle replacing the fuel pump. The gas acts as a coolant, and below a quarter tank, you risk long term damage. Your money, your choice.
Old Sep 18, 2014 | 01:57 PM
  #275
Amy Ling's Avatar
Oh okies, that is good to know!
Hope this helps!
That's what my instructor told me as well when I took an intro to mechanics class but I've always waited till the light come up when I had my first generation Ridgeline for 9 years until someone TBoned me this year and the truck was good. Although I do fill when there is only 2-3 bar left and I'd say that is still about 1/4 tank left only cause it should hold 10.6 gallons and everytime I fill up its about 7.5 or less.
Old Sep 18, 2014 | 02:26 PM
  #276
Gina*Baby's Avatar
I've always driven my cars that way and I've never had to replace a fuel pump or lines, and I've owned over 8 cars since I started driving 15 years ago (almost all of which are still in the family, minus the selling of two and the totalling of one).
My mechanic has also suggested to do it because if you're constantly filling at a quarter, you're not excersizing the pump (as eventually over time it will begin to stick at the same level) or clearing the lines and with older cars, you ran the risk of breaking the guage in the dash with the repetition of it never going lower than a quarter. Obviously newer cars do not have guages, so the second doesn't necessarily apply, but I believe him when he tells me it's ok to run past the light.
Maybe he's full of it, but he's been my mechanic for 15 years and he's been handling Honda's specifically since the early 80's.
Old Sep 18, 2014 | 04:25 PM
  #277
SilverEX15's Avatar
The most I've added is 7.5g, and the light hasn't come on. My son has gotten 8.0g, but he hasn't mentioned the light.
Old Sep 18, 2014 | 04:48 PM
  #278
simonx314's Avatar
I've seen the fuel light come on at least twice. I comes on when the fuel meter only has one bar left. Looking at my fuelly data, it was probably the times that I added 9.00 and 9.22 gallons. Maybe also that time I added 8.53 gallons. No way to know for sure.
Old Sep 18, 2014 | 07:20 PM
  #279
tmfit's Avatar
I have only had the light come on once, it was at 1 bar and took 8.15 gallons
Old Sep 18, 2014 | 11:15 PM
  #280
SheepNutz's Avatar
I've had the light come on 4 times. It always comes on at 2 bars, but not right when it hits two bars, so really 1.5 bars. Usually about 40 miles of range when the light turns on.
