What you DONT like about your Fit
Old May 1, 2013 | 04:35 PM
  #2061
cr4zy3lgato's Avatar
it's never as efficient when it's cold, just look at ecomodders blocking off their front grill...
Old May 2, 2013 | 08:13 PM
  #2062
Vince_TB's Avatar
Originally Posted by krunk13
Honda is actually working on technology to harness the static electricity of a few fits to power a small town. They should have more than enough power
Yeah! I mean, I did that a bit on my old 98 Civic, but every time I exit my Fit, I suffer a HUGE shock of static!
Sometime one when I open the door, and another when I close it!
Old May 2, 2013 | 09:51 PM
  #2063
Mini_Odyssey's Avatar
Hahah I remember that. I totally forgot about that static electricity that kept getting me. It's the seat material, I stopped getting that blast once I went to clazzio leathers.
Old May 6, 2013 | 09:09 PM
  #2064
Mbennett26's Avatar
I miss having a sunroof.
Old May 7, 2013 | 06:32 AM
  #2065
FitRocket's Avatar
Originally Posted by maybememories83
I have had my car for 2 months and there are many light scratches, swirls, and chips in the hood already. Seems the clear coat is thin on these cars.
I have an '09 sport with voice navi. i agree that the paint is sub par esp. on plastic parts
Old May 7, 2013 | 05:19 PM
  #2066
YoItsLo's Avatar
My 2005 Civic got way better gas mileage than my Fit.
Blind Spots take some getting used too.
Maybe I'm just short but the radio/dash is a little hard to reach.
Passengers always complain that I have an arm rest and they do not.
Other than that.. I love it.
Old May 7, 2013 | 07:53 PM
  #2067
DaveFL's Avatar
My passenger complained once, then I fixed it.
Rebuilt it wider so two arms can use it, neither one of us use it as a lift point so the original mechanism and rest can support two resting arms.
Have heard some people use the armrests to lift themselves until the door plastic breaks.
Also fixed the drivers door armrest with a gel pad from a computer wrist mat.
Only thing that hasn't changed is the reflection of dash in windshield, using a dark
dash mat to reduce it.
Old May 7, 2013 | 08:26 PM
  #2068
FitRocket's Avatar
I agree.....
Originally Posted by Mini_Odyssey
Haha yea my fit on feet only setting defrosts my windshield, warms my feet and comes out of the top vents all at the same time. Weird but yea it does odd things like that. The noise level isn't that bad after I added extra weatherstrips and low cost u seal roof flashing sound deadening in the doors and open cavities.
I hate the fact our lovely president forced autos to have those damned tpms, just another charge to absorb when you get new tires, and the clear coat is soooooo cheap too, i popped it when i put my sat radio antenna on roof. and that battery is so expensive to replace, can't find that size nowhere.
Old May 7, 2013 | 08:29 PM
  #2069
FitRocket's Avatar
I love the car, but it could still use a stiffer body, bigger engine, more horsepower and torque, i am 6'9" and have enough head and leg room
Old May 7, 2013 | 09:19 PM
  #2070
Wanderer.'s Avatar
What charge when getting new tires? You don't have to replace anything that has to do with the TPMS when you get new tires.
Old May 7, 2013 | 09:51 PM
  #2071
poorracerkid's Avatar
Highway mileage that struggles to break 31 mpg at 80. In fact I find that my city mileage is better than highway.
Old May 8, 2013 | 08:41 AM
  #2072
over40pirate's Avatar
After 3 weeks ow owning my new Fit:
1. Only 1 power outlet
2. Sunvisor design sucks. When on side window, the back end is a few inches higher than the other end. If the plastic pivot, had the hole at a different angle, it would be fine. If I could find a part number for the pivots, I would buy one and put a bushing in it and redrill at the right angle.
3. No map lights in Base
4. Another inch of ground clearance, would be practical. Already scraped the nose, coming out of a parking lot. I know this must shock all the ground huggers! I like the lowered look (to an extent) but I'm more of a practical person these days.
5. Injector lag, when shifting. When I let off on the gas, I want the engine to respond, now!
6. A lighter colored dash, would absorb much less heat
7. Bigger engine would be nice, for acceleration and mpg. The Civic is heavier, with a larger engine, and gets more mpg! Imagine how the Fit would perform with that engine.
But I still love her!
Old May 8, 2013 | 09:04 AM
  #2073
Steve244's Avatar
Elegant solution to #3
Still working on the SBC for mine.
Old May 8, 2013 | 12:02 PM
  #2074
FitRocket's Avatar
tpms
Sure. you have to replace them, the little o-rings in the valve wear out from the moisture thats in the air you put in, it's a basic rebuild. i avoided the 30 dollar fee at my local tire shop after i complained about having them. I said if i have to replace them i don't want them and just pull the fuse.
Old May 8, 2013 | 01:15 PM
  #2075
Wanderer.'s Avatar
No, you don't have to replace them. They will tell you you have to replace them if they're a crappy shop trying to take your money. Go elsewhere.
Old May 8, 2013 | 08:42 PM
  #2076
FitRocket's Avatar
Lets agree to disagree
Old May 8, 2013 | 09:01 PM
  #2077
Steve244's Avatar
valve cores are the only thing that could wear out and they're $2 for a set of 4. Easily replaced without removing the valve stem/tpms. You can do this yourself if you find one that has a bad seat. Sure there are gaskets/grommets (I don't think they use o-rings) but these are not likely to ever need replacing out unless you remove the valve stems.
Before TPMS valve stems were rubber and would degrade/crack after a few years causing leaks. It was cost effective to replace them at a couple dollars each when changing tires. TPMS uses metal valve stems. There's really nothing to degrade other than the sender unit which the tire stores aren't touching.
I do wish there was a way to defeat TPMS if you want to do without though (I don't think it's as simple as pulling a fuse; people are putting tape over the damn indicator light). But I think it's a good thing for 80% of the population. Checking tire pressure is a lost art.
Old May 8, 2013 | 11:36 PM
  #2078
13fit's Avatar
Im seeing a lot of complainging about the rear drum brakes.
LONG LIFE
GOOD STOPPING power
2 biggest reasons honda uses them. Quit complaining. disc brakes only have 2 things going for them; better looking and easier to change out.
Ill change to rear disc eventually, but not before I actually need to service the rear brakes at, oh lets say 100k miles.
Old May 13, 2013 | 09:48 PM
  #2079
Just found another don't like.
Can't drive with just the rear windows. The wind buffetting, will drive you crazy!
Old May 14, 2013 | 04:53 AM
  #2080
loudbang's Avatar
What did you do with the other windows??? LOL
