Old Jun 25, 2018 | 11:02 PM
  #1721
xxryu139xx's Avatar
Put my SSR Type Fs finally on. Needs a cleaning. Broke my wheel lock key while torquing down. Good thing it was the last lock and everything else was torqued down.
Old Jun 25, 2018 | 11:04 PM
  #1722
Tattoo Al's Avatar
Tinted today. 35% front, 5% rears.
What springs / coils you on?
Old Jun 25, 2018 | 11:11 PM
  #1723
Tattoo Al's Avatar
Originally Posted by TougeMonster_GK5
Just mountes this morning, Work CR Kai (2010 model) 16x7 +35 wrapped in 205/50 Firehawk Indy 500's
Hey dude, do you know if the RS wing will fit my 2018 EX??
Did you buy one from Ebay or another site?
Thanks in advance!!!
Old Jun 25, 2018 | 11:36 PM
  #1724
Bassguitarist1985's Avatar
1 thing I'd like to note, the end of the mini projector does make contact with the circular reflector thingee as circled in red:
said "reflector thingee" appears to be held down with 1 philips screw, you can see it by opening up your hood, and simply looking down in the area where one would reinstall a new bulb
Im about to throw down on this kit and see how it goes.
1. Can you get to the screw holding the reflector without removing the bumper and headlight housing?
2. Do you have a pic of it? If not ill investigate tomorrow on my 2017 and try to snap a pic.
3. Can the reflector be removed from the housing where the bulb installs?
4. The reflector may actually be doing some good preventing glare, wonder if adding a metal spacer to shift the reflector farther towards the front of the lens would help.
ill be looking at the housings more closely tomorrow. Pics and maybe a video! :-)
Old Jun 25, 2018 | 11:46 PM
  #1725
Tattoo Al's Avatar
Threw the Yakima RocketBox12 back on for upcoming roadtrips to Monterey, So.Cal, Yosemite. Need the extra room to pick up the new shoes stuck in Pomona.
Also added LED Front (switchback) bulbs and rear LED turn signal bulbs. Planning to do the load resistor mod this weekend.
Hey bro is that the RS wing from eBay? Do you know if it'll fit my 2018 EX?
Old Jun 26, 2018 | 06:14 AM
  #1726
xxryu139xx's Avatar
Tanabe Sustec Pro-C
Old Jun 26, 2018 | 10:47 AM
  #1727
Chitown Fit's Avatar
Thumbs up Carbon Fiber Wrap.
Originally Posted by 2Rismo2
You mean wrapped? Or the whole hood is really carbon fiber?
Yes I mean Wrap.
I've looked into getting a Carbon Fiber Hood itself. But I've read that it doesn't fit snug like the factory hood and it's also prone to chips and dings from road debris.
I also considered painting the factory hood black. But I won't be able to go back to the factory color if I change my mind.
I'll try the Carbon Fiber Wrap and see how this goes. The shop I'm going to has a durable weather resistant wrap that lasts a long time.
Old Jun 26, 2018 | 10:58 AM
  #1728
Post To The Honda Sport Guys.
If anyone is selling their blacked out Sport Wheels I'd be interested in buying a set. I live in Chicago.
Old Jun 26, 2018 | 11:46 AM
  #1729
DannyJ7's Avatar
Originally Posted by Chitown Fit
Yes I mean Wrap.
It kinda depends on the construction of the "wrap" on how long it will last. 99% of what's out there comes from 2 or 3 manufacturers, and pray it's not the stuff from China. Even in the best of conditions, with the best film, it'll fade within a year or two (depending on exposure), and start to visibly crack etc within 5.
Old Jun 26, 2018 | 11:57 AM
  #1730
Thumbs up Thanks For The Tip.
I'm not expecting the Carbon Fiber Wrap to last as long as the car. But at least long enough to get my money's worth. I've used the shop I'm going to in the past. Not for a Carbon Fiber Wrap.
Old Jun 26, 2018 | 06:26 PM
  #1731
from my vantage point, I was unable to get to the screw. it seems you'll either need an amazing screwdriver and boat loads of talent, or simply remove the bumper and headlight
I didnt bother taking any overhead pics
bulb installs?
it should slip right out. I'd imagine thats why honda put a small phillips screw to hold down the little reflector ring
I'm sure it does. the new led bulb appears to have its own method of focusing the beam forwards, and more than likely making the oem ring/reflector a non-factor. I'm no expert on the topic tho, maybe someone else can chime in and shed some light on this one
DannyJ recently did this, he may be able to offer some insight
Old Jun 27, 2018 | 11:50 AM
  #1732
pic of that screw ....
credit to the orig thread:
https://www.fitfreak.net/forums/3rd-...eadlights.html
Old Jun 27, 2018 | 12:53 PM
  #1733
@evilcharger's suggested projectors came in and were an absolute breeze to put in. No tools necessary and take about 5 minutes. Pictures of install aren't really useful due to location/ease of install. His concern about touching the reflective shroud are valid. Time will tell if that becomes a major concern. They fit as though they were meant for this application. 10/10 worth the money, even if they only last 6 months. More pics and thoughts in my build.
for those of you following the mini projectors topic:
for those of you wondering how the cut off looks like, here is a comparison of the bulb dannyj has and another setup with a proper retrofit. keep in mind, the retrofit is a much more expensive option, and installation is more involved
mini projectors:
retrofits:
Old Jun 27, 2018 | 03:18 PM
  #1734
DannyJ7's Avatar
Well, that SHOULDN'T be too hard...I'm waiting to see if there's actually any problems created from leaving it in place.
Old Jun 27, 2018 | 10:00 PM
  #1735
[LegenD]'s Avatar
I'm sure TougeMonster won't mind me jumping in - it's from AliExpress.
The Ebay spoilers are mostly the same. You can also find the authentic Honda spoiler on Ebay. Alternatively, you can give RHDJapan a shout as they can source just about anything.
Regarding fitment - the hatch is the same on the 2018 so you'll be fine. Just a heads-up, not sure if you're aware but even though it will fit, it's not really meant to so there are some holes that require patching up. Check the Spoon build thread or of course wait for someone with experience like Touge to jump in. Anyway, hope that helps a bit.
Old Jun 27, 2018 | 10:04 PM
  #1736
[LegenD]'s Avatar
Looks amazing on the SSR's dude! Sorry to hear about the wheel lock, that sucks. Oh yea, love the led pillars you recently setup as well !
Old Jun 27, 2018 | 10:22 PM
  #1737
Just threw down for the mini projectors, will be here Friday.
Been busy installing my heated mirrors and winkers (again) this week but before Friday ill see how difficult it is to remove the glare shield without causing any damage.
Old Jun 28, 2018 | 02:38 AM
  #1738
hondagk5's Avatar
Thumbs up
Nice ride. i got myself a 2018 sport as well.
Old Jun 28, 2018 | 11:42 AM
  #1739
there is a rad sale going on for tires, so I figured it'd be a good time to shed off 5 lbs per corner and get some lighter tires
Old Jun 29, 2018 | 01:46 AM
  #1740
[LegenD]'s Avatar
Lots of work done over the last few weeks. Recent mods - LED interior / exterior conversion, K-Tuner, Affection - Desire rear spoiler, Mugen tailgate garnish, and Mugen door handle protectors.
Uploaded a lot of new photos from the latest photoshoot and just wanted to share a few of them here as well.
