Old Nov 14, 2015 | 03:23 PM
  #14281
xxryu139xx's Avatar
ive been trying to eliminate this intermittent vibration i get from the front passenger side. its gotten to the point that it only happens when i hit a bump but it goes away. i thought it was from the torque rod mount rubbing on the cusco bar, so i had it taken off.
Old Nov 14, 2015 | 10:49 PM
  #14282
spryter's Avatar
Originally Posted by harry22673
Pics or it didn't happen
Annoyingly, I can't find my 10mm deep socket. Actually, I have three, and can't find any of them. And I'm too lazy today to wrench off the tie down posts. Here it is on my table, though:
Old Nov 14, 2015 | 11:57 PM
  #14283
555sexydrive's Avatar
Finally, had these painted and just finished installing these sexy hoes...
Attached Thumbnails What did you do to your GE fit today?-1a4e85c4-b3fd-4230-a991-24686b41343a_zpsho3k2ezh.jpg
Old Nov 15, 2015 | 12:03 AM
  #14284
xxryu139xx's Avatar
ok so i took the Fit for a cruise a little while ago trying to see if the vibration went away. unfortunately after taking the cusco bar the vibration is now present at all speeds and worse when coasting (not breaking).
things i've done:
1. wheel balance
2. wheel alignment
3. passenger side driveshaft and both tie rods replaced
4. cusco bar removed.
now, the way it was before i removed the cusco bar, the torque rod mount was resting right on top of it. everything was fine except sometimes i will get the vibrations. now that i've removed the bar there is nothing pressing up against the torque rod preventing it from excessive play.
i'm thinking its the torque rod mount. after a few months of rubbing and bouncing against the cusco bar, it damaged and wore out the rubber bushing inside and in the same way it also kept the movement of the torque rod to a minimum. upon removal of the cusco bar, it gave it more room to bounce around, hence the vibration. need to get under the car tomorrow morning and take a look and see how much play it has.
one good thing, the squeaking is gone.
Old Nov 15, 2015 | 01:55 PM
  #14285
wzlfit's Avatar
things i've done:
1. wheel balance
2. wheel alignment
Not that I'm a mechanic but your logic sounds right to me. Especially with coasting because it would put pressure on the torque mount. I also get a bit of vibration when starting to move or reverse. I feel it in the pedal when it happens & most of what I have read points to the mounts. I have also read that the reduction of movement of the torque mount can cause the other engine mounts to wear faster.
Good luck
Old Nov 15, 2015 | 04:29 PM
  #14286
sultanofslide's Avatar
Got some 205/50 R16s on the car finally, what a huge difference in handling and road manners its practically a whole new car.
Old Nov 15, 2015 | 04:37 PM
  #14287
xxryu139xx's Avatar
Good luck
to top this off i found two rounded off spacer lugs. my spacers are thin 11 mm and so are the lug nuts that it came with. i was able to change out the front tires to my snows, but i couldn't change the rears. FML!
Old Nov 15, 2015 | 08:34 PM
  #14288
Mr.Hollow's Avatar
Wheel specs? Thats good to hear you found some new life in the fit with a different tire option.
Old Nov 15, 2015 | 08:36 PM
  #14289
Mr.Hollow's Avatar
Well they definitely stand out now.
Old Nov 15, 2015 | 10:26 PM
  #14290
cajlog's Avatar
Haven't done much these past couple of days, however, I ordered the following:
- Tailgate cover is becoming loose, I think this happened after I tried to do the JDM wiper mod which by the way I had no luck with it.
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
- Taking off my HID kit, didn't want to mess with retrofit as I just purchased a pair of new headlight assembly and was too chicken to open them; went to buy some nokya artic white as I read around these forums they are as good as OEM bulbs.
- Replaced my brake pads, I still had the OEM ones; I had a rusty sound when breaking and replacing the pads fixed most of the noise. Also black-painted the drums, look better now.
- I removed the plastidip from the mugen spoiler, will be painting it tafetta white in couple of weeks, trying to have a cleaner look. I also removed the plastidip from the rear diffuser, think I got tired of it.
I haven't washed the car in couple of weeks, can't find the time to do it so hopefully I will do it after my nokya bulbs arrive.
Old Nov 16, 2015 | 09:26 AM
  #14291
wzlfit's Avatar
Murpheys law, that dark cloud seems to follow you between the chipped hood, vibration now this. My spacer nuts are funny, they flare out @ the bottom so the socket wants to teter while tightening.
Once again good luck
By the way, once I get the cash together i was going to give the ge innovative mounts a try.
Old Nov 16, 2015 | 11:42 AM
  #14292
twelvegage's Avatar
I rotated my tires last night. I lowered my car earlier last week, but it was so late that I decided I'd just rotate my tires this past weekend. Well, when I was pulling the wheels off, one of my lug nuts got gaulded and messed everything all up. So I had to go buy a tap and dye set, and after a bunch of struggle, I finally got it all fixed.
I ordered some Plastidip and it should be delivered on Wednesday. I'm hoping for enough time this weekend to get it done. I'll hold off on telling y'all the color until I get them painted, for a little bit of suspense :P
I also washed the Fit last night
Attached Thumbnails What did you do to your GE fit today?-80-image_22451431823_o_5bb1db20eb5202134be9963d8dce161617353292.jpg
Old Nov 16, 2015 | 01:10 PM
  #14293
xxryu139xx's Avatar
yeah man definitely frustrating. i went to pep boys out of desperation today to get the two lug nuts off. they did a pretty good job not damaging the lugs themselves, but they had to break off two of the two rounded nuts. they did not damage the spacers much more than i did but i don't think ill use such a thin spacer again. and of course, the kid that installed my blizzaks had them pointed at the wrong direction, so i had to swap em out when i got home. slapped some antiseize (which they didnt) and put my +25 mm spacers on (yes i havent learned my lesson).
the vibrations are still there. so after swapping out wheels and checking out the old tires, there was no cupping or uneven wear evident. i went ahead and ordered the torque mount from bernardi. I hope the repair gods are finally good to me and that fixes the problem. I hope bernardi shipping comes thru by the weekend so i can put it in.
Old Nov 16, 2015 | 04:55 PM
  #14294
connor55's Avatar
Man i hope your troubles end soon. Hasnt been an easy yesr for your fit
Over here im getting my winter tires remounted from my steelies to my new wheels as we speak!!
Old Nov 16, 2015 | 04:59 PM
  #14295
xxryu139xx's Avatar
thanks bro. 2016 will be a cheap year for the Fit.
Old Nov 16, 2015 | 06:18 PM
  #14296
connor55's Avatar
Got my rota slipstreams in the mail 4 hours ago, and just got my winter tires slapped on them asap! Goodbye steelies!
Attached Thumbnails What did you do to your GE fit today?-80-9b017842_dfad_4a26_9e5c_3795bd6ff579_81ad88df540adb20eb0937ff5aa8008517b30620.jpg   What did you do to your GE fit today?-80-66aee0de_5f24_49e3_aa79_81a1bf280409_52c7705f2ace9476112bdab33b3b2eeb3017b4fe.jpg
Old Nov 16, 2015 | 06:43 PM
  #14297
I'm still rocking the stock sport wheels with the Hankook Ventus 205's, I'd like to get some 16x7 RPF1's but there is a large Honda scene around here and they would just get boosted sadly.
Old Nov 16, 2015 | 10:32 PM
  #14298
counterFIT's Avatar
Damnn... Liking the red
Old Nov 16, 2015 | 10:40 PM
  #14299
Mr.Hollow's Avatar
Got some lugs for the new wheels, still gotta purchase new tpms and tires, so much for ballin' on a budget lol
Old Nov 16, 2015 | 10:50 PM
  #14300
xxryu139xx's Avatar
why new tpms?
