Old Oct 13, 2019 | 07:55 PM
  #18641
Goobers's Avatar
Well, the Odyssey has magic seats.
Old Oct 14, 2019 | 10:36 AM
  #18642
Americancosworth's Avatar
Honda Insight (2nd Gen) front and rear progressive springs, Tema4x4 30mm front Strut spacers, and Progress rear sway bar.
Not going to lie, I am shocked by the improvement in ride quality and handling characteristics that it now has. Body roll significantly reduced, no longer sways on the highway from wind, handles bumps/potholes much better, and with studded tires now keeps up with my Subaru (with no studded tires).
Old Oct 15, 2019 | 03:56 PM
  #18643
MontrealFit2012's Avatar
Firestone Firehawk Indy 500 update
Going to switch onto winters very soon
First summer EVER driving with sport tires
so I’m not the most experienced critic but here’s the things I liked
- obviously fantastic grip
- much quieter (especially on the highway)
plus more stable feeling on the HWY
- overall great ride and breaking
i think it now exaggerates the body roll more because of the grip which I’ll work out next year with all new suspension
Old Oct 15, 2019 | 09:53 PM
  #18644
Goobers's Avatar
What prompted this choice of purchase?
Old Oct 15, 2019 | 10:10 PM
  #18645
JRHPNG's Avatar
New LED numberplate mount lightbar
Just picked up one of these for our upcoming 2500km drive (over 5 days). Will be doing 10+ hours of night driving so thought it was a bargain at that price. ($99 NZD)
Old Oct 15, 2019 | 10:39 PM
  #18646
The expert tire dude at my local tire store highly recommended them.
The price was also agreeable to my budget
Old Oct 16, 2019 | 06:42 PM
  #18647
I might buy this windshield snow cover/thoughts?
https://www.icescreen.com/collection...tic-ice-shield
Old Oct 16, 2019 | 07:06 PM
  #18648
Stick shift swap
Hi
anyone swap out the shift stick?
i think a lower one would be more comfortable for my ergonomics
if so where could I buy one??
Old Oct 16, 2019 | 08:03 PM
  #18649
JRHPNG's Avatar
Originally Posted by MontrealFit2012
Hi
If you just want it lower you can just cut and re-thread the gear stick itself, if you want a short shift kit there are a few around.
Old Oct 16, 2019 | 08:04 PM
  #18650
JRHPNG's Avatar
Looks like a great idea, will save a heap of time taking the ice of your windshield..
Old Oct 16, 2019 | 08:25 PM
  #18651
Wish I had the tools!
Old Oct 16, 2019 | 08:42 PM
  #18652
GolNat's Avatar
Hi
https://www.ebay.com/p/717602671?iid...iABEgIAF_D_BwE
That is what I was going to buy before it got totaled.
Old Oct 16, 2019 | 10:06 PM
  #18653
Thx!
Damn sorry 😐 to hear that!
Old Oct 17, 2019 | 01:49 AM
  #18654
hotkey's Avatar
Originally Posted by SeEnCreaTive
Heh, it's my understanding the HRV IS a Fit more or less. Hence the magic rear seats
.... which is also a FIT!
Old Oct 17, 2019 | 04:30 PM
  #18655
Alignment
Over a year ago I bought my repaired used Fit knowing it had been in a bang up on the front end. It had really low milage.
I had the alignment done right after buying it.
Fast forward to now and I don’t recall going over any crazy bumps but my alignment may be slightly off again.
My question is/ If a car has been hit in an area involving the steering system will that car always be prone to getting out of alignment more than a car that’s never been hit??
Old Oct 17, 2019 | 04:41 PM
  #18656
JRHPNG's Avatar
Only if something is still bent or damaged that they missed (suspension or steering). Hope the frame is not bent...
Old Oct 17, 2019 | 04:47 PM
  #18657
It wasn’t a big bang up sorta straight in the passenger front wheel
I guess we will see
Old Oct 17, 2019 | 06:18 PM
  #18658
JRHPNG's Avatar
I guess we will see
It would take much of a bend in any of the steering assembly on that side to throw your assignment out.
If it is fine straight after you get an alignment there shouldn't be any issue, maybe try a different shop?
Old Oct 18, 2019 | 12:17 AM
  #18659
Goobers's Avatar
I'm slowly in the process of doing a rear drum to disc conversion...
I got the Scarebird conversion bracket and decided to test fit against the Wilwood brake kit's adapter bracket (so many brackets)... the 11" kit that is. And it doesn't fit together. There are three points of contention, that don't come into effect at the same time, they only appear if you attempt to clear the previous issues.
1.) the dual plate design of the SB bracket causes the main axle plate to interfere with the adapter bracket, preventing it from coming down to align the holes in the 11" position.
2.) even if you clear the axle plate, the adapter has a bit of a lip that then conflicts with the angled cut design on the SB's brake plate (the two black lines in the following image). The holes ALMOST line up as it is, just not quite enough to get a bolt through. If it was shaped like how the Integra's actual axle is, or just less angled, it wouldn't be an issue.
3.) I flipped both brackets to see how it would look if I could line up the holes for the 11" position... the adapter bracket ends up partially blocking the one of the four mounting holes on the axle plate. Leaving out one of the four attachment bolts, the closest one at that, sounds a little sketchy.
Well, crap.
The reason I bought the Wilwood kit is because it allows switching between 11" and 12.2" rotors just by moving the kit's bracket. But I bought the 11" version just to be sure it would fit in the 17" wheel. This kit claims needing "only" a 17" to fit... well, the BBK for the front claimed needing only a 15" wheel, but didn't even fit in the 16" Enkei RPF01. I ended buying 17" PF01s to fit the brakes since I couldn't do a return on the BBK.
So the two brackets don't fit together in the 11"position, but they do work together in the 12.2" position... now I just have to hope the whole thing fits as a 12.2" kit in the 17" wheel.
edit: Actually, I think I'll buy the bracket used in the Fastbrakes conversion kit. Based on the pictures in Steven Hung's thread, the holes in the bracket move down a few degrees and looks like it should fit.
edit #2: after doing some checking with rotating the Wilwood bracket around the Scarebird bracket, it looks like the Fastbrake bracket probably won't work as it is either. The only way for the Wilwood bracket to clear all the mounting holes and with enough room for a bolt head too, is with the adapter at the 12 or 6 o'clock (top/bottom) positions. But at that point, I don't know if there would be enough overlap between the two plates that would be welded together with enough rigidity and strength. I guess 12.2" rotors it is then...
Old Oct 18, 2019 | 03:59 PM
  #18660
A brake kit can fit 15" wheels, even if it didn't fit your 16 or 17" wheels. If you want brake clearance you need to be buying wheels that maximize brake clearance, the PF01 and RPF1 do not attempt to do so.
Research is useful.
There are brake kits for the S2000 that will clear some 16" wheels but don't even come close to clearing 17x9 +45 RPF1. My 17" Panasports BARELY cleared the OEM brakes on my S2000, yet some people have even put 15" wheels on them.
Oh and I took my Advans off & put my OEM wheels/Blizzaks back on the car.
