Old Apr 23, 2020 | 05:03 PM
  #18801
howarejew's Avatar
Made an RS emblem for my guage cluster
Old Apr 23, 2020 | 05:12 PM
  #18802
ArtJDM's Avatar
That looks great. How hard is it to take apart the gauge cluster? I've been considering doing some paining/tinting back there, but... lazy.
Old Apr 23, 2020 | 05:15 PM
  #18803
howarejew's Avatar
All you need is a philips screwdriver
Old Apr 28, 2020 | 09:42 AM
  #18804
MontrealFit2012's Avatar
Hi any feedback on this set?
Hi What do y’all think of this set Any good? Thx
Old Apr 28, 2020 | 01:45 PM
  #18805
Frenzal's Avatar
In the Montreal salt all winter long, don't use coilovers. They will rust and be stock in place...
Old Apr 29, 2020 | 01:06 AM
  #18806
GolNat's Avatar
Chinese junk.
Old Apr 29, 2020 | 03:51 AM
  #18807
dhuang's Avatar
Question Oil change today...
Oil change today at 150,600 miles with 5w-20 synthetic blend.
Dealership says I should come back in 5,000 miles, but the maintenance minder always seems to reach 5-10% in 10,000 miles. Who is right?
I know these cars can burn a quart in 5k -- it was scary to pull the dipstick at 15% and find it dry... added a qt of oil and it only brought the dipstick to the low mark.
Would running 0w-20 full synthetic elongate the change intervals? I'm quite religious about checking the oil on my other cars, but I placed too much blind trust in the Honda maintenance minder this time.
Old Apr 29, 2020 | 12:32 PM
  #18808
Originally Posted by GolNat
Chinese junk.
thx for the feedback 👍
I think these r better?
Old Apr 29, 2020 | 03:50 PM
  #18809
Frenzal's Avatar
You don't go wrong with Konis!
EDIT: Don't know if they drop the car or not... Another option is Eibach springs with Koni sports shocks. Have them on my Accord. Had them on my Civic. Have the shocks on my S2000 paired with S2000 CR springs. Never had a problem!
Old Apr 29, 2020 | 04:04 PM
  #18810
EDIT: Don't know if they drop the car or not... Another option is Eibach springs with Kon sports shocks. Have them on my Accord. Had them on my Civic. Have the shocks on my S2000 paired with S2000 CR springs. Never had a problem!
The parts dealer said it’s a 40 millimeters drop
Good all year round even in snow
Old Apr 29, 2020 | 04:20 PM
  #18811
ArtJDM's Avatar
I didn't know Koni made a kit. I've got Koni STR shocks with RSR springs, and I think they're great. A little harsher than stock, but that's to be expected. I looked up the kit, and it says it comes with Eibach lowering spring, so this should be a pretty good setup.
Old Apr 29, 2020 | 06:20 PM
  #18812
Frenzal's Avatar
Also nice: Eibach 1 million miles warranty and Koni lifetime warranty!
Old Apr 30, 2020 | 10:25 AM
  #18813
Fujiwara_toufu's Avatar
Fixed motorized side mirror
finally have time for my baby due to lock down, this is my first post in 7 years . . . Fixed her motorized left mirror and made a tutorial video on the process.
wishing all to stay safe & healthy
Old Apr 30, 2020 | 04:22 PM
  #18814
Frenzal's Avatar
Contact Carl from Perry performance for your performance parts. They also have a special on KONI every spring...
Old May 2, 2020 | 01:31 PM
  #18815
Ge8 wtih a grey bumper's Avatar
Managed to change my engine oil, gearbox oil and coolant.
A set of Konig hypergrams is on the way and i cant wait.
Looking to repaint the front bumper once the lockdown is over
Old May 11, 2020 | 01:26 AM
  #18816
Rick_a's Avatar
The other day was spent replacing a replacement axle, installing camber bolts, and replacing the transmission fluid.
Camber bolts are a hell of an upgrade for $25. My front tires have been rolling over hard in the corners with the outside edge getting pretty well scorched. The car feels much more planted now. I have calculated the setting at 1.2-1.3° degrees. I'll measure it for real when I align it here, soon.
Old May 11, 2020 | 08:37 AM
  #18817
ANGST's Avatar
Last weekend I did an axle replacement . I would recommend that both axles be replaced if you have the "dampener" on them at 10 years / 100K unless you live in Arizona or something. I broke my passenger side and was left in the middle of the road. I have a 2009 with 137K miles . I had the shop do the broken one, I did the drivers side myself, because it was not much further off from breaking as well.
Part of the procedure for the drivers side is the ATF drain and fill (2.6 qt) so I did that , and the oil change too .
Old May 11, 2020 | 01:20 PM
  #18818
Rick_a's Avatar
Mine's a 2010 MT. The Driver side has no dampener. The problem is that my "Import Direct" replacement axles have been loose out of the box and noisy with undue vibration on the highway. The new one is better than the last, but it still has a slight clunk under a hard mometary load. The other one was clunking all the damn time and both ends were loose as a goose by the time I pulled it.
Old May 15, 2020 | 05:26 PM
  #18819
GrE8_Fit's Avatar
Knob job
Old May 15, 2020 | 08:27 PM
  #18820
10fittingly's Avatar
Pick up Fit
Used the fit as a pickup truck . Took a load of rocks for my micro crawler scx24
