Old Oct 24, 2020 | 09:13 AM
  #18961
Rick_a's Avatar
Originally Posted by usert_l
It probably doesn't hurt to have it fixed before the boot is torn up more. I'd imagine that if the shock shaft gets exposed, rocks and debris can hit and cause damage to the shaft's surface.
Dirt builds up around the seal and nicks and dings on the shaft all contribute to premature failure. Even decent shocks are relatively cheap.
One of these days...
Old Oct 24, 2020 | 12:54 PM
  #18962
Goobers's Avatar
Originally Posted by StGemma
Glad I'm not the only one! Your method was a much better idea. Too bad I didn't think of it, because it would have been satisfying to remove the screw before using the rotary tool and such.
Oh well, the screw gave loose once I removed the rotor.
I figured, if I'm gonna cut into it anyway, might as well start small. If it had failed, I probably would've done the same thing you did, as I have an angle grinder too.
Old Oct 24, 2020 | 11:20 PM
  #18963
StGemma's Avatar
Originally Posted by Red 05
Were you using an impact drive to get the screw off? Maybe with a normal Phillips head? Those stupid screws use a head that is similar to a Phillips but not actually. I bought a JDM specific driver when I first took mine off. Kept them off too, there's no point to them after leaving the factory.
No, sir. I don't have an impact driver, so I took my chances. However, I did use a #3 bit, which is the correct bit, but I'm not sure if it was a #3 JIS bit.
Funny story, they actually sell those accursed rotor screws on amazon! xD
@Gobbers "I figured, if I'm gonna cut into it anyway, might as well start small." Yeah, I actually tried grinding down the head of the screw to match my 10mm flare nut wrench, but that was really difficult, so I said the heck with it and just ground down the entire thing, as seen in the pictures.
Old Oct 25, 2020 | 01:24 AM
  #18964
Swapped over to my blizzaks. All set for winter.
Old Oct 25, 2020 | 10:17 PM
  #18965
BaySFit's Avatar
Finally got around to putting on my Thule Traverse square bar roof rack! Picked this up for a steal from a community member, definitely digging the look
Old Oct 26, 2020 | 07:03 PM
  #18966
mikeymanifest1's Avatar
✅ JDM RS Bumper
✅ Stellar V Taillights
✅ “genuine” Red Emblem
Da booty
Old Oct 26, 2020 | 08:44 PM
  #18967
eulogy's Avatar
and this is what u call not ready for winter. wth
Old Oct 26, 2020 | 09:07 PM
  #18968
Red 05's Avatar
I take it you're out in the Midwest with all that snow and ice falling? Thoughts of warmer weather from central Alabama headed your way!
Old Oct 26, 2020 | 09:20 PM
  #18969
eulogy's Avatar
southwest..in NM. was in 80s past week. now this lol. thanks for the warm weather thoughts...i hate the cold!
Old Oct 26, 2020 | 10:23 PM
  #18970
Sheesh.
more than we’ve got up here haha
Old Oct 27, 2020 | 08:25 AM
  #18971
Fitsnstarts's Avatar
Originally Posted by teamkitty
Following up on my Civic Si seat install. I would NOT recommend this mod. I'm mechanically inclined, but this was an absolute pain in the ass. After days of drilling, grinding, and bolting the feet from my Fit to the Si seats, I got them in and they do fit nicely. But, the airbag light is on. I'm just bummed because I did everything by the books: unhooked the car battery before I started, swapped out the occupant position sensor computer inside the Si passenger seat with the one from my Fit, swapped one of the white airbag plugs from the Fit driver's seat to the SI seat so everything matched up, and reconnected the battery only after everything was installed. Not sure what the problem is, but fuck it, I'm driving without airbags for a while. I'm done with this project.
This happened to me when i swapped my 2009 seats for 2010 stock seats. I ended up taking it to the dealer for something else they were running diagnostics on (airbag recall). Turns out each seat sensor (passenger seat) is calibrated to the controller individually. So i paid them some $$ ($150 if I recall correctly) and they calibrated my airbag seat sensor. Easiest money I've ever spent. Don't mess with safety. On the upside, I verified with Honda America that the airbags will fire even if the lights are on and the sensor isn't calibrated but the car would have failed inspection.
Old Oct 27, 2020 | 08:29 AM
  #18972
GE Fit and Aliner Alite Camper
Picked up a camper! Wired lights and a brake controller. New tires all around and new roof rack. Ready America? Here we come!
Old Nov 5, 2020 | 05:35 PM
  #18973
Fit4Looks's Avatar
New to the Fit scene. Purchased a 2011 Sport that has lived a very easy life (until now). Easy stuff out of the way, windows tinted and 1" spacers installed. Everything else is stock. Drooling over all the cool mods. I need to drive the Fit for a while to learn it's personality before I start anything big. Lowering springs and rear sway bar are at the top of the list. Upgraded stereo for better sound and backup camera will follow shortly. Thule roof rack next Spring/Summer.
Old Nov 10, 2020 | 05:52 PM
  #18974
donlogan's Avatar
Old Nov 10, 2020 | 06:01 PM
  #18975
steve37's Avatar
That should do it....lol.
Old Nov 10, 2020 | 08:35 PM
  #18976
usert_l's Avatar
Before I learned about DIY car maintenance stuff, I used to take my first car to an oil change shop. They definitely tightened my drain bolt with an impact driver. I only realized this when I decided to do the next oil change myself and had to use a long cheater bar to loosen it. It was wayyyyy over-torqued.
Old Nov 18, 2020 | 10:07 PM
  #18977
Rick_a's Avatar
Seat rail fix
Finally fixed a stuck seat rail. It's been that way since I purchased the car a year and a half ago. Not a difficult job. Still a pain to dislodge some random junk.
Seat out
Offending rail
Offending junk
Old Nov 20, 2020 | 12:01 AM
  #18978
GrE8_Fit's Avatar
^I've been meaning to pull my seats and vacuum. This gives me hope.
Old Nov 20, 2020 | 08:20 AM
  #18979
Rick_a's Avatar
It should also be noted that the seat belt fastener was barely snug. That was a little eye opening. 😬
Old Nov 20, 2020 | 08:21 AM
  #18980
JerrySFL's Avatar
It is not a Phillips screw it is a Japanese industrial standard looks very similar,
VESSEL MEGADORA IMPACTA Impact Driven Screwdriver +3x150 (6") No.980 980P3150
makes an impact driver to remove those. You can also use two ballpin hammers, put the round part on the screw head and hit the The other hammer, ballpin hammers can be hit without exploding they are made to hit metal; DO NOT use a regular hammer to do this they will shatter, third method is to drill out the head of the screw. Non of these methods will damage the rotor or hub.
