Old Feb 3, 2023 | 11:32 PM
  #19381
spotnz's Avatar
new Tyre valve caps
They are the same colour as my Mugen Fit Shuttle
Old Feb 8, 2023 | 02:29 PM
  #19382
NSC858's Avatar
Got new tires
Old Feb 15, 2023 | 09:52 PM
  #19383
spotnz's Avatar
Door latch bling
Old Feb 16, 2023 | 01:57 AM
  #19384
ge808's Avatar
Innovative 75a mounts
Old Feb 16, 2023 | 07:29 PM
  #19385
NSC858's Avatar
turtle waxed my headlights
Old Feb 16, 2023 | 07:35 PM
  #19386
spotnz's Avatar
very nicely done
Old Feb 17, 2023 | 09:38 PM
  #19387
spotnz's Avatar
somewhat busy day
Carbon Fiber look ( actually rubber ) corner protection pads.
Whilst the rear corners NEEDed protection, due to prior ( to me ) scrapes. They also weren't anywhere near flat
rubber pads for the bottom of the front doors
Rubber front wiper hole covers
From this
to this. Only the small piece FITted, purrfectly. When trying to fit the larger part, the pressure from the wiper arm, made the outside of the rubber misFITing, due to gaps allowing dirt, etc entry.
to this
david
finished for today
Old Feb 22, 2023 | 02:46 AM
  #19388
spotnz's Avatar
Rockford Fosgate front door speakers are now mostly installed.
I was pleasantly amazed how nice the music is now. Even before some sound insulation is installed.
Next is some Siless
for inside of the outer door skin
With a cover of dynamat on the inside panel of the door.
Old Feb 25, 2023 | 02:22 AM
  #19389
spotnz's Avatar
Fitted a dash sun reflection eliminator.
before
during
After
Whilst it fitted. that was not purrfect.
I needed to enlarge
- the vent holes, nearest the front quarter light
- the auto lights sensor hole.
I also removed the strips partially covering the front dash vent. And replaced the useless velcro squares supplied, with larger & stickier bits.
It is a much needed upgrade, at a very cost effective NZ$21.46 delivered.
Old Feb 27, 2023 | 12:46 PM
  #19390
NSC858's Avatar
The joys of parenthood
Removed my daughter's car seat and found out what Im doing on my day off.
Old Mar 2, 2023 | 11:48 PM
  #19391
spotnz's Avatar
started the interior sound insulation
Whilst I was able to put a piece, under the felt. to do a complete job, would entail removing the complete dash
Old Mar 3, 2023 | 09:41 PM
  #19392
GrE8_Fit's Avatar
That door sill protector is legit.
Old Mar 3, 2023 | 10:28 PM
  #19393
spotnz's Avatar
agreed, it does fit my Shuttle well
Old Mar 12, 2023 | 11:02 AM
  #19394
NSC858's Avatar
Camera install
After seeing a bunch of questionable drivers and close calls with idiots. I installed a dash and rear camera.
Old Mar 13, 2023 | 07:01 PM
  #19395
Pyts's Avatar
@NSC858 Dude, got any links for that backup cam set-up? That looks sweeeeeeet.
Old Mar 14, 2023 | 11:29 AM
  #19396
NSC858's Avatar
i went with this company. https://www.grdian.com/shop. I went with this one because there was sonebody I follow on IG who had a discount code (JENNA). I was also debating between two companies Grdian and Wolfbox. Grdian got my vote because they are pretty responsive on their online chat, and assured me that the rear camera could even withstand a carwash and if it had any issues theyd replace it for free.
The overall installation was pretty easy. The hardest part was removing the hatch door cover.
There's another option for the WOLFBOX G850 4K Mirror Dash Cam: 12'' Rear View Mirror https://a.co/d/f6MNI9X. Theres a slightly cheaper version but I don't think the rear camera on that one is weatherproof.
Old Mar 14, 2023 | 02:42 PM
  #19397
Pyts's Avatar
That's a huge help, thank you so much. I've been looking at head units to function as the screen, but I'd be spending 2-400 just on the head unit, trying to figure out a matching camera..
Any issues with this unit so far?
Old Mar 14, 2023 | 03:31 PM
  #19398
NSC858's Avatar
Yeah I thought about getting an aftermarket head unit... but then i thought that might open the can of worms where I will want to upgrade my speakers... maybe add a sub. But really didnt think it was worth it since 90% of the time my kids want to listen to their kids songs.
But so far the only issue that Ive had was my mirror was a bit loose on the Fit. I was about to buy a new mirror but found a cheap but affective hack.
So far it works pretty good. Hit a few bumps to test how it would hold up and it holds pretty well amd hasnt flopped.
The camera works pretty good. Its been raining here so the rear camera has been exposed and has been holding up pretty well. Curious to see how it would handle with a car wash but it will be raining for awhile so wont get to test that.
I thought it would be useful to have it constantly on, but Ive been turning off the screen and using the mirror most of the time because I need to see my kids. But it is nice that it is triggered when my car is in reverse. It works really well and is pretty accurate and a whole lot better than having to look.
The UI is pretty easy to navigate. No weird issues Ive experienced just yet. I have the GPS option, but dont think it is all that useful. I was thinking it was going to have a navigation feature, but it doesnt... so if i were to do it over I would have opted out with getting the GPS.
Old Mar 15, 2023 | 04:05 AM
  #19399
spotnz's Avatar
insulated the rear door, against undesirable sounds
Tapping on the outside of each insulated panel, returns the desirable dull thud sound.
Comprehensive, yet not complete
Old Mar 15, 2023 | 09:45 AM
  #19400
Pyts's Avatar
@NSC858 You just answered every question I had. I wasn't going to ask expecting to be told to do my own legwork. That's some high-class community service right there. If I may bother you with just one more: how is the camera shut off? I share vehicles with an older family member who would give me hell if it was too technical
Thank you thank you thank you! And if you want me to do my own leg work on this one I will.
I busted up when reading your reason for not upgrading your sound system by the way. That's some smart parenting.
