High Mileage Fits
Old Jan 20, 2016 | 08:36 PM
  #341
Manning's Avatar
175k
2007.....175,000 miles..mobil1...all's well but for a dome light mystery
Old Jan 21, 2016 | 07:50 AM
  #342
Perrenoud Fit's Avatar
Dome light
Had a problem with a friends Fit and it was the door switches needed to be cleaned. Took each switch out and cleaned and lubricated make sure where the screw mounts to door frame is clean to. After that no more problems.
Hope this helps
Old Jan 21, 2016 | 08:19 AM
  #343
Manning's Avatar
Perrenoud, thanks for the thought on the door. If I manually push the door button, it reflects its status correctly with the light on the instrument panel, so I think the switch(s) are good. It's just the dome that does not come on.
Old Feb 5, 2016 | 12:26 PM
  #344
sanjay228's Avatar
Had an '08 5spd Sport I bought in April 2012 that got totaled back in Nov. 2014 with 111k. Got 9700 from insurance and bought the same exact color '07 Sport 5spd the next month with 184k for 2800. Now at 206k and still running like a champ. I figured since I still have the leftover money from the insurance, if anything major goes wrong engine-wise, I'll just buy a used one on ebay since they're so cheap haha.
This is the most practical car I've ever owned and I don't see a need to get any other lol
Old Feb 8, 2016 | 10:02 AM
  #345
collective's Avatar
Just opened an account (long time reader, though), to let the world know that I joined the 100k Fit mileage club last week.
Fit Sport 2008, purple, MT. The only issue it's ever had is a wheel bearing, the rest is just maintenance. The tiny battery is a hassle now that I live in NJ (Carolinas before that), and I plan to install a bigger one for next winter, but other than that it's an OEM Fit running like a champ after 100k.
My favorite car ever.
Old May 29, 2016 | 12:42 AM
  #346
sleazedpr's Avatar
390,000+ kms
I got a 2007 Fit just over a month ago, put over 7000 Kms on it. It's now over 390,000 Kms. Wish I knew the guy that owned it first to know its history but the first thing we'll have to do to it is recharge the AC and see if there are any leaks.
I had to learn to drive standard with it so hopefully I didn't wear it out too much.
Old May 30, 2016 | 01:44 AM
  #347
vap3's Avatar
My fit just turned 202,000 km and it doesn't burn a single drop of oil yet! Gets almost 40 mpg to the tank and only issue is NO A/C but I'm hoping a recharge will get her going again. Curious how much it costs on average to get the fit recharged?
Old May 30, 2016 | 11:30 PM
  #348
sleazedpr's Avatar
Ours is definitely burning oil but I keep a close eye on it and will be doing oil changes frequently. I found a recharge kit for 60 bucks, it looks easy enough to do.
Old May 31, 2016 | 09:25 AM
  #349
Jared592's Avatar
If you really want to fix it so you don't have to mess with it again, you need to find where the refrigerant leaked out. Make sure the stuff you buy contains UV dye (it's common that they do). That way, you can look around at night with a black light and find where the leak is.
Old Jun 5, 2016 | 07:56 PM
  #350
acutturi's Avatar
260,000 miles and still my daily driver
I have a 2007 Honda Fit Sport with over 260K miles on it and it is still my daily driver. Only changed the coil packs in the last year and regular oil changes every 10,000 miles. This car still runs like a sewing machine!
I just bought a new 2016 Honda Odyssey and might need to sell my Fit to make room in the driveway but I LOVE this car! I don't think I can let go of it. I just bought a 2004 Miata 5 speed, and honest to god, I like the Fit just as much.
Old Jun 11, 2016 | 01:17 PM
  #351
Xcrave's Avatar
Cheapest I found was for $90... DO NOT BUY RECHARGE KITS. They're filled with propane and not R134a. You have to be professionally licensed to deal with actual refrigerant.
Old Jun 11, 2016 | 02:40 PM
  #352
john21031's Avatar
Of course they contain R134A refrigerant.
You don't have to be licensed to use one.
You might, in some states, be encouraged to have ASE certification if you are employed in the business of auto repair, and we all know there are plenty who work without no licence/certification.
Old Jun 25, 2016 | 02:10 AM
  #353
adu1982's Avatar
just 136k, only thing replaced coil packs and plugs, and oil changes.
Old Jun 25, 2016 | 08:43 PM
  #354
fittenmittens's Avatar
Closing in on 250k, and no issues other than the usual maintenance.
Old Jun 26, 2016 | 05:35 AM
  #355
vap3's Avatar
damn almost hitting 210k and the a/c compressor went out. I didn't even get to use it once since I bought the car :9
my mechanic said it would cost $400 for the part and $400 for labor because it is a 4.5 hour job. With taxes in I'm looking at 1050 cad all in with taxes.
I've looked on ebay that had the clutch unit for the compressor for only $150 cad if I wanted to gamble on the mechanic just changing the clutch of the unit. But not sure if that is less labor intensive.
http://www.ebay.com/itm/A-C-Compress...RXPf2v&vxp=mtr
looks promising
Last edited by vap3; Jun 26, 2016 at 05:39 AM. Reason: verify if anyone had tried this part yet
Old Oct 1, 2016 | 01:14 PM
  #356
hondaconvert's Avatar
high miles 2007 fit
255,000 so far. nothing outside of ordinary, coils, plugs, etc. Air conditioner out, but not worth replacing compressor in New York climate. Misfires only recurring problem, causing engine light to come on, usually solved by a tank of premium every 3rd fill plus Castle injector cleaner & reset.
Old Oct 5, 2016 | 07:21 AM
  #357
grizzly1962's Avatar
Just an update...
I am now at 493,000 miles on my 2007 Honda Fit !
Still Loving it... still original motor and transmission and believe it or not original starter.
Old Oct 27, 2016 | 08:52 PM
  #358
cakacon's Avatar
what all issues have you had out of curiousity? thats a lot of miles!
Old Oct 27, 2016 | 11:22 PM
  #359
vap3's Avatar
what's the best deal for a set of 4 coil packs in canada? I don't have any issues yet but winter is coming and I feel a rust issue happening :0
Old Nov 11, 2016 | 08:03 PM
  #360
nighthawk fit's Avatar
Thumbs up Wow!
Originally Posted by grizzly1962
Just an update...
I have a 2007 Honda Fit Sport Automatic I bought new in March 2007. I just turned 213,000 miles on it. A/C still works fine the only problem I have is the back right side window doesn't go down anymore. But I don't use it anyway so I don't care to have it looked at. And get this my last tank of gas got me 350 miles with 1 gallon left to go.
Save
