High Mileage Fits
Old Feb 24, 2014 | 03:02 AM
  #181
Scratch&Dent's Avatar
Selling my fit since i'll never catch him...
jk...
Old Feb 24, 2014 | 09:02 AM
  #182
p nut's Avatar
Originally Posted by derykisonder
Best is 91 octane
Incorrect.
Old Mar 4, 2014 | 12:48 PM
  #183
cl juice's Avatar
just a craigslist post i saw today. Thought i'd share
438k miles 2007 honda fit
2007 Honda Fit 5 Speed
Old Mar 5, 2014 | 04:29 AM
  #184
craigquakertown's Avatar
Originally Posted by two-five boy
For the guys with hi mileage, what octane gas have you been pumping into the car? I'm trying to determine if there is a correlation between better gas and engine longevity.
I got 90k I still use 87 due to gas pricing in new York being so high if you live in suburbs and do all highway it would be worth the jump cause your not buying gas as much
Old Mar 6, 2014 | 10:17 AM
  #185
karebu's Avatar
'07 fit 155k (km)
running 16" since 10k (km)
tein s-tech springs since 30k (km)
in this order:
1) rear left bearing
2) rear right bearing
3) engine mount x1
4) driver windows control switches (left rear window wouldn't go down)
5) rear left bearing
6) engine mount x1
7) AC fan (the front-mounted fan beside rad fan)
8) rear right bearing
currently:
my brake discs are quite scratched but still works. mechanic advises AGAINST skimming them.
AC feels a bit weak (not cold).
ride is bumpy and hard as hell at the back but my dampeners have yet to leak.
Old Mar 6, 2014 | 10:26 AM
  #186
karebu's Avatar
i have zero engine problems with my '07 155k (km) fit.
99% of the time it would be the cheapest gas (91/92 RON) and 1% of which would be premium gas (97/98 RON).
I mix brands (the best brand is the one along the way), I mix petrol grades (when there's a sale) and I don't feel any difference in power or mileage or experience knocking/pinging.
Old Mar 15, 2014 | 02:46 PM
  #187
Fit_Dr's Avatar
08 Sport 176K miles.
Replaced both front wheel bearings but that was my fault due to experimentation with camber bolts.
A/C condenser due to taking out a small dog.
Coil packs at 150K.
Replaced front rotors and stock brake pads somewhere around 50k because they sucked so bad. Put on Brembo GT rotors and Porterfield R4-S pads and they're still going strong with 120K on them and stop so much better.
Rest has been just maintenance.
Old Mar 22, 2014 | 03:56 PM
  #188
Stevie D's Avatar
high mileage fit
I am a UK owner and our 05 1.2 GD has 112K miles. Got the car in 2008 with 65K on the clock. No major problems just some of the annoying water leaks(rear wheel well and rear passenger footwells).
Steve.
Old Mar 22, 2014 | 06:56 PM
  #189
ikutoisahobo's Avatar
Steve.
There's a how to on here to resolve the water leaks. Seems common. Might shed some light: https://www.fitfreak.net/forums/1st-...eak-trunk.html
Old Mar 23, 2014 | 05:23 AM
  #190
Stevie D's Avatar
Thanks Ikuto I have utilised the fixes recommended here for the rear footwell problem, and also a good fix on the club Jazz(UK) forum for the water in the trunk. Pleased to say both have worked and our Jazz now stays dry.
Steve.
Old Mar 26, 2014 | 01:29 AM
  #191
makufit's Avatar
how the heck?? I have 167,000 and serious misfires. Had OE coil packs done, OE plugs, valve adjustment, and Beck arnley reman injectors. Had compression test done (was fine), fuel sample (was fine)... Have u had any serious misfires. PS 2007 Honda Fit Sport MT
Old Mar 26, 2014 | 09:26 AM
  #192
Fit_Dr's Avatar
Misfires or hesitations in general? Fuel pump or filter? Any codes?
Old Mar 26, 2014 | 12:11 PM
  #193
makufit's Avatar
Misfires. I have an actron plus and spits codes with written descriptions. Misfires in 1 and 2 and a random. These are not consistent with moving the coils and change to other coils at random.
Old Mar 26, 2014 | 02:15 PM
  #194
Fit_Dr's Avatar
Sounds like you replaced all the electrical you could. Could it be a bad ECU or engine harness?
Old Mar 26, 2014 | 04:43 PM
  #195
makufit's Avatar
Where could I get the wiring harness for the coil packs and also the wiring harness for the fuel injectors? I've been looking...
Old Mar 27, 2014 | 09:13 AM
  #196
Fit_Dr's Avatar
Outside of a dealer I really don't know.
Old Apr 3, 2014 | 10:25 AM
  #197
DaveFit's Avatar
I have a 2007 Fit (Sport) with 110,000 on it. At 54,000 I had to have clutch work done and now at 110,000 I'm noticing that the drive axles seem a little loose, not sure if they should have any play in them.
Old Apr 3, 2014 | 11:07 AM
  #198
MTLian's Avatar
If you jack up a wheel, it should spin freely but NOT have any wobble.
I believe it could have to do with the tie rods. Here's a video on that. See if it's the same symptoms.
Old Apr 3, 2014 | 06:14 PM
  #199
Bernie46060's Avatar
2008 sport @ 160K mi. Besides just recently replacing my tires for the 3rd time, I replaced the battery at 70K, new front brakes @ 100K, replaced Catalytic convertor at 150K, and finally new set Spark Plugs that took care of misfiring and lack of power were done the other day.
Old Apr 6, 2014 | 09:49 PM
  #200
gmanfit's Avatar
2008-auto fit sport--
just oil, trans, and routine services--
158k
