**Official K-Fit Pictures Thread** (no BS)
got the hybrid racing shifter box in the mail yesterday and modded it and did install same day, and as promised did a write up on it, i like it, feels solid, took me a total of 2 hours to get it to work, feels great to have my cupholders and console back on , and shifts feel smooth and dont have to worry now about anything coming lose.
Where are you guys getting your axles? I need to order mine
RSX base axles works for EG!!! - K20A.org .:. The K Series Source . Honda / Acura K20a k24a Engine Forum
thats what iam useing, the box said eg k swap axles, i talk to brian and he said same specs, so any eg k swap axles will work cuz fit have a 32mm hub same as eg do, iam working with karcepts to see if his 36mm hubs will work with ours like they do with eg chasis, with those you can use the type s axles which are stronger, hoping to have an answer in bout a month, iam sending him a used set of hubs to test, once confirmed ill test on my car and share results
ive learned alot of do and dont so if anyone has any questions or problems hit me up and ill help
another thing i found out that you dont hear bout is the head light harness that runs under the stock rad suport, if your using the stock rad suport, that harness will touch the serpentine belt the way it goes normally, i foundout if you run it in front of the rad suport by bending apart of it back everything will still bolt down and plug up fine and will be out of the way of the belt, ill take my bumper off saturday when iam not busy and take pics of the way i did it, not hard but will save you time and headache. I ALLSO HIGHLY RECOMMEND YOU GET THE INNOVATIVE MOUNTS, atleast the 65a ones, iam useing the 85a ones now, which might be to stiff for most people, it vibrates the dash some but i like the stiffness. the stock ones are crap!!! motor would bounce all over the place, watch the video in this thread of my car on the dyno to see how much play there is with the stock mounts.
yes, the hasport fit swap mounts are just adaptor to the stock mounts, not like true swap mounts, so upgrading the fit mounts will help alot
do you have the part number for those mounts that you have
here a link to them
05+ Honda Fit/Jazz Replacement Mount Kit
here a link to them
Yo do you by any chance know who drives a silver gd3 that is lowered around the syosset/jericho area? I keep seeing it on jericho tpke
yeah...exhaust wasn't tight n untuned
