What you DONT like about your Fit
Old Jan 25, 2011 | 09:30 AM
  #1201
jbarber1's Avatar
dislikes, etc.
I've found my '10 Fit sport headlights to be okay. Maybe I was lucky and they came properly aimed.
The fog lights are sort of a disappointment; I thought they would have more reach forward. As it is, they mostly light up the shoulders on each side. Has anyone found better units to replace the stock foggers?
The lack of a 6th gear is my biggest complaint. The first 5 are great for performance from such a small engine, but a sixth would surely help with highway economy and engine noise and wear.
I'm sort of surprised that I haven't seen any cool mods that added nice engine temp and maybe oil pressure guages. I'm old school and like to have the data available.
Finally, the mpg guage seems about 3-4 mpg optimistic, and not affected by ambient temperature. I take care to use a particular gas pump consistently, and fill the tank pretty slowly when nearing full. I quit on the first activation of the pump's auto-shutoff. I probably drive 70-80% on sometimes hilly highways, 60-65 mph when prudent. Real (manually calculated) mileage runs 34-36 mpg in winter, with snows on base steelies, and 36-38 in summer. The mpg meter seems most accurate when I'm taking a multi-hour long trip on a thruway, and it will read about 40 mpg, confirmed by manual calculation. I wonder if Honda can re-calibrate the meter to improve on accuracy. I thought the '10's were supposed not to have this problem, after the '09's indicated that attention was needed.
Old Jan 25, 2011 | 09:51 PM
  #1202
fit.sport's Avatar
Why No 6th Gear
Whatch this video: Motoring TV : Quakerstate Garage?
Old Jan 25, 2011 | 10:07 PM
  #1203
jayhawker's Avatar
So far, the only thing I really don't like is the color. I have the Milano Red and it was the only 2010 Fit Sport with man tran so I took it. I had a MR Civic Si back in 1999 so I am sure the color will be fine. I was hoping for white.
Old Jan 26, 2011 | 07:23 AM
  #1204
jbarber1's Avatar
yup. 6th gear is a natural
Originally Posted by fit.sport
The video is great, but it doesn't really highlight the improvement in noise and engine wear. My wifes '04 Corolla auto loafs along at about 2200 (maybe less) at 60mph in high gear, and can get up to 35 mpg that way. Just about the only little car I've driven where the auto trans thinks like I do, and gives great performance. My old 91 Civic wagon had a top gear/final drive ratio like the Fit's and that was good----its 91 HP and Fit-similar weight probably would have strained with a 6th gear. The old dear went 296,000 miles before I had to give it to the crusher. I only hope the Fit lasts so long. The Fit gives up too much without a 6th gear, but I still really enjoy driving the little thing.
Old Jan 26, 2011 | 09:16 AM
  #1205
Goobers's Avatar
Fog lamps aren't supposed to be for forward illumination, at least, when its clear out.
The idea of the fog lamps is to use them when its... foggy outside. The low position of the lamp means it reaches the ground more easily than the headlamp, giving you the ability to see the road in fog (heavy rain and snow).
Obviously, more side light means you can see the lane markers and the curb in those same conditions... you know, so you don't end up driving into a ditch or something.
But apparently, a lot of people don't give a flying F*** about it, and use it all the time with brighter bulbs... which only serves to blind oncoming vehicles. The output isn't controlled like headlights, they do shine "everywhere."
Old Jan 26, 2011 | 07:13 PM
  #1206
jbarber1's Avatar
Good points, and some of it news to me, esp. the bit about not being controlled. I knew about the intent to provide light on the sides. I just hoped that it would reach out farther in front, two. But you're right, they only show their value when there's actually fog or snow. Then you get more light than the low beams alone, and much less problem with the light reflecting back to you off the fog or snow. I sure don't want to blind oncoming drivers, so I'll leave them alone unless there are good replacements around that won't cause that problem.
Old Jan 26, 2011 | 08:36 PM
  #1207
ha-y-nferio's Avatar
The only thing I wish I had on my GD Sport is a sixth gear for highway driving, a map light, and the rear window glass popped open so you could open the hatch glass like on a CR-V to carry long cargo. But, I am still happy with my Fit and thankfully the last two are easily remedied by buying the JDM maplight, or getting a roofrack....the 6th gear can only happen with a K-swap, so it may take a while for me to get to that, haha.
Old Jan 27, 2011 | 09:25 AM
  #1208
JCrimson's Avatar
Originally Posted by Fitfreak07
Yea stock headlights sucked. I went with the 10k Hids and its daylight all the time now.
10k plug and pray HIDs are worse than your oem halogen bulbs. you mean "its bluelight and less visibility all the time now"
Old Jan 31, 2011 | 09:05 PM
  #1209
Ekeh Mayu's Avatar
I'm a little upset Honda didn't bring over the sun roof from the European models and the 4wd/awd on the Asian models
Old Jan 31, 2011 | 09:30 PM
  #1210
JJIN's Avatar
ive about remedied most of my dislikes on my fit.
all i really need now is raceline to finish developing their supercharger and ill be completely satisfied with my fit.
Old Jan 31, 2011 | 10:21 PM
  #1211
ThEvil0nE's Avatar
and I thought they stated that January is when they start developing it... it's February now...
Old Jan 31, 2011 | 11:34 PM
  #1212
Kstreck's Avatar
try reclining seat slightly
Originally Posted by ~AMC~
Hey guys, new to this site and have been lurking awhile. I tried to go through all 60 pages of this but it's a bit time consuming. Do any of you have a work around for taller people to get the seats to go back further then the stocks allow? Thanks!
I'm 6' 2" and I recline the back of the seat a little. It doesn't provide more leg room, but the position is more comfortable and seems roomier.
Old Feb 7, 2011 | 11:40 AM
  #1213
jdubatl's Avatar
Carpet, The stock stereo is lame (Replaced with Apline DVD/Navi) Lack of power (I guess thats what you get for better mileage)
Old Feb 8, 2011 | 02:23 AM
  #1214
egw84's Avatar
Thin paint sux! Front lip too low for stock (removed & sold). Lack of telescoping steering wheel for taller drivers (raised seat with longer bolts & spacers/nuts on underside), pedal resistance (installed stiff spring), seats uncomfortable (headrests flipped backwards & rears removed to flip them down whenever, I think I gotten wear in the shoulders cuz they make me hunch), wind noise & drift (eibach pro kit, feels lower than it is, great diy)...
Old Feb 13, 2011 | 01:30 AM
  #1215
senoBDEC's Avatar
For some reason people like to race my Fit. It's a 2009 Fit Sport MT. Now I tend to push it a little now and again, especially when merging on the freeway because it almost demands it for safety purposes (to get to ~60-70 MPH before merging).
I've had a an older model AMG (among other cars - Impalas and BMW 3-series too) do the ricer fly-by left lane while I'm cruising at ~70-75 MPH or so, AND then brake and merge to the lane on my right and do it again.
I mean honestly, even if my car were a Civic Si how would you EVER match that kind of HP/torque?
So I found my solution... it's called, toss change in front of their car if they keep at it. Works for me.
Old Feb 13, 2011 | 02:45 AM
  #1216
JJIN's Avatar
DUDE i dont know what part of cali youre from but youll get shot or a tire iron through your windshield if you pull that kind of sh1t in most of socal freeways.
Old Feb 13, 2011 | 12:43 PM
  #1217
Krimson_Cardnal's Avatar
Phew - sort of makes me think that what I don't like most is some of the folks that drive 'em. I thought Connecticut drivers were bad...
Old Feb 13, 2011 | 03:04 PM
  #1218
DiamondStarMonsters's Avatar
No kidding, we had two truck drivers stab eachother to death out front of my office on US41-N a couple months ago because of a perceived slight and some tailgating.
I hope he is armed with more than pocket change if he is going to do crap like that.
Old Feb 13, 2011 | 03:13 PM
  #1219
SilverBullet's Avatar
Those truck drive give trucking a bad name, a few more miles and would have been in Wisconsin and no death penalty. Also the scales with state police were open then, there would have been no fight.
Old Feb 13, 2011 | 03:17 PM
  #1220
hogwylde's Avatar
The only thing I have to complain about the car is actually a good characteristic. But I hate (not used to) how responsive the steering is. The car reacts to the slightest movement of the steering wheel causing it to swerve making you look like a drunk driver when all you were doing was reaching into your pocket for some change to pay the toll.
