What you DONT like about your Fit
Old Mar 31, 2011 | 11:22 PM
  #1281
john21031's Avatar
Hope you didn't buy the drowned fit.
BTW, put a full tank of gas in it and drive reasonably. You will be fine.
Old Apr 1, 2011 | 11:07 AM
  #1282
ha-y-nferio's Avatar
adjustable rear camber. i guess i could try to find a kit, or ghetto rig it.
Old Apr 4, 2011 | 04:27 AM
  #1283
buckyfit's Avatar
fuel gauge tick marks
I know this is super nitpicky, but... I don't like how the fuel gauge does not have tick marks. Only tick marks are full, half, empty.
Old Apr 4, 2011 | 07:26 AM
  #1284
kurisux92's Avatar
The lack of a coolant temperature gauge. Drives me crazy.
Old Apr 4, 2011 | 08:01 AM
  #1285
rk5busa's Avatar
I'm new to the forum and saw your post under static shock. I know it's an old post (2007) but I had this problem only After I installed my HID's similar to yours. When I originally put them in I did not properly ground them, I mounted the ground to the radiator bolts because it was the easiest. Then I started getting shocked. I moved the driver side ground to the battery (- negative side) and the passenger side ground to the Motor mount ground. Once this was done I have yet to be shocked.
Old Apr 4, 2011 | 08:35 AM
  #1286
XJP5's Avatar
Agreed. It also bugs me that there is such a limited availability of aftermarket support for the GE compared to the GD series. The manufacturers just seemed to abruptly stop supporting this vehicle, with a few exceptions.
Old Apr 4, 2011 | 08:56 AM
  #1287
Schoat333's Avatar
I have to agree. It bothers me so much that I may just have to add an aftermarket gauge.
Old Apr 5, 2011 | 01:34 AM
  #1288
gkitf16's Avatar
My gripes about my Fit
Mine's an '09 fit base with 16k on it. I've had it for about 3 weeks now. For the most part I really love it, but there are a few annoyances. One is the glare from the extremely long dash area in front of the driver when you are driving toward the sun, very fatiguing on your eyes , should have been designed with less shiny plastic/different angle so as not to reflect into the windshield.
Of less importance, getting your right foot adjusted comfy on the throttle is hard to do for cruising, and seems there should be a little more "spring tension" feel to mashing the throttle, too light. Hard to maintain steady speed at cruise, makes me wish for cruise control if I had the Sport.
Just got done making the modification by putting in plastic debris screen inside the front bumper grille. I was lucky - after removing the top cover, I found already a BIG chunk of broken chromed plastic (somebody's broken headlight reflector or something) about 4" round or so had flown thru the grille and was lying inside . Scary, you can reach your hand inside with no screen there! Fortunately the condenser fins didn't get beat up or crushed. So, if you want to keep your baby safe, do this soon! Pretty easy, but tough to reach down low inside and thread zip-ties thru, I have short arms and it's tight reaching past the nose-grille, scraped my arms up . But finally looks great and no more danger of crap getting inside!
Finally, I got the keyless remote (hate using the key to open up all the time ), tired of having to manually open, double click to open rear doors, then re-lock before closing them each time. A trip to the dealer to get it programmed $$$, but will be SO much nicer when it's done !
Old Apr 5, 2011 | 07:25 AM
  #1289
cr4zy3lgato's Avatar
Easy simple cheap mod:https://www.fitfreak.net/forums/fit-...gas-pedal.html
this does wonders to the feeling, perhaps i would choose a slightly stiffer spring than whan Polaski suggests...
Old Apr 5, 2011 | 10:10 AM
  #1290
Texas Coyote's Avatar
The spring fix is wonderful.. About the glare from the dash, it can be dealt with by getting a velour dash cover. I got one from J.C. Whitney for around $30.00 and it solves the problem.
Old Apr 5, 2011 | 10:36 AM
  #1291
ThEvil0nE's Avatar
UltraGauge will soon have that feature
Old Apr 5, 2011 | 11:22 AM
  #1292
Thanks for the link. I'm definitely getting one and giving my scan gauge to my son for his Ridgeline.
Old Apr 5, 2011 | 11:44 AM
  #1293
Black3sr's Avatar
my spring fix
Old Apr 5, 2011 | 12:32 PM
  #1294
Krimson_Cardnal's Avatar
UltraGauge does have that feature. On the Fit it will return 50 gauges, least on my 2010. A nice unit that will show six gauges at a time on three selectable displays. That's a total of 18 you chose out of the total 50. Gonna start an UltraGauge thread soon and list them out for everyone.
Old Apr 5, 2011 | 01:05 PM
  #1295
ThEvil0nE's Avatar
oh, so they do have the coolant temp update... sweet!
Old Apr 5, 2011 | 01:10 PM
  #1296
fitchet's Avatar
I have to add a developed dislike about my Fit.
Not a deal breaker type of problem, but I have the reported and notorious "Squeak" when it shifts into park and the doors unlock.
It's intermittent, but I think getting worse. At this point? I'm stuck where I don't think it happens consistently enough to push for warranty repair...but I'm afraid it is happening more often...
Old Apr 5, 2011 | 02:17 PM
  #1297
Subie's Avatar
Thumbs up
Awesome. Definitely will check this out. Thanks for the link... BTW how's the brightness of the display? Is it adjustable? Thanks again
Old Apr 5, 2011 | 03:08 PM
  #1298
Display is light sensitive and controllable. No problem at all.
Just stared a new thread: https://www.fitfreak.net/forums/gene...on-thread.html
Bring it all there, thanks.
Old Apr 6, 2011 | 05:53 PM
  #1299
meestersteph's Avatar
I don't know if I've said this before, but the paint sucks. Honda paint is so thin
Old Apr 6, 2011 | 06:17 PM
  #1300
i really love the Fit, and the handling is amazing! but damn...
...i don't get it, everytime i get out of the car there's a smell of burnt rubber
