New Project..
Old Dec 4, 2012 | 09:54 PM
  #241
DiamondStarMonsters's Avatar
Gauges arrived, these things are sharp and brilliant modular wiring. Would Recommend ISSPro to anyone looking for gauges and I have a contact for them if interested:
Diving in head first we grabbed a bunch of the DOT Push to Lock hardware, will report back on experience after install and again after running them, seems promising:
Old Dec 5, 2012 | 03:28 PM
  #242
Starting to get the gauges in:
Remote Oil cooler mounted, should allow for two full-size rad fans and a 7" fan on the oil cooler
Old Dec 5, 2012 | 05:14 PM
  #243
Making a Vent-Delete to mount the rest:
Old Dec 5, 2012 | 11:18 PM
  #244
Revisions made to the Trans Shield
Old Dec 6, 2012 | 09:49 PM
  #245
180* Shield finished, provisioned for a full 360* when required by certain sanctioning bodies
Waiting on one more gauge (ignore the silver bezel pyro), not the final order they will be in but basically how the console will look when done and then the wideband will be under the switch panel next to the turbo timer and electronic boost controller
Old Dec 12, 2012 | 02:14 PM
  #246
Street wheels arrived today:
16x8 with 4.5 BS Cragars.
Billet Center caps and Hankook Ventus RS3's in 225/50 coming this afternoon!
Going to be running these at the Chicago Half-Mile shootout in June!
Old Dec 12, 2012 | 08:52 PM
  #247
center caps due tomorrow.. but the tires made it:
Old Dec 13, 2012 | 06:30 AM
  #248
Texas Coyote's Avatar
You be bad boy...It's looking great.
Old Dec 13, 2012 | 01:43 PM
  #249
haha thanks Dee
Can't wait to get it rolling. Deciding on parachutes now.. stuck between stroud and simpson.
At this rate should be heading towards the dyno in 4-6 weeks.
We're left with working on the coolant system, meth system, and the electric is almost done. Powertrain and drive train work is done for now, brakes are done. Sensors and meth nozzles left after that.
Then first fire and base tune and off to the rollers!
Old Dec 13, 2012 | 03:05 PM
  #250
Caps, lugs and such.
Old Dec 13, 2012 | 03:16 PM
  #251
vinnymac's Avatar
'' Very exhilarating! ''
Old Dec 13, 2012 | 05:10 PM
  #252
Hey vinny where you been?
Think this should be enough cooling.. two 14" SPAL fans on the radiator and a 7" on the remote oil cooler
Old Dec 13, 2012 | 10:37 PM
  #253
Caps and open ended lugs
Old Dec 13, 2012 | 11:51 PM
  #254
vinnymac's Avatar
.....I'm still peeking in on ya' bro... Haven't seen this thread in a while and almost lost it in my pants when I looked at it today...Lol!
Old Dec 14, 2012 | 04:05 PM
  #255
lol nice
Converting all the fluid fittings in the car to push lock or AN
Thermostat housing, waterpump and radiator all having -16AN fittings welded on.
This is the water pipe being modified to clear the trans shield, shifter cables and the soon to be 5" turbo inlet pipe
Old Dec 14, 2012 | 04:11 PM
  #256
TPColgett's Avatar
Maybe its my perverse sense of humor, but I love seeing Cragar's on an import LOL I hope you like those RS3's! I actually managed to over heat one of mine recently at an AutoX...
Old Dec 14, 2012 | 04:27 PM
  #257
I remember you telling me that when we last had a text exchange, but I won't be in need of lateral grip (I hope!) this was more for the street duty the car will see and for pavement runs if I ever need to brake. The slight water channels are a plus as well.
They are also speed rated for 168 according to DOT but the bodies I will be running under allow them to 200+ on pavement
Send me a follow up when you get a chance at either PM or email on that potential project you mentioned. I would also be curious to hear your thoughts/see some data on the most recent tune revision if you decided to flash over to it yet.
Old Dec 14, 2012 | 04:31 PM
  #258
TPColgett's Avatar
EMail with logs incoming >_<
Old Dec 16, 2012 | 06:05 PM
  #259
SilverBullet's Avatar
Looking good Chris. How long before start up?
Old Dec 18, 2012 | 11:40 AM
  #260
Hey SB, hows it goin?
I'm hoping 4-5 weeks! A bit over budget so dyno time may have to come a bit later in the spring.
Radiator hoses are being done with -16 AN fittings for peace of mind
