High Mileage Fits
Old Apr 7, 2014 | 01:11 AM
  #201
Scholzpdx's Avatar
Originally Posted by gmanfit
2008-auto fit sport--
just oil, trans, and routine services--
158k
What do you mean by trans? I've got one at 143k and I hope I don't have to ever do a trans replacement.
Old Apr 7, 2014 | 02:13 AM
  #202
ikutoisahobo's Avatar
He probably means a service....I hope.
Old Apr 9, 2014 | 08:18 PM
  #203
gmanfit's Avatar
Smile
lol-- just trans fluid--
Old Apr 9, 2014 | 08:58 PM
  #204
GinoLicious's Avatar
I just did an oil change with mobile 1 synthetic. I have 154,xxxkm on her. In the next few weeks I will be wiring up my fog lights, replacing rotors and pads and rear shoes, coolant flush (just need to figure out how to the bleed the engine) closer to June I will be doing a valve adjustment. Had this car original owner since 2007 bought brand new. Use to be dealer serviced now it's DIY service lol. I did a MTF change in Feb. It was long over due and needed. Threw GM synchromesh in there, love life. Huge difference.
Old Apr 10, 2014 | 01:29 AM
  #205
makufit's Avatar
So when u did the tranny fluid drain/fill and didn't use OE fluid, did you notice any problems?
Old Apr 10, 2014 | 03:17 AM
  #206
MTLian's Avatar
The more you talk about it, the more I want to throw in some Amsoil Synchromesh. I've read rave reviews. My shifter is rather hard to get into 1st gear.
Old Apr 10, 2014 | 08:17 AM
  #207
No issues with the GM synchromesh. GM makes really good MTF. I do recommend it. Go to the GM dealer as buy two bottles of it. It'll cost you $20-$30. My reverse has never been this smooth. Right when I did the change everything was like butter. I've now driven at least 5-10k on this fluid and it still holds up similar to the way it was right when I did the change. I highly recommend it. If you are curious try it. There is no harm that it can do. I you don't like it can always switch it. I know in June to August I will be changing again. Or may wait till Oct/Nov so I don't have to change the fluid in bloody cold February. That was nasty this year. Same with the blown battery issue I had to swap in -40 lol
Old Apr 10, 2014 | 10:50 AM
  #208
MTLian's Avatar
Why are going to change your trans fluid again in oct if you just changed it?
Old Apr 10, 2014 | 11:05 AM
  #209
I drive a lot. And the reason for oct is that it'll be right before winter and I won't have to change the fluid in winter. This winter was a pain.
Old Apr 10, 2014 | 04:14 PM
  #210
Turbo McNasty's Avatar
'08 Fit Sport MT
105k + still going...and going...and going...
(running like a champ)
im going for 500k mark on this baby....
wish me luck.
Old Apr 10, 2014 | 10:48 PM
  #211
MTLian's Avatar
Isn't manual trans fluid good for 50k miles!?
Old Apr 11, 2014 | 02:16 AM
  #212
konig_feather's Avatar
2008 SSM 5-Spd Base 198K...
Old Apr 15, 2014 | 04:00 PM
  #213
kwb's Avatar
kwb
We have an '07 base auto. It's at~183k, it hasn't held up as well as I'd hoped, but we're also rough on our cars. That said, we do love it!
* We had the interior carpet warranty-replaced when it came up by the feet... has kept happening, I just reglue now.
* our calipers stuck during a 5,000 mile road trips, so we got new pads, rotors, and I cleaned/re-lubricated the calipers and haven't had a problem since.
* Our drivers side door lock cylinder is seized up, I found it easier to just install a key-less entry kit then repair that.
* If the radio gets hot, it won't turn on sometimes.
* We had some door seals fail and the interior flooded a little (our driveway has a good slope so it pooled in the back seat and tire-well). New rear gate seal seemed to resolve that problem.
Right now I'm tracking down a fuel issue, our economy is 25-28 mpg and my ScanGauge has us running lean to very-lean most of the time. I don't think there is a vacuum leak...
Old Apr 15, 2014 | 05:22 PM
  #214
Wow, KWB. You've had a lot of bad luck with her.
Lemon maybe? Don't sound like regular wear and tear problems to me.
Old Apr 15, 2014 | 08:01 PM
  #215
kwb's Avatar
kwb
Maybe, we beat the hell out of the car though. I think we cleared the warranty period before 18 months. We've moved cross country 3 times in it, each time I'm sure we cramed way too much into it. We live coastal, and for a 3-yr period in a marina, so lots of salt spray and intense sun... who knows. I'm not sure another car could put up with our abuse though
Old Apr 20, 2014 | 11:50 PM
  #216
Paulo107's Avatar
Thumbs up
160xxx and still going. Runs smooth as hell
Old Apr 21, 2014 | 01:24 AM
  #217
116.9k miles. No problems, only coil packs.
Old May 5, 2014 | 10:27 PM
  #218
junior40er's Avatar
205,000 miles here
Old May 5, 2014 | 10:33 PM
  #219
Fit's keep looking clean even after so many miles! I've also noticed the headlights are more resistant to hazing than other cars. 117k on mine and no haze.
Old May 6, 2014 | 02:16 AM
  #220
dtinyfit's Avatar
I have a 2008 Honda Fit Sport. Black Betty has 156k miles on her! The only things I've had issues with so far is the ignition coils. I learned the hard way you must use genuine Honda parts for those! Don't buy the ones from a parts store, they will not work for long! I love my fit!
Get in where ya FiT in!
