- honda civic tune up trouble
- How do I remove pully bolt to get to timing belt ('99 Accord???
- Back to '04 V6 Accord Ping - Or, Why I do the work myself
- 92 Integra Idler problem FIXED
- gasket sealer type to use?
- how to get bolt out from civic alternator?
- FS: 95 Accord hood--gold color--$50
- 98 accord V6 intake port question
- 1995 prelude 2.2 vetec high rpm about 4000 grand
- I need help decoding 1998 CRV speaker wiring
- 96 Honda Accord electrical and speaker problem...please help!
- Civic Hood Insulation
- 1990 honda civic
- accord keys
- VCM worth the wait?
- clutch master & slave cylinder replacement notes (94 Civic EX)
- Hybrid Cars
- Civic Door door won't open
- 2006 Hondas
- Can an older Hybrid run without its battery after it dies?
- 94 civic ODBI or ODBII?
- Re: 88 civic SI burning oil at acceleration...
- Re: auto paint touch up kit
- Still white steam after head gasket replaced?
- civic acceleration question
- 99 Civic starting issue
- potential speed sensor issue
- 6-Disc CD Changer in Dash & MP3 Special Edition
- Accord 2000 - Question on Brakes wear
- sorry I meant filter not pump I just realized that I typed pump
- 1990 Prelude 2.0 Si where is the fuel pump?
- TeGGeR's appraisal: TeGGeR makes a boo-boo
- 2005 Honda Insight
- The new 2005 Honda Odyssey
- "Rattling" sound in '97 Honda Civic...
- Navigator DVD Update
- headgasket? repair or not?
- Renovating Hondas for Income & Fun
- Civic Horn
- humming noise or grinding noise
- 91 Civic Will Not Start
- 94 Civic Lx Intermittent no start
- 2004 Accord airbag/seatbelt issue
- PorscheStoriche
- 2005 Accord Road Noise
- 95 honda Odyssey starts and cuts off when I let go of the key
- radio
- 99 passport>>> dash board lights!
- ecu transfer
- T-rated vs. H-rated tires of 97 accord (Goodyear Assurance Comfortred - bad ride)
- 04 Accord V6 light sustained ping on acceleration
- 88 Accord DX auto: How to replace manifold coolant hose
- Speed Sensor Location on 94 Accord VTEC?
- FA: New JL Audio Free Air Subs Rare Discontinued
- "Piston slap" / diesel sound in '94 Accord
- poor fuel economy
- 96 Honda Accord "chrome" plastic handle
- 2004 Accord 2dr- Window Tints Bubbles
- 1992 honda gets code 41
- 2005 Honda Accord Hybrid
- Anybody ever have their tach and speedo stop working?
- Unofficial FAQ: online seller list
- 97 Radiator boil over, general rant
- Front Quarter Panel Replacement (1999 Civic)
- how can I tell if 1.5L spark is weak?
- Check engine light.. Code: P1362
- Restart stalling on '99 Accord ULEV-4
- Civic 03 Driver Door Lock
- DIY Oil change-Filter removal
- Surprising Insurance Appraisal on a 6 yr old Civic
- License plate light
- 96 Honda Accord
- How to fix a nitrogen oxide problem?
- new idea....
- K&N airfilter 4sale
- Flaring
- Unofficial FAQ igniter updates...
- 97 Accord "Buzzing"
- 1997 "Honda Tap"?
- Honda Fit/Jazz - Is there a way to get Honda's attention?
- Honda Engine Makes Rattle at 30mph?
- 1994 Accord Heater Control Lights
- TeGGeR's appraisal!
- Midas vs Speedy
- Honda FIT at Import Shows !
- Uk honda Civic 1.8VTI (98 model)
- Thinking about buying an Oddessy
- Heater takes a while to get hot.
- Re: 88 civic si exhaust pipe cracked...
- How much to pay for a used Del Sol Si
- Does fan should running all the time?
- HRV Rear Speaker Access
- Small dent and getting it out??
- honda stalls on take off
- Loose rear view mirror- 1990 Accord
- purchasing 2003 EX Civic.. Help!
- where to search for recent price-paid for a new accord?
- Thanks for the FAQ Brake Master Cylinder replacement
- Anyone need '83 Prelude factory service manual
- '91 Civic HB Antenna -- HELP!!!
- 1997 CRV
- STRUTS
- Factory pressed dvd movies, ps2 & xbox backups for sale
- SRS Light..
- Need Hubcaps 1990 Accord
- vibration - low idle speed...
- Changing oil on a '94 Accord LX
- timing belt parts kit
- Rattling noise
- Which Gasoline Grade is Best for Honda Hybrid 2005?
- 97 Civic front brake lockup problems...
- Honda Pilot VTM
- 2005 honda accord running a little rough
- Anyone need a '94 Integra factory service manual
- A/C pipe leaking freon
- Rear Alignment in '91 Civic?
- Idle speed dips after letting off gas - 92 civic d15b7
- Honda prelude vtec main relay
- Brakes Bigger rotors or just slotted and or cross drilled?
- A Good Honda Mechanic (GTA Only)
- New Honda antifreeze formulation?
- Odyssey Transaxle Fill Plug?
- vibration on acceleration, 90 accord
- DRL 95 Honda Accord EX
- Tires on a 2003 Accord
- After market Stereo for 2001 Odyssey - recos?
- OEM speakers for my 1998 Honda Civic DX HB: question for remplacement
- 2003 civic ex
- Need Body Part Name for '97 Civic
- Brake question for TeGGeR
- Brake Question for TeGGeR
- Sirius SIR-PNR1 and Honda Civic 2001 installation
- Windshield rock damage
- How do you replace headlight bulb in Honda US Wagon
- Transmission Gone Bad --Sell or Fix
- Odyssey 2000-2001 questions
- Reflex wipers on an 05 Accord?
- wont run uphill
- '88 Accord spark plug gap
- 2000 I-4 Accord: Jerky shift
- Cup holder--$75????
- 1990 Accord LX, manual transmission
- Looking at buying a 94 Prelude. looking for any info????
- 93 prelude main relay problem
- Onboard diagnosis interface - reading ECU data?
- 95 Accord cooling fan fuse blows
- Vibrating Honda
- A Blog About Making Money With Your Hobby
- Loose caliper on Integra?
- 1993 Honda prelude vtec
- 95 Accord AC problems - NEED ADVICE!
- Do It Yourself Distributor Change
- Question on "Maint Reqd" light
- Replacement Battery '92 Accord Question
- Honda Civic EX vs Mazda3 S
- A new milestone!
- TIP: Ignition switch replacement (smoking)
- honda passport AT fluid
- HRV Wing Mirror
- '02 Civic with cracked manifold
- diagnosis/cost: 98 accord lx hesitates @ startup
- 93 Accord - AT tight when in PARK
- injector on/off ratio display
- Vancouver Area - Acura Club ideas
- repair shop recommendations near Palm Beach Gardens, FL
- rear weel area griding noise when turning
- Muffler pipe ? ('97 Honda Civic DX)
- A/C 94 Civic
- 2005 Accord EX - nose mask
- Insurance problem with Japan Prelude SI VTEC 1992
- 1994 Accord A/C pretty useless
- 99 Civic LX won't start (sometimes)
- Unofficial FAQ: Brake Master Cylinder update
- Civic Check Engine Light - Code P1336
- shift stick drivers
- 94 Accord AT going bad?
- Filetoad.com Latest Software Virus and spyware
- Hood supposed to be insulated?
- 2000 Honda Civic EX-G (Canadian Model) Exhaust issues **Need Help**
- FS 1990 Honda CRX HF (DFW)
- converting refrigerant, 1990 Honda Accord
- Re: Big Bertha Thing blogs
- Re: bicycle rack for Insight? anyone?
- Anybody had the Civic ('97) bumper off?
- Looking for advice about service for Accord
- 94 Integra burst A/C suction hose question
- Tegger: Did you do your clutch yet?
- 91 Civic corrosion of rotor button
- What are the best model years to purchase used Honda Accords?
- Integra-95 Demister
- Engine light keeps comming on
- Honda Accord Bumpers
- buy and sell your autos by posting free! www.why2buy.com
- Noise-suppressing carpets for Honda Element?
- Civic AC weak?
- Honda Elite-problems
- Honda CR-V 2003: can the 12 volt outlet be 'always on'?
- BUY AND SELL YOUR HONDAS! www.why2buy.com.. just check it out
- 2000 Odyssey trailer hitch bolt size?
- 98 civic check engine light
- Civic GX
- 1991 Civic Stalls
- 97 accord srs light on
- 1998 Honda Accord Coupe
- 2004 CR-V "first oil change" technical bulletin?
- Unofficial FAQ: Ignition corrections
- Oil in spark plugs
- Los Angeles Mechanic
- 2005 Honda Accord Coupe EX V6 Demo Price?
- 1990 Accord Distributor
- NY Go Kart Endurance Racing - Arrive & Drive - 6/17/05
- where to get 04 honda pilot aftermarket side bars and front bars
- CRV radio audio input
- Dealer recommended me to change brake pads, charging $220, what to do?
- www.fantasyshop.com.au
- 93 Honda Civic Engine Longevity
- Buy and sell honda parts, free exposure for your honda item www.why2buy.com
- 2005 Accord 12 Volt Accessory Socket
- 93 Honda Accord Ex , 2 door
- dedTUNIA: Gegen kreisrunden Haarausfall - Against circular loss of hair - Contre Alopécie Areata
- Alignment Problem 95 Integra
- Adjusting headlight aim on 94-97 accord
- Can anyone comment on 2005 Accord EX V6 Navigation system?
- Soft brake persists after Brake Fluid Flush.
- Toyota to raise prices out of consideration for U.S. car makers
- 95 Civic - Clutch?
- '93 Honda Accord with some problems
- 5w50 synthetic instead of 5w20
- Test Message
- Bad vibration at idle when AC compressor kicks in
- 05 odyssey navigation doesn't load
- AT has better MPG than MT?
- 2005 Civic Hybrid -- A/C problem?
- 94 Civic spark plugs: type and socket size
- Gear shift lock out
- handaaccessories.com
- ok, what's with this?
- Full size SUV?
- Honda Jazz UK CVT holding on hills
- Rain leak, CR-V, 2001
- honda accord LX 2005 MP3 Player
- DIY Hatch Glass
- Re: Any recommendation for aftermarket headlamp bulbs for 94-97 Accord
- Replacing Master-Cylinder twice
- Re: How long do aftermarket struts tend to last (Sensatrac)? (harsh ride on 97 Accord)
- 1990 Accord
- Anyone install Goodyear Assurance Comfortred tires?
- 94-97 Accord - How long do front springs usually last?
- 96 Civic DX, steering becomes too soft
- Ignition Timing Question
- 96 Civic passenger side water leakage, A/C
- civic timing belt adj bolt?
- replacement tape deck for 88 honda civic
- 05-Accord - Questions
- Re: 200 My 1 Accord EX leather seat problem
- Honda Accord depr & trade ?
- Immobilizer Theft-Deterrent in Honda Civic Ex 2000
- best stuff for removing stains in auto carpeting? (ink, taco sauce etc.)
- Ladder rack?
- Key Remote programming
- Problem Entering & Exiting 2005 Accord EX
- 90 Civic main relay replacement, how to release connector ?
- ABS Warning light
- New! The Unofficial FAQ is now searchable!
- Does anyone have wiring diagram for Civic 93 EG si model ?
- 2000 Accord Brakes - Ceramic Pads?
- Honda Odyssey DVD Player
- '05 Civic EX: Looking for no drill Type I receiver hitch
- '05 Civic EX: Transmission slips from 3rd to 4th sometimes
- fuel pump noise 1994 Integra
- Fuel Filter location of Civic 89
- HELP- Changing Headlight
- Belt-like squeak when clutch is out
- Shock absorber bushing
- Can't get the %$#@! license plate off
- 96 Civic No Start
- * * * Please Read And/Or Print This! * * * Press [Ctrl][P] Keys On Your Keyboard To Print >> June 1, 2004 9:31:37 pm >> http://115639.aceboard.net/forum2.php?rub=158&cat=61&login=115639&page=0#id96 << * * * * * * * * *
- Sound dampening can cause rust?
- FS: Tokico front struts for '88 Accord
- Leak Near Rear Window - 2003 Accord
- DIGITAL CLOCK HONDA ACCORD LX EX DX SE 94 95 96 97
- (Recommendations) Ones I found useful: Consumer Rights Trouble, 2005 car reviews & Car Safety Seats Guide. [w12332]
- 2005 TL vs 2005 Accord
- Color Opinions
- 91 Accord Fuel Filter question
- 2001 civic autotransmission - hesitation
- Power Window Switch
- Civic Type R fuel economy?
- Examples of Gender Bias in Car Sales
- 2003 Honda accord Head unit display
- Accord vs. Camry ?
- 94 Civic: exhaust system replacement
- CR-V SatNav DVD backup
- replacing single rear brake caliper?
- 2003 Accord Radio Display Problem
- 87 Accord alternator part 2
- 1992 Honda Civic VSS(?) problem
- Need Help for a 93 Accord 10th Anniv. Edition
- 99 Honda Odyssey Radio - Anti Theft
- Strange noise behind my 1997 Acura CL 2.2
- Header Ciivic 1.5L ?
- Honda Element right door lock: unsafe?
- how much labour to change distributor - 93 accord
- 2003 Accord EX-V6 stereo backlight is out
- Re: Re: 1989 Sterling 827SL Ignition output problem one spark on
- I need help: 1998 Honda Civic 4 door LX
- 95 civic suspension upgrade
- looking for a car?
- 2000 Civic w/Leaky Moonroof
- You want can be found! Perhaps
- '91 Accord won't start when wet
- NY Go Kart Racing - This Saturday - Arrive & Drive!!
- FS: 2004 Honda Civic EX 5 spd with side airbags in Virginia
- Honda Civic 01 Alternator change at 58K
- Honda Element Full Back Cargo Mat with a logo!
- 1991 Accord Balance Shafts Belt Tensioner
- Best game ever
- '93 Accord transmission problem.
- Rear light stuck on 92 Accord
- HELP! 99 Honda Accord dashboard backlight is out!
- 1999 Odyssey water under carpet...
- 2000 Accord EX-V6 Wipers
- 97 Prelude Value?
- Ignition updates to the Unofficial FAQ
- 1987 CRX questions
- 1990 Honda Civic Wagon
- How Dare Could America Industrial Property Office Be In Conspiracy With Jungang International Patent Office To Make An Extravagant International Crime ?
- '90 Civic Driveability Issue
- Honda vs Toyota ??
- How to take ball joint out of Knuckle
- How to Clean Heater Core? - 93 Civic
- change in car acceleration Honda Accord
- Civic - Honda service or mechanic?
- bleeding order for 2000 Accord
- Pics of my Civic
- Pics of my Civic - corrected
- What year did the Civic have fuel injection?
- Civic 2002 LX (Canadian Model)
- Brake Specs: 99 Civic LX
- 95 Civic 1.5L how to do head gasket?
- 94 Civic 1.5L 5 speed LX head gasket 170k miles?
- 93 Honda Civic Needs Repairs 234,000 miles
- 93 civic cx transmission
- check engine light 1990 honda civic wagon 2wd
- Odyssey Sunroof - how to adjust/lube/service?
- Re: In Van. BC where to buy door window?
- e.g.r. valve maintenance
- Ran car with no steering fluids now leaks. `89 lxi Accord Honda
- Question re: Platium Spark Plugs
- 87 Accord oil burning when cold.
- Honda CR-V brake failure
- What is wrong with Civic 2001 front suspension?
- 13" vs 14" wheels on 94 Civic - best MPG?
- Testing alternator.
- 95 civic master cylinder replacement
- 91 Civic: Seat belt alarm
- NGK spark plug update
- Converting Rear Drums to Discs on an EG Honda Civic
- 2001 Accord LX-V6 - rough idle
- 2003 Accord Radio dead
- Some good sites for Civic owners?
- auto tranny 93 civic cx
- 2000 Civic P0135 heated HO2S
- 1993 Accord Wagon - brake job mess
- Spark Plug Hex Nut Disintegrated
- Tachometer doesn´t work on Civic 2000
- Radiator drain cock - how tight
- Honda Element improper oil change?
- 94 civic transmision failure
- Brake fluid leak from Brake line
- 92 Honda Civic No Crank
- Setting the clock in a 2004 Civic stock radio
- 98 Civic Windshield Difference?
- Re: 88-91 honda civic 2dr- are driver side door windows identical for these years? I need to replace my '88. thanks, eom.
- fyi- cool deal
- 1992 Honda Accord EX 2.2 L pinging Does this car have knock sensor
- Radiator Cap
- Honda/Accura model similarities
- New Timing Belt at 360K Miles?
- 2000 Honda Accord EGR valve
- Leak in Master Cylinder
- Honda Pilot ok in sand?
- 91 Accord - "Change oil" indicator is on but....
- computer codes
- Re: computer codes
- Civic release date
- 91 Civic Problems
- Weak radio solution
- 92 Civic radiator fan doesn't work
- Re: 92 Civic radiator fan doesn't work
- Installation of struts/shocks
- Wiring pinout for ELD,
- Click sound from wheels, Integra
- Crankshaft pulley turns but not cam
- NY Go Kart Endurance Racing - www.OVRP.com
- Jesus said, "I am the way, the truth and the life: no one can come to the Father(God)(in Heaven), but by me." (John 14:6) This means that if you die without trusting in Jesus Christ as your Lord and Saviour you will die in your sins and be
- Re: Integra 91 A/C
- WTB: carb for Prelude
- Brand New Ball Joints
- Homelink
- Duct Cleaning
- 94 Civic vibrates at low RPM
- suggestions to buy accord
- Timing belt inspection, 90 Acura Integra
- Stolen side view mirror on Honda Civic '97
- 05 Accord Pictures
- changing a tail light (Prelude '01)
- static electricity shock when exiting car (97 Accord) - anti-static straps?
- How to check whether timing belt slipped on 88 Accord
- 98 Accord LX hesitates after starting
- Are new Hondas maintenance free?
- When to top off oil
- Thoughts on Cooper Tires Please
- 1987 Civic with d13_a2 1.3L
- Civic Website
- 1994 Honda Civic- Ignition lock
- CRV driveshaft replacement
- Seized Bolts to Anticipate?
- slight vibrations from everywhere in 05 accord
- 99 Accord ignition recall disaster
- Life saving driving tips
- '90 Civic Rear Suspension Clunk
- Alldata 2004, [4 DVDs], [53 CDs], Mitchell CDs, year 2005 - 2003 , 53 CDs, total 107 CDs
- Req: Link for brake service routine 2001 Civic
- battery corrosion on 95 Civic
- 05 Accord - Tires?
- Modine radiator for 91 civic std hatchback -- CANT FIND ANYWHERE
- 05 Accord 4 cyl Engine Break-in?
- Set of Neuspeed Racing Springs for 96-00 Civic
- Honda Civic - D16A2 Engine
- Question for electronics experts...
- Transmission
- Door lock making noise
- 05 Accord Hybrid engine light blinks, no code
- New to Hondas, got a few questions
- Newbie here...Honda civic 1998..help needed
- Is the D4 light on a 1998 Honda Civic supposed to be illuminated while driving?
- 95 Civic overheats when not moving
- 1990 Acura Legend Jack Points
- Re: 89 Hond Prelude Service Manuals on CD
- Honda Legend Workshop manual 4 sale
- 86 Legend workshop manual 4 sale
- 92 accord - front drivers side rattle and shake
- Water pump selant required beside rubber gasket?
- intermittent start
- 2 Honda Civics FS in North Central Iowa
- Subject: Looking for more information.
- Noisy Sunroof
- '99 Accord Blinking Oil Light -- sanity check
- Last rites declaration of Ioannes Paulus PP. II (Karol Wojtyla)
- Unknown switch assembly.
- 96 Accord front rotors badly warped
- 1998 Civic LX Wipers Don't Work
- Honda Civic 1.5 Lx
- Transmission Oil Smell
- Low idle knocking
- Spark Plugs Vibrating -- Valves?
- Windshield Wiper Hell
- 91 Civic muffler
- 2002 CRV and MAINT REQUIRED LIGHT
- '94 Civic EX MSD Install question...
- '05 Accord EX - Poor FM reception
- 92 civic 1.5 dist. seal
- anyone know where to get cheap factory honda pilot foglights in toronto
- 2000 HONDA CIVIC QUESTION
- Honda EX --- mp3?
- 93 Honda Civic
- CV Boot
- Vibration at Idle
- PCV Valve
- Changing Timing belt
- Ugly MPG surprises after tire / wheel upgrades?
- How to replace wiper squeegees?
- Re: 88 PGMFI accessing PCV tube at crankcase?
- 94 accord High idle when driving, low idle when stopped.
- Finding TDC on 94 accord
- Where to get electrical power on Civic Hybrid?
- "Real time" fuel consumption measurement
- OE steel wheel weight for Accords?
- Max velocity for 2001 Accord EX coupe
- Set the clock?
- 93 Honda Civic
- reasons for overheating
- Anyone here do their own 15K & 30K scheduled maintenance?
- ticking from AC fan in Civic
- 19997 Accord EX timing belt woes
- Accord Hybrid Air Conditioning Question
- Re: Smell gas--'05 Civic
- sorry, but i gotta spam y'all
- Calipers
- how to check the water pump
- PCV valve location for D16y7
- OE Tires: Load index and safety?
- Should I fix my Lude?
