- Steering Wheel Controls Addon w/ aftermarket radio
- Device to make sure car is locked
- 2007 Fit Sport - Wiring Questions
- Help finding the right wiring harness
- 2006 door speaker replacement (front & rear)
- Enlarged Speaker holes?
- 2007 Fit Remote Start Issue
- Weird lock issue w/ electronic system!
- 2007 Fit Base Model Audio System: How does this look?
- Trying to upgrade my audio for the first time (budget buld)
- Does the 2020 Honda Fit Sport HU have a sub output?
- 2013 Fit (UK model) replacement touchscreen?
- Turn on backup camera while driving
- Alternator ECU Bypass Charging System / Battery Sensor
- SiriusXM Bluetooth Dock Now Available
- 2010 Sport Kenwood Install
- I finished my weekend install for a compact audio upgrade and gave it a review.
- GD3 - 5.25" Speakers in Doors with Little to No Modification?
- SiriusXM Installation '09 Fit
- A Tailgate Subwoofer in a GD3?
- 2018 - Flash Drive folder structure/file naming...
- Dual Amp Wiring Help
- Audio Formats Explained
- Stock crossover and radio questions (2)
- Anyone with a powered sub?
- WAGO Wire Connectors
- Pioneer mvh-1400nex Reverse camera help
- Anyone ever use this grommet as a passthrough?
- Aftermarket Head Unit Help
- Best Aftermarket Battery?
- GE Dash cluster disassembly
- GE Radio disassembly
- Alpine Halo 9 installed look and fit
- Problem with radio after installing Aux audio
- Opinions On Adding "underseat" Subwoofer + 3 Way Speakers
- Steering radio controls, aftermarket system ?
- Apple CarPlay
- The never ending quest for more speakers!!!
- Crux HDMI bypass boards
- Fit 2013 (GP1) audio player/head unit upgrade
- Neg/Pos wiring no difference, help please
- Adding Aux to 07 Fit
- Aftermarket Radio and Keyless Entry
- radio swap 2016 fit Lx vs radio from ex
- 2016 Honda Fit Stereo Issues/Voice Recognition
- 2009 sport nav most recent firmware version. cpu/ram upgrade
- need someone in So Cal to install my speakers
- Anyone do a big system in their fit?
- Speaker fuzziness help
- Bluetooth wiring help
- Girl noobie
- Do you want Android in your 1st, 2nd, 3rd gen without changing deck? I may have your
- Can any Honda techs assist?
- 2008 CD player says a disk is in the system when it isn't
- 15' Audio Upgrades
- MP3/WMA player that plugs into CD changer socket - UPDATE
- Replace antenna and/or new nav unit (2007 jazz)
- Put sport Radio into base
- Pin-out diagram
- For those of you hoping that CarPlay would be coming to older models...
- '10 base -- 6-speaker stereo?
- External DAB Antenna
- Power Windows Issues
- Google just released an app for those that don't have Android Auto...
- usa spec bt45-hon3 for Bluetooth
- Double Din or Single Din ?
- GD3 LED door sill plates
- If you need more bass up front, I found a space saving solution
- Immobilizer bypass help
- stereo dash kit pocket part number?
- Audio Upgrade 2007 - 2008
- Installing new head unit in 07 Base
- Installing aftermarket HU.. wiring harness ??
- For those still on the fence on whether to get XM...
- Best $150 head unit for 1st gen Fit
- Get the top SiriusXM Radio 1/2 off/ free ground shipping
- Stock Honda Gd Keyless system + aftermarket PTS system
- 2nd gen replace cd player with nav system
- Where did you install alone XM radio?
- Rear speaker test
- Polk DB651 vs DB651S
- Installing New Components in GE8 Sport - No Signal/Sound
- Current Opinions: Metra vs Scosche
- Stock Auxiliary Line Question
- Replacing factory stereo jazz 2004
- Bluetooth adapter for my new Fit Sport 2013
- Stock radio Nav with amp help !!!
- 2008 Fit Sport Stereo WIring Harness Question
- Help needed: Audio/CD unit replacement bulbs
- 2008 Fit Audio project
- Honda FIT hybrid 2010 GP1 AMI Cable for USB
- Remove A/C knobs during dashkit install?
- Australian 2005 Jazz double DIN
- Tablet Mounting
- '07 fit radio static while using cig lighter
- Replacing stock speakers
- Double DIN Installation?
- can u tell a difference when u upgraded to aftermarket
- Have Garmin? want to change the Vehical icon to a Honda fit? Here it is
- Looking for a DIY on a stereo install.
- How to fit your Scosche Kit properly, OMG IT FITS!
- Amp and Subwoofer Writeup 06 honda fit!!!
- FIT IPOD questions
