- Want to get lower..suggestions?
- Anyone have these yet?
- Zero Fighter Rear Center Brace Installation
- What supporting mods do I need when installing a coilovers?
- RS rear brakes
- Spoon springs vs swift
- Progress Sway bar Banging
- REV09 Coilovers
- Coilover gang..
- Eibach Pro Kit compatibility
- Cusco front lower arm bar
- HFP suspension compatibility
- RV6 Downpipe Discontinued
- Reccomend me a coilover.
- FREE GK5 Full suspension
- Unsure of how to adjust camber.
- 9th gen civic coilovers fits a fit?
- 2015 Honda Fit Rear Air Shock Absorbers/Front Lift
- Suspension Techniques X series coilovers for GK5?
- KYB 3430057 Rear shocks back in stock
- Towing with a fit
- beatrush c pillar bar fitment -
- Torque Specs Reference etc?
- New rear disc option?
- Gen3 owners who have installed rear sway bars
- Pads AND rotors or just pads?
- Cross country with a small trailer?
- Coilover install help
- Time for Coilovers/Lowering Springs! Advice?
- Hfp 2015
- 2015 Strut fitting.
- Fastbrakes 2015-2020 Rear Disc Conversion Kit
- BC racing coils.
- 2018 HFP suspension on 2016, Verified good!
- Eibach Pro springs
- Eibach Pro lowering springs on closeout.
- Megan Coilovers
- Want to purchase a pre-loaded strut for a 2015 Fit
- Considering Disc Brakes
- GK Fit DIY rear disk brake conversion
- Installing Koni STR.T what another parts should I replace? Bushings, bearings ect??
- Hardrace 'HD' Endlinks----FAIL
- Progress swaybay
- Coilover question
- Rear camber kit
- New owner of gk 2019 Fit
- Wheels, tires & lowering spring clearance
- About coil spring
- 2015 Thinking about suspension upgrades
- New Honda Fit Owner
- HFP Suspension
- Tein SAZ coilover for GK
- Coliover recommendations
- Truhart Shocks for GK5
- Camber Issues - not enough negative!
- Anyone use the Koni Orange STR 8750 1102L&R
- Lowering Springs on Stock Shocks/Struts
- NEW GK5 front A-Arms by Art of Speed Racing
- GK5 coilover suggestions, feedback
- Tein pillow ball mount for VSB80-C1AS2
- Good shocks to go with Swift springs
- Tein Flex Z
- Cusco vs Tein coilovers
- BC Coilovers Install Help
- Art of Speed Racing makes GK5 A-ARMS
- tanabe strut tower brace
- TANABE lowering springs
- Tein Flex Z coilovers clunk sound driver side on GK
- Rear Shock / Coilover Install Content - Rubber, Rear Damper Mounting (52725-SAA-G01)
- Eibach Pro Kit for GK5 installed
- 2018+ rear sway bar??
- Rigid Collars
- Megan Racing Rear Add-On Sway Bar for Honda Fit 2015+ / City 2014+ - MRS-HA-1293
- Coil overs
- Lightweight Brake Rotors and Drums
- TRU HART Struts and Shocks
- Swift 4H021 VS Swift 4H916
- Megan Racing Lower Arm Bar (MRS-HA-1291)
- Oem Alignment Specs
- HFP suspension
- Koni Orange STR.T And B&G Suspension Lowering Springs
- D2 Racing Springs - F Drop 1.5 / R Drop 1.5
- Rotors for GK
- Lift Kit for GK 2015 Jazz (Fit) - soem questions.
- Wilwood on GK5
- Brake drums held on only by lug nuts!
- EBC BSD850 Rotors & Akebono Pro-ACT (ACT1394) Brake Pads Installed
- ‘15 rear shocks
- 2018 HFP Shocks?
- Air Lift 1000 - Model 60901 Universal Air Spring Kit
- Hawk HPS fitment for GK
- Coilover Recommendations?
- H&R springs (settling uneven)
- I might be the first one have done it
- Sportlines on stock springs
- Eibach Pro-Kit Installed
- Torque Rod fill
- EBC Green Stuff brake pads(review)
- Beatrush Suspension Components
- Which struts would you pair with Tein springs?
- Any Good Aftermarket Shocks Yet?
- Urethane Bushing Kit for GK5?
- Did you install your GK springs?
- stop drop and roll out!
- Wilwood kit on GK5
- Eibach prokit
- upgrades do make car more fun to drive
- Lowering spring comparison?
- Having a problem after coilovers install
- Progress Rear Sway Bar
- Goodridge Stainless Steel Brake Lines
- Megan Racing front roll center adjuster
- Megan Racing Front Subframe brace
- Ground Control coilover sleeves
- Spring Replacement Guide?
- Ultra Racing Suspension Braces
- Megan Racing lower arm bar
- Megan Racing front sway bar (28mm)
- Jounce Springs
- This is why you MUST install Tanabe DF210 TDF185 lowering springs!!!
- Tanabe DF210 TDF185 lowering springs
- Videos of rear shim installation?
- Big brake kit
- Best coils
- Tanabe sustec strut tower bar
- KW Suspension Coilovers for GK5
- Progress sway bar group buy
- Spoon Sports Fit3 Suspension Parts
- ordered Swift springs
- Swift Springs for the GK5 - Review & Pics
- After market suspension questions
- Stainless Steel Brake Lines
- 2015 fit LX better than stock shocks
- Rim and Tire cleaner
- brake dust
- CALLLING ALL 3rd GEN FITS!!!!!!
- Tanabe Pro S-0C coilovers (GE8) fit on GK5s
- Swift Springs for the GK5, specs are out.
- Lightweight Front Rear Spring Shock Absorber Weight
- Eibach Pro-Kit for the GK5
- GE8 Coilovers on GK
- Swift Sport Springs for 2015 Fit coming soon
- anybody try Ark GT-F lowering springs ?
- BC Racing Coils Installed
- my gk5 lowered in Tanabe Springs
- BC Coils
- Just lowered my gk5 ex
- Koni STR.T Orange Shocks 8750-1102L, 8750-1102R, 8050-1131 do they work OK on a GK?
- Tein springs p/n
- ""feed back please"" honda fit superdown sus springs 2015
- Eibach Springs 4091.140
- Rear Disc Brakes for the GK
- The hardiness of ride....
- EX H&R Springs
- LX 6spd Lowered on D2's
- GK Camber Bolts
- Rear air shock absorber mod
- Buddyclub N+ Coilovers for GK Fit (BC02-NP15GK5)
- Coilovers for new fit
- Suspension question..
- Winter Tires
- suspension upgrades
- Sway Bars
- Help on How to lower an GK
- Tein Coilovers and Spring Kits
- H&R Springs
- Who has lowered their GK??
- Friend's 2015 LX lowered on Swift springs for GE! (2nd Gen Fit) - Pix + review
- !!!!! Finally my GK5 Lowered !!!!!
- Spring rate?
- Gk5 lowering springs
- lowering springs
- Lowering spring for GK5
- possible to frankenstein rear disc brakes???
- Coilovers, worth it?
