- Code 43 Fuel Delivery diagnosis
- EGR valve????
- why short the service check connector when setting timing?
- Jazz vs Hyundai Getz, Matrix and Kia Picanto
- is my 94 accord ex v-tec?
- 1996 Accord Lx V6 Engine RPM surging ?
- 1992 honda civic
- Car cover for 2005 Accord, which brand?
- Moonroof visor for new Accord? (any downsides?)
- 93 Honda Civic DX
- '93 delSol Rear Driver Quarter Panel Needed
- My Honda will not stay running/Help me
- shift stick problem
- Honda Accord (98-05) theft rates? - engine immobilizer
- Service manual for 2005 Accord (where to buy?)
- Accord alloy wheels - acid based wheel cleaners ok?
- 2005 Accord navigation system? (worth getting?)
- Finding the best rate for new car loan? (2005 Accord)
- Synthetic oil in new V6 accord? Is it worth it?
- Check engine light won't shut off
- Accord Diesel
- New radiator for my '94 Accord
- 90 Accord cruise control diagnostic
- Extended Warranty - Worth It????
- Independent Honda mechanics - Montreal?
- Dipstick for ZC?
- rear light stay on even turn off light and engine
- Why does Civic Hybrid have that Roof Antenna
- Cracked exhaust manifold aftermarket parts recommendations
- 98 Accord Alignment Problems
- New Si (06 production?)
- Battery light won't go out/Overheating
- question: timing belts adjustment
- Brake lamp light stays on
- AVOID Major Oil companies!
- Clearcoat cracking and peeling
- radio light question
- check engine light - evap
- RPM goes extremely high when in Neutral?
- Replace Alternator to fix SRS light problem? Did I get took by the dealer??
- no power - no lights nothing - just changed battery but NOTHING
- Re: overheat on 96 accord
- overheating problem 96 accord
- 90 Accord fan relay/motor
- What did timing belt job do to cause sputter?
- advice replacing worn rings pls...
- 1986 Accord - fuel pump relay problem - HELP!
- Latest mileage woes on the Civic Hybrid
- Re: Big Bertha Thing blogs
- Civic SRS light
- alternator needed
- 2002 v6 ex sedan front speaker door panel removal ?
- any advice for changing valve guide seals? 90 Civic Ex 1.6L 5spd
- 1997 Civic LX
- posting 20050826
- 91 accord doesn't start
- Shift indicator light burned out on 95 Civic
- honda (88) accord (dx) locked in park
- 90 Accord tires
- Timing Belt + Labor Q's
- Mobil 1 Oil Filter Part Number Enquiry
- Earn 12% daily of your investment!!!
- 98 Honda Accord
- maintenance required indicator
- 92 Civic EX electrical glitch
- how do you extract original stereo system to allow new radio to be fitted?
- 2001 civic whirring sound at pre-ignition...Fuel pump priming itself?
- Honda Accord Coupe EX
- Honda Insight CVT
- HELP ! Need '86 Prelude cooling system info
- prob on leak and front parts
- 92 honda civic intermittently not start
- 92 honda intermittently not start
- 99 Accord
- When to add tax?
- Car turning over but not starting, or stalling as soon as starting
- Fog Lights
- "Splats" for '93 Accord?
- how good are the pilot fog lamps?
- 03 Pilot - can I add outdoor temp and heated mirrors?
- 94 Civic is on the road finally
- Wiper fluid problem
- Need 2001 Accord Brake Bleed Sequence
- 94 Accord A/C not working
- Who does NOT agree that Honda should fire their designers
- 1991 accord distributor
- aftermarket seat for Element to seat 5?
- question regarding battery behavior
- Installed Brembo front rotors on 97 Accord: So far so good.
- Honda Parts
- Easy test for worn rings
- Accord Hybrid wheels/tires
- Accord Remote Lock: No Headlight Flash /Horn
- Curious about automatic window
- oxygen sensor
- dex cool class action
- stuck window
- Guys, please check this
- Just called Napa Auto Parts in Langley - Main Relay $104 Canadian
- Not '93 honda civic savvy
- 2002 Subaru WRX for sale 22xxx miles runs LIKE NEW asking for $17400
- Secondary O2 sensor
- Is rustproffing really necessary?
- why change shifter bushings??
- 98 civic domelight doesn't work
- Audio Problems!!
- test
- I bought a 2003 Pilot LX
- 2006 accord? difference between EX and LX?
- Resetting SRS light on Pilot.
- Heater stuck on, A/C won't work
- Avoid Costly Legal Issues!
- Hanging air freshener badly marked up center console
- TIT QUIZ - sex positions
- backtalk@motherjones.com
- 97 honda civic a/c problems
- brakes are squealing
- Honda Parts
- help feather my clutch
- pre O2 sesor replace on 00 Civiv
- Poor gas mileage (2005 Honda Civic LX AT) ~25 MPG
- (2) 88 accord DX shift lever locked in ' park' prob......UPDATE.
- Could it be contaminated differential fluid???
- CR-V - what years to consider?
- Pilot - good years & Towing?
- accord vs jetta vs camry
- Water killed my AC and Radio, HELP!
- To Tegger re: alt brush assy replacement
- UK Used Car Hondacare Guarantee
- Article: Plug-in hybrid
- Accord 2000-4DR-EX-5Spd Fluid Changes
- Poker tournament entry for sale (win $2k)
- how to clean valve guides for 88 civic pgmfi...
- ignition timing question
- Please walk me thru an alternator brush replacement for a '91 Integra gs
- Transmission Control Module rebuild???
- gas tank mistery: 3 gallon missing
- 91 SI oil eater after rebuild....?
- Honda Civic 91 Air Conditioner Help please!
- Temp gauge reads cold - 1994 Accord
- CRV Power Module Upgrade-Worth it?
- Car Dealer Ratings
- Si '91 eating oil after rebuild.
- 98 honda civic LX 1.6L a/c systea
- Hood Pins
- A/C working improperly
- 1999 Honda CRV - Low Engine Idle
- Swapping out brake bleeder screws
- Maximum speed using stock tires (2005 Honda Civic)
- hail damage
- 91 SI..eating a litre of oil a week, after rebuild???
- 92 civic suspension
- Life-Time Brake Pads?
- Advice for buying used Accord/Civic, please?
- Groaning / Squeaking / Screeching noise from LR wheel???
- 2003 Accord Battery Problem...anyone else ?
- 91 SI rebuilt motor eats litre of oil per week!!!
- unbelievable!
- Correct tire size?
- honda accord window regulator
- 92 Honda Accord station wagon with EFI start up problems
- FUTURE PRIDICTIONS - STOCKS - PRODUCTS - FUTURE GLOBAL MARKET
- 1988 Accord LX
- Radiator coolant
- valves or pinging?
- does 1999 4 cylinder have balancer shafts
- How do I find (and fix) problem with main relay on 91 Accord??
- Frozen and/or broken brake bleed valves.
- Replace old seats ('94) with seats from newer Accords?
- D15 sleeving
- Update: Glueing door fabric, 90 Accord
- Civic 2k Cabin filter
- MPG with AC on - 92 Civic AT
- Water coming from under the dash while a/c is running
- 1990 civic wagton overheating?
- wav or mp3 file for pinging sound?
- A/C and radiator fans not spinning.
- Replacing Timing belt 1986 Honda Accord LX
- 96 accord cooling fan
- Honda Power Steering Fluid
- Noisy stabalizer links
- Hybrids: Single-Driver Lanes
- How do I pass brake light inspection?
- Battery light in Dash lights up when parking brake is on
- which interior color hides dirt better?
- 95 accord starting problem
- Honda S2000 Starting Problems
- brakes
- interstate batteries for honda accord
- Quality of distributor cap and rotor
- warm air from ducts - even though lever is in cold - 93 accord
- anyone interested in buying a 95 civic si coupe?
- Hot tranny -> Hot neutral safety Switch -> Starter solenoid not engage
- installing a new clutch in a honda accord
- noise from clutch - 97 Civic LX 1.6L non VTEC
- 90 Accord how to setting idle speed and timing
- happy with http://www.manhonda.com/
- coolant flush: scale remover?
- key-in-ignition piezo beeper in 98 civic
- 94 Civic EX: NYC emissions results / question
- would a gear box out of a 95 civic SOHC fot a 97 civic coupe SOHC?
- Air Conditioner Blows warm to hot air
- Anyone ever used gasrefund .com
- Gagnez de l'argent sur le net
- What glue for door upholstry?
- OBD-II and fuel millage
- 94 Civic: low power in 1st
- Fit/Jazz - Scion Xb Comparison
- what kinf od expoxy to use to bond honda rubber bumper cover?
- Noise from suspension on 2001 CIVIC
- 1990 civic wagon fuel economy
- Dark Side of Hybrid Vehicles
- starting problems want turn over
- Horn & healight chime not working 94 Civic?
- 88 Accord steering boot rips then leaks.
- 91 Accord Cooling Fan Runs Slow?
- seat covers for 2002 Civic SI?
- Instructions for installation of Jet V-Force 67002
- What's with red rear turn signal?
- SUNROOF
- O2 Sensor, One or Two on 99 Civic LX?
- Aftermarket Brake Pads
- best way to get MP3 into radio?
- Horns!
- 92 Accord 4WS, ABS pump running
- Failing catalytic converter code
- Towing a Honda
- Re: 2001 Accord EX brake light on dash
- 94 Accord LX Exhaust Replacement - Dif Parts for Cal Model?
- 90 Civic EX update.... new OEM wires, plugs, thermostat, rad cap & flush,
- how long do brake pads last?
- a/c high & low pressures?
- Can you ID this wheelmaker's logo?
- Honda Element 2005 EX
- Performance Shop in Albany, NY area? Specifically, wheel balance
- Radiator fan is always 'ON'
- Trivia : Why is Honda S2000 50kg heavier in Germany than France?
- 97 Civic EX upgraded emission recall failed smog check ?
- honda pick -up
- shift knob?
- Thank You Tegger
- Thank You Tegger
- HONDA CAR PICK-UP
- Coil / Ignitor / Main Relay Cont.
- Bike Rack for 2002 CRV
- where is the nearest seller
- 2004 Civic EX: Flashing Battery Low Indicator
- master cylinder info
- 2000 Accord EX ran out of gas with 5 gallons left in tank
- batteries for honda accord lx 01
- repl battery for accord lx 01
- Good body shop in Dallas?
- Accord 2000 LX - Ignition key stuck, and then can't start the car. Pls help!
- Integra rear trailing arm bushing part number
- Old suspension bushing photos
- 92 Accord overheats when AC turned off. Honda
- 91 Accord engine stall
- spark plug wires: old but under 10kOhms
- 99 Accord Water Pump
- Civic brake disk thickness?
- which first: pads or fluid?
- 91 Accord intermittent door locks
- 91 Accord temp gauge
- 90 CRX Won't start- fuel pump???
- Rear suspension is off!
- hot civic no crank
- Suspension bushing question...
- 30,000+ hi-res car wallpapers - free!
- 2005 Accord DX(VP) Power locks?
- Ignitor / Main Relay on 92 Accord
- pilot feels like it stalls
- Civic Hybrid -- gas/electric usage
- problem with cd player on honda accord
- hydrocarbon in the coolant v/s pressure test
- Honda Accord Assembly Sites
- Re: pilot feels like it stalls
- How to fix busted passenger side window (97 honda civic)
- protecting bumpers from scratches - what works?
- Honda radiator boil
- Where is thermostat on '95 Civic?
- What is a power steering grease - where to get one?
- 91 Accord Brake Master Cylider
- how much brake fluid
- 84 Prelude
- CV joint boots
- 2000 Cr-v many need new battery
- How to determine radiator mfg?
- '90 Civic: Extremely sluggish low-end acceleration, poor fuel economy
- Can clutch be changed from above or below?
- 97 accord 4 cylinder Problem changing fuel filter
- 90 Honda AC Problem
- Speakers for Honda Civic (1998, UK Model)
- 2005 Accord EX V6 16" Alloy Wheel-Lug Nut Torque Specification
- 88 accord DX trans locked up in 'PARK'
- what company is JDM?
- 99' Accord Brake Squeak - just replaced brakes, rotor and rotor again
- unplug the spark-plug: error code or not?
- Re: 1999 CRV: Keeping clock bright when lites are on?
- Prelude dash removal
- hondacar-swich/orsensor
- '90 Civic hot after 1 hr highway trip, overflowing coolant
- Dimmer Question
- Bad morning for cars in my life.. long
- 96 Accord Keyless Entry Install
- Downshifting Grinding noise
- 1993 HONDA PRELUDE
- air conditioner filter (cabin filter)
- speedometer
- Odyssey 2000 EGR system
- 1999 CRV: Keeping clock bright when lites are on?
- too late for synthetic?
- Replacement of Manifold Gasket
- 99 Civic SE gauge swap?
- need info
- Ginding noise in 94 civic 5sp tranny
- '95 Civic making rattling sound
- Oil change frequency for highway mileage?
- Timing belt 4 sale (Festiva, Prelude,323,Tracer)
- Free TECHRON and maybe gas rebates?
- Door Sills and Aluminum Pedal & Foot Rest
- 2002 civic transmission problems
- best head gasket for 90 EX 16V
- Civic LX 97, LED on the RADIO, what is it?
- Civic LX 97 not-so-stellar-performance
- What Is Term For Metallic Particles In Paint?
- Ontario Camera ticket
- Selling CRX
- Prelude '93 resetting engine light
- 96 Integra A/C whine
- 2003 civic ex door lock mechanism broken
- Ping: jim beam (was: Mighty Honda Civic)
- Window run channels on '01 Prelude
- A/C Problems on 92 Civic
- 2000 Honda Civic Starting issue
- RE: Tips to Boost Gas Mileage & Performance!
- 97 Accord: power window only lasts 4 years
- 92 Honda Civic
- cd-rw media that works in your honda?
- speedo cable chirp
- 94 Civic: coolant drain/flush and thermostat
- 1991 honda accord transmission
- Exhaust help
- 2004 honda odyssey
- 94 Accord Wagon Failed Emmissions - Running Hot?
- 1997 Civic LX Compression
- Window won't roll up shut. `92 Accord Honda
- Battery drains overnight (twice.) `89 Accord Honda
- Fuilds for a CR-v
- When does the cooling fan come on?
- 03 to 05 accord floor mats
- civic brake shoes and Helm service manual
- Timing belt - mileage vs time
- Fuel gauge for 2001 Odyssey
- 88 Accord : Which fuse for the dashboard backlight?
- Mission impossible: Replacing prelude side lamp bulb
- Honda Dealer in Palo Alto, CA
- Honda Civic Sedan EX Special Edition
- Question on 99 Honda Passport
- 94 accord, no oil to top of engine- Oil light on
- Honda Civic Reverb 2005
- 89 Honda Accord
- WANTED:CRX-HF in the northeast states
- VSS diagnosis?
- '97 Accord overheating bizarrely
- Steering hose sprays exhaust when making U-turn. `88 Honda Accord lxi
- honda civic tune up trouble
- How do I remove pully bolt to get to timing belt ('99 Accord???
- Back to '04 V6 Accord Ping - Or, Why I do the work myself
- 92 Integra Idler problem FIXED
- gasket sealer type to use?
- how to get bolt out from civic alternator?
- FS: 95 Accord hood--gold color--$50
- 98 accord V6 intake port question
- 1995 prelude 2.2 vetec high rpm about 4000 grand
- I need help decoding 1998 CRV speaker wiring
- 96 Honda Accord electrical and speaker problem...please help!
- Civic Hood Insulation
- 1990 honda civic
- accord keys
- VCM worth the wait?
- clutch master & slave cylinder replacement notes (94 Civic EX)
- Hybrid Cars
- Civic Door door won't open
- 2006 Hondas
- Can an older Hybrid run without its battery after it dies?
- 94 civic ODBI or ODBII?
- Re: 88 civic SI burning oil at acceleration...
- Re: auto paint touch up kit
- Still white steam after head gasket replaced?
- civic acceleration question
- 99 Civic starting issue
- potential speed sensor issue
- 6-Disc CD Changer in Dash & MP3 Special Edition
- Accord 2000 - Question on Brakes wear
- sorry I meant filter not pump I just realized that I typed pump
- 1990 Prelude 2.0 Si where is the fuel pump?
- TeGGeR's appraisal: TeGGeR makes a boo-boo
- 2005 Honda Insight
- The new 2005 Honda Odyssey
- "Rattling" sound in '97 Honda Civic...
- Navigator DVD Update
- headgasket? repair or not?
- Renovating Hondas for Income & Fun
- Civic Horn
- humming noise or grinding noise
- 91 Civic Will Not Start
- 94 Civic Lx Intermittent no start
- 2004 Accord airbag/seatbelt issue
- PorscheStoriche
- 2005 Accord Road Noise
- 95 honda Odyssey starts and cuts off when I let go of the key
- radio
- 99 passport>>> dash board lights!
- ecu transfer
- T-rated vs. H-rated tires of 97 accord (Goodyear Assurance Comfortred - bad ride)
- 04 Accord V6 light sustained ping on acceleration
- 88 Accord DX auto: How to replace manifold coolant hose
- Speed Sensor Location on 94 Accord VTEC?
- FA: New JL Audio Free Air Subs Rare Discontinued
- "Piston slap" / diesel sound in '94 Accord
- poor fuel economy
- 96 Honda Accord "chrome" plastic handle
- 2004 Accord 2dr- Window Tints Bubbles
- 1992 honda gets code 41
- 2005 Honda Accord Hybrid
- Anybody ever have their tach and speedo stop working?
- Unofficial FAQ: online seller list
- 97 Radiator boil over, general rant
- Front Quarter Panel Replacement (1999 Civic)
- how can I tell if 1.5L spark is weak?
- Check engine light.. Code: P1362
- Restart stalling on '99 Accord ULEV-4
- Civic 03 Driver Door Lock
- DIY Oil change-Filter removal
- Surprising Insurance Appraisal on a 6 yr old Civic
- License plate light
- 96 Honda Accord
- How to fix a nitrogen oxide problem?
- new idea....
- K&N airfilter 4sale
- Flaring
- Unofficial FAQ igniter updates...
- 97 Accord "Buzzing"
- 1997 "Honda Tap"?
- Honda Fit/Jazz - Is there a way to get Honda's attention?
- Honda Engine Makes Rattle at 30mph?
- 1994 Accord Heater Control Lights
- TeGGeR's appraisal!
- Midas vs Speedy
- Honda FIT at Import Shows !
- Uk honda Civic 1.8VTI (98 model)
- Thinking about buying an Oddessy
- Heater takes a while to get hot.
- HRV Rear Speaker Access
- Re: 88 civic si exhaust pipe cracked...
- How much to pay for a used Del Sol Si
- Does fan should running all the time?
- Small dent and getting it out??
- honda stalls on take off
- Loose rear view mirror- 1990 Accord
- purchasing 2003 EX Civic.. Help!
- Thanks for the FAQ Brake Master Cylinder replacement
- where to search for recent price-paid for a new accord?
- Anyone need '83 Prelude factory service manual
- '91 Civic HB Antenna -- HELP!!!
- 1997 CRV
- STRUTS
- Factory pressed dvd movies, ps2 & xbox backups for sale
- SRS Light..
- Need Hubcaps 1990 Accord
- vibration - low idle speed...
- Changing oil on a '94 Accord LX
- timing belt parts kit
- Rattling noise
- Which Gasoline Grade is Best for Honda Hybrid 2005?
- 97 Civic front brake lockup problems...
- Honda Pilot VTM
- 2005 honda accord running a little rough
- Anyone need a '94 Integra factory service manual
- A/C pipe leaking freon
- Rear Alignment in '91 Civic?
- Idle speed dips after letting off gas - 92 civic d15b7
- Honda prelude vtec main relay
- Brakes Bigger rotors or just slotted and or cross drilled?
- A Good Honda Mechanic (GTA Only)
- New Honda antifreeze formulation?
- Odyssey Transaxle Fill Plug?
- vibration on acceleration, 90 accord
