PDA
View Full Version : 3rd Generation GK Specific DIY: Repair & Maintenance Sub-Forum
  1. Sluggish acceleration
  2. Repair manual / web resource
  3. GK5 MT 4th gear vibration
  4. My mother needs help
  5. "Power Is On"
  6. Good battery, no crank.
  7. AC System Troubleshooting - What am I missing?
  8. No Start - Electrical
  9. Transmission Vent? Missing Bolt?
  10. Coo3A-14 Rear Speed Sensor
  11. Fit Frustration
  12. Heat/Cool Blend Door very stiff
  13. Plastic clip for drip sill broke weird, what to do?
  14. Maintenance code 4
  15. Battery Box And Cover Upgrade To 51r.
  16. Rear wiper motor
  17. Immobilizer System activated after changing the car battery?
  18. Undoing electrical connectors
  19. Confirm part numbers for Transmission Fluid Washers for 2019 Fit
  20. replacing both o2 sensors, what size sockets are needed?
  21. AC Compressor Clutch Relay
  22. VSA & EPS lights plus Check Charging System
  23. Manual Transmission Oil Change and Misc
  24. 2015 EX CVT - Alternator replacement
  25. Lot of problems after I ran over a 12" pothole at 45mph
  26. How to remove main interior fuse
  27. How often should you change your coolant?
  28. Help me diagnose a no start problem-new member
  29. Need your help Honda 2020 radio console problem
  30. 2015 vs 2020 Fit
  31. Engine splash shield
  32. 2015 EX start failure
  33. How to remove temp control panel?
  34. Fuel injector parts
  35. Electronics!
  36. Oil filter change every second OCI?
  37. Lower Shield and Oil Change
  38. Royal Purple Synchromax
  39. Squaeky Clutch pedal.
  40. Oil life declining quickly???
  41. Rear wheel bearing assembly
  42. Wiper Cowl
  43. New Fit Owner - 2015 EX
  44. Sunroof maintenance
  45. Back Seats Won't Stay Down
  46. Gen3 clutch bleed - tubing size?
  47. What is this grinding noise on startup?
  48. Gen 3 Clutch Fluid Change Interval
  49. What Mileage to Flush FIT Radiator?
  50. Honda Jazz 2015 chronic misfire
  51. Valve EGR in honda Fit GK
  52. Bare Metal Under Battery Tray.
  53. GK5 CVT transmission Oil Filter, should it be changed?
  54. Is it possible to adjust power steering?
  55. Lower Torque Mount Replacement
  56. Possible rear wheel bearing replacement needed?
  57. 3rd Gen Oxygen Sensor - What To Buy
  58. Help with 15' diagnosis ?
  59. 2015 Honda Fit Start/Stop Button Replacement Help
  60. Programming key FOB
  61. Replaced front struts, having noise turning the steering wheel
  62. Replaced the stupid Front Engine Splash Shield thingy...
  63. New Owner!
  64. Drain bolt and crush washer
  65. 2018 maf sensor bad?
  66. gk3 service manual
  67. (Please Help) 2015 Fit rear door garnish / pillar
  68. Need help identifying a suspension part
  69. Castrol 06811 CVT fluid change
  70. OBD2 bluetooth dongle that reports AC codes
  71. Turn on backup camera while driving
  72. Dot 3 brake fluid recommendations?
  73. Alternator ECU Bypass Charging System
  74. KYB or Gabriel
  75. A/C Issue with video (compressor won’t stay engaged) P0532
  76. P0793 error code?
  77. A/C compressor won't stay on or won't start (intermittent) Subscribed
  78. A/C compressor won't stay on or won't start (intermittent)
  79. Red Temperature light blinking!
  80. In need of p2422 code advice
  81. 2015 LX front end sound
  82. Honda Access Side Mirror Glass install
  83. Front pads and rotors
  84. Serpentine Belt and Failed AC Compressor 2015 LX
  85. cabin air filter flow
  86. Rumble under braking
  87. Removing Accessories on a Leased 2017 Fit?
  88. TPMS, ABS, Stability Control lights won't turn off
  89. "Check Charge System" mystery issue on the highway and going up hills
  90. GK diagnostics tool
  91. 2015 Car Won't Start
  92. non-oem fuel injectors
  93. 2018 Fit EX-CVT Maintenance Minder
  94. CVT drain plug bolt and check bolt torque spec
  95. Two horn beeps upon ignition
  96. Help identifying part
  97. Blown fuse... Which fuse is the front cig lighter?
  98. Squeaking sound front seat area
  99. 0-16 Oil?
  100. Is Honda going to recommend the new 0W-16 oil?
  101. Rear Shock Absorber Replacement
  102. Check Charging System
  103. Programming Keys
  104. PCM (ECU/ECM) - have you had it replaced?
  105. Left rear Wheel Binding
  106. Hood sensor
  107. 2017 Fit CEL, VSA, EPS, TPMS all on!
  108. Adjusting the parking brake cable
  109. VTC actuator solutions
  110. reprogram automatic door lock behavior
  111. 5MT fluid change.
  112. How to reprogram key fob (no remote)
  113. Turning(machining) 2015 Fit rotors
  114. Honda Fit D light flushing and Engine cutting
  115. Orange fit replacement spray paint?
  116. Brake Pad/shoe recommendationd
  117. 2015 Fit - all dash lights
  118. Rear Window Washer Hose Damaged
  119. GK service manual
  120. Oil Change Frequency
  121. Fuse Problem
  122. SRS Light reset after accident.
  123. Starter button
  124. break fluid change
  125. Drain Plug Torque Specifications?
  126. GK service manual
  127. 2015 Honda Fit hook up cable wrong.
  128. [VIDEO] Weird CVT noise when D mode engaged
  129. 2017 EX Transmission Oil Change?
  130. Front strut "clunk" and play issue
  131. Under Body Guard
  132. Would someone please post a picture for me?
  133. Need a new EGR Valve for my 2015 Fit LX
  134. 2015 Honda Fit - rear lights aren't coming on when I turn on my headlights.
  135. Guess you do need to change plugs...
  136. How to change CVT fluid - 2016 Fit
  137. Rear Wiper "Repair"
  138. Tool Storage Options in the GK
  139. Need help. Intermittent warning lights
  140. Download the GK-Specific Owners' Manual
  141. Starter Relay Location?
  142. Hatch struts, come in Left and Right?
  143. Replace Push button start switch?
  144. Power outlet not working 12 volt 180 watt max
  145. Honda Fit GK3 - Engine oil ?
  146. Dragging Wiper Blade Issue Finally Solved?
  147. CVT tranny with metal shavings
  148. Cleaning up fuel injectors
  149. Windshield Molding Question
  150. Maintenance Minder - Main Code ONLY - NO Sub Code
  151. Advice Needed: Transmission and Brake Fluid Flush
  152. 5W30 Oil Synthetic
  153. GK clutch replacement
  154. GK5 JAZZ CVT fluid
  155. Electrical problems after reversed polarity jumpstart
  156. 2016 Fit, CVT fluid type?
  157. rust issue?
  158. ODB II Code 2422
  159. 18 fit sport s for lights
  160. GK5 with 92-00 Civic Radiator
  161. AC PROBLEM - 2018 sport S
  162. Any recommendations for Battery replacement on 3rd gen (2015)
  163. Will Rhino Ramp work with 2018 Honda Fit Sport?
  164. door rubber seal glue
  165. engine oil filter question
  166. any advice for an owner with a fit that's almost out of new car warranty?
  167. Brake fluid change
  168. Should I replace radiator/heater hoses on 2015 LX 100,000 miles?
  169. Question for those who've had to replace a side view mirror - just the glass
  170. Wiring diagram
  171. Recommendation on washer fluid / engine coolant?
  172. windwiper specification ?
  173. Hatch doesn't unlock sometimes
  174. Changing Fit air filters
  175. possible battery issue?
  176. CRC Intake Valve Cleaner, where to spray
  177. Service/Maintenence intervals and MM
  178. Rust-Proofing Vehicle Instructions Help
  179. Carbon Buildup on FIT Earthdream Engine Valves @ 52K--Input?
  180. HCF-2 Transmission fluid - Weird bottle
  181. A/C Condenser replacement OEM or prev. models
  182. Side Markers anyone?
  183. 2019 fit sport cvt
  184. Alternator replacement
  185. 2015 Honda fit won't start
  186. wtf?? you need to set the valves in 2019?
  187. Ac compressor
  188. K&N Air / Cabin Filter.
  189. CEL on, wont rev past 3k in park
  190. Nut torque specs
  191. First Major Service 2015 Fit..
  192. Does the MTF drain plug use the same crush washers as the oil drain plug?
  193. Flickering MPG/Miles Dial
  194. Torque For Plugs
  195. Windshield Washers
  196. Valve Lash Adjustment GK5
  197. Backup Cam Stopped Working
  198. Dipstick/ Oil capacity issue
  199. Break fluid exchange recommendations
  200. Starter Hesitation / Remote Starter Issues
  201. Self-Locking Doors
  202. Help please
  203. Spark Plugs For 2015 Fit EXL
  204. Can someone confirm for me that this is the right part I'm replacing?
  205. Spark Plug Change
  206. 2015 Fit EX wont start
  207. "Extreme" cold prevents windows from opening
  208. Reprogram a Key Fob?
  209. thickest transmission grease that's safe? 2015 honda fit ex 6 speed manual.
  210. I went with the 151R
  211. Battery and "Check Charge System" on 2016 Fit
  212. Where to find plastic pins for engine under cover?
  213. TPMS, VSA, EPS, Check Charge System.
  214. My Maintenance Diary
  215. 2016 Center Console Latch Button Broke
  216. Flashing TPMS, VSA OFF, ABS and Powersteering lights
  217. Front suspension overhaul
  218. Spark Plug Socket
  219. CRC GDI Intake Valve Cleaner
  220. Starter replacement
  221. 3 year / 25K Maintenance?
  222. 2015 Honda Fit a/c compressor fuse
  223. 2015 Fits prepare now for larger battery
  224. fuel injectors and catalytic converter problems
  225. VALVE ADJUSTMENT - *SOLVED* - Misfires eliminated by replacing injectors
  226. Floppy cup holder
  227. trying to replace spark plug
  228. Replacing broken wing mirror cover and door attachment piece
  229. Startup Rattle
  230. Has anyone done an induction service?
  231. Serpentine belt
  232. Checking The Brake Fluid
  233. Do replacement spark plugs need to be gapped?
  234. Online Service Manual
  235. 2017 Temperature knob replacement
  236. Windshield Wiper Prohibition!
  237. Torque specs for front brake job on a 2015...
  238. 2015 Fit, no heat, heater knob won't turn
  239. Starter replacement 2015 ex-l
  240. 'Clunk' shifting from 'R' to 'P'
  241. Anyone know how to bleed the clutch?
  242. Changing my own Spark Plugs?
  243. LaneWatch Harness and Install
  244. Valve clearances?
  245. 1st gear hard to get into sometimes
  246. Turn signal plug/socket
  247. 2016 fit/jazz fuse box relays
  248. How to check manual transmission fluid level and change the fluid?
  249. Splash shield screws and retainer clips
  250. 3rd Gen Splash Shield Screws and Retainer Clips
  251. cycling on/off humming/vibration from the left front 70-80mph
  252. How much for a Windshield Replacement for 2015 Honda Fit?
  253. 2015 Fit LX MT 3rd gear
  254. 2015 Fit Rear (hatch) door panel removal?
  255. New Cabin Air Filter..Easy Project
  256. 2105 Fit - Blowing hot air only
  257. Alternator failure at 50k
  258. Rear Wipers
  259. Steering Wheel Off-Center
  260. 2015 battery low after only 1 day of non-use?
  261. How much would a key cost?
  262. Replacing the Wiper inserts on 2015 model
  263. Warranty Denied?
  264. Additional fixes for coilpack misfires worked
  265. 2016 Fit Defroster Problem
  266. how to adjust headlights?
  267. Anybody have a shutter when turning wheel hard left or right??
  268. On eBay 172205R0008 Air Filter 2015 LX CVT
  269. Second Gear Pulsating
  270. Replacement passenger mirror with LaneWatch
  271. Maintenance Minder
  272. New Antifreeze, Anyone?
  273. Has anyone adjusted the headlights on the 2015?
  274. My car smells like it where burning
  275. passenger vent no air, hvac and other vents are perfect
  276. 2015 Honda Fit 6MT Problems
  277. Coil Recall Done
  278. Engine knocking
  279. Air conditioner stinks and Honda won't help
  280. Fuel Pump 2015 gk
  281. Dust and Pollen Filter - Very Dirty
  282. 6 month old 2015 not starting!
  283. Dust and Pollen Filter Replacement
  284. CVT Fluid Change
  285. OBD not ready (emission test MA)
  286. Brake Pedal Flutter?
  287. DIY: Cabin Air Filter Replacement/Cleaning
  288. cabin air filter replacement
  289. Take off and 1-2nd gear clunk
  290. Placed Jack in the middle?
  291. Cargo area door: shiny "chrome" plastic strip is disgustingly dirty
  292. A few maintenence questions
  293. Honda parts store in Bejing PRC?
  294. Shark Fin Antenna for Fit EXL-Navi
  295. Electric Power Steering error
  296. Anyone else get a loose engine splash shield under their car?
  297. Tailgate handle plastic cracked
  298. <100 miles, brake warning light on
  299. Got a mouse in my 2015 Honda Fit
  300. Rattle in hatch
  301. Time for First Service. Advice, Please.
  302. Possible Interior Quality Control Issue?
  303. Windshield cracked while I was away
  304. Car Cover for 2015 Fit
  305. Deep scratches to rear wheel and side door in small accident
  306. Cabin Air filter replacemt and air flow
  307. Strange Vibration after start shifting to Reverse
  308. Warning lights...all of them.
  309. CVT Fluid Replacement
  310. 2015 Fit: Fuel feed problem?
  311. Shorted wire car wont start HELPP
  312. Changing LX CVT HCF-2 transmission oil procedure?
  313. How do I check the transmission fluid on the 2015 LX CVT?
  314. Which FRAM Air Filter for 2015 Fit LX
  315. Newbie clarification- when to do first oil change?
  316. Valve cover seep.
  317. UOA - 2015 Honda Fit - Honda Ultra Next 0W-8 oil - 5800 miles
  318. Creak/rattle from a stop
  319. PIAA wiper blades
  320. Oil Change km
  321. Best replacement wiper blades for LX?
  322. Front jackpoint on the 2015 Fit?
  323. Engine Shutting Down
  324. Dash warning lights keep coming on
  325. Shaking/stutter when making hard right turn...?
  326. Moonroof Trouble
  327. Maintenance Minder Question
  328. New to Fit and Forum - oil change question!
  329. New Fit does it need a oil change before 5k
  330. Where is the Transmission Dipstick?
  331. Looking for some good GK DIYs
  332. Corrosion on door handle brackets
  333. 2015 White Orchid paint issues
  334. Tire pressure light won't turn off
  335. Ignore miles, follow Oil Life?
  336. 2012 Fit - took the cowl off and checked for lose spark plugs.
  337. engine lower panel removal
  338. First OIl Change - On Ramps
  339. Defrost issue
  340. Dealers and maintenance minder
  341. How do you remove the under panel?
  342. 2015 CVT fluid change
  343. Valve adjustment/MM codes?
  344. Oil/Coolant
  345. Clunking Noise: Drive to Reverse
  346. Break in oil dont change till 8000!?
  347. Oil change on the GK
  348. Rear Suspension Snapping?
  349. Window Rattle with window cracked
  350. Check Charge System..
  351. Ticking sound from front passenger side
  352. Paint chipping issues
  353. 2nd-3rd Gear Clunk?
  354. Engine Oil Life Indicator
  355. Dealer Caused Damage- Need Advice!
  356. what filter to use?
  357. Need your help and advice...
  358. Windshield Wipers Squeaky
  359. Alternator whine?
  360. Battery woes!
  361. M/T: Shaky Second Gear?
  362. Maintenance Schedule
  363. Quality Issues with new Fit
  364. A/C doesn't seem cold
