- engine ignition loud clicking
- new fit owner...some simple questions
- Factory window tint % question.
- <===newbie!!
- rubbing solution 16x7" - i need opinions
- things to check for when buying USED fit
- Quick Cheap Map light solution
- anyone interested in a seattle area meet?
- throttle controllers
- Ebay lug nuts?
- i know this may sound stupid... but...
- Need help modding my 07 FIT
- Oil Life Meter is finally working
- New To Me Fit Owner
- Potential Fit Owner question
- collegehillshonda/gd3 parts
- ITT post your car ownership history
- A/C usage and lower MPG...ways that Honda can fix that problem
- Fit stutter and sketchy garage
- Help Please - running wires to top of dash.
- Bad Catalytic Converter
- Gd3 parts on Gd1 ??
- had a cheap intake idea...worth it?
- awww man!!!
- Recall
- MR Fit in Key West?
- Fit Sport Tires
- Miami lets have a meet
- USB kit for 09 work in 07?
- Just "wasted" $130.
- Aftermarket items that came with my Fit
- perfornance chip/module
- Problem: Gearbox lock & tail LED light gone off {Help}
- Southern Regional Car Show
- 07 Fit Clutch "no action"
- Megan mid-pipe
- new tries 08 Sport
- Automatic Transmission Fluid @ 60k Help...
- Undertray SEVERELY Damaged
- 07-08 Honda Fit High-Boost Supercharger Kit
- cleaned the ride today, came out nice
- Battery standards?
- "Gritty" Clutch Pedal
- Interior Color
- Should i get the FIT or a GTI
- I need these rims in 4 lugs?
- Protect my FIT from my monster of a puppy!
- 2008 Passenger Side Tail Light
- Need front lip for type s bumper!
- spoon headers
- The Mystery Stain
- mouse borked my recirculate flapper
- Ac help !
- fml friday!!!
- 03 check engine light
- My engine use oil...
- 6000 mile road trip report
- Fron license plate cover damage
- Aftermarket Sunroof Unanswered Questions
- 03 GD Wiper Problem
- Terrible MPG!
- twin loop insatlled (pics)
- guages
- Ground Control coilovers- questions
- Horn location
- HELP! OEM wiper replacement insert keeps sliding out
- New shoes! Konig Feather / Goodyear GT's
- Cracked FOG lightS.
- HFP wheels. Spacers
- Radio Theft Error Code
- TMP rebuild kits
- Auxiliary Hook Up
- Giving up my FIT (to sibling), buying a new car...
- Cleaning the Windshield Washer Nozzles
- JDP Carbon Lip Installed!
- GE rims on GD, HELP
- Thule Rooftop Rack Installation - seems a mystery....
- Premium Gas and MPG
- Honda remote programming
- Loud Music and rattle from front passenger door
- Exhaust tip and smoked tail light suggestions?
- Surprise...
- Z-Max Micro-Lubricant?
- Two Mugen Titanium Exhausts?
- Rear Alignment Issues Solved
- VolkRays TE37 rims - offset question
- RHD double din stereo installation console
- Stereo problem in Ireland.
- compression pump kills my fuse
- Seibon CF hood ?????
- cruise control still doesnt work ..... Why???---help
- 08 Sport Rear Spoiler removal
- Can you help me on my new stereo?
- OEM Sport Muffler with Auto trans?
- Transmission
- My 2 year old put coins in the cd slot!
- What did you do to the GD Fit today?
- Required major maintenance 80k so far..
- Help! suspension DIY
- NEX SS Full coilover for the GD
- what clips? rear bumper clip
- HELLPPP...FUSE #22 burn over and over again!!
- Replacement for Buttons on the Steering Wheel?
- Lowering spring question???
- Automatic Transmission Filter
- Help: M/T Broken differential?
- The dealership left something behind...
- Service Manual Jazz 2006?
- TPMS sensors 09 not compatible with 08? dealer says no!
- It's for my wife... she's 5 ft only
- 2007-08 doors
- Need some help diagnosing this vibration.
- MR got new rims
- Rear Springs to carry more weight and keep original ride height
- Stock Stereo question: Re: Aux input?
- will this gearknob fit ?
- a/t jumping in first gear
- sosoqtpinoy's VPB GD3 (updated pics)
- Looking for a dash kit
- Removing the gauge cluster?
- What will happen when the timing belt breaks?
- Does the GE Mugen short shifter fit the GD3?
- why no armrest for the driver or body side molding?
- A hissing sound when turning the car off
- a/c evaporator question....
- Grade Logic in 2008 Honda Fit?
- Anyone own a jp honda fit 02-06 w/ navigation?
- fender liner came off on the interstate..
- Road trip
- Picked up a shark fin antenna, need help
- Looking for a one of these....
- Tires vs size and weight
- Ran into another Fit owner yesterday
- Clutch issue - Anyone else?
- Who wants more miles per tank, not MPG?
- Tires
- Should I buy this Fit?
- p2649 and fuel cut at 3750rpm
- Anyone have a loose drivers side window??
- Diff Question
- online source for wiper blades?
- Speakers under waranty?
- Should I get this for my GD3?
- Just thought I would say Hi
- It happend again!
- Anyone riding Motegi rims?
- CEL on, but can't read codes......
- Light Replacement
- Got my recall notice, have you?
- 2010 fit rims on the GD?
- Customize inside door panels?
- Paint the Honda Emblems? Yes/No
- new guy, 07 fit sport
- 17" wheels with eibach pro kit springs
- What Springs FIT the best?
- Cargo Rack?
- 07 Fit MPG
- Anyone know which fuse controls the immobilizer
- soft brake pedal, bleed brakes?
- 17" wheels on eibach sportline springs
- help changing cvt fluid.
- Recall message from Honda Owner Link site...
- crack on bumper..
- 2007 Coolant Leak.
- Weird noise when backing up
- newb with a handful of questions
- A/C Switch Removal.....How?
- Water leaking into interior caused by remote starter
- im new and have a problem,:>
- The Fit - Choice of 1 out of 25 doctors!
- headlight wiring colors
- Uneven brake pad wear?
- Hello! Just got 2007 Fit. Love it.
- Weird braking sound
- Put stock spring back on...Car sits leaning back!
- mugen short shifter?hfp wheels?
- Honda Fit 2006-07 1.5 Sport - What type of transmission in my CAR?
- Does anyone know the part# for the OEM rear H emblem for the GD3?
- Do you paddle?
- CPO 2007-2008 Fit?
- New front brake pads at 160,000km
- UH-OH... Car Won't Start!
- Rolling cargo cover
- frog light is cracked
- Gas Mileage affected by bad O2 sensor
- need help
- a question of aftermarket radiators
- Honda Fit Sport 2007 model AT milage question
- Smoothest Riding Struts?
- Recommendations for 07 Fit Standard
- Need some feedback on running a 17x7 rim w/42 offset
- Vinyl Tint on GD3 Tail Lights
- New Fit Freak in Town
- Jazz/Fit Roof strips
- Older OEM body kit fits on newer model?
- Replacing drivers side mirror
- How wide of a wheel can you run?
- skunk2 short shifter help
- Thinking New seats
- Steering wheel judder
- Maintenance & upgrades
- Which Fit Sport Color would look best on si wheels ?
- 2007 dies when cold
- 1.2 base with alloys, heavy steering & roll ?
- 2007 Fit component speaker upgrade
- where can i buy bride RO type seat rail cheap?
- Thinking about this! Suggestions?
- Why I think Fits are brilliant
- rear tow hook?
- Snow packed in wheel wells, wrench light came on
- Hood vent
- RooF MounT BikE RacK ~ HELP !
- High pitched noise when lights and air-con on
- want to sell my 2007 fit
- Worth Buying This 2008 Fit ?
- Do i need a battery re-locator for a Fujita Intake?
- RPM's drop from 750 to 400 instantly when moving gear from Park to Drive, NEED HELP!!
- what wheel spec is best?
- Animal Liners
- trade in my 08 dodge magnum for a honda fit[GD]
- Fifth Gear making the car shake?
- Excessive interior window fogging?
- Fluctuations in rpm Help me!!
- CRX is tired, looking at a 2007 Fit Sport & have some questions
- Removing AC / heating controls on their own
- Tell me what you think wheels choices
- anyone running Tein S-tech springs w/factory strut?
- Will these fog lights fight our USDM cars?
- *Part 2* Pioneer unveils NEW products at 2010 CES [Video Coverage]
- Turning Off AC When In Windscreen Vent Mode
- So im looking at ebay
- 2007 Jazz/Fit Keyless upgrade ?
- Front ABS Sensor Rust/Corrosion
- East coast snow storm.
- AUX Port
- water in trunk/boot
- cvt problems
- Fog lights for my 2003 fit
- yakima rack question.
- Help! Clanking/popping noise from front end
- PLEASE HELP!!Can the rear disc of EG fits into JDM GD.
- 07/08 Transmission noise when put in drive.
- Help!!!! Interior light and taillight went out!!!!!
- price for fit sport rims
- Rear Seat ! curse!
- 2007-2008 Fit recall
- Worldwide Honda Fit/Jazz recall!
- Will this fit?
- JDM Dry Carbon Power Chamber
- The big 3 cables
- Is there a DIY for installing struts?
- Cupcake meet in Austin
- engine sees to miss fire when fan comes on.
- Who's replaced their seat(S) due to discomfort?
- Damnit I broke something on my Fit
- Haynes Repair manual
- heat not working?! help
- Diy: Acura mdx map light roof console
- Honda Fit Aria GD8 2004
- questions about first oil change
- Odometer Readings 100k miles+
- Black/carbon fiber front lip on white fit
- Carbon fiber fenders?
- Pioneer unveils NEW products at 2010 CES [Video Coverage]
- fender?? socal?
- gauges from fit to jazz
- replacement key cutting cost
- Transmission light help
- onlycivic.com - Anyone ever buy parts from them?
- how to wire a sub
- AT in drive, shows "4" on dash???
- Removing Driver Seat Cover
- Offset and centrebore
- trunk garnish
- 1st time newbie questions
- loud sound coming from rear suspension
- wiring help squirrels ate some wires help
- HELP!! How To Remove a Steering Wheel?
- Anyone have the factory service manual?
- Wheels and Tire Choice
- Automated / Drive through car wash safe?
- Everywhere I go
- Lug Nuts...
- car dies when not driven for a day
- Fuel Consumption CVT resetting
- minor scratch repair - unsolicited plug
- Graduate from fitfreak - Becoming Senior?
- Interested in tinting windows
- Faulkner Honda Fit Custom
- What do I need to be Xenon ready?
- Any Gas Cubby or VehiCal for iPhone users wanna share stats?
- What Bumper/Kit is This????
- Aftermarket steering wheel w/ horn?
- Fit Got Hella Presents!
- Ksport Coilover Install Gone Wrong . . Any Help ? PLEASE and Thank You
- Happy Holidays
- Intake manifold torque spec
- current draw at off.
- Classifieds posting question
- Popping noise From suspension install
- Kid teaches us how to park a micro
- headlights broken helppp
- Any other East Coast Fits Pushing Snow
- does anyone know where the transmission fluid pressure sensor is ?
- Which lug?
- New to the Fit. Just bought a 2008 Fit Sport
- Car Alarm suggestions
- Part Numbers... Help me out!
- Might swap out my Front End... opinions?
- aux jack
- Got tires rotated, garage lost a lugnut, put on a generic...
- Any Fitfreaks in Boise, ID?
- What were the odds?
- HONDA OEM wiper blades
- Maintenance Minder - Early Read
- What the heck is this?!
- Where is diagnostic tool plugin?
- Your Scan Gauge reading under sub zero temperature?
- First winter experience
- 2007 Fit - need recommendations on convertible carseat
- Extended Warrantly Transferable to New Owner?
- new front bumper
- Poor Gas Mileage. Suggestions?
- Honda Parts Appraisal Program
- Jazz electric window switch
- big problems!!!
- So long all - my Fit's for sale
- Another FF'er with a bad EPS... lost power steering twice now
- Piston slap anyone?
- Son installed under-dash LED, TPMS and fogs stop working
- Friends VW GTI stolen
- Do You Need A Radio Code?? Message Me
- spoiler-help!
- HPS Short Ram Intake
- Seat bolt cover removal
- Whump-whump-whump noise, and new tire recs..
- when do you guys change your belts
- Unable To Start Fit 2004
- Horn changes pitch??
- Mold in carpet -- how do I know if it's gone?
- Am I getting bad fuel economy?
- Interior Paint
- question about TPMS sensor
- 2007 Honda Fit For Sale St Pete, FL 9,900
- Right front seat well flooded
- 3rd brake light for GD?(LED)
- Fuijita Short Ram Intake
- A Model Fit and a Slot car Fit
- Should i go Dual Xhuast?
- question about rear brakes
- Playing MP3 on the CD Player
- 2008 Honda Fit Vs People Mover. Round one!
- Keyless Entry+Dome Light+Radio Not working
- Door rattle? Try lubricating the seals
- Fit earns it's 5 star safety rating!
- Look of the base model VS sport
- Tire size 195/60/R15
- Cabin air filter - - how does one change?
- Blue vs Yellow?
- Toyota Tacoma Bed Extenders
- headlight removal help
- Gas mileage w/205/40-17's
- Water leak between door and door panels?
- Be careful PA peoples!
- Scangauge 2!!!! Help!!
- Throttle delay/hesitation & noise
- Check your front bumper/quarter panel area for paint chipping. Warranty repair OK.
- CEL Madness!
- I need help...having a hissy FIT.
- Header gasket leak!!!!
- wheel fitment question
- Nevermind
- Optional factory exhaust
- what size drop?
- Blinking D Light
- 06-07 Honda Fit
- oem tires & arrow markings
- Question about Selling my car
- Site suggestions?
- Need new rims. Suggestions? Difference from the 15s?
- 07 Fit Sprot DashDyno
- Rear Garnish question
- GD3 Gauge Pods????
- Roadtrip in brand new (to me) Fit
- TPMS light on, fogs don't work, spare tire pressure
- Looking at 07 Fit - any tips?
- wipers?
- Losing coolant?
- Is a 2007 Fit Sport automatic transmission the same as on a 2008?
- can a 2007 Fit be towed behind a RV with 4 wheels down?
- battery life?
- Interior Wet From Leaks? PLEASE READ!
- wink . . .
- 07 Fit OBD II connector location
- driver's side axle popped out.
- hi all new from uk
- Cel iPod Accessory holder?
- Fit power steering trouble
- Setting autolock on GD
- Jumped friends car .. burned headlight!
- Regular Maintenance?
- The First Hundred Thousand
- Someones dog scratched my Fit...
- That time of year.....I am looking for a remote starter
- Someone just hit and run me
- Civic Coilovers????
- Updated pics of my 07 Fit Sport...
- sway bar question
- Does anyone know if the 09 wheels fit on 07-08 fits
- Help: legit check
- Hi and thanks from Newbie
- Couple of good websites...
- Mega newb questions
- AT Sport better MPG with paddle shifters
- about springs
- everyone loves noob questions
- Sh*t, my son crashed my GD!!!
- Give me your opinions!!!!
- Need opinions PLEASE!!!!!
- Idling Problem
- JDM or USDM Bodykits and Spoiler?
- suspension noise . .
- mysterious noise
- [HELP] Is Megan racing parts decent?
- Drilled or drilled and slotted rotor with ceramic pads for under $100.00 shipped
- Hacked Fujita CAI.
- fog lights
- cf hoods
- When should I change my air filter?
- 07 newbie
- Sun Visor Question
- im having trouble dropping my car!!!
- Drop in Filter Question
- Noticed something in the trunk
- help me find!
- headers
- shift boot install question
- Pre-sale inspection in Toronto, ON area
- help with rims!
- 2007 Manual Clutch Judder Starting from 1st
- looking for a first car
- CF Emblem
- My engine just died while in park........
- mysterious ownage !!
- Has anyone tinted their mirrors?
- CupCake Meet?
- So my Fit is going to be in a commercial.....
- I need some feedback....PICS
- Nearly decapitated my Fit
- engine oil level dropping
- unusual noise-please help me . .pls
- door lock , difficult to insert key
- Un-Fit after 39K
- looking to mod my new to me fit
- who wants to help me???
- 2007 Honda Fit Key transponder
- header fitment
- Clutch Disc, Lightened Flywheel
- Miles on Empty?
- 60000 mile maintenance.
- help! need part numbers......
- Going to Honda
- Megan Racing Lowering Springs
- Headlights Problem.. PLZ help
- Rust on the rotor/hub
- More newbie questions (engine and cabin air filters, fuel injection cleaning)
- transmission click?
- skunk2 catback
- pioneer speaker
- Calling all Honda Fit Skunk2 ProC Coilover Owners
- wire tucked fit?
- Doing Up Jazz VTI advice please?
- The time has come.....
- 2007 Fit Sport suggestions
- Possible new fit owner, just some questions?
- ebay rotors and pads?
- Brake Recall GD3?
- Firing on 3 cylinders?!?!
- coilover question . .
- premium gas
- Electrical fault killed toddler
- Yikes, only 200 miles on a tank of gas!
- Ignition Coil
- Any suggestions of whats a good scan tool / scan guage for honda fit
- JDM Center Console $199.97
- 4K to go
- is there a group in the 909 area?
- PLEASE HELP! Header install question
- New clutch...
- Mod identification please? on front bumper
- First brake inspection and tire rtation
- Where to replace fog light plastic cover?
- Extended idling with AC on full blast. Bad?
- a/t not going to park
- 2007 Fit Total Loss
