PDA
View Full Version : 1st Generation (GD 01-08)
Pages : 1 2 [3] 4 5 6 7 8 9 10 11 12 13
  1. Road Trip in the 2007 Fit
  2. 2007 Sport Ac & Raditator fans won’t turn on.
  3. 07 Cruise Control Puzzle
  4. Weird power load
  5. What condenser from Rockauto? UAC, GPD, Denso, ADPI?
  6. Slow getting from fourth to fifth gear
  7. Rear brake size
  8. Led lights
  9. New tyres
  10. Help with aftermarket seats on 07 fit sport
  11. Condenser fan replacement video (not mine)
  12. non- running or crankingGen 1
  13. TorqAmp electric supercharger 5psi on 07 GD3
  14. non- running or crankingGen 1
  15. What to do with bad motor after engine swap
  16. More on faulty ignition coils!
  17. No reverse gear manual transmission
  18. Fuse for interior lights
  19. 08 Honda Fit won’t stay running
  20. Fit is TRYING to lock me out of the car
  21. Ran out of gas - air in the line?
  22. 2013 MT on 08
  23. No CVT problems/search
  24. Key wont turn forward in ignition all of a sudden
  25. GD3 Rear crossbars
  26. Quick intro: 2008 Honda Fit Sport M/T
  27. New to this. Engine compatibility question
  28. 2007 fit sport replace shocks and struts but still bottoms out on left side
  29. JDM vs USDM front differences!
  30. Astra car alarm isn't working - a ghost in the machine?
  31. Keyless system won’t start consistently
  32. Jerky/stutter acceleration and hesitation
  33. Seeking to acquire a Honda Fit
  34. Suggestions for 07 tune up please..
  35. Got mine re painted
  36. JDM hazard switch install ...
  37. Help! Honda Fit Sport 2008 overheating/loosing coolant
  38. GE8 steering wheel to GD3
  39. Do all sports have keyless entry?
  40. Honda fit gd18 06’ mt from cvt
  41. 2007 Fit Sport New to me
  42. Doors lock but won't unlock
  43. Control arm issue
  44. 2008 Fit Weird electrical problem
  45. I like to stop when I press a brake pedal
  46. car not not starting after changing the engine and its harness, gearbox and computer
  47. Need help finding a no start gremlin
  48. Help: ecu pinout for jazz gd
  49. Starter [noise] update
  50. My 5 day nightmare (and other introduction stuff)
  51. Turn signal light stays on
  52. DIY: Wheel cylinder rebuilding!
  53. Engine Mounts 08 Base MT
  54. Slight click/clunk w clutch pedal
  55. USB bluetooth adapter that works in 2009 Fit Sport
  56. 2007 Honda Fit Aftermarket Drivers Seat Resistor help
  57. Partial 12v Power cut out when driving
  58. Lots of work done already, what else can cause the misfire problem?
  59. 04 GD3 fit HID problems.
  60. metal "shearing noise" coming from alternator area of engine?
  61. dry and broken car window weatherstrip seals
  62. 2008 hatch/trunk cover
  63. Steering wheel trim change
  64. Overheating issue
  65. Clunk gets better when cold
  66. Strut Replacement Options?
  67. Low beam headlight problem on 07 Fit
  68. 2007 FIT Shakes then Stalls
  69. Completely dead in freezing temps, starts up perfectly in the afternoon.
  70. Please help
  71. 3rd/high mount brake light question
  72. cold air intake
  73. Trying To Source New Carpet
  74. Missing at Idle only
  75. Mortorcycle Trailer
  76. 07 Honda Fit Sport- Bent Ally/Aluminum Rim, suggestions?
  77. Other owners thoughts when upgrading to a newer model.
  78. How Does a CAI Affect MPG at Highway Speeds?
  79. Catalytic Converter replacement for manual Fit (Cali)
  80. Idle problem and aircon problem
  81. new (to me) '07 fit! three issues
  82. 07 Fit - transmission suddently doesn't engage, just makes thumping noise
  83. Testing an engine block heater
  84. Remote Car Starter options for a 2007 Honda Fit Sport..
  85. Moog sway bar end links
  86. Fit Neutral Drops
  87. Blower speed control fell apart
  88. 07 fit on 33's
  89. Rock auto closeouts!
  90. Sprintex charger in first Gen/L15A1??
  91. Oil sump the same????
  92. Strange behavior 5th gear
  93. catalytic converter - which one
  94. DIY valve adjustment but still ticks
  95. broke valve cover bolt, how to replace?
  96. Fit code p0443
  97. Throttle body spacer gd3
  98. Will the Tein Basis Z fit a 2008?
  99. honda fit 2004 model high rpm problem
  100. Starter swap; it's not a solenoid!
  101. Hanging Wires at Muffler
  102. Honda fit 2004 issues
  103. I'm super confused by this power issue, please help!
  104. Power window to manual conversion?
  105. '08 cold start fail (120K) - local shop in Springfield MA?
  106. Replacement Key Fob Programming
  107. Did any gd3 fits have stock rear brakes?
  108. “Unusual” spark plug wear
  109. Bad Battery or Bad Alternator?
  110. 6 spd trans swap
  111. MUGEN Visors Legit Check?
  112. Scraping noise front left
  113. Stock airbox mod *first post!*
  114. How many miles does a automatic transmission last on a 07 Fit?
  115. Ventilation + pencil = no good
  116. Throttle body spacer
  117. Honda jazz 06 jumpy and weird noises
  118. looking for a part of the door lock 2007 Sport Model
  119. TPMS Sensors in Indirect TPMS Wheels
  120. Alternator Replacement or Spark Plugs
  121. wheel bearing/abs wheel speed sensor problem
  122. Lurching while accelerating
  123. P0420 - the mistery
  124. Need mechanical advice for my 08
  125. Yellow Fogs
  126. Polk DB651's - Starboard side speaker is cutting out
  127. Unknown wire connection
  128. Looking for more low end torque . 08 5 speed
  129. Junk yard visit (bonus: torque converter)
  130. Least grabby, low dust Ceramic brake pads for GD1
  131. Bolt size for backseats?
  132. Ignition plugs
  133. 2008 Honda Fit Sport Keyless Entry Troubleshooting Story
  134. help with fuel pump housing, 1st gen FIT
  135. More mods !!!
  136. Strut / Shock Replacement How To Guides
  137. Gd3 bolt ons so far
  138. Wheel Spacers
  139. Starter noise elimination trick
  140. P0700 & P1705 after instrument cluster change
  141. Check Engine Light indicating issues that my mechanic says aren't there
  142. Trouble after head gasket
  143. Bad noise in engine (video included)
  144. is it possible to use a 2007 honda fit ecu in a 2006 honda fit?
  145. Brake pedal pad thingy
  146. My first Valve lashing experience. (not good)
  147. Taking starter solenoid apart
  148. GE8 Springs on a GD3 - I have Questions?
  149. L15a1 turbo build
  150. New wheel/tires setup!
  151. AC on and off (mostly off)-2008
  152. 2007 fit A/T. just bought today, a bit loud in the top end under load?
  153. Water leak?
  154. The saga continues... 2007 Fit 120K miles.
  155. Protecting J's Racing CF Lip?
  156. Exhaust flange dimensions
  157. Weird problem; stuttering intermittently, not a misfire (but feels like it)
  158. 2007 base model keyless entry
  159. how to tell if you got ahonda fit burnout ecu/pcm
  160. Gd3 bolt ons
  161. shocks question
  162. Won’t start
  163. Check Engine Light randomly coming on
  164. Airbag Replacement Advice
  165. scanner wont connect to ecu after rainy day and key started flashing too
  166. No crank no start
  167. Camshaft position sensor
  168. Belt idler replacement pictures
  169. How do you hold up your phone for GPS?
  170. Root cause of starter grind is identified 11 years ago!
  171. Poor white fit (YouTube videos)
  172. Manual trans
  173. Heavy steering and loud vibration when turning left
  174. Honda Fit leaking oil from under exhaust header
  175. Power Steering Failure & EPS Module Replacement: Are my symptoms consistent?
  176. Hondata
  177. Think I've got at least 1 bad coil, and I'm broke too...
  178. Detached Muffler Hanger
  179. Installing Keyless from GD3 Sport in a Base 08
  180. 08 5-spd Fit-have to wait an hour or so before my 08 Fit will restart
  181. How difficult is it to replace Evaporator on 2008 Fit
  182. A/C Issue (Honda Fit 2008)
  183. Junk yard visit: white fit covered with cement dust
  184. Honda Fit Jerk -CKP Sensor
  185. Rear strut bushing orientation?
  186. High-pitched grinding from left-front wheel
  187. Engine rocking when shifting into gear
  188. Shock & Strut Recommendations, with photos!
  189. Valve Adjustment Tools List
  190. Country Roads to Canyon Climber... Refreshing my '07
  191. Newbie . Just landed a 08 sport auto.
  192. Piston slap explains jumping ignition timing angle on my car
  193. Window issue
  194. Headlamp lens removal
  195. Los Angeles Mechanic Recommendations
  196. JDM Engine swap?
  197. Horn contact point
  198. Engine ticking-- source located
  199. Help me search...air problems
  200. Cooling fan and Radiator Fan
  201. possible disconnected hose underneath car?
  202. New Here and Thinking About a GD Fit for Next Daily Driver
  203. MT Shift Lever Sheared off!
  204. 2007 Base Fit - Rear Passenger Door Lock - Maybe not actuator?
  205. AC/Radiator fan issue
  206. Hie everyone
  207. Looking for a first gen driver door
  208. Fuel Injector Replacement
  209. Horn not working
  210. How many miles are you covering when the low fuel light comes on?
  211. Advice on buying 2003 GD5 with 456k km (283k miles)
  212. Idle roller change (Don't cry for me, Argentina!)
  213. AC clutch not engageing. Owners manual?
  214. Tire Wear
  215. Taking starter apart (to fix the after start noise)
  216. Mugen NR 15s
  217. Replacing rusted out rocker panel
  218. CV axle change - fluid loss?
  219. Cheap intake
  220. Poor Mileage on an 08 Fit
  221. 15 vs 16 - wheel sizes - pros and cons
  222. installing after market radio, missing some dash lights
  223. AWD to FWD Conversions?
  224. Honda Fit Sport 07 not as peppy as it once was
  225. AC only works good while driving fast
  226. Wrecking yard visit; alternator dissection
  227. Time for a new Catalytic Converter
  228. Radiator drain valve petcock safe to operate?
  229. 07 fit sport A/T
  230. Idle RPM and Slight Clicking Noise
  231. Sanity Check Please
  232. How Many Are Left?
  233. Weird screeching noise
  234. Honda Fit feels very loose in the rear
  235. Experience with LED bulbs - blinker & reverse
  236. Where do I find front lip/spoiler installation brackets?
  237. GTA CarKit bluetooth system?
  238. Under bumper/engine plastic panel info..
  239. Has anyone ever made a table for the back?
  240. Speaker wear and Integrated Bluetooth installation
  241. A/C Flush Questions
  242. Honda MTF.. Are they all the same?
  243. Brake issues all of a sudden
  244. Broken windshield wiper assembly
  245. Reliability
  246. What is this part?
  247. A smog check disaster entered junk yard (2008 Fit Sport)
  248. Gd3 newbie what should I do? Suggestions
  249. 2007 Fit Problem(s)- 67,000 miles
  250. Rack and Pinion replacement
  251. Rumbling Engine after AC Turned on
  252. Lowering Springs or coilovers?
  253. Vibration when accelerating between 60-70km/h
  254. 2007 Fit Sport Won't Start? Starter or electical issue?
  255. Gd L13a swap to a gd L15a non vtec
  256. Fit overheating. Need help.
  257. 2007 Honda fit sport wheel change suspension problem?
  258. 2007 Fit Sport AT 15,000 Mile Service
  259. I finally got my hands on a fit! cleanup, and suspension refresh
  260. Blower motor problem solved
  261. 08 GD3 Fit HVAC Diagnostic Trouble Codes
  262. Possible transmission issue?
  263. HVAC Recirc Air Door Problem - Need advice
  264. Is there a hot lead somewhere to connect a USB........
  265. Transmission mount
  266. How to quiet down the cabin noise?
  267. A/C Black Death
  268. Junk yard visit (wheel cylinder wear analyses)
  269. GD3 SRS airbag cover
  270. 2003 gd led headlight bulbs
  271. 08 sport fit towing
  272. GE exhaust on a GD
  273. Wet passenger footwell
  274. Swap seats form 2007 fit to 2015 fit
  275. 08 fit sport features?
  276. [Advice] 07 Sport - Rear Roofline Weld Failure (and the dealership says suck it up)
  277. 08 ECM Programming
  278. Brake shoes spreader and Junk yard visit
  279. Honda fit 2008 starting issues
  280. Suspension knocks?
  281. Need help with choosing wheels for my GD3
  282. Is this a misfire?
  283. USDM Front bumper options
  284. Buying a 2008 Fit tomorrow. What do you think?
  285. Anyone recognizes this car? (So Cal)
  286. Fit 2007 right side power windows problem
  287. CV axle won't come out
  288. Performance shops in AZ
  289. 2008 Base Fit - Aftermarket Key Fob Suggestions?
  290. Help! 2008 Fit radio faceplate problem
  291. Relay locations
  292. Honda fit 2005 gd1 speaker size
  293. I need help plz!!!
  294. Clutch replacement/recommended maintenance
  295. Mods for NA Sport
  296. Thinking of buying a first generation Fit. Is 200k miles too much?
  297. turbo kit
  298. Homemade key? Not quite well:)
  299. Airbag recall on 2007 Honda Fit
  300. Is the GD sport radio a direct replacement for the base radio?
  301. Faster shifting?
  302. Rear camber kit?
  303. ❤️ my Fit, but car noob. Your advice?
  304. Door lock cylinder repair experience
  305. Power Locks Issue
  306. Coolant Sensor Troubles / Control Box
  307. Honda fit 1.5 vtec low rpm and hesitation
  308. Cheapest possible key for Honda fit _sport_ 2008?
  309. How thick should new rear drum shoes be?
  310. Parking pole question...
  311. Power steering not working!
  312. Spare Tire Mount in Trunk
  313. Spare Tire Mount in Trunk
  314. Passenger Side Water Leak Hunt
  315. Will OEM 16" 2009/2010 Fit Rims work on an 08 Honda Fit?
  316. Roof Storage / Coffin Recommendations
  317. Cable or Chains?
  318. AC Compressor Clutch Won't Engage
  319. Misfiring Fit
  320. Honda Fit Aria 2007 - GD08. Misfiring/Skipping Issue.
  321. #3 coil misfire
  322. Interesting video about Denso starter noise
  323. Need help with motor swap
  324. Spare key replacement.
  325. Air coming from oil fill hole - PCV?
  326. Looking for an air cowl scoop
  327. Sound system setup
  328. install a head unit in 1st gen honda jazz
  329. obd2 plug help
  330. Anyone know what other USDM GD lips are on the market?
  331. Fit engine pullies,, anybody tried swapping?
  332. baterry light goes on and off after new altenator and battery
  333. Bad coil package honda fit 2008?
  334. Speed sensor stupid question...
  335. 2007 Honda Fit Clicking
  336. 2007 Fan speed control issue *NOT BLOWER MOTOR*
  337. Fit losing & gaining power
  338. 2008 honda fit bad mpg
  339. Fumoto for ATF?
  340. whatisthatfor?
  341. adjusting to save more gaz
  342. Could it just be the valves?
  343. Head replacement vs "new" motor
  344. Rear driver side floorboard is soak!
  345. Center Arm Rest add-on?
  346. CEL Flashes on Cold Start
  347. Please assist with this part
  348. Lowering my gd3
  349. 2007 Fit steering column cover
  350. Honda Fit dress up ideas.
  351. Aftermarket lower control arm options
  352. New Member 07 Fit Sport
  353. Coolant replacement (calculation)
  354. Rear Drum conversation to disc brakes.
  355. Weird Fit
  356. 2006 Jazz 1.5 vtec (L15A1) engine vibration
  357. Under shift cable protective cover
  358. Ksport review?
  359. Shocks + struts - Gabriel, KYB, or Monroe?
  360. Thermostat change instructions (read intro first)
  361. CEL, simultaneous codes P0103, P04E5 and P0003
  362. Mods on Honda Fit GD1
  363. 07 fit sport Mod recommendations
  364. Engine swap
  365. Engine swap
  366. Radio knob removal with special tool
  367. Control arm bushings showing their age
  368. If my battery disconnects, will car keep running?
  369. Looking to buy a 08 Sport...Question about Paint?
  370. Help With Starting issues
  371. LCD radio display change notes (with pictures)
  372. Finally! LCD radio display change video
  373. Did my transmission just die?
  374. All power windows out! Please help
  375. Greeting another Fit on Pick Your Part!
  376. Car won’t go into Park
  377. Bearing for an idler roller
  378. GD3 7 Speed Mode not working
  379. Your Favorite Brake Pads?
  380. Brake making grinding sound while driving, skipping while braking, car pulls to the s
  381. Coolant circulation in GD3
  382. Found a starter replacement video (Check his channel!)
  383. Junk yard visit: accessing starter
  384. Part # or hose ID please
  385. USA/Canada vs Mexican Brake pads?
  386. Window switch?
  387. **Aftermarket Advice**
  388. Transmission fluid
  389. How long did your 100 month battery last?
  390. GD Engine removal with no hoist - remove from top or bottom?
  391. 02 ep3 si seats installed in my 07 fit sport
  392. HELP PLEASE(CUT RADIO PLUG)NOW NO ALARM/no obd2/ OR NIGHTTIME RUNNING LIGHTS
  393. 2001 ep3 si seats installed in my 2007 fit sport pics included
  394. Drivability issue help?
  395. How many miles is too much?
  396. This bag did not save the driver (wrecked Fit)
  397. Battery quesion....
  398. Running w/ Unplugged EGR
  399. Which 02 sensor
  400. P0304 Misfire - HELP!!!
  401. SmartCard Key
  402. '08 Shudders, Loses Power When Starting Up
  403. Inside of the throttle body (pictures in Doc file)
  404. AC works for the first couple of minutes
  405. 2003 Honda Fit valve adjustment?
  406. Are the Jdm chrome door handles for the GD3 plastic or aluminum?
  407. How are your license plate placed on your GD3 trunk
  408. The Honda Rust Spot
  409. Door locks on the fritz
  410. Hello, long time lurker, '08 Honda Fit getting older
  411. I wonder if the 6 speed manual can be replace with the factory 5 speed manual
  412. What is our 16450-PWC-J01 Fuel Injector flow rate?
  413. Diagnose of random low idle speed (engine warm)
  414. New idler pulley - Febest 0387-GD
  415. High Mileage Items to Watch, Replace?
  416. Scangauge II is saying my Fit is averaging 15 mpg, LOL
  417. Looking at a 1st Gen Fit. Common issues?
  418. Help diagnose this rattle (CVT in Drive when stationary)
  419. Dashboard Flickering
  420. 1st gen honda insight wheels
  421. ABS/brake light
  422. Ktuned Universal harness
  423. Turning the backseat area into a storage area
  424. 2007 fit service manual
  425. Noise front right
  426. My Fit has some quirks...
  427. Need some help please - Seicane
  428. Experimental drum brake job (to test a tool)
  429. Turbo Install questions
  430. Clutch not Springing Back??!
  431. '07 MT front bushing WTF?
  432. Purchasing a 2008 Fit
  433. Newbie
  434. 07 GD3 High revs low acceleration. 45 MPH fifth gear
  435. Won't start Code 61-1
  436. Assistance on Cruise Control, Please
  437. do 2015 honda fit tires fit on 2007 honda fit
  438. Info on DBW setup
  439. New member questions
  440. Transmission fluid
  441. What’s this?
  442. L13a egr
  443. 2007 fit a/c cold and warm
  444. Blitz Throttle Controller = Weeeeeeee
  445. Another junk yard practice (including tearing down a/c condenser fan
  446. Transaxle Stress Cracks?
  447. 2008 Honda Fit Sport keep or set free
  448. Odd engine noise when accelerating
  449. rear door parts??
  450. 08 Honda Fit ECO gearing swap
  451. Is there a go-to roof rack people like?
  452. Tein Flex Z on a GD3
  453. Can’t disarm factory alarm with spare key w/out remote - HEL
  454. 2007 Honda Fit Starter Bolt
  455. Part # ID
  456. Automatic lock feature on 2007 Fit?
  457. How do I post/link video to ff?
  458. 08 Manual Transmission Fluid change
  459. Towing a small trainer with 08 Fit
  460. rear suspension springs (Upgrade?)
  461. This is a knock, right?
  462. Help me identify this connector
  463. Omex limiters
  464. Any suggestions on a repair for a key fob?
  465. Issues with power lock and window in one door only
  466. Race Thread?
  467. 230k miles - replace gas filter?
  468. 2008 Fit AC Problem
  469. 07 Can't Get it Started
  470. I'm back baby!!
  471. New brakes
  472. Recurring problems with CEL and Engine Coolant Temperature Sensor #2
  473. 2008 Honda Fit Sport IAC location?!
  474. Racing scca autocross h street need suspension advice
  475. Honda fit 2002 gd3 L15A vtec engine information about
  476. Any recommendations of new tires?
  477. Sideview mirror glass cracked HELP
  478. Lifting my fit
  479. Challenge: Identify this missing fastener (front door hinge)
  480. D17 Honda Fit/Jazz
  481. USDM J's Racing front lip
  482. The dead pedal issue again...
  483. Is My Fit Dying Loud Knocking
  484. Parts for a 2003 Honda Fit
  485. Axle problems??
  486. New (Old) Fit owner with suspension questions (not lowering)
  487. JDM Red Honda Badge size
  488. Second, 1st gen
  489. 07 fit sport stalls after driving 30 minutes
  490. High mileage maintenance questions
  491. Check your condenser fan / Easy how to replace condenser fan
  492. GD Bargains and Finds
  493. Progress Rear Sway Bar - Review for GD3
  494. Best way to do rear brakes
  495. Inside of a/c and defrost switch
  496. Cowl Scoop, Air Scoop
  497. Any aftermarket bumper for USDM GD?
  498. How do I replace the condenser fan in my 08?
  499. Brake rotor replacement
  500. AC works... for a few minutes after a cold start
