PDA
View Full Version : 1st Generation (GD 01-08)
Pages : 1 2 3 4 5 [6] 7 8 9 10 11 12 13
  1. Excessive Vibration
  2. Bumper screw part
  3. Maintenance for Coast to Coast Move
  4. Pointed me toward some good speakers
  5. Dragging spring?
  6. Steering Wheel Audio controls for '08 Fit Sport
  7. vtec question
  8. I need a good book.
  9. Radio wiring harness diagram for 2007
  10. 2008 Honda fit parts?? & where?
  11. Door keeps locking
  12. Hard shifting in AT 07 Fit Sport
  13. DIY cabin air filter?
  14. 2008 Honda Fit / 140k miles
  15. NEW Fit Owner in the tropic
  16. JDM Red H emblem sizes for GD2
  17. P0300 + Other cylinder misfires, only under load.
  18. Radio display flashing off with left turn signal!!!
  19. New Honda FIT owner, now what ?
  20. Bad ignition coil or just boot and spring?
  21. Do I have to let the ECU "learn" after replacing the coil packs?
  22. 07 GD3 noise
  23. brake issue,
  24. What is the service menu for GD3 for each service intervals?
  25. 2005 Honda Fit/Jazz GD2 Parts??
  26. GD2 body kit questions??
  27. Make it hotter!
  28. 1,000,000 m/km?
  29. hid problem/bi-xenon..
  30. Near stall at idle
  31. We serve the bumpers of GD3 to GD1 ...?
  32. O2 issues & Exhaust
  33. Wear to buy blues mirrors
  34. Question about Fit Horns
  35. Omg super deal on ebc brakes!!!!!!!!!
  36. newbie looking for advice on buying used
  37. CD/radio no power
  38. 2002 GD Engine and Transmission Replacement
  39. Curtain Airbag Went Off - Anyone know how to repair this / have a shop manual?
  40. mugen style Door Visors/Wind Deflectors
  41. Blinking D Light/Check Engine light issue
  42. Code P0497
  43. 2007 Fit Sport Battery Usage when engine not running
  44. 08 misfires once in while
  45. 07 fit sport got 4 engine codes need help thx
  46. Valve adjustment
  47. 07 fit sport dont wana start help
  48. valve adjustment question
  49. New tires have killed my fuel economy
  50. Strange noise from front dash?
  51. 85k Maintenance Interval
  52. new owner of a preowned fit
  53. 07 Fit Dies on Uphill Stop
  54. Separate Key and Remote?
  55. Need advice
  56. 2007 Fit won't start
  57. Looking for black headlight housing for the gd.
  58. Does GD clutch master cylinder have a delay valve???
  59. gd3 ABS
  60. Just wondering about hondafittuner.com?
  61. Clutch upgrade??
  62. front rotor options...
  63. Car Trouble / Possible Trade in Question
  64. AC on recirc, where is the intake?
  65. New build thread/forum intro
  66. New build thread/My intro to the forum
  67. Honda Jazz Left Mirror And Window not working
  68. Headlight dimensions? Retrofit
  69. Car came to a wobbling halt..branch, brakes, or BS?
  70. Wanted: Rent me your 1st Gen Honda Fit, Jan 31 - Feb 1 Los Angeles area
  71. Heater
  72. installing Keyless Entry
  73. 2007 Clutch DIY
  74. Car jerks when in 5th gear and going up hill
  75. Car won't start, battery is good. HELP
  76. To buy coil packs in Toronto
  77. Ipod cable
  78. Engine replacement
  79. 2008 Sport DIY Variable Intermittent Wiper
  80. Stalling when cold and other problems
  81. Stiff motor mounts
  82. O2 Sensor
  83. Interior colors....bright titanium?
  84. HELP...Emblem grille honda 2003
  85. Exaust Fumes In Cabin After Jacking Car
  86. Has anyone here NEVER replaced their coil packs?
  87. Keyless entry
  88. Possibly purchasing '08 Fit Sport MT
  89. Cruise control
  90. It wont let me post in FS! Apexi N1 in SoCal
  91. New 08 Fit owner; snow tires rubbing fender liner?
  92. New Parts for my FIT from Torque Solution
  93. O2 Sensor question
  94. Engine whines a bit when starting in cold weather
  95. GD3 all wheel drive off road in Russia
  96. engine warning hasn't reset after new part install
  97. Question Involving DTC Codes
  98. New Here
  99. WD-40 to unstick a hazard switch?
  100. Hello Everyone...
  101. Rough Idle and Acceleration
  102. Hatch Window Replacement?
  103. Noise with the 07 Fit
  104. LED headlight problem
  105. Car Alarm
  106. engine stutter at stops
  107. Weird "whistling" sound only while in gear and after car warms up
  108. Driver's side window not working after recall
  109. Transmission question
  110. Material cracking under carpet near firewall
  111. How long does a Fit battery last?
  112. Can I fill up the back of my car with firewood or too heavy?
  113. Front bumper clip repair?
  114. Seibon Sale!!!!
  115. honda jazz
  116. js racing grill any one help
  117. CVT issues.
  118. hi there new member from scotland
  119. Recomended Camaera's/ ??
  120. broken sun visor clip
  121. engine oil viscosity
  122. Newbie From Ireland
  123. P0718 due to Overheating AT engine/Transmission
  124. While replacing battery, my wrench sparked between +/- posts. No power at all.
  125. Another new Fit owner checking in
  126. Spare Key
  127. ECU swap question
  128. Different wire harness between 07/08
  129. car won't crank
  130. Part name for sun visor holder?
  131. GD vs GE cargo space
  132. Coil on plug mounting screw torque
  133. help bumbers
  134. TPMS light on GD3
  135. Need to identify this weird noise
  136. Car dies for split second and comes back.
  137. Need Help: Replaced remote battery but nothing works
  138. Virtual Driving GD3 (need help measuring the suspension geometry)
  139. Slight idle issue
  140. 2007 Honda fit sport- engine replacement
  141. 2007 Fit Sport 101k miles - Dealer wants to put new engine
  142. exhaust help
  143. Honda Keyless Entry installed, lights blink incorrectly
  144. Annoying dashboard squeaks and rattles
  145. kraftwerks automatic belt tensioner info?
  146. 08 honda fit AIR BAGS
  147. Odometer/Trip meter problem
  148. Acceleration issue
  149. 2008 Fit cold weather, won't start
  150. Tire Size for 2006 Jazz GD3
  151. Do I need to jack up car to change coolant?
  152. Transmission Fluid Pressure Sensor/Switch "B" Circuit Low
  153. New Fit Owner Intro
  154. Need help with ELM327
  155. Looking to trade by LED Tail light
  156. Disable auto lock on '07?
  157. My "new" 211kmi '07 Fit
  158. running rough - wiring harness?
  159. Re-keying locking gas cap p/n 17680SAAG00
  160. Newbie
  161. k swap
  162. driver side (left side) cowl removal?
  163. Smart key shenanigans
  164. Armrest advice
  165. Engine swaps for the fit ?
  166. Trying my luck... Voltage/electrical problem.
  167. Need help to buy new rims!
  168. New comer
  169. GD3 Grill Help !!!!
  170. recirculation doesn't work?
  171. EGR valve
  172. Vibration when going 0-20kms
  173. 2007 Fit Brake Job –Midwest style-including alternate solution to rotor run-out issue
  174. Thinking of making my Own Roof Rack???
  175. car wont turn over
  176. First smog check :0 uh oh.
  177. 2007 Fit Base Keyless Workaround?
  178. Hesitation/hiccup when accelerating
  179. Question: JDM bumper parking pole
  180. Question re hitch install / frame inserts
  181. Anyone know where I can find a Perfect Fit Bug Deflector For 2008 Fit Sport?
  182. Airbag shrapnel
  183. PID scan results
  184. Front Clip Question
  185. Making OBD2 scanner fit into Fit (pardon the pun!!)
  186. Are there any Colorado Fit groups?
  187. windows not working
  188. Fasteners for Front Facia 2007 Fit
  189. Looking for 2007 stock wheels and suspension for my fit
  190. Help a brother out! 2008 Fit with 120K
  191. Newbie intro, front plate mount, and floor mat questions
  192. 07 Fit Sport Dome LIght
  193. Looking to buy: 33k miles vs 150k miles
  194. Camping in a Fit?
  195. Phone charger power cycling
  196. Sourcing a Tailgate Weather Strip
  197. All About Tablet Mounting
  198. 20HP and 20ftlbs torque gain?
  199. Replacing interior carpet
  200. the old "add an AUX" thread has dead pic links
  201. New to FitFreak!
  202. tell me about radio codes?
  203. Remote start needed
  204. New Fit Owner - Looking for Fitment Advice
  205. GD1 queries
  206. Winter Floor Mats
  207. Immobilizer??
  208. The missus has a Fit
  209. New from the island of Guam
  210. New member, got Fit!
  211. Thermostat showing -52 Celsius
  212. XADO CVTF? Any one tried?
  213. Just got an ELM327, what's a good app?
  214. Raceconsultingagency.com legit?
  215. Coasting in neutral ..auto..
  216. Radio display screen dimmed
  217. New Look for my GD3
  218. An amusing video on a guy and his FIT...
  219. What would handle winter best- a 2007 Honda Fit or a 2007 Dodge Charger RT?
  220. Help New Honda Fit 2007 Owner in Canada
  221. New GD3 owner here!
  222. Need help on my washover please
  223. Base vs Sport odometers MPH calculation same?
  224. Hey guys im back!
  225. Jazz 03 GD Tailgate
  226. New Fit owner
  227. Finally a Fit Owner!
  228. Do the Canadian 1st gen Fits have the telescoping wheel feature?
  229. New To The Fit Scene
  230. I think my door panels were installed incorrectly
  231. Pale blue 1st gen. FIT
  232. over filling gas tank
  233. How much do you think 190k fit is worth?
  234. new owner here 07 fit
  235. new guy saying hey !!
  236. First Post - Introducing My 07 SSM Fit
  237. New guy with an 07 Sport 5MT checking in
  238. Found an 08 Fit Sport Auto at salvage today
  239. NO ETANOL in BP silver grade gasoline mid NC
  240. Tsunami Wave!
  241. Have you tried: DIY USB seat cushion fan?
  242. Just curious...how long have your rear seats been down?
  243. Any help? Im new
  244. Fyi
  245. seeking advice from the community
  246. Honda, Mazda, Nissan issue recalls over airbags
  247. Selling Parts or Quick Give Away
  248. 07 fit electrical issue
  249. How hard is it to replace front tie rod?
  250. "Fit" Emblem Location
  251. Will non-remote key work for 2007 Fit Sport?
  252. Spark plug issues
  253. stuttering 2007 Fit with MIL
  254. Code 2647 - Rocker arm actuator stuck on repair.
  255. Strange Washer Fluid Situation
  256. Bolt Won't Come Out
  257. Squeaking/Grinding in reverse
  258. ATF Question
  259. Honda Jazz CVT fluid Australia
  260. Starter removal: upper bolt
  261. Piece of rubber boot fell inside spark plug hole.
  262. How to remove the tow hook cover?
  263. 60 and 90k maintenance
  264. Replacing spark plugs
  265. Valvetrain noise when cold.
  266. need help pls... base map greddy emu turbo
  267. Leaking from gearbox
  268. Tire PSI
  269. Skunk2 Short Shifter install - Sloppy in neutral.
  270. AC Problem now it won't start, diagnosis?
  271. Did my first valve adjustment
  272. Automatic shifter light
  273. What maintenance should I start with first?
  274. Carbon Fiber Hood with Hood Deflector
  275. k20 swap
  276. 2008 Manual Shift boot replacement.
  277. Bad starter no crank no click (new battery, old problem)
  278. Manual Transmission Fill Plug really awkward
  279. Dangerous problem please help!
  280. Worst thing that happened to your Fit?
  281. Please Help ME!
  282. J's Racing front lip???
  283. New fit owner
  284. Would 2010 Weathertech floorliners fit a 2007?
  285. New to me 2007 Fit Sport
  286. Electrics die but engine doesn't stall
  287. License Plate Frame Bolts Coming Off
  288. WTH: Bernardi parts closed?
  289. 07 sport shudders at 2500 rpm
  290. New (to me) 2008 Fit Owner
  291. Fit 2001 Parts
  292. What should my next upgrade be?
  293. Valve Adjustment?
  294. Fog light wiring question
  295. Buzzing vibration on low speed braking while hitting a bump
  296. Honda fit Japan and Honda US Interchangeable parts
  297. Assistance needed (Honda Jazz 2007)
  298. new to me 07 fit locks don't stay locked
  299. Radio LCD Problem
  300. Messed up my dash with a phone mat, & alcohol
  301. New owner, this site rocks
  302. What are the torque specs for 2008 valve cover bolts?
  303. Service interval
  304. Random starting woes 2008 Fit Sport
  305. Rusty drive axle covers!
  306. continuous fluctuation rpm when driving uphill
  307. I'll be hitting 100k...
  308. Gurgling/rushing water sound
  309. New Guy Post
  310. Bizzare shift patterns
  311. Anyone in Orange County have a set of camber bolts I can buy tonight or in the mrng
  312. Rear end noise?
  313. good spots to tune in socal?
  314. good spots to tune in socal?
  315. Searching for a Honda Jazz 2007
  316. New to the forum. Have a lot of work to do on the car.
  317. Possible Buy but body work
  318. ipod hook up in my glove box. (suprise)
  319. Looking for a dead pedal
  320. Engine oil leakin' ?
  321. Car Dealer's badge removal
  322. Rust bubbles on driver's side door
  323. ATF Filter?
  324. new FIT owner :)
  325. 2008 Fit Sport Buying Advice
  326. Driver door lock cylinder problem
  327. Before I pull the trigger (high mileage fit)
  328. Haze in head lights
  329. Clazzio Help
  330. Missing headliner clip
  331. Stiff steering and no self center wheel
  332. jack compatibility...
  333. Repair Manual?
  334. Water Leak
  335. Hit and Run
  336. Hello, new guy question
  337. Fresh Meet Spring Bash
  338. Plx gen 3 wideband/0-5v diagram wire output??
  339. will not start
  340. Was is the difference between lb/ft and ft/lb?
  341. Misfire problem!
  342. Pretty Mad
  343. 2007 Fit Clutch problems
  344. Purchesed '13 base model with 5 speed auto for $15,954
  345. X-guage CANLF questions/revelations '07 base
  346. cyl. 1 misfire,again.
  347. Clutch Adjustments
  348. upgrades for my wife....
  349. Engine vibration at idle.
  350. GD L15 to L13
  351. 2008 honda fit lowered
  352. Unusual O2 codes
  353. New to thread
  354. Clutch Problem 2008 MT
  355. GD1 fit Jerk at stop light.
  356. Can my 1.4 idsi uses 1.5 gearbox?
  357. Who's Got Intake Info?
  358. Broken Wheel Studs
  359. Auto to manual 07 fit
  360. 05 UK sport bumper fit on 07 USDM?
  361. 07 Fit; can't fix p0302
  362. 08 Fit won't start( not a battery issue)
  363. ABS/Hand Break light on
  364. Airbag light on (not passenger) [PIC]
  365. Manually lock door without holding the handle open?
  366. Another FNG & Question about Interior issue
  367. Does your fit give any warning before the battery conks out?
  368. 2007 Fit... Red Flags, what are they?
  369. bad 12v accessory socket?
  370. Water inside doorwell problem
  371. hondata mobile
  372. What are the correct, or best spark plugs for a 2008 Hinda Fit Sport?
  373. Need to find this part for my fog lights
  374. Anybody recognize this car for sale in Jersey?
  375. Replace 2007 FIT Rear Shocks
  376. Coil pack cleaning
  377. Spark Plug Gap? Denso Iridium Power IK20L # 5358
  378. NJ Meet up!!!
  379. Broken coil pack bolt... what to do.
  380. High RPM
  381. First Gen Honda FIt 4 wheel drive video.
  382. Honda Fit Base vs Sport Rear Bumper
  383. Traveling misfire...
  384. Just got an 07 Sport @ 140k, what should I be looking out for?
  385. Honda service troubles
  386. 2008 Fit Sport-Radio Shuts Off When Driving
  387. engine shakes on cold start up.
  388. New coil packs needed, inlet, exhaust side or both?
  389. HELP!! Big Trouble.
  390. Excessive fuel consumption and shudder above 70mph
  391. Newbie needs advice ...where do I start....
  392. What to expect on a front brake pad replacement
  393. Parking Light Replacement Issues! Help!
  394. Help me
  395. Catalytic Converter Heat Shield
  396. Small head units
  397. Need advice on salvaged 2008 Honda Fit Sport
  398. Need help removing rock chips off my honda fit asap!!!
  399. Someone here have a retrofitted Q45 projector?
  400. Low beam headlights don't work but high beams do?
  401. SKUNK2 Short shifter adapter for Honda Jazz GD3 2004 MT
  402. I get locked in the car.
  403. Rattling noise when a/c is on
  404. Back door won't open from the inside
  405. newb
  406. Bumpers- What Should I Do?
  407. People with 38+mm offset rims
  408. check engine light question
  409. Engine shaking/bad coil/ PCM reprogramed
  410. Just replaced my plugs/coils because of a common issue
  411. Question on replacing Hatch stay set (hydralic lifts)
  412. brake light
  413. Cargo Covers form ebay?
  414. Replaced 4 ingition coils still weird rpm
  415. Finally paid off my Fit!
  416. Car vibrate when switch on aircond and put in R gear
  417. Rough Idle
  418. Rear Wheel Bearing Part No
  419. Fake Megan Racing Header
  420. Grinding and Clunking Noise HELP!
  421. New to the forums. How to get some extra GO out of my Jazz.
  422. Plasticky rattling sound from bonnet
  423. Interested in s2000 parts on a fit
  424. help: major problem? cel
  425. P0133 - Heated Oxygen Sensor (HO2S) Slow Response Bank 1 Sensor 1
  426. Seat Swap
  427. Should I pull the trigger on an 07 Fit?
  428. Intalling electric doors
  429. Re-Upholstering the doors on the GD3
  430. Water Pump, Maintenance or Melarkey?
  431. P0718 Mainshaft Speed Sensor Intermittent Failure on 2007 Honda Fit
  432. Will adding bride seats disable all airbags
  433. CEL, PO304 Code for 2008 Fit?
  434. turning signal bulb
  435. CEL blinked and shaking but no code?
  436. Reintroduction
  437. Honda Fit GD1 Flatuating Revs
  438. $4 Castrol Transmission fluid on Amazon, Any Good??
  439. 2009 fit sport - SRS harness replacement
  440. 08 manual, in addition to the stalling there's a screech when started
  441. Strut/damper options for GD3?
  442. - Introduction -
  443. 2008 Honda Fit Sport 5spd
  444. Clutch judder / chatter never gets fixed no matter what =( getting desperate here!
  445. new fit owner =)
  446. Weird Fit Issue
  447. Burnt Coil from a 2007 Fit
  448. Trying to find headlights/tail lights and fog lights
  449. kwsc with torque damper compatible combo???
  450. Rear wiper washer and third brake light not working
  451. Replacing the splash shield on '08 Sport
  452. What part is this?
  453. Sideskirts and Rear Lip
  454. 7 feed mode switch
  455. Wheel fitment
  456. Brazilian Honda Fit 2007
  457. 5th Gear, Should I Be Worried?
  458. 2001 Fit new Buyer
  459. RPMs dropped really low - when coming to a stop
  460. R i p
  461. Fuel odor after car sits?
  462. Fit wheel offsets
  463. What type of fuel injector cleaner do you use for your 1st Gen Fit?
  464. Can I use super glue to fix cracks on my engines air filter housing?
  465. Do I really need to buy Honda 50/50 antifreeze?
  466. Greetings
  467. Can't find serpentine belt for '07 NO AC in Canada
  468. Fit 2004 transmission problem? help needed
  469. My manual car came with an auto ECU...
  470. Passenger Replacement Mirror Help
  471. '08 Fit, tell me about 17" wheels, stock height
  472. looking into some parts on h-fit and have a question pertaining to them
  473. Electrical Problem... Help
  474. New GD3, but no manual and a bit confused
  475. Bad o2 or valves or cat?
  476. Towing a small camper with Fit 08??
  477. Any ideas? Help?
  478. Any one running flashpro and a D1 Spec Throttle controller?
  479. passenger airbag light under stereo
  480. Will JDM hood fit on USDM Fit?
  481. 2007 Fit Sport 101k starts in -6 F temps but stumbles.
  482. Fit 2008 condenser fan speed
  483. Weapon r header donut crush gasket size?
  484. Battery only charges at high rpms
  485. Recommend a good obd2 scan/monitor tool
  486. adding high tone horn to gd3
  487. 15" Wheel options, (Daily driver)
  488. broken wheel stud
  489. Honda fit 07 Cold start problem
  490. Rear middle seat belt cover
  491. Meldew issue
  492. 2003 Jazz/Fit Electrical Cut-Out and Stalling
  493. Fit needs some love
  494. Ultra Racing 4pt Rear Strut Bar
  495. Recommended maintenance IN LIEU of MM
  496. yes plugs again
  497. 2001 Fit - direct from Japan.
  498. Cargo Space - GD vs GE
  499. New owner 07 Sport
  500. Greetings and Introduction
