- Trouble installing rear door panels?
- Required Services?
- Intermittent Flashing CEL when accelerating/uphill
- AFR vs. O2 sensor
- Whats the average engine check light time?
- coilover top mount question???
- Any idea what happened to this antenna and how to replace it?
- What is your MAP reading at idle?
- operating in the low end of power band
- Spark replacement
- Best brake shoes for 2007 honda fit
- Carpet coming up. Do I glue it down?
- Autopsy of a junk yard Fit (2008)
- Central locking problem
- Fell into a puddle, stalling shortly after driving.
- Honda Jazz steering wheel controls
- Winter tire recommendations for '08 Sport?
- Cold Start Misfires
- Collapsing pcv tube
- Positive Battery Terminal Replacement Question
- map lights
- cold starting grind sound starter / vtc actuator
- DC Sports Short Ram Intake... Any owners on here?
- More vibration! Now with A/C in Neutral/park
- Gearbox match?
- Ignition Coils PLEASE HELP
- No power steering
- Help aftermarket motor mounts !!!
- sudden drop in power during normal highway drive?
- Diagnosing MPG (20-23 City / 30 HWY) And going from 100k to 200k
- tyres wearing out every year or so
- Dashboard not working after changing the alternator
- 08 fit sport (purple)
- Cruise control safety cut-out?
- Losing torque
- My fit electronics cut off
- Lag before starter reacts to key
- Automatic locks
- Hitachi coil vs... Hitachi coil!
- Sticky Rear Hatch Lock
- Alarm goes off when using key to open door and can't be silenced?
- Aftermarket radio problems
- Jdm ecu pinout
- Want to buy 07-08 shop manuals
- Getting 11mpg (city) on a 2007 Sport w/ 108k - Any Suggestions?
- AT Fluid additive
- Vibration (not misfire!) while idling in Drive
- knocking sound in cold weather: elongated timing chain
- Honda recalls 2015 Fit for coils, but not 2007!!
- ABS modulator bleeding
- Non LED Jazz taillights
- Replacing my front hub and wheel bearings
- Power windows/lock issue!
- Master Window Switch Recall Reimbursement???
- Gd3 Resonator
- Instrument Cluster Bulbs
- Low speed issue and hard downshift
- Is it worth replacing the engine on an '08 with 160k miles?
- *serious mechanical issue*
- [story] 2007 Honda Fit, recent purchase 147k miles, was throwing EVAP codes but...
- ecu help please (turbocharged)
- Winter Tires and Rims
- 2008 Fit Sport Engine Swap
- Leaking spark plug (just answer)
- Replacing stock front speakers
- front replacement bumper
- Squeaky AC
- What You Choose, iridium or normal?
- Hey guys wondering
- power steering issue
- 08 shop manual please 1st gen
- Started once & died after major repairs- HELP PLEASE
- Weird shaking with AC on at idle; other issues...
- I just need to kick and scream...
- EVAP monitor is not ready...AGAIN
- ABS issues
- Thoughts on 08 Honda Fit sport?
- Are Jazz and Fit's front brake replacement pads the same?
- Question about front disc brake pads
- 07 fit, key stuck and no start
- Do you know this part number?
- Should I replace the AT Filter for my 2008 Honda Sport
- cloudy headlamp replacement
- ""TPMS" light not (_!_) indicator stays stays on
- Brake lights not working
- Water running noise after engine off?
- Coil pack broke on me on the highway
- B124 Maintenence questions from a noob
- Single cylinder missfire (new coil, plug, injector, valve adjust)
- Resealing the plastic liners found behind door panels
- Using Innova 3040 scanner on my Fit
- Rusting Axle Shaft
- GD will not start after filling with gas.
- Misfire sensitivity testing for ECU
- misleading Justanswer, of why mechanics are incompetent!
- Can I put 195 50 15 on a 2008 fit lx
- 07 08 service manual North American
- largest wheels, rims for 2008 Fit LX
- Air Filter Change or not to Change?
- Hard To Shift after Man. Trans Fluid Change
- using A/C recycles radio
- Broken bolt in catalytic converter.
- Misfire P1351 & P1353 code, engine intermittent hesitation
- Try Cleaning Spring Contacts on Ignition Coils to Fix Misfire Problem
- Do you Know about ASHIKA brand?
- Help! 2007 Fit bucking and revving when accelerating and idling
- Front control arm assembly bolts
- Passenger Power Window not working
- 07 Sport Misfires after spark plug and coil replacement...
- Throttle Body Cleaning
- Handbrake Problem
- Easier removal of the AC/Rear Defog switch.
- OBX exhaust...crap or just cheap??
- 2008 Honda Fit Sport Headlight/turn signal switch
- AC Condenser Fan Replacement
- Need Help Identifying Part
- Two Fit Family !
- Is Valve Adjustment Recommended as Periodic Maintenance?
- Engine Bay Hot Feels Hot / AC Stops Working
- A/C problems
- Hiccup only when idle
- radiator and condenser fan sizes
- Drive shaft too long! HELP!
- 2008 Sport throws engine light, (D) blinks
- Blown out spark plug? Cylinder head remove/install??
- Jazz/Fit 2004 - Front wheel hubs - can I use ones from any other model?
- Car stopped dead - won't move at all
- 2007 Honda Fit Leaks (Rear passengers, Spare Tire)
- Slight vibration, more gas in tank than usual
- Engine noise - not consistent
- Idle Stumble, bucks under high load
- Anyone know wha this is?
- Second and fourth difficult to shift into
- Gas smell at startup
- '07 & '08 Airbag recall
- Coolant/Water Temp Sensor
- That 2nd gear downshift grind....
- coolant flush question
- Passenger side airbag recall : 2007 + '08 likely included ....
- Idler Pulley Hardware 2008 Fit Sport
- P2647 Car power retarded
- Need posts for WTB thread and bored
- Iam about to give up on my car.
- Can't remove cooling fan
- 08 Fit Base – adding the Aux feature
- Anyone have this DC Sports Intake issue?
- Old starter wouldn't catch, new starter won't even try!
- Transmission removal problems
- Seat Replacement Question
- questions about manual transmission fluid change
- '07 manual suddenly very difficult to shift intermittantly
- Front Adjustables for sale
- High pitched whining accompanied by engine drag
- have been looking at FITS...close to getting an 08 sport, some questions...
- Misfire Problem followed by P0420 code
- New Member Intro
- JDM engine
- 2002 Jazz/Fit Fuel Pump issue
- Weird Rubbing Sound
- Door Locks - Damaged/Failure Fix?
- Fit Freak Wisdom. New Fit owner. ....
- obd2 bluetooth dongle, which one works ?
- Low MPG on Fit 2007, ignition coil?
- End of the Road
- My transmission mount is broken, again...
- 2007 Fit troubles
- Clutch replacement
- Oil pan
- Troubleshooting Keyless Entry
- Power door lock malfunction
- 2007 Fit Condensor Fan
- Engine replacement 07to 08
- Will they fit the fit
- Bleeding brake
- Need advice on 2008 engine
- Catalytic Converter
- Intake Manifold
- Driver door hit from behind while half-open
- Poor Transition when Changing Gears
- Best place to buy parts?
- Clutch issues and replacement.
- Transmission blown?
- Black Fit with Red Garnish Pics?
- Fits are coming to California PYP
- Unusual aftermarket LED switch. What is it?
- New 2008 Fit Owner - Need ATF change help
- Automatic Transmission HP limits.
- Replacing Fit/Jazz/City brake booster to double layer booster
- Has anyone installed air bag "helper springs" in their rear suspension?
- Possible bad battery/starter/solenoid
- night lights on 2005 Jazz/Fit radio
- Front Bumper Removal question.
- Strange buzzing sound and ABS? issues
- Valve lash inspection and adjustment
- motorcycle back rack for stationary towing
- 07-08 Base Front Grill fits in a 02-06 Jazz...?
- Who wants a freebie?
- Smog check--CAT monitor not ready on 2007 Sport
- Buying used high mileage 2007-08 Fit
- 2008 Honda Fit Odometer blinks and beeps twice
- How to Replace 2007 Honda Fit Sport Rear Door?
- Strange (related?) problems: missing, blinking D light, brake warning lights
- Do '08 Fits have a history of water leaking into drivers side doorwell?
- Honda Fit 04' Transmission Failure
- denso iridium ik20 vs ik22 better
- 2008 Honda Fit, P0301, ssues
- Fit N00b With Questions
- Can you install Navigation in 1st Gen Fit
- Diagnosis help: Loud whine when backing up after 4hrs
- Vibration/Rub Noise While Turning Left
- valve adjustment at 69k!?
- changing the stock antenna/wiring on GD1
- Do you have function form type ii??
- Will US 1.5 parts fit UK 1.4
- Problems resolved. Thank you guys!
- P2A00 and P0133
- Continuously variable transmission (CVT) greabox problem on Honda Fit 2006 1.5S
- Need new Front Right engine mount do I have to pay $250?
- ECU Repair
- Whats the symptoms of a bad release bearing?
- Grinding Noise At Low MPH
- Picking up 2008 Fit Sport auto as a parts car - goodies to save?
- A/C causing short, Where to start?
- Honda Key Woes
- CEL codes. Need help!
- Noise at cold start.
- Gas in Oil
- Fuse 10 in my 07 keeps blowing.
- What is the best 1st generation Fit to buy
- my FIT has 109,000miles, what should I do?!?!
- Catalytic Converter Different for Manual VS Auto??
- Will a oem sport radio in a base model?
- 07 Fit misfire in cylinders 1 & 2
- idler pulley?
- Honda Fit Newbie
- Misfire Battle
- Anyone know where to find....
- Shipping parts from Brazil.
- Honda fit l15a1 cam lifter
- Must have upgrades for my 07 fit. (High mileage)
- What does your exhaust manifold look like?
- Strange cracking sound when steering.
- Poor Mileage 2007 Fit
- Air intake questions
- The Dreaded Code P2649, fixed witha $3 gasket
- Another Wheel Fitment Question
- Slides around driving over 40 mph -- on dry roads?!
- 08 Fit, Is my oil overfilled by dealer?
- Coilover install issues
- Car meet today in Houston area
- i have a short that drains the battery in 3-4 days
- 2008 Fit Totaled (Sun Roof a Standard Option?)
- Noise I couldn't quite pinpoint
- Dome does not light - different problem
- 07 Fit Sport (Wheel/Tire Question)
- OBD2 Door Lock for Gen 1
- Scan Gauge 2 owners?
- What type of grille is this...?
- Suspension Question
- 2008 honda fit engine replacement and interchange info needed
- Mugen seat covers
- Hatch Latch: botched repair vs. wear and tear
- Could a throwout or pilot bearing cause thumping?
- Possible Valve Issue?
- '07 fit base vibration under load
- Clicking/pulsing at idle
- 2008 fit, new to scene, have questions..
- Will these fit the USDM Fit? OEM Xenons..
- Rubber Dampers
- Bad shaking under acceleration
- Swimming pool modification
- Honda Steam Windor Visors compatible with Honda FIT GD1 ?
- Air Intake Upgrade
- Key Lock Cylinder Replacement #2
- strut tower bushing or sway bar bushings
- Blank basic key for 2007 Fit SPORT
- Lower MPG after transmission switch replacement
- car jerks in D on an 05 Automatic
- Fuse/Electrical Issues
- Rear end "loose" or "floaty" over bumps
- Engine failure light blinking
- Frankenstein Builds
- Honda oddessey alt on fit?
- Rear suspension axle mount bushings
- Do you have a FORMFIT hood protector installed?
- "Tight valves"
- does your windows clean when you up down them?
- Driver's side window stuck 3/4 - Off track?
- L/100 woes
- Anybody try Duracell batteries in their Fit?
- 2008 Fit sport on PYP Anaheim
- New to me - 2007 Sport - Looking for Add-Ons
- P0303 Story
- Wandering issue
- Front Break Pads
- Manual transmission help, hard to shift with engine on, clutch not disengaging fully?
- BPM 2008 5 spd.
- Bulb type-id-size
- my dealer no help with my stalling
- Check Engine Light / Oil Line Pressure Switch?
- Just bought my Fit
- Accessing duct behind heat unit
- Is a rear right seat belt for a second generation compatible a first generation?
- Second gear grinding
- Does '09 USB adapter work in '07?
- Cheap Lowering
- Flickering Problem
- 2004 honda fit rs jdm turbo build
- '07 fit now shakes/vibrates. Positive it's the coil packs?
- Will a 2012 Honda Fit Roof Rack fit?
- Preventive Maintenance 50k miles on 2008 Fit
- Clutch component identification
- Where do you guys buy your OEM parts from?
- GD1 Headlight Beams
- Radio from a junkyard
- JDM console fit the Base/ LX model?
- Sloshing Noise Concern
- What's the size of the radiator hose? (L15A)
- DBA-GD1 spoilers and lips
- Front Bumper Cover Problems 2007 sport
- bought me a 2008 Fit; starting from scratch, engine dirt question
- loud throwout bearing?
- Regular key (NOT keyless entry) for 2008 Sport?
- Help! Headlight Safety Recall Repair/Fail?
- Strange Noise
- Help I've changed 4 coils w/4 spark plugs now it's worse
- Solid Red blinking light
- AFC NEO for my 07 Sport
- What's behind this panel?
- coil pack failure at 110,000 mls but ok
- Change bulb in gear shift?
- Jump start on highway
- i Have a problem
- HID retrofit completed - Thank you HID Illusionz!
- who makes the OEM spark coils?
- Electrical problem?
- AC compressor part number
- AC compressor noise? This normal?
- Jumped with Inverted Polarity...
- Noise, like a broken spring
- Heat Shield for 2007 Fit
- Door grab handle/armrest replacement
- Exhaust Back Box Diameter
- LED Tail lights causing radio to dim
- Strobe lights?
- Question about lowering springs
- Flushing break fluid, what order?
- Si seat wiring in gd3. Need help
- ABS codes
- 07 with pulsing lights
- 07 Fit Keyless Entry
- Radiator Cap Type
- Wheel Thefts - is it just for the alloys?
- 08 fit sport headlight troubles
- Ignition Coil Repair
- New Owner - Maintenance
- New member here
- '08 GD3: A/C randomly stops running with *twangs*
- Find the cheapest Fit, shocking !
- removing cover for ignition switch on 2005 Fit with proximity key
- 2007 Honda Fit Sport / Squeak in front driver side while turning left
- Missing Inner Fenders?
- 2007 Fit Sport / GD/ AC works intermittently; shop says....
- Trying to achieve a comfortable driving experience. Looking for solutions...
- P0172 Diagnosis
- Problem with 'jerking' Honda Fit 2002
- Had shaking issue, replaced coils, plugs, worked good for a day, then c..
- Clutch Line Not Aligning
- What is this noise? Sounds like fart first time decelerate.
- 2007 sport "cheaper" factory key how-to
- Can't adjust my clock!
- Exactly which engine is used in the GD?
- fuse size and problem with remote
- ngk iridium spark plugs worth it or not?
- How to open plastic wire harness container on top/rear of engine?
- 2007 Base Clock Replacement
- Check engine light on, no code from OBD2 scan, now what?
- What is this?
- Special tool for fuel pump required?
- Any options other than the Honda Applique
- 2008 SRS light on
- Jazz dull lights
- Help trouble shooting noisy front end
- GD3 Driver Door ( Blue )
- belt squeal when hot
- Best Adjustable Coilover Honda Fit '04 JDM
- Bumper vs Bumper Cover
- About Switch
- 2007 Sport new2me: advice?
- Cost for Catalytic Converter
- Changed ignition coils; still doesn't work!
- Looking for part recommendation
- Bumper gap
- VTEC replacement cost
- '07 base Cyl 3 misfire, changed plugs and rotated coil packs; now what?
- My dead battery in my 08 fit
- Diagnosing P0420 Code with Torque App (need help)
- 2007 Honda Fit Sputtering, Jerking, Misfiring (RESOLVED)
- Wheel stud broke off..what's the proper way to fix it?
- Repairing Folding Mirror - Motor Constantly Running
- My fit died =(.. well kinda
- JDM Stuff
- new guy
- 2008 Sport - How many amps can my USB charger be?
- Rear bumper cover
- Instrument cluster lights replacement
- online parts place for engine intake cover?
- Is the 2008 Fit under that air bag recall or not?
- How do I install an Odyssey battery?
- R18 TB install gives code p2101, faulty actuator
- Bottom fender vs. Sidewalk
- HELP adjusting coilovers for HEAVY SYSTEM
- Duplicolor yes or no
- My first generation Fit
- How to install third-party keyless entry
- 2008 Fit transmission fluid leak
- Mod recommendations for 2008 Fit Base Auto
- Fit Stalls - Any Ideas
- Dual DIN decks
- used Honda Fit 2008 advice
- 2005 Jazz Tranmission fluid level
- 2008 Base Honda Fit - Keyless Entry
- new owner
- Buying a Sport 07 (AT) with 125k miles. What do I need to know?
- A/C compressor connector questions
- High milage
- Engine Serial number
- JDM GD carpeting. Where to buy?
- 1st Gen AC Delete / Pulley bypass?
- New Honda Fit i-DSI (2006) owner
- B124 Maintenance?
- Truck mount bike rack position
- Engine Mounts
- What is the name of these parts on the Jazz bumper?
- Axle Shaft
- O2 (downstream) replacement
- need help if it's safe to run w/o END LINKS and camber
- JDM power mirror question..
- Hesitating again after coils & plugs?
- uk gd1 ongoing project...
- Will JDM Hood Install On USDM?
- Need Some Info
- Shorter Rear View Mirror?
- New Fit owner!, Couple Questions
- Front wiper motor went out
- Weird sensor on front windscreen
- Just bought a 2007 Fit
- UOA PU 5w-20, 7461 Mi, 07 Fit AT
- 07 AT - Amsoil ATF?
- Blinking "D" on transmission
- Slight ticking noise from slightly above idle to 1050 RPM only. Any thoughts?
- Emergency Wheel Bearing Question
- OBD code 2422
- Stock Gd3 Manual motor mounts
- gauges not working
- jazz 06 aux input problem
- This Time It Was A Starter
- Intemittant creeking noise
- Gd trunk tray kit help!
- 2007 Honda Fit Sport Lower Control Arm Bushings-Who's got them?
- Speaker Replacement Tutorial
- K sport susp thinking on buying but need ur opinion
- Key question
- 3rd and 4th gear do not work
- Axle Nut Torque Specs
- OBD2 nightmare. Honda Jazz 2002 MK1 UK
- GD3 is Dead LOL
- Broken Left front drive shaft
- New owner !
- Synchronizer / Gear set (3-4) fitment
- Lighter outlet
- Body to tailgate electrical harness rubber boot repair.
- Mugen Sport Suspension/Seats
- any gd with lightened flywheels?
- Brake squeal at low speeds
- P0339, whats broken ?
- Turkey Red Honda Jazz +
- Ask oem JDM parts
- Seat lever broke
- 1/24 scale Fit
- '08 Sport vibrating, hissing, help!
- Radiator Hose Longevity
- 2007 base stereo for trade
- 2 questions..
- Why is my mpg 24 - 25?
- Screeching noise on front right wheel area
- Help me find a home for my relay!!!!
- rear wiper not stopping
- Will Not shift to Reverse
- What part is this On my Fit? (changing alternator/drive belt)
- MY 2008 1.5 And what i love, hate and dont know and whats next
- my 2008 Fit Sport Mileage
- Engine stuttering at acceleration, engine light going on and off
- 14 inches wheel, should i get some 15 inches wheel ?
- window visors GD3
- Mini Cooper rims and tires on GD3?
- Test aftermarket coils
- I have issues after coil/plug replacement on 2007
- Needed advice and have questions
- Excessive Vibration
