PDA
View Full Version : 1st Generation (GD 01-08)
Pages : 1 2 3 [4] 5 6 7 8 9 10 11 12 13
  1. Looking for certain fuse
  2. Info needed Gd1 k swap fit/jazz
  3. Question about installing front brake calipers
  4. Are OEM Shocks Really the Best if I'm Not Racing?
  5. OEM -01 Brake pads after 45,000 miles
  6. 2008 AC condenser fan doesn't spin, but AC works for a while.
  7. Junk yard practice: windshield wiper linkage and dog poo in the car:)
  8. Honda Jazz 07 - Hazard buzzing sound problem
  9. Flashing dash and rear brake lights
  10. Aftermarket Alarm won’t stop going off
  11. 07 fit misfire at idle with AC on.
  12. Turbocharged GD
  13. Sticky Hatch Latch - Low Tech Fix
  14. A/C compessor drag after adding freon
  15. Where is the fuel pump relay?
  16. 07 Sport Key Separated From Fob...
  17. Air conditioning issues
  18. 2010 shocks on 2007 GD
  19. Sun Visor's adaptability Question
  20. Are GD and GE coilovers interchangeable?
  21. Sport vs Base tire size
  22. Rpm 4k at 80kmph
  23. High pitched whsitle sound when accelerating ?
  24. Problem with a cvt gear box
  25. GD3868EW Air Conditioning
  26. floppy Visor fix
  27. Can't release hatch latch - Handle OK
  28. Help buying a 2007 Fit
  29. New member introduction
  30. 2007 Honda Fit Headlight Bulb Replacement
  31. P0420
  32. 2007 Misfire and O2 Sensor
  33. Car misfire once or twice a week
  34. 2007 Fit front coil spring broken trouble sourcing replacement
  35. 2007 Fit FUSE #3 keeps blowing
  36. 2007 fit drove up from south of border
  37. OEM Part Dealer?
  38. Possible Strange Electric Problem?
  39. RIP fit
  40. When does your gas light come on?
  41. Fit 2008 GD3: looking for original Windshield Wiper Arms
  42. Car misfire under load
  43. Slow start when engine is warm (03 GD01 I-DSI)
  44. 5th gear swap?
  45. Can I swap the complete gd3 08 front to my Fit gd1 jdm 2004?
  46. Finally joined Fitfreak!
  47. Hood deflector
  48. Thinking of buying a Honda Jazz Sport (UK)... Questions on modding parts...
  49. What is the horrific sound my 2007 is making?
  50. brake light/tail light bulb
  51. Cold Start Stumble.
  52. Thrown rod or collision damage?
  53. coolant temperature stays on even before engine warms up
  54. Blown fuse?
  55. Whats the purpose of this white plastic in the door? size speakers in front?
  56. fit does not start and scan tool cannot connect to.find the issue
  57. fit does not start
  58. Power to back up camera monitor?
  59. What do these two (always on) idiot lights telling me?
  60. Steering jerking at high speeds
  61. CODE P2646, no accerlaration after 3,500 rpm Help
  62. Missing rear left seat belt buckle and center anchor
  63. Are the brakes the same in 2003 as in 2007?
  64. 2008 Honda Fit battery light
  65. Help: Trying to replace stut mounts and stuck.
  66. missing rear hatch internal grip
  67. Auto GD3
  68. Fit hesitating, twitching and stalling in low RPM under load - video included
  69. Help with ABS and Check Engine Light on
  70. Remote unlocking stopped working after dashboard swap
  71. durable struts
  72. Where is sensor for dash lights?
  73. It's not the coilpacks, it's the ignition boots insides
  74. Dead Pedal for GD - Questions and Interest?
  75. Help please... Input shaft bearings or?
  76. 1st Gen fit door locks going crazy
  77. '08 Fit Hood Latch
  78. At my wits end with my 08 Fit Sport
  79. Swapped CAT / Loud & Rattling
  80. Hondata Flashpro User Info
  81. Honda Jazz GE steering wheel on Honda Fit GD1
  82. Revs staying high when flooring it?
  83. wheels for 2004 Jazz (UK) (GD)
  84. Headlights do not come on when turning the ignition key.
  85. And all at once it all went crazy....
  86. Accessory Socket Dies When Phone Plugged In
  87. Fans going nuts after coolant flush!
  88. Local Sale. Toronto. Tires mounted on alloys.
  89. DIY power outlet for the rear area
  90. Fit gone. Complete Manuals and parts F/S
  91. Go to dealer or mechanic if alt/battery problems? and could that cause fan problems?
  92. Honda service
  93. Honda Access Trunk Tray
  94. Car not changing
  95. Oil change question.
  96. Help!!
  97. Gd1 l13a1 turno suggetions
  98. Wtb gd sideskirts
  99. Leaking Rain/Water In Cabin
  100. Said Bye-Bye to the Fit this weekend...
  101. Swapping GD3 tailgate onto my GD1
  102. door water leak. Service Bulletin
  103. Part numbers for Clutch Master and Slave Cylinder on GD1
  104. Dying Alternator? 2007 Fit
  105. Gas Mileage Concern
  106. Ignition key not turning/Steering wheel locked - Tried everything I can think of
  107. Readiness Monitor set question
  108. 1st gen totalled. Shopping. Is 2nd gen better?
  109. Ep3 seats into GD
  110. Bypass AC compressor 2007 Fit
  111. 08 Manual Trans question(s)
  112. Valves adjusted
  113. Battery Replacement Options
  114. Front brake caliper problem
  115. Radio Problem - NO CODE message
  116. K Swap Miami
  117. Car jerking when shifting to D or R
  118. Oh Goody, a new noise
  119. Any places I should check for a water leak? (wet rear seats)
  120. 2003 fit gd3 D blinking, speedo doesnt work.
  121. Best Brake Pads
  122. DIY valve adjustments
  123. Strange noise from my Fit when the rear windows are down
  124. Whining/weezing sound but only when accelerator is presse and car is moving.
  125. totalled. favorite car ever. saved my ass
  126. Window washer questiopn
  127. Dying in the cold
  128. PICTURE REQUEST: J's Racing GD3
  129. Shock/strut replacement - anything else I should do at the same time?
  130. Will a Sport front bumper fit a base (2007)?
  131. Will a Sport front bumper fit a base (2007)?
  132. Starter Going or...?
  133. Why no gauge cluster?
  134. Starter Suddenly Quits In The Cold?
  135. If no Fits, then what?
  136. HELP! Other jack points for front.
  137. jerking helpp
  138. How i reset ECU ?gd3
  139. 1st Gen found in my care
  140. A hairline crack may cause spark plug to came loose
  141. P0848 right after Dealer's ATF change
  142. Amazon coilovers
  143. Check Engine Light flashing intermittently - help!
  144. 2007 Fit AUX Input Volume got really quiet
  145. Bad TPMS controller or ?
  146. my car jerking while acceleration and loosing RPM
  147. 2002 Fit Funny alternator issue?
  148. 2007 Honda fit P301 misfire driving me nuts!
  149. 2007 Honda fit - Location of Camshaft position sensor (37510-pnb-003)
  150. Multiple Questions in one
  151. Cruise Control Cutting Out
  152. 2007 Honda Fit Map Sensor
  153. Base vs Sport - differences (GD)
  154. My 2007 Fit is dead. Totaled.
  155. Fit gd1 central locking not working
  156. Sold my 2008 Fit
  157. Need help gd3 spoon template
  158. "Mode Control Dial" broke
  159. Question about AC compressor
  160. 2007 Fit Clutch Noise Identification
  161. shocks/camber/tires/wheels
  162. Brake Issue Fixed
  163. 07, Struggling with multiple misfire codes
  164. Car crank but no start.
  165. Electrical repair (tailgate harness connector) lesson learned
  166. 07 Fit Sport engine whine. Need ideas
  167. Ocassional jolt, is it electrical?
  168. gd3 real mugen grill
  169. My Fit makes a clicking( ta ta) sound as a switch on the ac and start going forward.
  170. 2008 Honda Fit Sport | Squeal while driving only
  171. Idle bounces with AC on
  172. P0420 Code after valve adjustment
  173. Tailgate Gas Struts - Please Give Me Good News!
  174. P2A00 after changing upstream A/F sensor
  175. Alternative jacking points
  176. Glove box Rattle
  177. Honda Fit 2007 very sick
  178. Advise needed : Honda Fit is sick
  179. Rear Shock Tower Mount Q
  180. Wet Floors & Trunk
  181. Gas inlet cut
  182. Broken axel
  183. Door locks not activating by alarm.
  184. Hiding compartment in the door panel?
  185. Suspension Clunk - Strut Mount?
  186. "Normal" Catalyst Monitor values for 2008 GD3?
  187. How do I get 40 mpg?
  188. P0301-0300-0302-0303
  189. Pending Coil Problem Then Sudden Engine Shutdown... won't start... cannot read OBD2
  190. Replaced bad ignition Coil and still stutters, help
  191. Trans input shaft failure?
  192. Goodbye, Fitty-Cent. :-(
  193. Immobilizer issue
  194. EPS Replacement
  195. Change ball joint or whole lower control arm
  196. Odd "clicking" on acceleration
  197. Our GD Build Thread
  198. help!! 2008 fit sport rattle
  199. Where does cargo light connector come from?
  200. Seat Belt Upgrade?
  201. Parts for 2004 L15A Manual.
  202. ABS seems to enable when slowing to a stop
  203. Same car, two shops, 2 different alignment readings
  204. CVT knocking,delay and strong vibration from cold start
  205. Leftover part
  206. Radiator fan
  207. Another bad discovery (windshield wiper linkage)
  208. Throw out bearing issue
  209. Power Steering (Torque Neutral Programming)
  210. Any shops ever run an alignment special?
  211. Which GD do I have?
  212. Honda Fit 2007 GD3 ESM
  213. Valve Adjusting soon
  214. Outer tie rod end boots on–car replacement
  215. Side Mirror Assembly replace on 2008, 1st G
  216. Anyone break an ignition coil?
  217. How do you reset the oil/maintance display?
  218. 2004 Honda jazz Front turn signal replacement
  219. 2004 Honda jazz Front turn signal replacement
  220. 2007 Fit making strange noise when coasting
  221. My Fit was drowned in a flood...waaaaaaaaaaaaaaaaaaaahhhhhhhhh
  222. Your Experience with EPS(Electrical Power Steering)
  223. GD3 OEM radio screen digits fading out??
  224. Is this a good price for ignition coils?
  225. 200k Preventive Maintenance
  226. Engine mounts! Any recommendations?...
  227. P0302 Code | Start With The Coil?
  228. Power window problem
  229. Fit Aria 2005 Cigarette Lighter outlet replacement
  230. 5speed Stuck in Neutral
  231. Multiple leaks in trunk
  232. Oil Pressure Sensor Location on GD1
  233. how to convert emanage blue to ecu gd3
  234. Driver's airbag recall...pending?
  235. Idle revs dropping, car jerking when stopped in 'D'
  236. Location of clutch bleeder screw?
  237. Seat Belt icon not light up
  238. Mysterious steering problem! (Fit 2005)
  239. P2646 issue
  240. Any tips or WATCH OUTS for cleaning the engine compartment?
  241. Whats the latest options on replacement headlights?
  242. P0420 Diagnostic steps?
  243. What is everyone doing for base tires these days?
  244. List of To Do for 07 with ~200k manual
  245. Can't find Pollen Filter
  246. Couple of questions, actually
  247. Tore my CV boot.... Are Left-right outer boots the same?
  248. 1st Gen Fit engine swap performance thread
  249. Recall/service campaign SRS occupancy sensor?
  250. Clutch shudder -- let's revisit please
  251. Door locks only work at certain times
  252. Newly installed AC cooling fan won't turn on
  253. Fuse #3 blowing
  254. Key Less Entry 2008 Fit LX
  255. Bogging Down With A/C On
  256. 2002 Fit acceleration issues
  257. Installing 3rd party alarm on GD1
  258. Salvaging the brackets on the rear hatch struts
  259. Electric power steering really acting up
  260. Rotten egg smell (new finding and paranoia:)
  261. Help Me Pick Suspension
  262. Drive axle installation
  263. Rear wheel bearing hub - which one to buy in the US ? (for a Japanese car from EU)
  264. Best Rear Hatch Struts?
  265. Online manuals available
  266. Recover lost power? ~230k miles
  267. My hatch is not locking (noob)
  268. Rear hatch won't open
  269. Code on key for '07 or '08?
  270. Looking for rear bumper
  271. 2007 Honda Fit engine noise *please listen to the video'*
  272. FIT LED 3rd brake light - anyone have one?
  273. Electrical issues?
  274. 2007 Fit/Starts - Won't Move
  275. Constant squealing while driving/idling
  276. High speeds
  277. High speeds
  278. coolant drain bolt to engine
  279. Honda Fit GD-3 (2003) Wiring Diagram
  280. Mis-Like with AC running
  281. Wiring Schamatic A/C System
  282. Strange voltage issue
  283. Buying 2007 Fit
  284. Power window modification
  285. Can a eg spoiler fit on my jazz gd1
  286. Rear headrest missing - my first post!
  287. ENGINE DIES IN DRIVE, REVerSES WELL. FLICKS DRIVE LIGHT. SLOW TO CHANGE GEARS.
  288. Replace oil pan
  289. Is this normal ? 2007 JDM GD3 M/T
  290. Door Locks Won't Work Anymore.... yes, I checked fuses
  291. low voltage codes: what v is normal?
  292. GD2 parts search
  293. gauging any interest in rear strut bar & sway bar
  294. Power Steering Intermittently Working
  295. Weird but can I see pictures of your windshield trim?
  296. Jazz 04 Headlight Covers
  297. Cylinder Misfire but not Coil Packs or Plugs
  298. Intermittent Popping Noises
  299. Can't find the flasher fuse and relay
  300. Welding crack lines on front struts mount
  301. Driver's door won't open
  302. Car Radio Stolen & now some electrics don't work?
  303. weird electrical issues
  304. Looking at getting a used 07/08 Fit
  305. Anybody ever installed a shift improver kit in a Auto Fit?
  306. 2007 Fit Hatchback Lock
  307. Front End Squeak and Clunk
  308. 2008 Fit - Radio Install wiring
  309. Fixed radio -- now vents are stuck
  310. Honda Fit Trailer | Registering in CA
  311. No power, no crank, no lights,
  312. First-gen door visors
  313. Broken Valve Cover Bolts--Replacement?
  314. ATF fluid change interval on Fit vs Civic
  315. Accessory socket fuse burns out
  316. What is the name of this window part? needs replacing?
  317. Stock Height Replacement Suspension with Best Ride Comfort?
  318. MPG's and tire pressure
  319. driver door replacement - thoughts and insight appreciated...07 fit sport...
  320. 07/08 Driver sun visor "drop" problem...
  321. Battery light blinking intermittently after replacing alternator and battery
  322. Mr
  323. Dummy Pedal
  324. Noise emanating from right rear, exhaust, wheel bearing?
  325. Newbie Fitment Question, correct offset?
  326. Door handle removal
  327. Dreaded Misfire issue. Intermittent on a GD1
  328. Oh Crap. Door Striker Issue
  329. Auto door locks on M/T
  330. Cold air and ram air intakes, whats the point?
  331. Haulin with Da Fit !
  332. That gas smell in the cabin
  333. Alarm on fit 03
  334. Cooling coil
  335. 2008 FIt sport with 42000 km....?
  336. 2008 Fit Weird AC issue
  337. possible sway bar project
  338. Best parts to replace
  339. Knocking sound at Idle
  340. Question about Possible Battery or Alternator issues on 07 Fit?
  341. 07 Honda Fit oil pan , auto and manual
  342. variable valve timing oil pressure switch low voltage
  343. Which tires to run with 16" rims?
  344. GD3 Keyless Entry Info (2017)
  345. copper anti seize in the spark plug threads.
  346. swift springs on stock shocks
  347. Jerky acceleration, 2k+ rpm, especially up hills
  348. Axle leak from tranny
  349. Can I still buy 2008 enduratech coilovers?
  350. Muffler Bolt Size?
  351. 2008 fit sport wont stay on... please help
  352. 08 HonFit Won't Start--not the battery!
  353. Speaker Install with New Faceplates (Show Me What You Goooooooot)
  354. P0304 checklist.
  355. Buzzing / rattling from stereo
  356. does anyone refurbish the sport wheel ?
  357. 2007 FIT use qestions ... new owner
  358. Rain still sleeps through door, idk what to do anymore
  359. trace of oil on coil pack
  360. Part 4
  361. Part3
  362. Part 2
  363. Small gift to the forum members
  364. 06 Fit ?air flow meter problem
  365. DIY: Starter Replacement
  366. Lost a hubcap
  367. Daily Racing Seats
  368. Drivers side door lock broken, installing keyless an option?
  369. From Honda factory manual: Axles
  370. Airbag recall... fail!!
  371. Brake fluid and replacement
  372. Florida fit owners
  373. cost for a paint job?
  374. Tour of a GD head gasket replacement.
  375. How many times have you replaced coil packs?
  376. Auto jazz "flaring" - downshifting, revving, sometimes cutting out completely
  377. Can I run E15 ethanol in my 2008 Fit?
  378. Speedo swap
  379. Reversing indicator and wiper stalks
  380. Honda Fit GD auto air conditioner switch
  381. Dome Light | Seeking Info
  382. small hose on top of trans?
  383. Let's talk control arm bushings: SuperPro? Whiteline?
  384. Start up problem for GD1 L13A please help
  385. Replaced fuel pump, car won't start
  386. Honda Fit was broken into... glove compartment lock for gd3?
  387. Sloppy Seconds
  388. Grade logic expalantion
  389. Transmission Pressure switches
  390. Kenken?
  391. What the heck is up with these rusting rotors?!
  392. Unequal left-right power steering assist
  393. Best intake manifold/intake combo
  394. Tires? When To Buy?
  395. Gas Smell In Cabin After Plug Change
  396. Best Price Front Oxygen Sensor?
  397. 2005 Honda Fit, tadpole looking thingy leaving crumbs? issues
  398. Anything I can do to a automatic 06-08 Honda Fit GD3?
  399. Rear bumper clips, white ones...
  400. Last year I replaced spark plugs due to jumping issue
  401. I have a 2nd gen fit....and a big part of me wants to back to a GD...talk to me!
  402. overheat jazz gd1
  403. 2007 Fit Sport - Replacement Transponder Key Information
  404. Honda Jazz car stereo - fascia swap?
  405. Honda Jazz ABS failure - pump needed? Anyone got experience with this?
  406. Low Mileage Fits
  407. HELP! Oil leak!
  408. Just bought an 07 with P0172
  409. Replace cupholder light? (lights right under climate control)
  410. washer fluid on comming out of 1 jet
  411. Can GE or GK halfcut into GD8 body?
  412. P0420 code after misfire and bad gas mileage since forever
  413. % of first gens w/ water leak?
  414. Anyone recognise this noise ???
  415. 07 Fit Clunking After Suspension Change
  416. 07 Fit Sport - Factory Security System programming?
  417. Something happen when i'm try to relearn/calibrate my cvt
  418. Lock actuator part #
  419. Idle Stutter/Misfire (yes, another one)
  420. Can't get the DRL module out because of a metal tab below it
  421. Flywheel Bolts Torque Settings
  422. Anyone know the cargo hook break strength?
  423. 2007/75k miles transmission failed
  424. Adjust idle speed?
  425. Low RPM Problem
  426. Cooling Fan
  427. GD Parts
  428. serious automatic transmission problem **HELP**
  429. Two different FIT options to choose from...
  430. Clutch not engaging
  431. Installing a powered subwoofer with stock head unit
  432. LED Headlight Kit
  433. 2007 Honda Fit issue
  434. 2008 Fit - Died, No start
  435. Wheel lugnuts
  436. fun with alternator
  437. Front brake pads Fit 2007
  438. air filter, engine, Fit 2007
  439. Auto door lock/unlock issue on 2007
  440. Battery/Alternator/Coils??
  441. 07 Fit starter replacement
  442. ? about headlight recall
  443. engine tempreture hot
  444. 2007 Fit died driving down the road
  445. Engine Block Heater - Max Plug-in time
  446. 07 fit starting issues in very cold weather.
  447. Another coil pack thread
  448. Replace sway bar links with bad shocks?
  449. misfire & hesitation when acceleration
  450. 2008 Honda Fit Mystery Misfire/Hesitation ***SOLVED***
  451. Diagonal Rod Near Tire
  452. New Tire Suggestions?
  453. 2007-2008 Enkie vs. Kosei Wheel
  454. Wet Back Passenger Floorboards
  455. Vibration/misfire when hard acceleration & vtec not open
  456. temperature light
  457. Groaning after alignment
  458. Starter Grind When Cold Trick?
  459. Totaled my Accord a week ago. Looking at an 07 Fit Sport w/ 150k
  460. How do i know if i have CVT transmition
  461. Help! Planning to change the color of my honda fit gd1 I want something green
  462. Chris's build: The little Fit that can!!
  463. Power flickering/cutting out while my 2007 fit is trying to turn?
  464. Adjustable steering does not lock well.
  465. A/C compressor always comes on with fan
  466. New member in Front Royal Va..
  467. Replace Third Brake Light
  468. 08 Sport MIL steady then flashing?
  469. Independent mechanic near Pasadena, CA
  470. Blower motor issue
  471. Upgrading the gfs jazz
  472. Gas mileage questions!!
  473. P0420 and emissions test failed
  474. Lurching 2007 Fit (manual) – not the typical stutter
  475. No Heat from Heater after Coolant Bleed, Refill and New Thermostat
  476. 2007 Fit sport, spark plug question
  477. Please help. Wet engine bay!
  478. Looking to buy a 2007 Fit Sport
  479. Just Bought 2007 AT FIT SPORT
  480. Trim panel under passenger door coming off. How to secure?
  481. Help With Drive Belt
  482. MR. LS400's 07 MR GD3 (Sophia)
  483. Engine Light on after Idling
  484. Pressure switch on transmission
  485. Another Junk yard find
  486. Where could I find a decent wide body kit for an 07?
  487. My son rear ended a 530i...
  488. puttin oem springs back on my 07
  489. GD3 adjustable cam gear
  490. 07 Fit Sport PLEASE HELP
  491. upgraded fan shroud or fans
  492. Did a valve adjustment. Runs great but valves are loud now.
  493. Clutch replacement now won't drive in gear
  494. How bad is removing the engine on a 07 fit?
  495. A/T to M/T Hypothetical Question
  496. axle issue
  497. O2 sensor - upstream or downstream?
  498. Two hundred twenty nine and some change
  499. DIY: Automatic transmission rear mount replacement on 2007-08 Honda Fit without lift
  500. Trouble installing rear door panels?
