- I'm about to have a Fit (Mechanical Issue)
- maintenance question - tranny fluid
- 09 accord horn to gd3?
- Never going back to using Walmart Supertech Full Synthetic Oil
- WTA: Jazz GD using Civic FD steering
- Leak from Rear Tailight Assembly into spare tire well
- Seat Covers Question... Wet Okole Vs Clazzio
- GD3 JMD rear real oem bumper
- need help installing camber bolts
- Gd3 jmd rear bumper
- The only reason I hate winter...
- Trouble Disconnecting oxygen sensor from exhaust manifold
- Lowering Problems
- Is it my starter? Or is it from the cold. New battery was installed.
- ***Official GD Parts/Weight List***
- Question about Dashboard Lights
- Weapon-R Intake Manifold on 2008
- Help with a plug near the AC unit
- Mugen FogLights
- Getting ready for record low temperatures
- Who makes this carbon fiber air intake?
- GD Owners Help!
- Pioneer Double-Din install (Picture heavy)
- Clunking sound coming from the front left wheel
- Running non-OE seats in a GD
- The good and bad using 1.5 vtec throttle body on 1.4 idsi
- fuel gauge
- Need help
- new join new car!
- led arrow signal light for gd3
- 2007 gets loud grumbling in front drive line area turning to the right
- puddle of water under brake pedal? 08' Fit Sport
- Whirling noise when I press the gas
- Help needed please....new to site.
- Pulling up diagnostics without a scanner? Fit is being weird
- Replacement LED unit for JDM taillights
- Sensor testing
- auto trans wont shift into 5th gear
- Help! Wire broke off at the connector :(
- Are all coil packs created equal?
- Maintanence schedule Q?
- Intake Manifold vs Flash Pro
- 07 fit malfuncation Ind Lamp
- Battery on GD3 needed 2 boosts in 2 days.
- New battery and EVAP monitor
- Used 2007 LX 295,000 kms...how much?
- gd w 15x8 25mm will it work ?
- First post, looking at a 2007 Fit DX, what do you think?
- 1st to 2nd lugging
- Need Cheap Battery Tie Down
- Removing Cowl
- Where is the upstream Air Fuel (oxygen) sensor?
- Strange marking inside oil filter.
- Strange brake light problem
- Vtec solenoid cover?
- HELP! Need Steering Wheel Boss Kit for my GD1 Jazz/Fit
- 2008 sport front strut replacement
- Synthetic Oil Change how many kms?
- Anyone install a warmer thermostat?
- 2008 Sport won't start
- Door locking issue, need part info
- Availability of Keyless Entry Parts
- advice request : driving on snow covered roads
- 60 MPH Shudder/Hesitation '07 Auto Trans 192k
- Problem after head cylinder removal - Help requested
- Gimme a can of gas and a lighter.
- I'm screwed. Need help.
- 2007 model compatibility with Fits made in different countries
- Removing coat hook...
- 07 fit cruise control
- Question - Front Strut Bar
- Hello everyone~!
- HELP- 2007 Fit Sport Jerking While at Stop
- Radiator Fan P/N - GD1, L13A
- Rear shock makes metal to metal knocking noise on bumps.
- I need advice please!
- 2nd to 1st gen engine swap
- Front jacking point
- 2008 Mexico GD3 to US GD3 Brake Swap
- Cigarette socket at the back/trunk?
- 2007 Honda Fit Sport Shaking Issues
- Questions on switching 08 sport headlights
- Throttle response question
- Tow Hook Install Question
- Dash kit advice
- Immobilizer in GD1 Fit?
- Sway Bar Recommendations For GD3
- Item/part number of KYB AGX
- Help Needed for Serpentine Noise
- Just started using Fuelly. 20mpg?!
- Front Bumper Screws
- Voltage Issue, or Noise, or Not?
- My radio won't work
- gd3 manual tranny question
- Duckbill for GD3
- No Power to door lock fuses
- Radiator coolant level.
- Wiper problems
- Just bought a Fit...have some questions
- [HELP] - Extended Wheel Hub Stud Options/Opinions
- Key does not fit driver side door anymore
- New to GDs. First post!
- CD button no longer works
- Spring spacer
- difficult into gear sometimes
- Fit temp gauge and head gasket question
- Changing Armrest Top Cover From Non-slide to Slide
- Misfire in #3 code
- HELP MECHANIC JUNKIES!!!Serious problem with my 07 fit and I am out of options!
- just bought an 08 sport
- Red CT 1st Gen spotted in Westfield, MA
- 2008 Fit Sport totaled; how much should I ask for it?
- New to Forum and my new FIT!
- New to Fit Questions
- Mr. Rusty under doors and more!
- sup peeps new member here with a question
- 07 Fit Sport Map Light Install?
- Do you think this is salvage or repairable?
- scraping sound near left wheel
- Looking for Sport Body Kit - Custom made or original
- A14 maintenance
- CEL vid
- Rear wiper arm removal
- No start problem - 2007 fit sport 5 sp - fuel problem most likely - please help!
- Aftermarket spoiler and factory holes??
- Help Wanted: Replacing Wheel Bolts (Lugs)
- 2007 Fit Engine Stutter -AC issue
- Disable/Program Immobilizer?
- Hi guys, im a Newcomer to fitfreak :)
- Issues trying to start up 2007 Sport, any ideas?
- 08 Fit speedometer question
- Rough shifting 2007 manual w/95K
- Water damage?
- Front Brake Pad Replacement
- Lights
- H&R or Swift lowering springs?? Undecided
- Improving Cosmetics 2007 Fit
- any advice for a fit owner in atlanta?
- Trasmission flush question
- a few questions?
- high beam flashes off?
- Steering Noise, 2002 Honda Fit (Jazz)
- Honda Jazz badge in NA
- Spare / Available feed from ignition
- short ram air intake with costco battery ?
- Fast spin but no crank
- Broken tailgate latch 07 Fit
- Do I need to raise the car to change auto transmission fluid?
- honda jazz 2002 abs light.
- Door between kitchen and hallway
- Batteries died prematurely
- Steering/Trans interlock reset
- A/C Fan Cutting Out
- 2007 Fit Flickering- Help Please
- Too much engine braking when coasting
- Brake Pad Identification Help
- Hanging Idle
- 2007 sport mudflaps.
- It's practical, but is it useful?
- Which Code Reader Do I Buy?
- Stalling when cold...
- Cleaning Throttle Body?
- Acura
- HFP muffler help please,
- 07 Sport pedal adjustment/seat adjustment?
- advice on maintenance
- Some questions, I'm about to start maintenance on GD.
- Please HELP..Drive shaft came off when I change my suspension
- hit 90k, decided to do valve adjustment earlier than scheduled....
- Injectors 07 Fit
- Hard time finding a JDM center console...
- Car cranks, no spark, no fuel, no codes
- Howdy Fit Lovers!
- what is hanging?
- Uk jazz / fit owners?
- First FIT - used car - Advice appreciated
- Road noise "higher"
- front grills, done to death...
- Q's about a k20a3 into my 08 fit sport 5-speed
- Price est -2008 Fit clutch dropping at 161k miles
- Need help with Honda Fit 2004
- Need help with error code
- Shake at idle.
- Tire numbers
- What is the right Size of Rims for a Jazz/Fit?
- Front tow hook specs?
- How to jack it up to rotate tires?
- Add oil or not?
- My A/C stopped working and the side view mirrors don't move
- Strange whine from engine bay 07 fit sport m/t
- New Jazz Owner
- what is this part?
- New Battery
- Your Dream Garage
- Cylinder Head Cover Bolt and Cap
- Duckbill wing?
- GD3 coilovers on GD1, will they fit?
- New Fit/Jazz Owner
- offset question
- Scan Tool
- 150k miles problems
- Annoying Lurching While Picking up Speed
- What is this Part??
- Fuel Filter Replacement
- Installed: Shuriken SK-BT20 AGM battery + PW:JDM relocation kit
- New to the site.
- Still putting her back together
- Which buttons, switches, and dials have backlights?
- Any detailed instructions on removing the bumper on my GD3???
- Pulsating rough idle 08 fit auto.
- Removing the Rubber Spacers to lower the car?
- New Fit owner here!
- I made it!!!
- 2007 shutters at idle
- Cruise Control Issues
- Whats the best offset for my 07 fit?!?
- Bought and Installed Lowering Springs but not enough
- 07' Sport Needs Front Wheel Bearing Love
- Poor Fit
- Which cat and resonator?
- Scratches and paint chips best fix solution?
- alarm keeps going off if try unlocked. urgent, parked in the city.
- Injection to carburetion modification: Fit 2005
- SRS Light
- How important is the resonator?
- SRS Computer Location
- Need some rubbers
- pre-facelift jazz/fit parts
- Needs Advice: Replacing stock shocks to coilovers
- Noisey 2007 Fit
- Horn is blaring when turning!!!!
- '07 clutch or tranny problem?
- Difficulty of installing OEM Armrest Console?
- Driver-Side Fog Light Not Working
- 16v pulley on 8v engine?
- Transmission shifts hard & other quirks
- New Recall on 2007-2008 Fits
- a/c compressor delayed
- Dashboard indications
- Check Engine Light
- Air Bag Issues
- Car paid off now I can get the parts I've been wanting!
- Will these fit the front of a gd?
- What wheel covers will fit 2007 Base?
- spoon front tower bar for GD
- Rear Brake a Grindin'
- Where to tap power if I want to install a rear car DVR/cam.
- Broken arm rest lid latch
- What I did today
- Upgrades for better performance
- '07 MT Problems
- 07 Honda fit questions
- Power chamber filter, too good?
- Heat shield for apexi pod filter help
- strange noiseys
- Where, exactly, is the A/C Evaporator Drain Hose?
- High boost kit for a/t kraft werk???
- Rotrex c15-60 a/t with shifters ?
- rust in trunk
- rear tires wear uneven
- Denso IK22 for idsi twinspark?
- 07 Fit
- enkei rpf1 scraping issues/ solution?
- Parting out Honda Fit 2008 Sport
- Running on 3 cylinders?
- weapon r ss on a 1.3 idsi
- Oil leak
- Honda fit clips vids for sariouse racing builds?
- It happened again!! ughhh
- Mugen vs Sport front lip
- When to change the brake fluid?
- Gd, down pipe, with a cat welded onto the b-pipe before the resonator?
- AC Problems Help!!
- Foglights Without Headlights?
- Help! Need photo of upper R engine mounting tabs
- Weapon R manifold on a 1.3 idsi?
- A/C problems
- New GD3 bulletin coming
- Finally after 3 years, things are rolling along :)
- Engine Bay Noise
- Comparing front strut bars
- New to Fit
- 07 sport AT transmission delay
- 2003 Honda Fit Okinawa Japan
- Cat, cat, cat converter!
- Help!!!!!!
- Konig Feather 38+ Offset Question!
- What do you think of these headers?
- what are they worth?
- Just Bought a Fit!!!
- Water puddle at foot paddle area
- Intermittent A/C
- coilover preload
- Newbie to fits
- honda jazz aircon pipe
- loud cabin noise
- Wtb: Original rear spoiler gd3
- Alternator power wire
- 2006 Jazz Sport CVT - 07-3 Internal Failure of SRS Unit
- Tail Lights Conversion, Specific Issue
- swapped in new"used" engine, new engine wont start
- Does the Honda Fit 2005 model have chain or cam belt ?
- "Boing!" sound after rear suspension install
- Helicopter noise after tire rotation
- Aftermarket cruise control options for 07 base AT
- Diagnose Speed Sensor issue for new owner (P0500 VSS)
- Jolt when coming to standstill - 2008 automatic
- Engine check light (EML) problem need help!!!
- 07 sport fit a/t and m/t shifter tranmission question??
- Storage solutions for the Fit
- Noise behind dash sounds like cow bell
- O2 sensor help
- Dad's Fit
- GD1 s90 Throttle Body, worth it?
- My "new" 2008 Fit Sport MPG tracking thread.
- Battery dummy light
- Sleeping in Fit
- DIY oil change and MM codes
- Brake + Clutch fluid change
- 07 sport 4 blown rings
- steering wheel shroud?
- Folding the front seat flat?
- Introduction
- Larger tires for stock wheels on 08 base Fit
- Solenoid Circuit Problem
- tsx sunglass, and telescoping sun visor
- Do GE floor mats fit the GD?
- 2008 Fit Aftermarket Stay set (tailgate hydraulic lifts)
- 250,000 Miles - What to Watch?
- 08 Keyless Entry Canada
- Need a 2007 Fit Sport Window Sticker (from CA)
- hydroplaned.....need advice on route to go (long read)
- WTB: Stock Spoiler (willing to post to UK)
- Plasti-Dip Colors
- Help with headlight issue
- Coilover Questions
- AUX / CD player buttons not working
- Vtec question
- 100k service coming up
- GD05 rear spoiler
- Replacement clutch suggestions?
- Sport Rear Bumper Lip Removal
- Help ! She's at it AGAIN
- Wheel Stud thread patterns?
- Anyone doing a cruise in on the premier night for Fast/Furious 6?
- 2007 Honda Fit: How easy is it to remove REAR BUMPER?
- Looking to Buy Used, How to check MT fluid? And Hitting Redline Okay?
- New Fit/Jazz owner
- Still having issues after valve adjustments
- Where to find replica mugen parts?
- GE m2 performance springs on a GD?
- Hid kit question
- Replacement Key / Fob for Base Model
- Aux port not working
- How Do I Replace Gear Shift Boot on a Jazz?
- Fascia
- Help finding part # for door trim
- Single Wiper Conversion
- GD1 biiiig wheel question!
- what parts would you like to have available?
- Trying to buy eibach sportlines
- T1R Basics Groupbuy
- The Fit 2 years later
- Would this be a good first car? Jazz - 2004
- Spark Plugs
- Clutch riding itself and possible goof up w/ spark plugs
- First hot day in Chicago and my AC button does not work!
- Alternator removal / intake manifold question?
- Fitless and it feels bad :(
- Jazz With a Twist
- How to remove sun visor?
- New to the Fit community
- engine light on | car stutter in low rpms
- AC high pressure switch
- CVT Issues
- Rims and fault code
- R7 Carbon Cowl Scoop (GD3)
- Weird sound front
- Help! Looking to buy an 07 Fit !
- jazz 1.4cc 2002 fuel sender unit tank
- Lights flicker when stereo is on
- MPG: roof rack update & door visor question
- Steering wheel
- Please help me radio code needed
- Exhaust Issues/Concerns - Tanabe MT
- Possible to sync up parker/licence plate/tail light w/ dome?
- Can I use my stock radio to hook up my amp and subs? and how?
- Fit BAse LX model with a sport key fob
- Lowering Springs Question - TEIN S
- please help! bumper scrape repair
- OEM Coil Pack Part Numbers for 2007 Honda Fit Base Model
- Grinding / Rattling noise when I come to a stop
- Idle lowers when I stop
- Throttle cable adjustment GD3 CVT
- Water Leakage in my Honda Fit yr 01
- 2005 Jazz RHD Radio Removal
- Rough studder after shift
- Finally joined FitFreak!
- Gd3 DIY superchager build??
- Has anyone bought this spoiler for their 07-08? axis replica
- door lock unlock problem-honda Jazz - Requires a locksmith
- cracked front lip/under spoiler :(
- Jemz's Build Thread!!
- Jdm cluster into us fit
- Anyone buy from nengun?
- Paxton Supercharger Kit
- Magnaflow muffler for GD1?
- Exhaust sound video
- SW388 spec help!
- Honda Fit 2003 Japan - Shifting from 1st gear to 2nd Gear Problem
- Sport Lip on Base Rear Bumper?
- Misfire Help
- led fog light bulbs ebay fittiment?
- jdm type r ax grill question ???
- Removing Mugen Visors (or any other stickies visor)
- WHAT is falling off the undercarriage of my baby!?!?!?
- Battery Size
- Loose wheel studs. Need help
- Continuous Coil pack problems
- Issues with 2007 Fit Headlights
- Water leak in trunk
- What size muffler for GD1 gli?
- Electronics or transmission problem
- How long did your stock clutch last??
- GD1 looking for a new muffler and tip!
- 07-08 exhuast on ebay? N1 axle back direct fit
- Keyless Entry Module
- MPG with roof rack?
- How to get a new c? pillar (not trim or a sticker)
- Replaced bad bearing
- aerial/antenna base replacement
- transmission question
- 07 Sport AT
- is this normal?..
- GD Coilover recommendation for comfort
- Idle problems on 08 fit
- Front fender to door gap ... trying to figure why?
- First honda, and first fit :)
- 2005 GD 1 jerky and shuddering at low RPM and CVT slipping???
- NEED HELP - How do I install speakers for a 2007 Honda fit?
- cannot unlock car after replace remote key battery
- Parking Light LED trouble.
- Throttle Response while double clutching
- Can I use Castrol GTX 5w20 instead of what Honda recommends (Honda oil)?
- Is it possible to re-programme the radio
- Remval of SRS warning light
- Few questions about maintenance
- Need help with installing front bumper
- Used engine questions
- dyno numbers of flash pro ? iwant to see one
- Replace Side View Mirror Housing?
- dyno'd the fit finally
- Driver's side power window Fit 07
- help needed looking for a part
- Wet Carpet from Door Leak Fix
- Hi ya"ll
- Rear Bumper Diffuser
- Side Mirror Replacement
- Spark plug ejection w/ coil blow out
- Gearbox Coolant
- Jerking/bumping feeling when going up hills - engine or transmission issue?
- RIP Silver Bullet. My SSM 07 Fit Sport has been totaled by a LARGE doe.
- Help Recaro Seats.
- will an 08 honda fit take 11 sport edition fit rims?
- Enkei rpf1 off set question??
- new high flow cat from Motiv Concepts on its way
- Rear Strut Help
- Front 15inchers tyres rubbing within when making full right or left u turn.
- HONDA JAZZ 04 SPORT - 5th GEAR POPPING OUT!!!
- Drooling Rear windshield nozzle replacement
- Mouse access points
- heated mirrors?
- Battery Maintenance
- 2007 Fit Sport Clock and Dome Light Issues
- Power Upgrades
- Water dripping from sun visor
- Spring questions..yes another one
- Do I need a new deck??
- How do I disconnect positive terminal of battery?
- importing a fit???
- Positive battery terminal attachment very loose
- Absolutly No Idea What So Ever....l
- Jazz 2004 GD1 - Maintenance info
- Had valves adjusted but can now hear them when car is cold. Normal?
- Honda Fit GD3 vs. Scion FR-S, EVOX, and Dusted by S2000 :/
- newbie here with electric window issue
- Poor gas mileage
- Frustrated cant find blower relay location anywhere!
- Loss of torque blips at highways speeds problem
- Brake problem. Yikes! Please advise
- Different Engine Ideas for the Fit
- $8k for a 2007 Sport with 97k miles - good value?
- Car shakes when turned on 1st thing in the am.
- Transmission Flush
- Tired battery = strain on the alternator?
- No idea
- Car dies while warming up
- Moving or relocating battery behind bumper
- Help! cel after valve clearance adjusment
