PDA
View Full Version : 1st Generation (GD 01-08)
Pages : 1 2 3 4 5 6 7 [8] 9 10 11 12 13
  1. Engine chatter (audio included)
  2. Aftermarket coil packs
  3. 2004 Honda fit with 750 miles
  4. code P0956
  5. wiring for stereo
  6. hello
  7. Cat delete on N/A engine. Wil it increase performance?
  8. Do expensive brake rotors help?
  9. Hondata Flashpro and vtec-E on the GD3
  10. Opening the tailgate panel?
  11. to all orlando fl area fits
  12. Cvt problem
  13. New owner, need maintenance advice
  14. Engine mount part number
  15. How big is the standard exhaust/headers outlet?
  16. Need help with idle issue/power loss
  17. Radio Button Extra Functions
  18. Need a replacement Stereo bracket for 07 Fit (RHD)
  19. Stereo Face Auxiliary Button Issue
  20. Coils
  21. not fit but can i still join ??????
  22. fit hesitate while accelerating
  23. Gasket falling out of rear windw stop light- how to fix?
  24. THE Spoon Fit for sale
  25. stumped
  26. hondata flashpro gains???
  27. What did you get for Christmas???
  28. Merry Christmas!
  29. Question for people with 07 08 fit downpipe fix??
  30. Honda Jazz GD5 Mint Green Project
  31. modifying stock injectors
  32. harro from iowa
  33. Bad ignition coils
  34. Best Extended lugs and lug nuts with locks?
  35. Electrical connector direction or diagran.
  36. Honda Fit Radio Dash Kit
  37. Parts interchange fit v sport
  38. Sport automatic Fuel use and unwanted revving
  39. 2008 Honda Fit Sport 5sp 87k
  40. Top speed question
  41. SRS Light Codes 15-4????? HELP!
  42. Wheel almost fell off while driving
  43. Computer change
  44. Spooky electrical problem
  45. Torn...
  46. Upgrade to...?
  47. Anybody completely take off their spoiler??
  48. Bbs rs frustration help!
  49. Check out our Christmas Specials!
  50. 15" steel wheels for winter snow tires on 2007 Honda Fit Sport
  51. 08 honda fit sport transmission issues
  52. Is there a brake issue after service at Honda garage?
  53. Problems with HID kit after 2 years
  54. Fit Sport 08 - Multiple Misfire - Cylinders 3 and 4
  55. Rear wheel rubbing on one side after aftermarket rim installation
  56. 2007 Jazz (fit) with air con query...
  57. 07' Fit Sport Stuttering
  58. Check Engine Light
  59. Christmas is almost here...
  60. fog issues
  61. cat backs
  62. Im looking for a front tow hook
  63. No blower, no mirror controls. Please help
  64. Anyone in Columbus/Dayton Ohio want to do valve check / adjustment?
  65. Help! :-) Engine Lamp in the panel lights up constantly
  66. AC, Defogger, Airbag light
  67. extended warranty on a used high miles honda fit
  68. Buying honda fit 07 turbo kit
  69. 08 Sport 3rd Brake Light
  70. CariD Dash Kit
  71. How many of you have 2 child safety seats installed?
  72. '08 Brake Fluid Change - Tips or Lessons Learned?
  73. Rough idle during warmup
  74. The "sweet spot"
  75. '08 MTF Bolt Torque Specs?
  76. Post you GD related Black friday purchases !
  77. Largest motor that will fit under the hood
  78. When were the seats changed?
  79. moved up north fit battery died, after jumping works fine, do I need a new one
  80. Radiator water always dry
  81. help. Pioneer Patch Cable to GD1 steering wheel controls.
  82. 07 Fit -- Install an AC unit???
  83. 08' Sport Gas Mileage Not Up To Par?
  84. Does this sound like I need valve adjustment or coil pack?
  85. Buying Honda Jazz 1.2 2007
  86. Petrol Magnet Fuel Economy?
  87. Valve adjustment question
  88. Vajazzle's Build Thread!
  89. Wheel bearing?
  90. question about the progress rear sway bar
  91. Project: Engine Bay Fit GD1 JDM
  92. no luck
  93. need some help with (warm) tire pressures
  94. Hit a deer -- managed to hit a bunch of surfaces
  95. my heater sucks
  96. Front left brake noise
  97. Where Is The Beeper Located?
  98. One Year With Fitty Cent...
  99. ideal iPhone dash mount suggestion
  100. Oil drain plug over tightened???
  101. Fit Shop Manual in PDF
  102. Honda Jazz 2005 front passenger door rattling noise
  103. Anyone have feedback on isc coilovers?
  104. Can I put Sport stereo in 08 Base dash and install Aux input jack somwhere?
  105. new GD3 mod and maintenance suggestions
  106. purchasing a high mileage FIT
  107. carwash decapitation
  108. Emission light on. Strange goings on..
  109. GI: A custom air box?
  110. Where is air bleeder valve on 2007 Honda Fit
  111. Battery or Starter
  112. New to the forum!
  113. Raceland Coilovers
  114. GD3 Sport Auto Escutcheon Replacement
  115. Check Engine LIght on!!
  116. Hesitation at accelerate from stop and multiple codes but no apparent elec problem
  117. How to access the headlights for replacing?
  118. New GD3 owner from Japan
  119. Used fit sport test drive/what to look for
  120. Help!!! head gasket
  121. Drivability & ergonomics upgrades
  122. Value of Engine and Tranmission
  123. for those that dont already know- Hondata
  124. Strange Noise
  125. Parts which are usable for a JDM Fit L15A Engine
  126. Brakes brakes brakes! So many to Choose!
  127. High mileage oil....???
  128. Door key wont enter into key hole
  129. have you acheived 45mpg or higher?
  130. 2007 Fit Sport recommendation
  131. Car shuts of after it says its not cold anymore
  132. is there a 07 fit hks catback exhaust?
  133. cvt fluid change at Honda
  134. GD1 Scrub radius
  135. Exhaust; which one do i get?
  136. 08 fit sport AT (gd3) with tpms light on, took it to dealer and...
  137. Keyless entry remote
  138. H.I.D problems, no low beam 2008 fit
  139. Camber bolts and rear shims
  140. 14"X6" 55+ Sub 10lbs wheels
  141. Any Weapon R race header updates???
  142. mods for $900
  143. 2007 Sport Auto/Paddle Question
  144. Odd noise from passenger coilover
  145. Steering wheel questions
  146. What wheels should I choose?
  147. Car buying advice for 2007 Honda FIt Sport
  148. Great mods for about $300
  149. Clunk in front pass side - steering rack?
  150. RPM drop when start/stop condition (tried almost everything but still not fix!)
  151. Intake for GD3
  152. ***HELP*** Clutch issues
  153. All I want for my Fit This Christmas is...
  154. Is an exhaust header worth it? 07 fit
  155. Changing Antifreeze on my 2007 Fit Sport
  156. Recaro seat install!! Wrong area but need quick answer
  157. help with new interface, mp3 player
  158. Spoon vs. Mugen!
  159. Do I really need a new clutch at 59k ?
  160. Washer sizes for Drain and Fill for MTF change
  161. aftermarket A/C installation?
  162. Noise, won't go away, Tried a lot!
  163. R.I.P. 2008 Honda Fit Sport
  164. how far can you go?
  165. just bought a fit
  166. New guy here....
  167. 2007 Honda Fit Throttle Body Cleaning
  168. STI Splitter on ge8, anyone try on gd3?
  169. Transmission Shudders at Highway Speeds
  170. Tints or No Tints?
  171. 1st or 2nd GEN 2008 Fit I own?
  172. [Question] Need help identifying part
  173. Back Seats Removal
  174. ABS Light on
  175. lightweight wheels
  176. 2007 honda fit ecu jet performance questions??
  177. Got OBD scan tool
  178. Whirring
  179. Help CEL after valve adjustments
  180. 08 Fit Sport ABS and Brake light on: all others off
  181. 2008 Fit Sport RPM problems?
  182. GD3 Limited Slip Differential
  183. Serpentine belt
  184. My 08 Fit
  185. Radio/CD volume goes down at intersections
  186. Speed limiter JDM GD3?
  187. my lame GD3
  188. the accessories of the car
  189. Engine vibration past 4k RPM / knocking at idle?
  190. Gearbox!!
  191. 08 sport with high pitch whirling sound heard from inside car while idle and driving
  192. Coil Spring clamps
  193. My seat KILLS my back!!!
  194. 08 Fit Base Wheel Question
  195. What do you wish?
  196. CV Joint
  197. Where can i source stabilizer link rods?
  198. Anyone have pics of nose mask / BRA installed on 07-08 Honda Fit?
  199. 2008 Fit Sport Problems
  200. Floor Mat Hooks...
  201. Help!! Knocking noices on full lock
  202. A'Pex i. Air intake
  203. Thinking about new rims
  204. HelP Axle Problems
  205. on my dashboard the SRS light is on when im driving
  206. What kinda of Exhaust
  207. help! radio code
  208. Help! Does any know how to fix a lossen Shifter (03 GD3)?
  209. i'm new to fitfreak but here's my jazz GD mmc
  210. High oil pressure in crank, low pressure in rocker arms??
  211. Looking into getting a Fit
  212. advance ignition distributor tuning
  213. Suspension options.....
  214. 2009-2012 Side Molding on GD?
  215. What Springs will go good with the MONROE MA811's?
  216. Trunk grab handle?
  217. This bracket popped off--do I need it?
  218. 08 Honda Fit Base Front Struts
  219. What is this weird part inside the front doors? (2008 Fit Sport)
  220. Misfiring? Here are a few things to try before buying coilpacks...
  221. Factory radio help
  222. man this stuff is confuessing.. 08 fit
  223. How to Adjusting the clutch pedal free play
  224. HELP! How to lower my rear coilovers?
  225. What tyre will give a nice stretch on 16x7J wheel?
  226. Just Moved to Madison from New York
  227. My GD1 2006 build, first honda jazz i'v owned and im a UK fitfreak
  228. 260 Watts OK for 2008 Fit?
  229. front bumper
  230. New to me 08 Fit
  231. 07 Fit Front Door Speakers
  232. T-Boned & Totalled Fit, found Fixed & FOR SALE on Craigslist!!
  233. What would/did you to to make awful commutes better?
  234. Fit Newbie with low rpm question
  235. New Fit Owner
  236. Spoiler Fitment J's Racing
  237. GD1 Parts Wanted
  238. floor mats?
  239. Help Regarding MT Fit
  240. Happy With These Tires
  241. 07 Fit Sport vibrates when A/C is on.
  242. 2007-2008 fit stalling in drive when first started
  243. Where to put this part?
  244. Gd ftw!!!!!!!!!
  245. Cylinder Head needs to be rebuilt
  246. Took my car on some park trails for fun...
  247. Carfax report for a Fit please!
  248. Stock GD3 Jazz VTIS suspension, is it the same as the GLI & VTI?
  249. Why are you still driving your Fit?
  250. Rdiator Fan
  251. lol or end life now? Just installed 4 new coil packs and AIT sensor, idle still sucks
  252. MPG has TANKED! Anyone else?
  253. Mpg
  254. Seat Belt Chime Issue... PASSENGER SEAT
  255. Help! Is 90000 miles too much for 07 Honda Fit?
  256. Info button on stereo
  257. Torque converter problem with 08'
  258. Beve Vested Washoe County
  259. Rear tires diagonal scuffing
  260. It's unravelling fast...Carpet
  261. 2007 sport vs. culvert. culvert wins. scrap yard?
  262. introduction
  263. Coilpacks - again...
  264. 2008 Honda Fit Sport Radio Removal - How to?
  265. A/C + MT = Terrible in the city
  266. The bottom radiator hose cold and the top one hot
  267. Jazz Typhoon Food Victim
  268. Back seat is stuck closed??
  269. Gas Tank amount
  270. Need caster / camber kit for tire wear
  271. Cargo cover for Fit 2005?
  272. fit powertrain longevity?
  273. 2007 Honda Fit ECU issues after reseating connectors???
  274. So, I'm an idiot...
  275. Got this purple Fitty 08', what should i do now?
  276. Any idea of origin of engine noise
  277. 08 Fit Sport - What do you think of this deal?
  278. Changing Automatic Transmission Fluid / Anti-Freeze
  279. Identification request : vent port near key.
  280. Airbag Fault...200 miles out of warranty.
  281. Armrest Installation Instructions
  282. Front End Repaint
  283. Holy mother.. spark plug stuck -> rubber gasket melted
  284. Please Advise: Strut/Shock R/R
  285. Can you program 07 Fit door lock?
  286. How to replace a grill in a honda fit Sport
  287. Adding Keyless entry to my 2008 LX
  288. Oh Hail
  289. Dropping the glovebox (CD changer/AUX input mod)
  290. Get the CEL error codes
  291. Factory stereo going bad? Weak output
  292. Recommend a 2007 Sports armrest for me
  293. Just purchased '07 Sport -- Any fun suggestions?
  294. ac filter gd \ jazz 08
  295. Need advice setting up my 2001 FIT
  296. after market rims on my 07 fit sport..please help
  297. Is my Fit hydrolocked?
  298. A/C evaporator freezing -- bad thermistor?
  299. Parking bulb type?
  300. Car "skips" while idling.
  301. Can Facelift stereo fit pre-facelift?
  302. Wiper blades
  303. Fit vs. Jazz aftermarket issues (help needed)
  304. Help AC problems in Alabama
  305. OEM 2008 wiper fit on 2007
  306. Rear clicking noise? Rear Bearing?
  307. maintenance on a low mileage fit
  308. Where to buy parts (Canada) online? Rear seat latch
  309. Fog light Lens
  310. Roof Rack on 2008
  311. Fuel filter Fit 2003 4wd
  312. Cutting springs?
  313. battery light
  314. Catalytic Converter: Which Universal replacements are the best options?
  315. Honda Jazz lumpy running
  316. 2008 LX Rims & Tires
  317. 2008 Stereo & Speakers
  318. Forsale
  319. Whistle sound from driver rear mirror
  320. A/C problems, need advice
  321. hondafittuner.com product reviews, plz help...
  322. Jazz GD1 EPS Power Steering Problems
  323. Coilovers or springs
  324. summer tire for 2008 base?
  325. Dome Light Problem(yes i searched first)
  326. Gas Mileage increase
  327. Music from Ipod
  328. My Fit's 48hr makeover.
  329. Towing my Cruiser / motorcycle with my Fit
  330. NOOB WARNING: troubled engine hiccup (dont think its the coilpacks)
  331. Check Gas Cap
  332. Disturbing noises
  333. Fit in the snow
  334. A/c | heater blower is weak!
  335. Oil andfluid changes for low miles on 2008
  336. 06 1.4 CVT Jazz/fit with odd running fault. Help!
  337. hondafittuner.com??
  338. New owner of 2008 Sport - maintenance plus ?
  339. My jazz\fit
  340. gd1 ecu pinout
  341. Tpms ?
  342. A small fun mod to my Jazz
  343. 2008 Ram air intake.
  344. Ken ken spoiler
  345. Any major maintenance for 100k Fit?
  346. Cleaning engine compartment
  347. brake pads on wrong side?
  348. Finally... I did it... RALLY ARMOR Mud Flaps on GD =)
  349. Cleaning AC condensate drain
  350. Cruise Control and Sports Feature out
  351. FireFox Fit Persona
  352. A FIT Sport 2007 needs help
  353. 1.3 stock lsd into 1.5 gearbox
  354. Guy Steals My Visors
  355. Auf Wiedersehen to the Fit Nutt
  356. Automatic Transmission Oil Cooler Install
  357. Speaker upgrade, 2007 Fit Sport
  358. Oversized dome LED?
  359. Powertrain - Unintentional Acceleration
  360. On-line supplier of parts for A 2001 Honda Fit?
  361. 07 Fit, weird battery mystery?
  362. wanted: coilies
  363. Skunk2 Pro-C Coils-trying to get rid of them.
  364. New to Fit
  365. Wheel noise can't figure
  366. How much sag is normal?
  367. Roof rack with sunroof, will it fit?
  368. M/T popping whenever i shift
  369. whats a good new clutch upgrade
  370. Ignition Switch Replacement?
  371. I think I need a new clutch?please help
  372. Can't believe what I am being asked to do...
  373. cf parts for my 2003 gd
  374. Hello everyone
  375. Hello to all!
  376. '07 Fit Sport Vtec Solenoid Question
  377. Win a date with Melissa Riso!!!
  378. b-12 code? Just got the car? Help Please
  379. Newbie saying "hello"
  380. New member intro. Potential fit owner.
  381. Sticker Ideas?
  382. Anyone with issues Seibon CF lip
  383. Hopefully soon to be Fit owner
  384. Tires
  385. where do u guys buy your mods, like dead pedal and more
  386. Sway Bar end links
  387. Honda Fit 2002 GD1 i-SDI 1.3L; Turbo kit
  388. New to the forums!
  389. Floor mats
  390. Pls help, gf210 springs
  391. A/C ReCycled Air VS Outside Air
  392. Where to buy a Mythelogy crank pulley.
  393. can u put spoiler on base
  394. 2008 Honda Fit Armrest
  395. Honda Fit Spedo Swap
  396. some new wheels...=(
  397. People with hood dampers. HELP!
  398. Would bad ground cause idle misfire?
  399. Grinding or Gravel noise when turning wheel all the way to the right
  400. another fit to the car grave yard
  401. New to the Fit Nation and need help
  402. AC not blowing cold and summer is approaching quick!
  403. transmission fells smoother after service
  404. I miss my GD :(
  405. B spec Fit comparo in this months C&D
  406. Hood damper & OEM JDM hinge install help!
  407. Question from a future Fit owner
  408. J's Racing Lip Owners, GET IN HERE!
  409. Random TPMS light. (not squishy tire)
  410. 2007 vs 2008 service manual
  411. Question about airintake
  412. New to fitfreak
  413. Will TSW 17x7 +45 fit on my 07 with the Eibac sport springs?
  414. Will TSW 17x7 +45 fit on my 07 with the Eibac sport springs?
  415. Please Help!! Brake issue??
  416. DC Sports CSB1319 Strut Bar
  417. Will 2nd Gen Fit wheels "fit" 1st Gen Fit?
  418. Where can I buy here in Japan Honda Fit Type S Front Bumper
  419. What would you do?
  420. T1R B-MAX CF INTAKE Questions...
  421. Where to get dai led
  422. not happy after dealer MT fluid change.
  423. Honda fit Rotary swap, 20b 13b
  424. Battery Terminal Too Small
  425. carpet problem, what did you do?
  426. enjoying my little car
  427. My Dealer Says Fits Don't Need Valve Clearance Adjustments!
  428. CF front lip
  429. Why not hid's?
  430. electrical issue on my 2007 fit :( please help!!!
  431. Black Honda Fit Sports Grille
  432. high beams come on only when car is started
  433. Lower Control Arms
  434. which droplink??
  435. Fit Successor
  436. Supercharger in 2008 Honda Fit Sport
  437. Used Injen CAI for $100. Good Deal?
  438. Password JDM wiper delete?
  439. Supplemental(secondary) battery question..
  440. Steering wheel cover?
  441. Need help locating Fog Light Relay In fuse box
  442. Wipers controlling Signal lights??
  443. Need some info on high flow catalytic converters
  444. 02 sensor location.
  445. New to the fit world
  446. What clutch should i get for my fit?
  447. If you live in the Baltimore/Columbia area
  448. Floor mats
  449. good hid kit and do our lights reflect
  450. Looking to buy a Used 07 or 08 Fit, questions?
  451. Help needed :( asap
  452. Best/cheapest place to buy OEM accessories
  453. ordered CF spinning replica spoiler
  454. MES Connector location on an 04 GD
  455. umm what is the thing that looks like a floor mat but only on driver side
  456. K & N Replacement Filter
  457. Hp difference between GD and GE
  458. quick release bumper fastners questions
  459. Opinions on this armrest?
  460. Did my alignment at Firestone and got lifetime
  461. Not fully satisfied with my Megan Coilover drop
  462. New to FitFreak
  463. Jdm front bumper fit ment Question
  464. Cornering lights?
  465. Has anyone tried the DC Sports CAI?
  466. 08 GD3 lurking around
  467. SRS Units compatibility for GDs
  468. Slammed and hella crushed
  469. busted OE sport foglight replacement.
  470. TPMS problem, please help!
  471. Someone Using my Photos on eBay
  472. What Service to do on 2008 Fit Sport???
  473. Best springs?
  474. How to install aftermarke air intake?
  475. Radio Auxilliary dead
  476. 1st post! Hello all!
  477. adding hitch/trailer, need to beef up suspension
  478. Looking for used GD in Montreal
  479. what up everyone. newbie here.
  480. Can I put 18" wheels?
  481. i'm a new found freak! =)
  482. Anyone could find me instruction on installing thesepedals
  483. Does anyone here play Car Town on Face Book?
  484. Problem with small rust sport on the door
  485. Aftermarket Intake AND Larger Battery
  486. ECU to the L15A
  487. New member, new owner, major efficiency drop!
  488. Alternator/Intake Manifold
  489. Unblock Window Spray Nozzles
  490. hello
  491. thinking about adding car audio is it worth it for the fit
  492. New Guy!
  493. Prelude vs. Fit, Should I do it? Safety?
  494. BOYCOTT JUNK2. (Lots of Shady Activity Within)
  495. Idle
  496. BBS rs wheels.
  497. AC Condensor replacement
  498. Ran 2008 Fit without oil
  499. GD with rubbing in front after rim and tire upgrade, need help!!
  500. DIY Remove drivers KEY LOCK HOW to???
