- Cross Generation Compatability
- Audio Jack Circuitboard Mod
- AMPG stuck
- RUST spots
- Disapointing fuel economy!
- Electrical Question: Battery to Starter
- whine when moving off in 1st / 2nd
- valve chatter and A/C fan..
- Daytime Running Light Fuse
- tein s tech w/ 17s
- All speakers out -- no audio.
- Addressing the purported noise issue
- About to move to Georgia in the FIT.....
- More Help Please: Rear Camera Wiring
- Starting Issues. Not Battery (?).
- Any help on this immobiliser warning sign (LINK)
- Newbie here from CA
- airbag help
- HI guys/gals anone knows how to FIX this please or what to do?
- Extended Warranties
- Bodykits in the UK for the second gen
- Hds????
- installed 75t battery in 2009 fit
- thinking of replacing starter....thoughts
- 2009 sport AT--28 mpg on 75% Highway-What could be wrong?
- Audio problem 2009 fit
- Final mileage stats for my '09 Fit.
- Seat Update
- Oil Change Level or Tilt
- 2012 Honda Fit Steering Squeal
- 170k 2009 doing its first clutch job GE8 M/T
- JDM vs USDM coilovers
- Help with trouble code p0172
- Hauling a kayak on a 2013 Sport?
- V6 Honda Fit Build
- Possible grill for 12-13 fit sport?
- looking for a turbo manifold for my 11 fit
- garbage door lock actuators
- Cleaning the Floor Mat Logo
- Containing cats in the Fit
- AT Went a little flakey yesterday
- Cracked dash and button rubbing off
- Side mirror replacement help
- B1 services at dealer - How much?
- About to buy a fit. What to look for?
- New Owner in Victoria
- Do the old instructions for programming keys still work?
- Advice on LED Side Light
- Greetings from the Bluegrass
- Weird Smell From Vents
- Battery Experiment (Please read if you like a mystery!)
- Car won't start, engine seems flooded
- Flashing D problem...
- Electrical problems.... maybe....
- just want to say hi
- Cleaning behind side skirts.
- Sun Visor upgrade?
- 2012 Fit LX without Navigation - Can I play music via Bluetooth?
- Radiator petcock drain access, underbody shield?
- Dumb request
- Mobile Diagnostics
- Another FNG
- How easy it it to replace the inner Rack End Rod on GE6 / GG6?....
- Time to replace my clutch... again. Suggestions for parts?
- 2009 honda fit multiple misfire codes
- Steering wheel controls
- Looking to sell, need help on pricing
- Storage in your fit?
- Service code changed?
- New Fit New Honda owner!
- Strut Replacement Help Needed
- Multi-information display language
- 2009 Fit Sport - require help
- used swift springs
- Do not buy from hondafittuner!!
- Trickle Charger for 2010 Fit
- Scammed by "Speed Honda" on Facebook
- Calling All Freaks
- Aftermarket rear hatch glass.
- change dashboard language in honda fit 2012
- Rear windshield wiper
- Engineering Explained Style acceleration tests for octane and weight
- New guy with pic request
- Manual Transmission - Strange acceleration and tire wear
- 2011 Sport bumper on 2012 base?
- Trying to contact JDP Engineering, no dice!
- Rear Wheel alignment
- Base to Sport conversion?
- Shifter feels funny. MT ppl help verify please
- Keyless entry remote
- Honda FIT 2011 Smart Key
- Is this the right hole to run an amp power cable? Warning: bad quality photo inside
- Front License Plate Holder Bolts
- This interesting port in center of the console in 2011 Fit
- road noise
- How low can your gas gauge go?
- Need help plugging stock steering controls back in!
- How to use DRLs with HIDs
- Where to attach a rope to rear hatch???
- AC switch button stuck on "ON"
- Media Display Standard (Non-Nav)
- The FIT has great aerodynamics... Maybe too aerodynamic.
- Performance slight but real mods...
- What is the best window visors to get?
- Just bought 2009 Fit Sport upgraded from 1997 Civic hatchback!!!
- Major HandsFreeLink FAIL...
- Deciding between 2009 and 2010 Fits
- Connecting an underseat sub from internal power wiring
- 2010 1.4Lx i-VTEC M/T
- OEM USB power output?
- Problem with Function and Form coilovers
- Simple interior lighting fix?
- Significant MPG increase switching to PP
- New member from P.a.
- Seeking Mechanic in Los Angeles
- Broken Wheel Stud
- Wheel Bearings
- 08 Fit ck engine lite....yay...
- 2010 FIT 1.5L L4 F/I ManAll Typhoon Kit (CA) 69-1017TTK Performance Intake Kit review
- internavi and honda access
- New member from Puerto Rico.
- stereo in Japanese or chinese language
- 09 cv axle and wheel bearing fix now ABS light is on....
- replacing the cat...advice?
- So did my first road trip with "eh" mpg...
- Transmission filter
- Cruise control question.
- #SakeBomb
- from MK1 to MK2 Jazz - Considering Switching- Just How different they are?
- 87 or 91 gas ?
- Misfiring & coil replacement not fixing
- Going to get 1st oil change + other things. Just want clarity
- Tranny fluid
- How many spark plugs? 4 or 8?
- Rodents have done serious damage to our Fit!
- What is my totaled car worth?
- Trans fluid change
- Used 2009 Honda Fit Sport
- Know what I like about my '09 Sport most?
- Need any help with SRS re-set.
- Want all dash lights off when headlights are off
- Please help
- Maintenance for pre-owned Fit?
- 2009 fit S with 180k miles
- does my engine behaving normal?
- New (to me) vehicle - 2013 Honda Fit Base
- OEM 13 Floor Mats
- Valve adjustment spec
- I'm new here, need your help finding product
- Honda Fit 2013 Remote Starter
- Engine L12B1 Vs L12B2
- Front Place Mount?
- tires question
- My Fit and wife's CRV (same issue)
- Modifying Seat Cover to Allow for Side Airbag
- 2013 Jazz, aftermarket fog lights?
- Passenger Map Light Not Working
- re: front lip sources
- disable AC when on screen defrost
- Bad MPG in 2011 Sport AT
- Kuo's Garage Product Portfolio
- Reality Check Me On Emgine Noise
- Spare key for honda fit sport 2012
- hi im new
- '10 engine rattling engine noise question
- unlocking the doors from the inside
- Help my dying fit
- Can a Raccoon get into a Fit?
- Window Tinting and Battery tip
- Some neat Swiss Jazz options!
- Why Doesn't Honda Do Forced Induction?
- CARB Legal turbo or Supercharger kit ? GE8 ?
- It's been a while, But here's what's happened.
- Ever wondered what a 140lb case of servers looks like on a Fit?
- Thud sound coming from the rear when at a complete stop.
- LED Bulb Change Out for Taillights
- New 2013 Honda Fit Sport Owner
- Help a new guy decide between good deal or too good to be true deal
- K20A in a GE8?
- Rides like a truck!
- Cargo liner $15 in CA (on ebay)
- Quick question
- 2008 Fit, won't start in cold weather
- Problem Starting
- Electronic FSM
- Changed H4 bulb from HID to Cree LED. Lowbeam too low
- Quick Question on Downshifting in D mode
- Center console cup holder light - wire tapping?
- Alarm light blinking
- Replacement/spare keys for the '13 FIT?
- GE8 MT using MTF-III with clicking sound
- Reset TPMS Light 2010
- '13 Sport MT update
- 6.7l per 100km or 35-36MPG my real world MPG.
- What apps from your phone do you like using in the car?
- Cargo Floor - seems flimsy
- Another hitch question
- Is the FIT safe for a childs car seat?
- Remote wont unlock car
- Grinding Sound at Start up?
- Would one of the Mod's mind posting bulb sizes for 12'-13'?
- 15x7 Draglite rims, but no centering rings
- Fuse Box: Where?
- JDM Honda Fit GE7 (AWD) HELP
- Louder horn
- Winter tires. will 205/55/16 work on stock 16" wheel?
- Do lighter wheels bring only good things?
- Intermittent Wipers DIY on 09 Base Fit?
- Seat belt, Looking for a 09~13 Sport driver side front belt
- Why am I having so much difficulty with this???
- wow are my tires bad
- Dealer completed alignment - now steering feels "loose"?
- Engine Noise - VIDEO
- Options on 2009 vs. 2011 Sport
- Paddle Shifters - Anyone use theirs?
- TPMS question
- Are JDM OEM Honda Fit Tails USDM Plug and Play compatible?
- Strange issue with vents
- Mugen Window Visors
- rattle at shoulder strap height adjustment
- what wing is this?
- OEM window visor installation
- GE Hood Air Duct Part#?
- Rear bumper detached
- 09 SPort BAttery Terminal Cover Question....HELP!!
- 12 Base: tailgate will not lock
- Help! Warm air through vents and condensation
- Any known bugs or issues for 2009 Base AT?
- Does anyone use E10 91RON Petrol here?
- My 2013 TF Sport
- Heads up Mugen 09-11 accessory parts slowly being discontinued
- Spark Plug Time 2010 Sport
- New airbag recall - are Fits affected?
- 2010 Fit Sport
- Buying Fit 2009 Base model AT. Want to upgrade rims and tint the car.
- A Nissan GTR part that "fits" on the FIT GE8
- mpg
- 2012 Fit 5MT Window Problems
- Possibly buying another Fit!! Have a few questions first..
- Hey everyone!
- Questions on paint
- newbie
- '13 Honda Fit Quesions. Please Respond!
- New girl and her fit
- switch for mirrors should it have a backlight
- Hi guys im new here and i want to knw if
- Brand New to the Fit Scene. Need Advice
- HELP! Honda Jazz hybrid user manual!
- Anybody ever try NanoLub RC-X?
- 2010 Fit Sport without paddle shifters?
- Blue temp lite?
- Is 336000 KM A lot?
- First extended drive
- 3.5mm won't work with android?
- 2009 Fit LX/Sport Vs. 2009 Toyota Matrix
- Problems caused by aftermarket 12V USB adapters?
- My 2012 sport
- Fit wins division title!
- Help with Turn off 2013 Fit Navigation
- Murphy's law in action: snapped speed sensor wire !
- 5MT how are you supposed to shift with the rev hang?
- 2010 Fit Sport MT 100k Maintenance Question
- using Autolite sparkplug in 2010 Fit.....bad idea?
- Selling my 2011 Honda Fit 152000 miles
- Dumb Question
- Package shelf support cords
- What is the REDLINE RPM for a GE Fit?
- She's alive! Just wanted to share.
- Can you coast down hill in Neutral with AT?
- Upgrade / accessories ideas please for 2010 Fit Sport
- Arduino Auto Headlight Circuit
- 2010 Honda Fit Sport -Airbag deployment/srs computer
- Got my 2013 Honda fit about 2 weeks ago and made some changes!
- Towing a U-Haul Trailer
- Is this WRONG?
- Advice for moving a double/full mattress with box springs please!
- where to find complete audio wiring diagrams for the 2012 navigation unit FIT
- 2008 Honda Fit Base Manual
- Should I be worried about this recall pre-purchase?
- Accidentally drove off of a curb
- First Post
- New 2009 Fit Sport owner - couple questions
- Wiper Travel
- 2013 Honda Fit Need Part Identified Help with accident
- torque pro in fit
- My first car and first post!
- What Fits? Hauling Tales.
- Automobile: 101 questions
- GE8 Tuner
- What size speakers fits a honda 2013 fit?
- 150,000 NYC area miles later in my Fit
- '08 Fit Sport "Chugging" at idle
- A couple questions...
- 09 Fit Sport Power Window
- Weapon R mods
- 2009 test pipe
- Ultra racing?
- Testing the waters (Mugen Fit)
- I'm new here
- WTB: GE: Don't just give it away to the dealer
- Does skunk2 shift knob fit 2013 fit?
- unknown button on the dash on proclip's website (and proclip advice)
- Finally bought 2013 a black manumal fit!
- what to consider when buying first fit (09 - 11)
- Wheel Alignment - Front only or four wheel?
- Manual trans owners, help me identify this
- Finally got wheels to go with my vinyl wrap
- New Fit Sport stock tire size --> Michelin Premier A/S
- Lesson learned
- Help Unlocking My Doors!!!
- Gaskets for t1r header and race converter.
- Crash! Help on Parts CAPA CERTIFIED vs OEM
- Help with mystery part found in pre-owned 2013
- 2009 Purchase: What to look for?
- New, don't punish me yet
- Fresh Washed FIT
- New to the Honda thing
- Anyone running newer Si wheels?
- Hello Fellow Fit Owners!
- How to route trailer wiring harness?
- New Here
- keyless entry remote for 2010 honda- advice needed!
- Reintroduction, CBP GE
- Transmission shot?
- Some new mugen goodies
- So it took a little over 5 years but....
- Bow & Stern tie down spots for kayak?
- FIT wheels being stolen?
- Difference between sport models
- Ciao a tutti!!!
- So, I wanted to buy a manual black fit
- Newbie here buying a used Fit
- Warranty, extended warranty and servicing..
- Possible Steering-Alignment Problem
- How do you adjust the angle of the headlights?
- Alarm chirp vs regular honk
- Brake pads change at 62K seem reasonable?
- NO ETHANOL in silver BP gas inupper mid NC
- Valve Adjustment: North Jersey
- best debadging method?
- Dinged Resonator
- First post...FINALLY! more to come
- First post... new shoes!
- Need advice on possible purchase
- Car Cover?
- New Owner: 2013 Fit Sport (Blue Raspberry Metallic)
- New 2014 Fit Sport
- Any Centric Brake Pad Users Here??
- Before I order a shot shifter
- Suggestions for trailer
- 2009 and up front wheel studs broken
- Weird Question of the Day
- Transmission Fluid Maintenance Minder?
- Sound from cold start
- "Best" ride height, bilstein PSSs
- MrKeishii GE8 Build Thread
- need help, and I'm new to the game
- Roadtest: ??? vs Honda Fit
- General Maintenance Questions
- New member - JDM badges
- Delete Please?
- A/C has stopped blowing cold air and started to hear clunking sounds from the engine
- Not starting as well?
- FLASHING GREEN "D" in DASHBOARD
- Maint code A 13 @ 70k replace transmission fluid!!!! ding ding ding ding
- clicking sound under the car when using shift lever
- All my 2012-2013 owners mugen grill group buy
- Hesitation at 3000RPM
- Fs: Ge8 parts
- Just bought a 2012 Fit Sport
- UK Jazz Bumpers interchangeable?
- Power source for under hood relay
- Power question
- Old couple rolls Fit, then poses for pictures!
- Door Unlocking/Locking and Alarm Going Off
- Brake Rotor Service Specs?
- Best deals on leftover 2013 Fits?
- AC load any different at different settings?
- AC/Heater not up to snuff?
- New '13 Fit Owner
- Is the way I shift ok?
- Replacing Spark Plugs
- any FF'ers in NJ with spare tires
- Stuck in need of help
- Tires and Brakes
- Air Bag Recall: What year Fits?
- 2013 Honda Fit Tune UP 50k
- Good Deal on Rim painting or powder coating Tampa?
- Transmission Fluid Pressure Sensor
- Sat in 2015 Fit today
- PN for Center cap for 15" steelies?
- Tire bubble...
- Car honks twice when I put the ignition to on/start the car
- New '13 Fit owner
- Front seats un-Fit for long trips
- Please help me to find a way to control windows with key fob.
- Power door lock issue
- Electrical, starter, or something else?
- Replacing body door weather seal 2010 Sport Fit.
- Another wheel question from another newb. Lil help?
- Upsize Tires on 2008 Fit Sport
- Use 1999 Civic wheels on 2014 Fit?
- discovered my used honda fit has remote start
- Snow tires or chains? In Pacific Northwest
- Air and oil filters.
- Pic Request: PMM GE8 with JDM or Axis Tail Lights
- Bluetooth on my honda, no moddification
- Hey guys
- Tires
- First Gen badge on 2nd Gen Fit
- Buying a Honda Fit? ...
- Missing splash shield
- Automatic Transmission Oil Pressure Switch Compatible?
- Radio Stopped Working!
- Badges
- 2014 Fit Promos
- Wheel compatibility
- What is my Fit worth?
- ModFyd: from Start to Finish
- Starter starting to go at 138,000 miles
- Honda Fit Sport 2012 (Is this a good deal)?
- Jazz GE8 Stance-wanna-be from Indonesia
- New Exhaust System
- Questions on aftermarket stereo install
- seeking shorter non AC serpentine belt
- Winter wheels/tires
- Honda to recall 1,038 Fit vehicles in US
- Honda recalls 2013 Fits
- Dumb Question #32: My fog lights are [already] yellow...?
- 2012 MT achieved 49 MPG today.
- Dashboard offset to the left?
- How far have you driven with the gas light on?
- "Green" Air filter for 09 Fit? (and new shift knob)
- Hood protector/ deflector
- L15B Swap
- 17s or 18s
- Low MPG – should I bring my 2012 in, or is this normal?
- 2013 Civic Si Seats in GE
- Air scoop install
- OE-style L.E.D Tails for '09 Fit?
- long distance travel with 2 dogs---advice
- First K20 GE8 Fit in the U.S!!!!
- Is this a great deal to buy the Fit?
- 2013 Fit being recalled for problem with right-side axle shaft
- Rear seat belt won't latch
- TPMS Sensors: How long do they last?
- 2010 Fit question
- T1R B-pipe
- AC issue
- Headlights Wont Turn Off
- Oil Question
- Loose Emblem
- Cargo Cover 2013 Fit Sport
- Crossed the United States With My Fit!
- 2nd Gen. Parts vs. 1st Gen. Parts
- Pure Speculation: The New Break-In
- Better Stereo for iPod?
- AmsoilByPass Filter Install: how to mount
- OEM Armrest console
- How Bad is wind/road noise?
- CR-Z 5 lug
- About the speakers on Base
- K&N air filter vs AFE dry flow air filter
- Ohio fit owners!
- Honda Jazz/Honda Fit most reliable car according to Warrantydirect.com
- JDM electric folding mirrors w/ LED (harness)
- Should I sell the Boss 302 and keep the Fit?
- 3000 Miles on Fit and already issues!
- The Payment Game
- stance super sport coilovers
- What accessories are must have for 13 Fit Sports?
- Dash Kit for Honda Fit Sport 2014
- My Bi-xenon kit already failed.
- 2013 Honda Fit Sports OFFER
- To Everyone
- Taffeta White or Alabaster Silver?
- What do we need to change once reached 100,000 km?
- Auto transmission replacement at 54K
- Black manual transmission oil
- So what does everyone think
- Chipmunk shitting in my Cabin Filter - How?
- My jazz has NO BATTERY POWER!!
- Found the perfect USB charger
- Broken sensor on driver side transmission cover
- The limits of cruise control, interesting behavior
- Lost earring in the gap between the driver's seat and the gear box in the railing
- Goodbye FitFreak
- am i missing something?
- Can OEM Sport driver armrest be put on base?
- My 2013 Fit Sport data and calculations
- Hello and Thank You
- To My Canadian Friends with 2014's
- A new member with a few questions...
- Exhaust opinion
- Tire suggestions wanted
- Firestone brake deal is the best! $89!!!
- Tirerack.com
- 2009 Fit Sport Air Conditioning not ice cold
- Pic request: JDP carbon licence plate frame
- 2013 vs 2014
