- New to forum 2007 sport
- Transferable Parts from 07+ Si
- Where do get all your anodized and chrome replacement parts like wiper frames ac val
- Pesky plastic clips
- 2005 honda fit engine swap
- Buying my first 1st-Gen for a track build - Tips?
- Hybrid Racing Short Shifter feels off
- Spare tire recommendations
- Windshield Wiper Linkage Replacement Issues
- My High Mileage 1st Gen 2007 Honda Fit Sport.
- Loose spark plug (pick your part car)
- Set the valve lash and r/r plugs and packs.
- Part Number
- ABS and brake light on
- Upgrade to high current alternator on a 2007 honda fit
- H&R lowering springs
- Backup Light Switch G1 2007 Fit Sport AT
- 2008 Honda Fit Sport Manual - Crank, No Start
- Opinions?
- Carplay unit type
- Should I buy one?
- Tire Question
- Pre-ignition even when cold
- P0135 issue
- please help. Exhaust
- Washer sprayer removal for 2007
- Audio through AUX Cable only playing through 1 Speaker
- Strange whining noise from front end (started suddenly)
- GD red positive battery terminal cover
- 2007 GD 5MT transmission oil
- I bought a $1250 5 speed with 140k miles
- No CEL, but misfire codes present on reader
- Loss of power after half hour driving
- 2008 Honda Fit – 208k miles – Intermittent P0171 with hot-restart, choking issue
- Engine clicking/ticking (did valve adjustment)
- Icky thump
- Need help removing driver’s seat airbag on ’08 Fit
- Right side impact sensor (second)
- Knob missing for interior fuse box - How to open?
- Jazz 2008 (GD18)
- Front strut/damper top mounts: how much play is too much?
- New to me 04 GD1, glitter in the oil
- Srs
- Here She Is!
- Getting wires throught the firewall
- Honda fit 2007 cvt swap MT
- Need to fix/replace front clip
- 02 CVT Acting Up
- Contaminated brake fluid
- 52748-SLN-A01 Has been discontinued. What can I use in its place?
- key fob stopped working
- Gear shift
- Curt 56011 wiring harness
- Popping/Clunking noise in Clutch Pedal (not the squeaking)
- 2007 Rear backing plates
- Cruise control!!!
- ['07 Sport] OE strut camber kit recommendations?
- WHAT!? I can’t buy just the throttle position sensor!
- 2008 Fit Sport clock spring replacement
- Replacing timing chain tensioner
- Power Door lock issues
- Request noise diagnosis from Fit experts
- Radio Issue
- What tool to loosen serpentine belt tensioner?
- Slow speed rattling problem going over little bumps
- Alignment scam
- Radiator Fans won't come on I've tried it all
- Advice on transmission or axle bushing
- 2004 GD1 Jazz - Fault Code 8 TCD Sensor?
- Looking for parts for GD3
- hesitate at 2000rpm to 3000rpm
- Intermittent power loss when accellerating
- HELP :New Radiator and thermostat and still overheating
- 2006 Front Brake Pads
- Who makes good wheel hubs?
- I seek advise about Catalytic converter best aftermarket
- Thoughts on Lowering Springs and Rear Anti-Sway Bar?
- Track day
- Replacing only the friction disc on the OEM clutch?
- First gen transmission rebuild guide?
- I-DSI L13A Fit join both coils pack signal cable from the same cylinder
- Mugen shifter shaft length?
- Which rad fan does what
- 2005 fonda fit muffler original
- Misfire Mystery (NOT Plugs, Coils, Injectors, Lash, Compression) - What's Left??
- Tails lights out, brake lights still working… Which fuse?
- Broken Passenger Side Engine Mount Stud
- 2006 Honda Airwave serious door water leak
- Please Help---Car not turning over-- antitheft issue??
- Replacement front windshield wiper arms for '07 Fit?
- Clutch kit alternative?
- Rear door stuck in locked posiiton
- BC Coilovers sleeve question
- 5 Lug Conversion
- Door Lock Actuator Problem
- Engine ticking/clicking noise under load
- Loud "Hum" When Accelerating Hard From Dead Stop
- Occasional Hesitation "Off the Line", Poor MPG
- "Loud" Braking at High Speed
- 08 Jazz/fit front CV spline count
- 6 speed GE gearbox on a GD
- EPS steering instrument clusters alternator none of it works
- Noise when car departs
- Tab on bottom of ignition switch question
- Any help on this
- 2008 sport Engine Coolant Temperature Sensors
- Rough Idle, Hesitation
- Key wont go into ignition
- 2013 Honda fit no power to ac conpressor
- 2008 AC problem
- Has anyone found replacement carpet?
- Question for experienced honda mechanics
- Why did my AC stop working?
- advice for coaxing poorly maintained 2007 across the country
- Fit Sport 2007 idle speed check?
- Noise when turning the wheel, while driving
- Just bought an old 07 for a long trip, engine cranking and struggling to start
- K24a into an 07 Fit Sport
- Been working on the fit
- Does Insight lift work an GD3?
- Error code 970 help
- Top Fuel Air Filter Part Number
- GD3 K20 coil pack upgrade?
- Unequal Fabrication Intake
- Honda Fit 2004: Central locking does not work
- Key programming not working
- CEL O2Sensor code
- Coil lead doesn't fit new Hitachi coil pack
- Potential Throwout Bearing issue
- Po335-po339
- New member, oil leak.
- Honda Jazz Fuse 3 blowing (2006 year)
- Lightweight Flywheel for my GD3
- What Gasket???
- 26R Battery retroFit - ongoing
- GD3 L15 Valve Rocker Removal (Stripped a rocker out)
- 2007 Honda Fit P0948
- L13 IDSI and L15 VTEC Gear Ratio
- Winter Front for 2008 Fit
- Apple carplay options for JDM HONDA FIT
- Does USDM fit windshield compatible with JDM fits?
- Is RPM drop and light dim normal for defrost/ac mode?
- very unusual noise
- In panic mode due to inspection
- Intermittent ignition issue
- Looking for r14 snow tires in canada
- crank, no start
- Engine Ringing Sound
- Serpentine Belt Replacement Miles - 2009 model
- Parting out a blue automatic. Major front end damage, no engine codes though.
- Power steering issue
- 07 Fit Sport rough idle, codes P0499, P2649, P300,P0301,P0303,P0141
- Just totaled my fit. What parts should I save for the next one?
- 2005 JDM GD1 - front brake part numbers
- Clanking noise @1500rpm - help
- EGR Valve or Something Else, Kid's car
- Third (center) brake light no power
- Which brakes to choose if I'm curious about high performance brakes but. . .
- Jerking
- Would a Japan imported 1.5L engine fit my 2008 engine?
- Drain fuel from tank?
- Marketplace Honda Fit Knocking Sound?
- Steering wheel control
- 2007 fit how to install kill switch
- What is this noise?
- Ignition Key Won't Turn - Any ideas?
- 7 speed CVT toggle switch not working
- Pulsing Sound At Freeway Speeds???
- Honda fit gd3, speedometer and odometer issue
- Automatic Trans Motor Mounts
- Torque specs (whoops, wrong bolt)
- Has anybody had any luck getting a recall covered when your vin doesn’t pop up?
- 2008 Electrial Issues
- Front Wheel Bearing Replacement
- Possible Piston Slap?
- Question on error code PS2647
- What can I do to make my Fit faster?
- GD1 P0302 code after changing plugs and coils
- Rain leak
- Rain leak
- Radiator / Hose "explosion" > need directions
- I want to lower my gd fit 15mm. What are my options?
- Sway Bar Bushings
- Coolant light - staying on blue
- ABS light on left front
- Brake lights out after replacing lamp unit, 2007 Fit
- Need help with purchase
- Swapping Prelude Seats Into a 07’ Fit
- 2007 Fit Auto up and down window doesn’t work
- 2008 fit ac compressor installation process
- AC takes super long to go on/ 2007 Honda fit sport
- What is this?
- 1st Gen sway bar links and rotors replaced - 08/2024
- Stuck rear shock bolt
- 2007 Honda Fit Sport 5MT Gas leak under vehicle
- Crank but no turnover, new sparks+coilpacks
- Tailgate sensor not sensing open boot
- Exhaust Manifold
- Will the 2008 passenger wiper arm mount to a 2007?
- Speed Sensor Wires
- Rear sway bar for JDM GD3
- Should I Change 2007 Fit Transmission Fluid?
- GD1 vs GD3 suspension components
- 07 sport manual trans, will not start
- No crank
- Aftermarket Wheels with Stock Suspension
- Security issue causing no-start?
- I guess I didn't tighten down the plug enough?
- 2008 Honda Fit Aria (Vin: GD8-1400635) Oil on spark plugs.
- Honda jazz 2004, loud knocking noise?
- S3 coilover install.
- Rusty axle — recall?
- Keyless Entry for 2007 Honda Fit Base Model?
- Lock Button on FOB not working
- No reverse lights
- Second gear grinding on left turns
- L13A M/T Wont revv beyond 5k
- Cruise Control and Catalytic Converter Codes
- Dash Mats?
- 2007 Honda Fit Cruise Control Set/Decel Button
- Can GD1 Kakimoto muffler fit on GD3
- 2007 Honda Fit Sport Complete Shocks and Struts Kit Needed
- Is my 2007 Fit Sport Worth Saving?
- 2007 Fit Cranks Longer Than Usual
- Compression Test Results - How to interpret?
- Rear rust
- Not-so-blind mice
- Pinout 08 A/C Compressor
- 07 cruise control issue
- Chain cover threads stripped.
- Access to the engine compartment from the inside
- New project car...
- What are all the dash lights? Is there a list or picture?
- P0339 code; how serious?
- Gd3 lowering springs?/my build(1st post)
- Bad Throwout Bearing?
- ABS Issue after wheel bearing and sensor
- Manual transmission dust shield compatibility?
- Wheel alignment, tyre wear, steering self-centering
- So I recently bought 2 shit missiles
- Looking for tips and lessons learned also…
- JDM Taillights Compatibility for my GD5
- Off center.. HELP!
- Searching for lower Tein Flex Z compatible springs
- Misfire worse with air on?
- AC failed in a strange way
- Best Floor Mat Suggestions Please
- Engine mounting
- 2007 GD3 L15A Engine Noise
- Crankshaft key
- Replacement Axles
- Oil on intake manifold gasket and runners 2008 homes fit
- Timing Cover Replacement
- Through bolt
- 2007 Fit Sport -reset alarm after jump start-no fob
- 2008 GD3 No crank no start but…
- Does the gasket matter?
- Will these wheel spacers fit my fit?
- 2008 Honda fit A/C issue - need some help/ideas
- Head gasket set
- Jerking when accelerating at low RPM, especially up a hill
- Leaking into the trunk of the car
- Is operational coolant temp 79-80C too low?
- HELP! Error code P1890
- Input shaft bearing question
- Cylinder head
- Do I have this SRS diagnosis right?
- GD FIT remove Airbag connector
- Rear Skid Plate M8 Factory Bolt Length?
- high pitch whine.
- heater core hoses.
- Frozen Seatbelt Fix
- 2006 Honda Jazz (from Japan) - 'jolting'
- Automatic transmissuion
- 2008 5-speed MT Ideas?
- 2008 Idler Pully eliminated
- GD3 Rust Guide
- Could use some help troubleshooting issue with screaming noise.
- To fog or not to fog...?
- Minilite wheels on a GD3 Fit?
- Help, clutch issues
- Second spark plug blowout
- Throttle cable adjustment: no slack OK?
- Water from the exhaust
- Wheel kicking water into passenger footwell?
- Misfire when decelerating
- 2008 Honda Fit sport transmission replacement
- oil leak
- Stem keepers
- Rubbing/grinding noise when I turn the wheel
- JDM Honda Jazz 2005
- Stem seals for honda jazz cvt 2005
- 2007 JDM GD1 Front Brake replacement
- Replace radiator without evacuating AC condenser
- CVT ECU on a Manual Jazz
- Rattle / grinding noise when starting 08 base M/T
- Stem seals replacement
- '06 Headlight update
- PCV plate bolt
- New Fit Owner (Need Help)
- My Honda Fit 2008 tires are eating on the outside!
- Honda jazz 2005 PVC
- Pvc
- Fitfreak
- PCV valve
- Anyone have STL/etc files for sun visor clips?
- Knocking Noise When Steering
- Exhaust Manifold - Needed but Discontinued!
- Can GE aftermarket parts fit in the GD? (intake, exhaust, etc.)
- 08 Lip and skirts upgrade on base model
- if someone with a 2007 gd3 would be so kind
- Poor GPM, loss of power, and rattling noise
- Need help identifying front calipers for Brazil/mexico fit
- 2006 Honda Jazz (from Japan) - mtce questions
- Throttle pedal connector wiring
- ***Installed CDV bypass, clutch pedal goes straight to the floor.***
- Redoing valves-- is it worth it?
- Blinking D
- GD3 w/MT having shifting issues
- Loud clunking/grinding sound when starting fast from stop
- Confirm Location Condenser Fan ...
- Annoying beeping sound when the engine is off
- Alternator? Other electrical?
- Coolant temp in freezing temps?
- What to check in a used Honda fit GD3
- Steering issue 08 fit
- rpf1 fitment question
- 08 Fit Sport overheating part 2
- Recommendations for Struts
- but Dr. House, there's no leakage in the fluid lines! (Trouble diagnosing no-start)
- Oil
- P302 code
- 2008 Fit Sport - Burning smell in the interior
- Fitment of disc brake pads
- 2002 CVT fit stalling in park but not in drive
- 2008 Fit Sport starting funny (misfiring?) - Honda dealership can't figure it out
- Incorrect code from obd2
- Valvle Adjustment Results - Should I Be Worried?
- Max Winter Tires
- 2007 fit sport fuel injector source
- Anyone Foung Spare Tires?
- Looking for coilovers in cali
- D,S,L won't engage from cold start
- 205/55/r16 on gen 1 fit
- FIX for gurgling/running water noise
- Something is rapidly clicking in thet location
- FIT 2006 wheels
- Will 185/70/r13 ties and wheels fit on my 07 Fit?
- '08 GD3 transmission
- Battery Tender to Cigarette lighter
- Climate Control Lights
- Hood stuck & won't unlatch
- Cruise control for mechanical throttle
- GD1 Key
- Accurate radio wiring harness diagram?????
- here in the uk with a poorly honda fit
- 2007 crank no start
- Looking out for a body kit for my first car gd1
- What Maintenace Would You Suggest?
- 2008 Honda Fit Sport, is 5W-30 oil ok?
- P0303 honda fit 07
- Can someone please sell me this Sport Grille/Modulo Front Grille?Thank you so muchhh!
- blue light coolant temperature stay
- immobilizer..won't start
- What transmission does a 1st Gen made in Japan Automatic have?
- '07-'08 Body parts interchange
- Sports steeling wheel same as the manual sports steering wheel?
- Dash Lights Coming On Briefly
- Rear axle bushings
- Steering effort different left to right
- 2008 Honda Fit Question ECM wire to ignition coil.
- GD Fit rear fog light switch placement inspiration
- Could anyone please help me identify this part
- Normal engine noise?
- Problems with starting my jazz
- Headlights both out at same time
- Engine cut out at somewhat random rpm always above 4k
- When A/C Turned on engine stutters'
- Clutch replacement tips
- Instrument Cluster keeps going out.
- Honda fit jerking/jumping issue
- 2008 Hona Fit AC blows cold for the first 10 mins or so then warm until youve parked
- Power window motor wiring diagram
- ‘05 GD1 ES Sport rocker panels
- CVT Mode switching issue
- 2008 Headlight bulb
- lowering spring
- EPS Power Steering issue, DTC 21-02
- AC fuse keeps blowing
- Where to find rear hatch lock actuator for 2007 >SPORT<
- 2008 Sport 5 speed auto, 3rd gear "slipping" or slipping?
- Coilover Conundrum
- Is my Fit still out there? 07 silver sent to Wisconsin
- Bypassing A/C compressor on an 08 Fit
- Wiring Harness partially pulled out from a tire blowout
- Door panels question!
- TPMS light won't turn off.
- Replacement Seats for GD3
- 2007 Honda Fit Sport Auto Transmission Slipping
- Fog lamp replacements
- Yup, it can tow!
- Mouse-like Squeak when turning wheel to left at low/no speed.
- My AC button won't stay ON!
- help opening this FIT service manual application on PC
- Bad Engine Computer Data
- I need help installing a Android 9 Inch radio! No DIN! 😭
- GD Front Bumper
- Silver U-Clip from seat track, need help identifying
- Hi new here, Looking for good Intake of the Cold type
- 08 Fuel injector
- Will 2007 fit stereo and speaker fit my 2006 fit?
- Guess the brand!
- Immobilization activated HELP
- oversized tyres and 40mm drop
- Pcv
- New to community first gd3 fit
- Rim size Fit 2007
- OEM wheels for GD1 fit
- Cat stolen: replacement suggestions please
- Rear Fog Light Switch
- 2007 Honda Fit - Looking for Remote Start solutions
- Dsi to Vtec
- Clutch delay valve delete on RHD Honda fit/ jazz gd
- Easy suspension maintenance item! LCAs
- 2007 Honda Fit Radiator Fans Not Engaging?
- I have a rusted out 100k fit that I'm getting a new body for. Looking for advice on m
- 08 MT transmission options
- Gd3 gas switch where can I get one?
- I turn the key and nothing happens
- Gen1 Jazz not starting up after fuel filter chnage
- Battery Light solid after new alternator, grounds, good battery
- 5MT: Will a GE8 transmission bolt in?
- Trico Ultra passenger side doesn’t fit
- Anyone able to tell me how to replace this part?
- Building my 2008 Fit sport -- need help :D
- Failed power steering, speedometer/odometer, plus some warning lights
- Squeak/chip when lifting foot off accelerator
- Looking for 08e60-sln-100 keyless entry
- Alarm goes off randomly unless I slam the hatch. Need help?
- 08 - LCA removal guidance
- 2007 Jazz fuel problem
- '08 Fit DX Door Locks Dropping Like Flies!
- Honda fit 2008 02 sensor bank 1
- Fit engine on bone yard
- Poor Gas Milage
- Has anyone swapped out an automatic for a manual?
- ebay steering emblem badge
- Help just bought a fit and it's rusted out!
- Replace clutch: OEM? Recommendations?
- Ignition coil upgrades?
- My first Honda. What maintenance items should I check first?
- Wheel size question
- Replaced the interior dome light with an aftermarket LED and WOW!
- L13A to L15A swap with manual tranny
- 08 Sport Manual dies completely while braking - then starts up!
- Voltage increases when off the gas
- What is that under the left rear?
- Loss of all electrical power while parked
- 2007 honda fit radiator replacement
- Strange noise when braking to a stop or releasing brakes. 2008 1st gen CVT.
- What is a good price for a GD Fit ?
- Starter motor -- stuck?
- What to do about terrible gas mileage
- Will manual gd3 ignition work on auto gd3?
- Blanking EGR valve
- Quarter Million Club
- Rocker Arm Assembly Washer
- Dim Headlights
- Can you repaint headlights
- P0128 low coolant temperature question
- Engine Rotates When Switching Gears
- Keyless entry
- Red Honda Emblems
- Central Lock Switch ideas
- In the market for a 1st gen what is this clicking noise?
- Weird issue with parking light, driver side front
- 2008 Fit Remote - Can these be reset after the battery dies?
- Finding TDC: a cautionary tale
- GD idsi to ivtec swap. Help.
- BEST LED Headlights with DRL function!
- Car died while driving
- CVT filter replacement?
- Keyless Entry Wire Diagram
- Lights flickering
- Keyless Remote Finally Died
- Manual Tire Pump?
- Help with old spark plugs
- GD1 wheel hubs and bearing
- Clutch Master Cylinder replacement options
- Excessive crankcase pressure 2007 fit 1.5l
- Honda Jazz P-1214
- 2002 VTi Auto - Jumpy when gently lifting off the throttle at low speed
- catalyst sensor tpms issue
- '07 Fit Hum
- Fun with sport
- Rear spring options?
- Starter screech at cold start up: new findings
- 2007 honda fit fuel trim lean po171 & p0039
