PDA
View Full Version : 3rd Generation (2015+)
Pages : 1 [2] 3 4 5 6 7 8 9 10 11 12
  1. SOLVED: Water leak in trunk and drivers foot area
  2. 15810-5R0-003 Valve Assembly, Spool
  3. Chasing water leaks on a '17 Fit
  4. Rear wiper motor
  5. All service lights carbon buildup injector issue very frustrated help
  6. GP5 Honda Fit Aftermarket Headunit require canbus for steering wheel button control?
  7. 2015 LX MT: What to expect at 75k?
  8. 2015 Fit - Consistent groan from top of engine?
  9. LED Conversion
  10. Identify rat eaten hose
  11. Identify rat eaten hose
  12. 2015 Fit - Rough Idle + Engine Ticking + Scraping Noise
  13. Leak into drivers foot well from hood latch release cable
  14. Eibach Pro Kit availability?
  15. What Muffler Are You Running With.
  16. Turn Signal Light in Side Mirrors?
  17. New member.
  18. Desperately trying to get to the bottom of some drivability issues on a Fit I bought.
  19. Is this a good deal?
  20. Broken front panel close to the radiator
  21. Replacing Center Console Question
  22. Any variations of 2018-2020 models?
  23. Check Charge System Warning
  24. Looking for 2018+ Honda Fit Sport Parts
  25. 2015 CVT stuttering when accelerating from stop or slow speed
  26. Keyless start sustem problem - engine won’t turn off
  27. Who's Your Starter?
  28. Frost! 2020 Honda Fit LX
  29. 2016 CVT Car Will Not Move
  30. Eight Snow Tires
  31. Rusty Brake Drums
  32. DIY Windshield Washer Fluid
  33. 2020- what should I know?
  34. Air Bag Recall
  35. Weird Starter Relay Noise / No Start
  36. Do Japan made 2018-2020 Fits exist in the US?
  37. Cup Holder Solutions for 3rd Generation Honda Fit EX?
  38. 2018 sport -- 30,000 mile service
  39. Seat belt buckle receptacle fell apart
  40. My Honda Fit journey - Please give your comments
  41. Right turn camera always on
  42. 2017 Fit sync key
  43. Replacement Volume Knob for 2019 Sport
  44. Manual transmission upgrade
  45. Looking for the JDM clear headlight reflectors
  46. Soft or just worn engine mounts (manual car)
  47. 2015 Honda Fit Ex Just Purchased
  48. 2019 Steering Click/Clunk on the left.
  49. Noise just prior to start up.
  50. Michelin X-Ice
  51. Rear hatch going crazy
  52. Gas mileage suddenly went up?
  53. 2018-2019 Fuel Pump recall
  54. Car randomly loses acceleration
  55. Water in the spare tire wheel well, coming from underneath?
  56. Flashing transmission indicator after transmission swap
  57. Honda Fit 2015 trim
  58. Adding a temp gauge, (feasibility)
  59. Hey Tuners
  60. Chrome delete - but with colors: trashy or no?
  61. Honda Jazz rear emblem location
  62. 2019 Honda Fit Rust bubble
  63. 4 maintenance light on dash came on
  64. 4 maintenance light on dash came on
  65. Class Action Lawsuit ??
  66. Is there a way to permanently change instrument cluster language from Japanese to Eng
  67. What is this plastic strip on the door sill of my JDM Fit?
  68. Redesigned Fit
  69. VTC, Timing Chain, Guides oh my!
  70. 2015 Fit System Inficators
  71. 2Bad starters-Both had bad ring gears on the 2015 Fit models.
  72. Water finding a way inside my Fit
  73. Yellow Xenon h4 question
  74. Honda Recall Over Fuel Pumps
  75. Is a 2.25" catback from Unequal Fabrication too big for a stock motor?
  76. Trying something new
  77. I miss my 2nd and 3rd Gen
  78. Purge solenoid question
  79. 2019 Fit Click
  80. Rear brakes
  81. Spaek plug replacment
  82. Getting ready to swap out headunit in my EX '20 -- Some questions
  83. 2017 Fit - 85k miles - lots of repairs needed, is something wrong here?
  84. 2018 Replacement side mirror glass?
  85. Aftermarket headlight bulb recommendations
  86. Trying to mod my 2017 EX into a (street legal)sleeper
  87. From 2015 to 2018 in a Bang!
  88. GK5 SPORT bumpers ?!?!
  89. Reputable dealers/mechanics to do maintenance in the Seattle, WA area?
  90. Changing Out OEM Foglights, 2018 GK5
  91. Broken wire near A/C pressure sensor
  92. Water found in spare wheel well area
  93. Weird 2016 honda fit starting problem
  94. Can I upgrade a 2018 EX head to a 2019 EX head unit?
  95. Seat Covers
  96. Battery won't charge, weird woodpecker noises coming from fuse box and power relay
  97. Wanting a Performance exhaust but not too loud
  98. Konig wheels offsets compared to stock offset w/ 205 50 16 tires??
  99. Rebuild/repair 2017 Fit alternator?
  100. Remove FogLight Cover Fit RS
  101. 2019 Oil Change Time Frame
  102. momentary rattle sound
  103. What hardware do I need for the inner fender assembly?
  104. Coolant question
  105. 2015 fuel injector failure
  106. 2016 FIT Rear Shocks Replaced/ Still Clanking
  107. NZ gk5 owners I got some parts I need to swap and sell so I can trade up
  108. Is this much motor movement an issue?
  109. Car won’t turn over after battery change
  110. Head Unit Full Pinout
  111. Alternator/ELD questions for 2015 Ex CVT Fit
  112. Opinions
  113. Honda fit running very poorly on acceleration
  114. Cruise control and throttle response
  115. Key Fob Issue
  116. 2015 limp mode - p0341 - runs perfect
  117. 2015 Honda Fit EX - 4 lights on dash - help!
  118. ABS and handbreak lights on when driving but off standing still
  119. "Brake!
  120. 2016 w/CVT- where's my gas going?!
  121. How many emus can you get into a Honda Fit?
  122. What's underneath the plastic floor plan cladding?
  123. Push start 2015 clicks once no start
  124. Wheel Alignment?
  125. Can't Drive, it won't shift into Drive anymore
  126. Need help identifying return line of CVT cooler
  127. How do you know you need valve adjustment?
  128. Dead USB Ports
  129. Honda Fit 2020 - Footwell LEDs wired to dome light
  130. Aftermarket Fog light Turn signal front & back, help
  131. Sore Right Knee?
  132. Windshield Wipers - Different!
  133. Click, no crank, slow cranking....
  134. Replacement radio problems
  135. Weird noise turning engine ON & OFF
  136. Replacing the stock Aluminum Wheels on a 2015 GK
  137. 2019 Honda Fit - Factory Wipers?
  138. Honda Fit 2019 Replacement Battery
  139. Wallpaper image stopped displaying
  140. Reverse to Drive delay?
  141. 2015 Honda Fit 98k miles
  142. Please delete
  143. Door check straps
  144. Parking Break Cable?
  145. Is car considered level on 4 jack stands - Transmission fluid check
  146. Battery drain/dead after starter replacement?
  147. Ecu wiring diagram
  148. Door locks activating by themselves
  149. Need wire locations for wiring aftermarket remote starter on 3rd gen Fit
  150. 2015 Fit ex manual timing valves both neither?
  151. While CVT is out - should I do rear main seal?
  152. What was the 3rd gen refresh change?
  153. 2019 honda fit EX warning lights
  154. Honda fit 3rd Gen cluster meter pin layout.
  155. Starts then immediately dies
  156. 2018 EX water leak issue
  157. Tail light assembly (right side/passenger)
  158. Temperature Control Dial Jammed (HVAC Blend Flap)
  159. Replaced Driver's mirror, now no HVAC fan, AC or mirror adjustment...
  160. Rattler
  161. Rattler
  162. Key Fob, flashing lights, and unlocking
  163. How much data does a 2019 Fit LX collect?
  164. 2019 Honda Fit holes under drivers side floor mat
  165. rustydude
  166. Use OEM microphone on aftermarket radio
  167. Oil Filter
  168. 1.3L 2018 Honda Fit - Japanse to English language
  169. 16" Full Size Spare, Valve Side Up - A Workaround
  170. Starter issue
  171. Starting Problem
  172. Pneumatic Hood Supports
  173. 97 psi
  174. Ticking noise when in drive 2019 60k miles
  175. LCD, USB stopped working.
  176. Oxygen sensor brands
  177. 7 warning light issue and my resolution
  178. Honda Canada Warranty Extension
  179. Honda fit sport rust proofing damage
  180. P0172 code (too rich fuel), Youtube vid on 2018 Honda Fit
  181. Saying bye bye to my blue 2015 Ex CVT
  182. The Red Stripe
  183. Disable Anti-thief System
  184. High pressure fuel pump
  185. Modify underbody panel for easier Oil Change? Fumoto valve?
  186. What do I need to install a hitch for a very long move in a 2015 Fit (Manual)
  187. Rear Brake Replacement - Mileage
  188. Leaking!
  189. Help Identifying This License Plate/ Bracket Theft Prevention Combo?
  190. sport ecu plus pedal boss??
  191. Key Warning Light and Starter Button
  192. Expected life of the Fit?
  193. Zero to Hero, Auction Honda Fit
  194. A/C evaporator removal
  195. Radio Code 2020 3rd Gen Fit?
  196. Dealership recommending fuel injection cleaning/transmission fluid change
  197. Rear Windshield Defogger Not Disengaging
  198. Dealership Maintenance Recommendations Question?
  199. Selling my 2016 EX (NY area) and saying goodbye
  200. Creaking sound in rear of 2018 Fit Sport
  201. 2015 EX - battery issue? worse?
  202. 3rd Gen Evaporator Core Replacement
  203. EGR Tips
  204. Best tires for rain/snow/ice?
  205. Steering Wheel Lock
  206. Passenger mirror
  207. Best Phone Mount
  208. Best Sunshade 2019 Fit
  209. Clutch Pedal Theories?
  210. playing music with iphone attached to charge chord-no music sound
  211. Changing key fob battery renders fob totally inoperable
  212. E85 with stock tune/fuel system
  213. anyone have pics of your fit with non stock size tires
  214. 2023 Honda Fit
  215. Death Wobble!?!? Is My Rack Smoked? Videos Attached.
  216. Help needed !!!! No lights
  217. Largest roof box to reasonably use with the Fit?
  218. No Rust on 3rd gens?
  219. AC Compressor Clutch Relay Honda Fit 2017
  220. New here, got some fit issues.
  221. Warning lights on, cylinder 4 misfire code
  222. Interchangeable Parts
  223. Camera for reversing
  224. Wheel mod for suspension improvement
  225. XM vs Radio. Radio is Winning
  226. RS spoilers on aliexpress
  227. Fuses to tap for dash cam?
  228. Trunk Hatch Wont Open, No Click
  229. Optional Front Grill.
  230. Manual driving "manual" & tips (2019 sport)
  231. Driver side airbag curtain rattle over bumps
  232. how i cleaned my center console arm rest.
  233. Class Action Lawsuit for Honda Fit Battery issues
  234. Coolant Light
  235. GK5 tail lights
  236. 2020 Fit Sport weird squealing noise when in drive and AC compressor on
  237. deflation warning system
  238. Serious Manual Transmission Problem
  239. Manual Swap on GK5
  240. Whining manual transmission?
  241. After market rearview camera
  242. Replacing PCV valve tips?
  243. Performance mods?
  244. Dry Clutch for GP5
  245. 2020 Fit directly drop in swap problems
  246. Radio Screen and Backup Camera Resolution Crashed
  247. New Shoes on GK5, 2018 6M Sport
  248. Dead Battery
  249. GK5 tail light wiring question
  250. 2017 injectors need replacing
  251. PCV valve
  252. Transmission compatibility
  253. Radiator hose & cooling system bleeding
  254. clutch slave bleeding
  255. Looking to get a GK Fit soon. Any tips?
  256. Rattling sound from the resonator
  257. New here. Learned a bit cleaning intake valves and replacing fuel injectors
  258. Feeling: 2 months before saying good bye to my 2015 Ex
  259. P0420 and exhaust leak.. anyone have this happen?
  260. Ran 3000 kms with just over a litre short of oil
  261. AUX input jack from 2017 LX to a 2018-20 LX
  262. Engine noises, looking for help
  263. Engine noises, looking for help
  264. past 60,000 but no maintenance minder code
  265. Anyone know where I can find the Morimoto headlights for the 3rd Gen Fit?
  266. Tighten fuel cap.
  267. Looking for a spare keyless entry fob
  268. Mysterious Whining Noise When Backing Up
  269. WTB OEM EX or Sport wheels
  270. My first Fit and just learning how fun it is! Any tips?
  271. 2017 Fit A/C intermittent
  272. 2016 LX alternator won’t come off
  273. Occasionally takes a second key turn to start engine. Suggestions about cause?
  274. Relays clicking/Something on engine bay when key is off. Dash lights/interior lights
  275. What part # is this?
  276. Battery lifespan
  277. Transmission fluid
  278. Remove "Chrom"-Rings on Foglight
  279. Safety Recall, Display Audio unit, low power
  280. Replacement Tire Recommendations Requested
  281. Lights galore
  282. Trading In Fit
  283. Anyone have experience replacing a cracked 2020 Fit EX Head Unit?
  284. Engine Air Filter and MPG Improvement
  285. GP 6 L15 engine type ID
  286. New Brake Pads
  287. GK Smart Entry System Indicator light
  288. Bought JDM late 2013 fit (3rd gen) Weird fisheye effect on reverse camera?
  289. Lifting
  290. GK 5 Rear wheel hub assembly bolts / brakes conversion questions
  291. Driver's door lock / Smart Entry problem
  292. 2020 Fit - Differences
  293. Wiper Washer Nozzle Replacement
  294. Cv shaft replacement
  295. 2020 Fit EX MPG
  296. Keyless entry system issue
  297. Those with higher mileage, how’s it going?
  298. Purchased a Used 2020 Sport trim (CVT trans) with 29k miles
  299. Just picked up this gently-used 2015 Fit EX as a base for a new racecar!
  300. Engine Replacement
  301. battery sleeve
  302. Very quiet whirring noise in neutral? Normal? Or Input shaft bearing?
  303. Hi, Oxygen Sensors
  304. Squeal/scrape/grinding
  305. Power without a tune
  306. Load Squeaking sound when Hill assist releases.
  307. Starting problems
  308. What is this in the picture?
  309. Part of electric dash goes blank
  310. Bad maf sensor at 115k
  311. 2106 started in zero degree F weather
  312. Stock stereo problems
  313. Head unit cables
  314. Electrical Problems
  315. Discovered passenger side rear door damage?
  316. 2015+ Front Plate
  317. Thoughts? <LED light upgrades>
  318. buzzing noise under dash with ACC on, keyless system
  319. ISO Non Lowered Stiffer Suspension Options
  320. 2015 push start won't start first attempt.
  321. 2015 push start won't start first attempt.
  322. CTV fluids and part number reference
  323. Oil leak
  324. Honda car parts stockist/dealer in Portland Oregon
  325. Air bag replacement
  326. Another Oil Change
  327. Spark Plugs - How often do you change them?
  328. hrv to gk cluster swap
  329. bilstein shocks and struts
  330. Does anyone else "skip-shift" their manual trans?
  331. GK Recall on BU Camera for Key Ignition VEhicles
  332. Battery upgrade fixes VTC start rattle?
  333. suspension issues maybe? Shocks? I'm no sure...
  334. Carpet removal for some rhino liner
  335. 14 Inch Wheels On GK5
  336. P219A for '18 with 55k miles
  337. Windshield Wipers Falling Off
  338. Plastic Piece Dangling from Undercarriage
  339. Help with p0420
  340. GK5 2015 2016 Honda Fit ECU Location
  341. 2017 Honda Fit underbody panels
  342. Valve Adjustment. Please Suggest.
  343. Multiple problem lights after being parked
  344. VSA light
  345. Maintenance Minder Code "3" for Transmission Fluid Two Times in a Row?
  346. CVT fluid change- some information
  347. 2015 Honda Fit VSA, TPMS, EPS Check Charge Lights
  348. Has anyone had CVT issues or breakdowns?
  349. CVT fluid change
  350. Timing Chain Replacement 15 ex-l
  351. Fuel Injector Warranty
  352. Fuelly - How To?
  353. Electrical problems on a 2016 fit?
  354. Do I stay or do I go... Timing chain/fuel injectors
  355. 2018 EX, plastic shield under engine fell off— should I replace it?
  356. Help finding '18-20 fit sport radio
  357. How to fill in spare tire space?
  358. Rear wiper - changing the resting position
  359. Hatch and rear passenger door locks unusual issue
  360. Help: 2015 Fit EX-L infotainment connectors?
  361. Tomioka Racing batteries
  362. How to install rear (back up) camea to 3rd gen Honda JAZZ/FIT (GK5) car
  363. Center Console Latch Spring Measurements
  364. Sunvisor Solution???
  365. Rear pillar led lights install + wiring
  366. 2019 no heat, but knob turns.
  367. 2015 bad 25 MPG Help!
  368. 2019 Fit Shift Boot Sagging, Retention Ring Missing
  369. Car not starting, electrical weirdness. (2015 LX)
  370. Honda Fit 2019 - help to identify this part.
  371. Honda Mk3 Keyless entry No lights, Will not start, Remote will not open doors
  372. 2018 only blows cold
  373. Oil Filter
  374. 2019 Fit Horn not working. Fuse okay. Relay location?
  375. GK HPD support?
  376. Undercarriage Shield Issue
  377. Manual trans drain plug
  378. Better cornering and handling mods?
  379. P0172 code after PCM replacement
  380. P0843 flashing D
  381. Help me explain how to get my 2016 started to a non-Honda person
  382. Replacing A-Pillar clips
  383. Air bag deactivate
  384. How many different styles of OEM GK5 taillights exist?
  385. GK5 Brake Light on hatch
  386. Honda GP6 Error P287C
  387. Dead battery then bad jump then no radio.
  388. Coolant Leak followed by Starter Problems
  389. Oil leaking from harmonic balancer side, can't find source
  390. Incompatible with android?
  391. questions about headlights
  392. Fit 2014 transmission fluid
  393. Buzz Sound
  394. is this excessive engine movement? the mounts look fine
  395. Wiring schematic
  396. Fuel mystery
  397. New stereo that works with right mirror cam (EX manual)
  398. Dash trim discoloration. Removal?
  399. Fixing the display menu
  400. Recommend A Place To Get The Instrument Cluster Repaired
  401. Anyone buy tires lately?
  402. 2016 CVT Valve Body Solenoid B...
  403. Will a 30" stove fit in a 2015 Fit?
  404. Accessing the top of the rear shocks?
  405. Driver/ Passenger Side Mirror Adjusting the Mirror Bracket Position Forward Daily?
  406. Hissing noise only when on the freeway
  407. KC screen on radio?!
  408. 2016 CVT fluid change...reset the Maintenance Reminder?
  409. How to install new speakers?
  410. No start. Key stuck. No display on tranny gear (cvt)
  411. Honda fit gp5 2018 foglight fitting
  412. Air Conditioner cables stuck
  413. Seeking an unusual measurement!
  414. AC Compressor Clutch Not Engaging
  415. 2015 EX Moonroof issue
  416. B-Pillar Vinyl Kit
  417. Opinion on valve adjustment
  418. Push button issues with 2015 Honda Fit
  419. Intake Valve Cleaning - Forget the Walnut Blast
  420. Amazing Coincidence
  421. 2016 CVT with PO741 code
  422. Ex break in from emergency key hole
  423. 4 Liters of Coolant not enough on my fit?
  424. Fuel Injector Recall.
  425. CVT Help desperately needed
  426. Black Sport Wheels On My EX.
  427. Hatchback won't open on 2015 honda fit
  428. PIAA Xtreme White Light Bulbs.
  429. How to disassemble front headrest
  430. Rear shocks - 2015 MY vs 2017+ MYs
  431. Issue with Defogging System
  432. Getting rid of dead skin on door panel
  433. 51 Battery Install
  434. Has anyone ever taken their Honda Fit 2015 ex on a road trip?
  435. 2015 Honda Jazz 1.2
  436. Replace rear hatch handle
  437. Radio control on steering wheel rubbing off....
  438. Manual Transmission hard to shift sometimes
  439. Blind spot accessory mirrors and placement, sideview
  440. Leaking air at highway speeds only
  441. Morimoto 4banger LED fog lights
  442. Clicking noise when Idling
  443. 2019 EX with P0303 code and now dead battery
  444. Replacing Timing chain, VTC act., etc.
  445. Platinum White vs Orchid white
  446. 250amp alternator upgrade, 2019 honda fit ex, advice please
  447. coil-overs vs Spoon progressive springs for Gk5 Lx
  448. Has anyone ever tackled replacing a 2015!AC compressor assembly ?
  449. Sudden iPhone Music Plays on 2018 EX-L
  450. Car audio electronic updrade
  451. 195/60r15 on a stock 175/65r15?
  452. 23mpg. Is it normal?
  453. Wheel Question from a novice
  454. Mirroring Android Phone with Infocenter
  455. ABS code U0401-68
  456. Wheel and Tire Size for Stock Height GK5?
  457. any info on these codes...
  458. Fuse Pulling 2017 Fit flat towing
  459. 2015 light issues
  460. Lost my key
  461. My Honda Fit is Haunted! Help!!!
  462. Fuel Injector issues - 2018 Fit EX @ 17,000miles
  463. Immobilizer kill switch?
  464. New Rims & Tires
  465. why won't my 2017 start when I push the "ignition" button
  466. I Solved My XM Radio Addiction Dilema.
  467. Mattress for refresh mode?
  468. 2016 Fit with black radio screen
  469. Do winter/snow tires makes sense of Fits?
  470. fuel pump recall
  471. 2016 LX Grinding Noise on Start?
  472. Is Your Fit Turning Into A Money Pit?
  473. feathering on rear tires
  474. Charging system message is coming after replacing battery
  475. At my wit's end with starting issue. 2015 LX MT
  476. How can I disable all doors unlocking when opening the driver's door from the inside?
  477. VSA Module Replacement
  478. 2019 honda fit dash lights
  479. Impact sensor 2019 honda fit
  480. Aftermarket radio installation,… But what about.
  481. oil leak under engine
  482. Maintenance schedule and no Maintenance Minder
  483. Tein aftermarket shocks for the GK
  484. Removing front grill
  485. 470 Miles at 47.5 MPG
  486. Intermittent Clunking/Grinding noise when lightly braking
  487. Clutch Slipped At 84,000 Miles.
  488. 2017 Fit EX Smartphone Connectivity
  489. CVT Transmission broken pieces
  490. Never changed CVT fluid deal breaker?
  491. Ways to carry long items
  492. Automatic Shifter Light/LED?
  493. Can’t unlock other doors with engine running (new issue)
  494. Rumbling sound after changing cabin filter
  495. Fuel/mpg
  496. Fuel/mpg
  497. IRP short shifter
  498. Rear alignment issues?
  499. 2018 vs 2019 vs 2020
  500. AC compressor fan cutting on and off...
