- Car acting weird when trying to start engine.
- Pull rear Drum(how to) check brake shoes
- Oil Life Meter (reset)
- Does My 2011 LX Have Electronic Stability Control?
- Where can I find the Rear Trailing Arm Bushings?
- Really strange transmission issue
- I am an idiot-Hooked up jump leads backwards
- Standard rubber tire valve stems
- Oops I loosened the wrong bolt trying to drain the engine oil
- Time Chain Cover - leak... how important
- Head lights (plastic Cataract Syndrome)
- What is this button?
- Are my side skirts missing?
- Direction of air flow?
- Wiring
- P0962 - Black Wire Cut - Rats?
- Air Bags on/off
- Fan Direction Control Knob not working?
- Difference in quarter panel on sport vs regular
- Weird noise from Upper Glove Box
- Interior Door Panels
- Battery Fuse
- Windows Fogging up
- Other Steel Rims that will fit THE FIT
- Remote Start 2009 Fit
- Driving An Out Of State car in CA.
- What temp will High Temp Warning illuminate?
- TPMS ---- Will this suck a bunch cash out of wallet
- Failed Mirror Switch Assembly
- Blower motor replace
- Fuel Smell and P0303 misfire
- Honda fit 2013 interior lights.
- Fit cost to own - nine year anniversary
- Attaching fuel pressure gauge
- SRS Airbag Light On after Battery Change
- Best place online to buy OEM air filters?
- Transmission Fluid Change Concern
- Speeding driver hit my parked car..
- GE8 2008 Lowering Springs Suggestions?
- Wheel Knowledge?
- Header bolts size
- Bad Day
- Coolant Loss?
- Recall!
- Own cup holder light
- Radio swap
- Wanted: 2012/2013 honda fit sport rims.
- Light out on cabin temperature control knob
- 2010 Fit stick shift - timing chain tensioner.
- 2010 Fit Stick shift.
- Decent Winter Tires
- GE8 Hazards / Blinkers not working
- Advices on Header fit ge8
- door lock problem
- Ge8 Header!!
- Suggestions on wheels size for Flush Fitment of 2011 RS Mugen
- Some light recommendations
- GE8 JDM brake light suddenly not working...
- "California Compliant" Fit ?
- 08 Fit Sport vs 09 Fit Base - Which Would you Buy?
- Need some advice on painting?
- Trouble Starting on Cold Mornings
- Project Touge GE8
- Air filter box clips
- New owner with a question about seatbelts
- Car seat booster question
- star light headliner
- Map lights
- New to me Fit owner!
- GE8 bed build
- Oil Change Frequency
- Side View Mirror Paint Advice
- Humming noise coming from front after bearing/hub change
- Just picked up a '13 Sport
- Winter wheels
- 2nd battery placement?
- Keep or replace
- CTBA Help!
- Replace pre-emptively?
- Adding Steering wheel audio buttons, With aftermarket Headunit
- Have I found a good deal (2013 Fit)
- Ge8 front lower control arm query
- 2012 Fit 92k oil pan gaket
- New owner - first upgrades!
- Cracked frame--Anyone else seen this??
- window visor recommendations?
- Anyone Know where I Can Get Cargo Lid Install Snaps?
- Airbag Light
- 2010 Door Lock question (Base model)
- New 2010 Base Owner
- This is what was suggested by my local performance store
- OEM vs aftermarket control arm and tie rod
- Cooling system ?
- Misfire after PLUG SWAP? valve adjustment?
- Subtle upgrades
- Do I need to repack my control arm and tie rod boot?
- CEL & TCS Light on at the same time with misfire Code P0302
- Converting FIT to Euro Spec JAZZ, Headlight debacle
- ECU messed
- Poor MPG - need advice
- Bad PCV Valve
- Uneven brake pad residue on new rotors
- High Oil Consumption
- Purchase used Fit with Navi?
- Weird gurgling engine noise and starter noise
- Lower Engine Cover
- Auto Transmission woes
- Starting issue different keys
- How to disconnect plugs from back of ecu?
- Gas mileage not as good as it once was
- Dash Harness...???
- what do you all prefer LED, HID?
- 2008 fit sport manual - clutch issue
- Launched a coil pack!
- Looking for coilovers
- Add-on tinted sun shield for driver side visor
- Has anyone cleaned their catalytic converter using lacquer thinner?
- Been a FitFreak member since 2010, just bought a 2009 Fit!
- Central Locking Not Working
- 2009 Fit Sport low beams on both sides keep burning out
- Is it safe? 90w bulb.
- Leak under steering wheel
- Should i Ship my Fit from NY to CA..is it worth it ??
- Rear Bumper from 2008-2011 to 2012-2014
- Original Battery...
- Hinds fit 2012 fluttering / clicking on drive
- Exterior Lights Indicator Issue
- Very grappy and chadder..ly clutch
- Tire valve stem too short?
- Front end questions - PFL - FL??
- TownFair tire replaced a TPMS sensor, light won't go out
- GE8 Tail light lens
- Stuck
- Automatic locks are draining battery? 09 Automatic Fit
- Bosch Spark plugs
- What is the difference in the Base vs Sport Model Seats
- Squeaking noise when driving; sometimes triggered by turning steering wheel
- Back up camera
- Frustrating Shifting(?) Issue
- 4 lug to 5 lug spacers.
- Replacement Seats: Let's Talk. Seriously.
- Need help with stuck driver's seat
- Has amyone made 17s fit?
- smaller winter wheels?
- Spark plugs
- Gas mileage change from 175/65 R15s to 205/50 R16?
- Anyone have a link where i can buy these?
- Android Honda fit Jazz 2009-2013 DVD GPS Navigation
- Power window problem
- Anyone take their Fit "Off-Roading"?
- Maintenance: 2012 FIT @ 100K miles
- GE and GK Muffler Differences
- Horn relay
- Recently bought a used 2013 Honda Fit Sport 5 spd manual
- Replacement HU -- Reflection issues?
- Honda Jazz EX 2012 first modifications?
- Stuck Magic Seat
- Yet another A/C thread!
- 09 Mystery clicking & dealer uncertainty
- Suspension noise
- TPMS On
- gas tank capacity?
- Basics
- Good price for a 2013
- Help me feel better about buying a high mileage Fit.
- EBAY Center Console / Armrest
- Another AC question/issue 2010 Fit Sport
- Does anyone know what this moulding piece is called?
- Electrical issues? 2013 Fit
- 2012 Fit Upgrade Options (Cameras, etc.) Question
- Little Story of a Fit's travels this summer
- Help with the independent fog light mod. Ge8
- Disable honking on second remote lock press?
- Trouble with Fit trying to auto lock itself.
- Fit ge and city have the same lowering spring ?
- Issues with power door locks (low voltage at plug)
- Code P0847 & P0756
- ? battery terminal access ?
- 3rd gen 6mt swap into 2nd gen 5mt
- Transmission issues
- Hitch bike rack - Strap?
- 2010 Fit. Driver's door won't unlock.
- Buying a Honda - help needed
- Amazon Spoiler
- How many keys?
- Hi guys... Been a while but...
- Replacing 2nd gen A/C Clutch question for experienced diyers
- Serpentine belt replacement
- Want Rims What Size
- Front damage most likely totalled
- GK L15 Reduction Starter
- Rusted Catalytic Converter
- 2013 Honda fit trouble starting, rough idle, stall.
- 2011 honda fit sport manual transmission mount
- Add one for my new 2009 Honda Fit
- Looking for Relay Diagram
- Suspension
- Stupid Thicc Tires on GE sport
- Relocating front licence plate - how?
- Using the key to lock and unlock the driver door.
- Air Intake and Exhaust Modification causing 02 sensor code
- 2009 fit Looking for simple upgrade ideas
- Cruise control engaging itself??
- AC not working, Blowing hot air
- 2009 Fit battery issue
- Nose mask & armrest
- Messed up and terribly scratched underneath front bumper
- B1 light on
- Dome light comes on for no reason.
- Weird Scratching at 2K RPM. Need help figuring out what it could be.
- ABS and tire size
- 2013 Base Fit OE tires
- Loose spark plug. Any tried and true remedy?
- Replacement part for A/C Compressor Clutch Relay?
- 2010 fit sport
- 2007 wheels on a 2010
- Worn clutch? Rolling back on hill in 1st
- No Power Locks, AC, or Radio
- Parts recommendations
- Paint/Clear Coat fading on blue '09 Fit
- Will this OEM grill fit my '13 sport?
- Gaskets Required for Valve Clearance Check
- What was the final verdict on parasitic drains?
- Front Left Clunk
- Torque Solutions shifter cable bushings wont fit?
- Weird intermittent sound
- Suspension fix? Softer???? (Yas!)
- Cargo Light
- Should I buy this 2013 Honda Fit?
- Doors/tailgate sensors
- Changed spark plugs and coils @ 154,000
- Found stuff that fits our cars
- Need help with stuck Passenger seat (disassembly)
- Code p0171
- How likely is it the whole coil needing replacement compared to the boot?
- 2015 Wheels and tires on a 2013?
- Help my car won't start
- Odometer roll back in fit?
- Weird noise when letting out clutch
- Key Will Not Turn 2009 fit
- Dual exhaust on 2011 Fit Sport
- Vinyl wrap headlights
- blank stereo Display
- 2nd gen lowered driver seat options
- L15A7 dry sump
- Can an 8 foot foam surfboard go atop a Fit?
- How to Program Door Lock without Master Lock Button
- What is the width between wheel wells in the cargo area of the gen 2 fits?
- Dead 2009 FIT in Kingston, Ontario
- Is there anyone know how to remove stock alarm as my alarm goes off randomly ?
- Low mileage '09 Fit Sport -- maintenance question
- Flashing check engine light & loss of power
- 2012 - 2013 Sport Front Bumper
- 2011 Sport Driver-Side Door Actuator Latch Assembly
- Braking issues
- Oil pan
- MPG plunges from 70 MPH to 80 MPH -- do other cars do this?
- Long Crank When Cold
- 200,000 MIle plus Fit comments
- Best Place To Find Body Parts
- Air conditioning diagnosis
- Headlight swap
- Unknown Disconnected Hose
- Engine tray
- New seats or covers?
- Low Beams and AC Stop working after oil Change
- Another Fit bites the dust
- 3 wire sockets
- Sad day yesterday
- Do I really need to replace tires in pairs or can I get away with just one?
- Need some help...
- GE8 Base Spoiler addition and batter relocation questions.
- Looking to upgrade my suspension
- Crankshaft Pulley
- spark plug help needed
- How has your aftermarket wheels affected the Fit's handling?
- Forward Window covers
- 2009 Fit Sport Fog Light Replacements
- Air bag maintenance
- Such a fun car.
- Oil Life & PM Schedule
- 6 speed?
- GE Newbie
- Air screen Rad Side
- Tune after aftermarket intake
- 2013 Honda Fit (Jazz Vibe-s) Fog Light Cover
- 2009 fit sport Conversion to 2013 fit sport front bumper
- Straight Answer Please
- 2009 Fit stumbles and (apparently) misfires ... bad PCM?
- Alarm goes off randomly
- Steering wheel on 10 fit
- What is it?
- What Generation ?
- Spark plugs on 2010 fit
- Replacing shocks?
- Acceleration problem
- looking for kswap info
- L15A7 on boost
- Help with speakers?
- Help on Oxygen Sensor Problem
- Howta' replace the front window(s) on your GE8 Fit / Fit Sport
- M/T owners where does this line/hose go?! help
- It’s been real, it’s been fun....
- Need to replace cylinder head
- Jerky when turning at full lock
- Valve noise after adjustment. Video included
- Air Con doesn't stay cold...
- If you have a GE8 Sport, could you confirm?
- Driver Side and Passenger Side Black bezel headlghts
- When to replace your shocks and struts - What brand?
- Rough Dirt road
- spark plug advice - 2010 Fit - stick shift.
- Has anyone driven a 2010 FIT up the Al-CAN Highway. Drive it2X in my Toyota wagons. I
- Foggy headlights
- Immobilizer removal/bypass
- Pioneer AVH-5500BS gps unit or rear view with gps
- Looking for best service manual for 2011 fit
- Loud buzzing sound during initial start up
- Aux Jack Music Question
- Looking at possibly getting new headlamps
- 2011 Fit, I need the most left corner of the wiper cowl piece
- Maintenance minder
- New Fit driver with some questions
- Bad Disc error on car radio when insert any mp3CD
- TPMS sensors with non-TPMS rims?
- '10 Honda Fit Sport AT
- New owner, lightly modded 2013 Honda Fit Sport
- PLEASE help, looking for a body part.
- Seat covers recommendations
- Maintenance on "Maintenance Free Battery"
- Change door chime??
- Ignition coil for 2013 honda fit hybrid
- Car alarm help
- 2011 Honda Fit Airbag drivers/passenger ?
- Engine choking/coughing
- Dash cluster lights when key is in accessory
- Another weird engine tick
- K20A Swap
- Flasher relay?
- LED headlights issue
- Rear Wiper Going all the time 2010 Fit Sport
- Hit 147,000 Tonight
- Mystery wires...
- Honda fit 2012 manual
- Ever present cylinder issue.
- axle-back exhaust
- What specific maintenance is needed?
- Lights on instrument panel.
- 13 Fit Unknown piece
- 2013 honda fit a/c low pressure switch
- 2013 fit a/c power
- Brake drum shoe size?
- Automatically turning headlights off when key removed?
- Recommended plugs & filters?
- AT pressure switch failures
- 2012 engine oil drains in 2 months
- 2009 Fit Sport Weird Radiator / AC fan Issue going on and off
- Total Under Hood Failure
- Honda fit 2012 front quarter window
- Catalytic converter options for Califorina
- Does anyone recognize where these bolts come from?
- Changing Fuses on My Fit
- Abs and Vsa randomly turns on
- 145k miles 2011 Base Fit MT, Maintaince
- No blower motor any speed
- short noise after completing turns
- s2k AP2 tips not fitting my 2012 Sport
- Transmission and milage issues - help?
- Engine tick or knock
- Noise in air vent - difficulty to fix?
- 15x8 +16/+20/+25 on base model suspension
- Tight parking brake after brake service
- Acceleration Issue
- Headlight Question
- 2010 Rough shifting (1st -> 2nd). Pls help :-)
- Just bought a 2009 Fit DX-A, have a few questions, would appreciate the help :)
- is there a how to video to change washer pump
- Vash's Supercharger buy list - Estimated costs planning
- Spintex fuel delivery
- Loud growling noise in Diff/Tran
- Factory Shop Manuals
- Brakes failing - vacuum issue. $30 part unavailable anywhere in the U.S. WTH?
- 2009 Honda Fit Aftermarket Keyless entry System HELP!!!!
- Finally, Cost effective Lumbar support!
- Easy Question about bilb replacement
- former 1st gen now 2nd gen owners? Comparison?
- #3 Missfire Cracked Crankshaft assembly plate
- Headlight bulb to HID/LED convert
- 2010 honda fit base model
- Battery Relocation/Intake
- Will 08 Cargo Cover fit my 2010 Fit Sport?
- '11 Fit Sport glovebox USB, does it provide power?
- Weird Electrical problems
- Ticking sound
- '11 Fit Sport, my first Honda
- P0420: New Cat Needed?
- Valve checks
- 2011 Fit Sport Rear Spoiler Repair
- How Much Weight?
- What is the sunshine button for?
- Innovative Mounts engine/transmission mounts
- Noise (whirring) that increases when I give it gas
- Front end noise help
- Fit drives differently after work from the dealership
- How to increase power on GE
- Lowering Springs Recomendations
- Jdm micu
- Has anybody tried this?
- Cold air intake
- Honda Fit sport audio
- Morimoto Fogs XB LEDs
- Weird fender liner retainer clip for 2012 Fit?
- Fuel Filter Change at 80kms/50000 miles
- MPG mystery
- Base to Sport bumper swap?
- Has anyone tried to paint their steering wheel trim ?
- EPS, Front Airbag lights on, radio off: any thoughts
- bumpy ride
- My 09 fit never thought she'd see snow again!
- New fit owner 2009 Honda fit 65k miles clean title
- Mice evidence
- Does anyone know how to remove these rear window garn r rr pawithout bracketing the t
- How to remove GE rear seat with picture instructions
- Manual Transmission Output Seal
- Anyone ever lift their Fit?
- Lost Key. Any way to avoid having car towed to dealership?
- A/C compressor mounting flange
- Bought a 11 Sport
- GE8 wiring diagram
- Please Fit Freak I need help!!!!
- Intermittent P0171 Code
- About to buy a used Fit, any tips?
- Anyone ever try quad projector retrofit?
- Another Jazz
- Rear Ended
- How Many Miles Before You Changed Your Clutch?
- Won't start
- Snow tire dilemma
- Under hood trip part fasteners: Part number?
- Battery keeps dying but Autozone said they couldn't test the alternator
- Car audio help for newbie
- Tail light gasket question
- 2012 AC on,revs falling at idle...car shaking
- bumpy ride 2
- It's so hard to say good to say goodbye... :-(
- 2010 A/T: slams from 1st to 3rd and wont shift into 4th
- Anyone rocking their original battery in a 2009 yet?
- Help! Check Engine Light and VSA light are on and staying on
- What to do to Fit/jazz ge6 2010 JDM version
- Electrical Diagram Trunk, Locks, - 2011 Fit Sport
- Engine got sound when idling
- 100,000 mile maintenance on 2013 Fit
- P0420 (CEL) on, off, and on again
- hi guys!
- EPS: Torque Sensor Coil Malfunction? Anyone?
- Anyone Need GE Owner's Manual/Tech Reference Guide/Consumer Info Booklets
- EPS Warning Light ON. Need Help!
- Stock rear height difference
- Driving Fit on gravel and dirt roads ?
- Looking for hatch mechanism diagram
- Cruise Control Issue
- Awful sound during cold start
- Where does the battery hold down bar lock on too
- Hatch handle repair
- Hatch panel clip
- Car won’t start, help.
- Looking for Honda TCS codes
- 2012 with 22k really?
- Carpet has ripped where the weather mat hooks in
- iOS 11.1.2 = Unsupported Version?
- Remote Start on 2017 MT EX?
- How to change the serpentine belt?
- Front brake caliper 2012 Fit
- Would you ever replace 3 tires?
- Engine noise after valve adjustment
- 2012 Fit Low Tire Pressure Light - How To Reset
- brake fluid reservoir cap loose?
- Winter Tires Question
- Installing a rear wing on a 2012 Honda Fit
- A deer hit my headlight
- AXIS style tail lights (AXIS black + clear cover)
- Modulo Wing
- 10 Base 5MT Trans/Clutch question
- Clutch Clusterf*ck- Need help! **long story**
- Saying Good bye to my 2010 Fit - HR-V??
- Battery Life
- Gas smell after spark plug change
- New Fit owner taking delivery this week
- Dor Locks
- New rattle on '09 Fit
- New (to me) 2010 Fit Sport
- “Unsupported” problem!
- Low RPM rattle
- Flooded GE
- Prospective Buyer
- Cold morning issues.
- Fog Lights on a Base Fit, 2013.
- Won't start after car wash?
- iPhone/USB not working with audio controls in 2011fs
- Anti-freeze/coolant service
